[PATCH 1/2] tester: Add option to specify how to load image with QEMU
Sun Aug 21 23:13:19 UTC 2022
OK for this change. I am not sure about the other one so I will leave that for
someone who knows. If no one says anything in the next day please push both.
Thanks
On 20/8/2022 12:16 am, Daniel Cederman wrote:
> Defaults to "-kernel", but can be changed to, for example, "-bios".
>  tester/rtems/testing/qemu.cfg | 5 ++++-
>  1 file changed, 4 insertions(+), 1 deletion(-)
> diff --git a/tester/rtems/testing/qemu.cfg b/tester/rtems/testing/qemu.cfg
> index 3c51bee..0b592ef 100644
> --- a/tester/rtems/testing/qemu.cfg
> +++ b/tester/rtems/testing/qemu.cfg
> @@ -78,6 +78,9 @@
>  %ifn %{defined bsp_qemu_extra_opts}
>   %define bsp_qemu_extra_opts %{nil}
>  %endif
> +%ifn %{defined bsp_qemu_image_type}
> + %define bsp_qemu_image_type -kernel
> +%endif
>  %define qemu_cmd  qemu-system-%{bsp_arch}
>  %define qemu_opts %{bsp_qemu_opts} %{bsp_qemu_cov_opts}
> @@ -85,4 +88,4 @@
>  # Executable
> -%execute %{qemu_cmd} %{qemu_opts} %{bsp_qemu_extra_opts} -kernel %{test_executable}
> +%execute %{qemu_cmd} %{qemu_opts} %{bsp_qemu_extra_opts} %{bsp_qemu_image_type} %{test_executable}
