[PATCH rtems-lwip v1 6/8] rtemslwip: Add functions for BSD compatibility
Kinsey Moore kinsey.moore at oarcorp.com
Tue Aug 23 19:47:39 UTC 2022
Add wrappers where possible and new functionality required to run code
developed for operation on *BSD. This also simplifies the code that
utilizes rtems lwip locking and makes it more consistent.
 lwip.py                                       |   4 +-
 rtemslwip/bsd_compat/ifaddrs.c                | 105 +++
 rtemslwip/bsd_compat/netdb.c                  | 115 +++
 rtemslwip/bsd_compat/rtems-kernel-program.c   |  89 ++
 rtemslwip/bsd_compat_include/arpa/nameser.h   |   0
 rtemslwip/bsd_compat_include/bsd_compat.h     |  36 +
 rtemslwip/bsd_compat_include/ifaddrs.h        |  41 +
 .../machine/rtems-bsd-kernel-space.h          |   0
 .../machine/rtems-bsd-thread.h                |  33 +
 .../machine/rtems-bsd-user-space.h            |   0
 rtemslwip/bsd_compat_include/net/if_var.h     |   0
 rtemslwip/bsd_compat_include/net/route.h      |  38 +
 .../bsd_compat_include/netinet/in_systm.h     |   0
 rtemslwip/bsd_compat_include/netinet/in_var.h |   0
 rtemslwip/bsd_compat_include/netinet/ip.h     |   0
 rtemslwip/bsd_compat_include/resolv.h         |  32 +
 rtemslwip/bsd_compat_include/sys/kernel.h     |   0
 rtemslwip/bsd_compat_include/sysexits.h       |   0
 rtemslwip/common/network_compat.c             |  57 ++
 rtemslwip/common/rtems_lwip_io.c              | 836 ++++++------------
 rtemslwip/common/rtems_lwip_sysdefs.c         | 185 ----
 rtemslwip/common/syslog.c                     |   6 +
 rtemslwip/include/rtems_lwip_int.h            |  92 --
 rtemslwip/zynqmp/lwipopts.h                   |   2 +
 24 files changed, 844 insertions(+), 827 deletions(-)
 create mode 100644 rtemslwip/bsd_compat/ifaddrs.c
 create mode 100644 rtemslwip/bsd_compat/netdb.c
 create mode 100644 rtemslwip/bsd_compat/rtems-kernel-program.c
 create mode 100644 rtemslwip/bsd_compat_include/arpa/nameser.h
 create mode 100644 rtemslwip/bsd_compat_include/bsd_compat.h
 create mode 100644 rtemslwip/bsd_compat_include/ifaddrs.h
 create mode 100644 rtemslwip/bsd_compat_include/machine/rtems-bsd-kernel-space.h
 create mode 100644 rtemslwip/bsd_compat_include/machine/rtems-bsd-thread.h
 create mode 100644 rtemslwip/bsd_compat_include/machine/rtems-bsd-user-space.h
 create mode 100644 rtemslwip/bsd_compat_include/net/if_var.h
 create mode 100644 rtemslwip/bsd_compat_include/net/route.h
 create mode 100644 rtemslwip/bsd_compat_include/netinet/in_systm.h
 create mode 100644 rtemslwip/bsd_compat_include/netinet/in_var.h
 create mode 100644 rtemslwip/bsd_compat_include/netinet/ip.h
 create mode 100644 rtemslwip/bsd_compat_include/resolv.h
 create mode 100644 rtemslwip/bsd_compat_include/sys/kernel.h
 create mode 100644 rtemslwip/bsd_compat_include/sysexits.h
 create mode 100644 rtemslwip/common/network_compat.c
 delete mode 100644 rtemslwip/common/rtems_lwip_sysdefs.c
 delete mode 100644 rtemslwip/include/rtems_lwip_int.h
diff --git a/lwip.py b/lwip.py
index b97d273..627d88c 100644
--- a/lwip.py
+++ b/lwip.py
@@ -75,8 +75,8 @@ def build(bld):
