[PATCH v1 0/2] Change to QEMU 5
Chris Johns
chrisj at rtems.org
Mon Aug 22 22:13:25 UTC 2022
OK
Thanks
On 23/8/2022 6:29 am, Ryan Long wrote:
> Hi,
> For this patchset I changed the hash of the glib hash because it has changed
> and it doesn't work on Debian 11, Ubuntu 22.04, and CentOS 8 Stream.
> After fixing the glib hash, I continued to run into other errors. So I brought
> in the config files for QEMU 5 since all the previously mentioned OSes had no
> problem building it.
> Thanks,
> Ryan
> Ryan Long (2):
> glib-2.48.2-1.cfg: Fix checksum of patch
> Add QEMU 5 configuration files
> bare/config/devel/glib-2.48.2-1.cfg | 2 +-
> bare/config/devel/qemu-5.2.0-1.cfg | 42 +++++++
> bare/config/devel/qemu-couverture.bset | 2 +-
> bare/config/devel/qemu.bset | 2 +-
> source-builder/config/qemu-5-1.cfg | 9 ++
> source-builder/config/qemu-common-2.cfg | 145 ++++++++++++++++++++++++
> 6 files changed, 199 insertions(+), 3 deletions(-)
> create mode 100644 bare/config/devel/qemu-5.2.0-1.cfg
> create mode 100644 source-builder/config/qemu-5-1.cfg
> create mode 100644 source-builder/config/qemu-common-2.cfg