     source_files.append('./uLan/ports/os/rtems/arch/sys_arch.c')
     source_files.append('./rtemslwip/common/syslog.c')
     source_files.append('./rtemslwip/common/rtems_lwip_io.c')
-    source_files.append('./rtemslwip/common/rtems_lwip_sysdefs.c')
+    source_files.append('./rtemslwip/common/network_compat.c')
     def walk_sources(path):
         sources = []
         for root, dirs, files in os.walk(path):
diff --git a/rtemslwip/bsd_compat/ifaddrs.c b/rtemslwip/bsd_compat/ifaddrs.c
new file mode 100644
index 0000000..dc6b7f2
--- /dev/null
+++ b/rtemslwip/bsd_compat/ifaddrs.c
@@ -0,0 +1,105 @@
+ * Copyright (C) 2022 On-Line Applications Research Corporation (OAR)
+ * Written by Kinsey Moore <kinsey.moore at oarcorp.com>
+ * are met:
+#include <lwip/netif.h>
+#include <ifaddrs.h>
+#include <net/if.h>
+#include <netinet/in.h>
+static struct ifaddrs *create_ifaddr_from_netif(struct netif *netif)
+  struct ifaddrs *ifaddr = malloc(sizeof(struct ifaddrs));
+  if ( ifaddr == NULL ) {
+    return NULL;
+  ifaddr->ifa_next = NULL;
+  ifaddr->ifa_name = netif->name;
+  ifaddr->ifa_flags = 0;
+  if ( netif->flags & NETIF_FLAG_UP ) {
+    ifaddr->ifa_flags |= IFF_RUNNING;
+  if ( netif->flags & NETIF_FLAG_LINK_UP ) {
+    ifaddr->ifa_flags |= IFF_UP;
+  if ( netif->flags & NETIF_FLAG_BROADCAST ) {
+    ifaddr->ifa_flags |= IFF_BROADCAST;
+  ifaddr->ifa_addr = malloc(sizeof(struct sockaddr));
+  ifaddr->ifa_netmask = malloc(sizeof(struct sockaddr));
+  ifaddr->ifa_dstaddr = malloc(sizeof(struct sockaddr));
+  if ( ifaddr->ifa_addr == NULL
+       || ifaddr->ifa_netmask == NULL
+       || ifaddr->ifa_dstaddr == NULL ) {
+    freeifaddrs(ifaddr);
+    return NULL;
+  ifaddr->ifa_addr->sa_family = AF_INET;
+  ifaddr->ifa_netmask->sa_family = AF_INET;
+  ifaddr->ifa_dstaddr->sa_family = AF_INET;
+#define inet_addr_from_ip4addr(target_inaddr, source_ipaddr) ((target_inaddr)->s_addr = ip4_addr_get_u32(source_ipaddr))
+  inet_addr_from_ip4addr(&((struct sockaddr_in *)ifaddr->ifa_addr)->sin_addr, &netif->ip_addr.u_addr.ip4);
+  inet_addr_from_ip4addr(&((struct sockaddr_in *)ifaddr->ifa_netmask)->sin_addr, &netif->netmask.u_addr.ip4);
+  ((struct sockaddr_in *)ifaddr->ifa_netmask)->sin_addr.s_addr = netif->ip_addr.u_addr.ip4.addr & netif->netmask.u_addr.ip4.addr;
+  return ifaddr;
+int getifaddrs(struct ifaddrs **ifaddrs)
+  struct netif *netif;
+  *ifaddrs = NULL;
+  LWIP_ASSERT_CORE_LOCKED();
+  NETIF_FOREACH(netif) {
+    /* create ifaddr from netif */
+    struct ifaddrs *ifaddr = create_ifaddr_from_netif(netif);
+      freeifaddrs(*ifaddrs);
+      *ifaddrs = NULL;
+      errno = ENOMEM;
+      return -1;
+    ifaddr->ifa_next = *ifaddrs;
+    *ifaddrs = ifaddr;
+  return 0;
+void freeifaddrs(struct ifaddrs *ifaddrs)
+  struct ifaddrs *ifaddr;
+  while ( ifaddrs != NULL ) {
+    ifaddr = ifaddrs;
+    ifaddrs = ifaddrs->ifa_next;
+    free(ifaddr->ifa_addr);
+    free(ifaddr->ifa_netmask);
+    free(ifaddr->ifa_dstaddr);
+    free(ifaddr);
diff --git a/rtemslwip/bsd_compat/netdb.c b/rtemslwip/bsd_compat/netdb.c
index 0000000..af6ba6f
--- /dev/null
+++ b/rtemslwip/bsd_compat/netdb.c
@@ -0,0 +1,115 @@
+ * are met:
+#include <lwip/netdb.h>
+#include <stdio.h>
+static uint16_t getserviceport(const char *target_service) {
+  FILE* file;
+  char service[16];
+  char protocol[16];
+  uint16_t target_port = 0, port;
+  int scan_result;
+  if ( target_service == NULL ) {
+    return target_port;
+  file = fopen(_PATH_SERVICES, "r");
+  if ( file == NULL ) {
+  while ( 1 ) {
+    scan_result = fscanf(file, "%15s%hu/%15s%*s%*[^\n]", service, &port, protocol);
+    /* Check for end of file */
+    if (scan_result == EOF) {
+      break;
+    /* Check for bad line */
+    if (scan_result < 3) {
+      continue;
+    if ( strcmp(target_service, service) == 0 ) {
+      target_port = port;
+      break;
+  fclose(file);
+#undef getaddrinfo
+int getaddrinfo(
+  const char *nodename,
+  const char *servname,
+  const struct addrinfo *hints,
+  struct addrinfo **res)
+  char aport[16];
+  itoa(getserviceport(servname), aport, 10);
+  return lwip_getaddrinfo(nodename, aport, hints, res);
+#undef freeaddrinfo
+void freeaddrinfo(struct addrinfo *a1)
+  lwip_freeaddrinfo(a1);
+const char *gai_strerror(int err)
+  switch ( err ) {
+  case EAI_OVERFLOW: return "EAI_OVERFLOW";
+  case EAI_SOCKTYPE: return "EAI_SOCKTYPE";
+  case EAI_SYSTEM: return "EAI_SYSTEM";
+  case EAI_BADHINTS: return "EAI_BADHINTS";
+  case EAI_PROTOCOL: return "EAI_PROTOCOL";
+  case EAI_NONAME: return "EAI_NONAME";
+  case EAI_SERVICE: return "EAI_SERVICE";
+  case EAI_FAIL: return "EAI_FAIL";
+  case EAI_MEMORY: return "EAI_MEMORY";
+  case EAI_FAMILY: return "EAI_FAMILY";
+  default: return "UNKNOWN EAI";
+#include <lwip/if_api.h>
+#undef if_nametoindex
+unsigned int if_nametoindex(const char *ifname)
+  return lwip_if_nametoindex(ifname);
+int res_init()
+  return 0;
diff --git a/rtemslwip/bsd_compat/rtems-kernel-program.c b/rtemslwip/bsd_compat/rtems-kernel-program.c
index 0000000..ae80e51
--- /dev/null
+++ b/rtemslwip/bsd_compat/rtems-kernel-program.c
@@ -0,0 +1,89 @@
+ * are met:
+#include <machine/rtems-bsd-kernel-space.h>
+#include <machine/rtems-bsd-thread.h>
+#include <sys/types.h>
+#include <sys/kernel.h>
+#undef printf
+#define RTEMS_BSD_PROGRAM_NO_STRDUP_WRAP
+#define RTEMS_BSD_PROGRAM_NO_STRNDUP_WRAP
+#include <machine/rtems-bsd-program.h>
+#include <rtems/extension.h>
+#include <rtems/score/percpu.h>
+#include <rtems/score/thread.h>
+#include <rtems/sysinit.h>
+static size_t rtems_bsd_extension_index;
+static const rtems_extensions_table rtems_bsd_extensions = {};
+ * This must only be run after the system has become multithreading such as in
+ * Init(). This must not be run as part of normal RTEMS initialization as part
+ * of a SYSINIT call.
+void rtems_bsd_compat_initialize(void)
+  rtems_id ext_id;
+  rtems_status_code sc;
+  sc = rtems_extension_create(
+    BSD_TASK_NAME,
+    &rtems_bsd_extensions,
+    &ext_id
+  if (sc != RTEMS_SUCCESSFUL) {
+    printf("%s: cannot create extension\n",  __func__);
+    rtems_task_suspend(RTEMS_SELF);
+    rtems_fatal_error_occurred(0xdeadbeef);
+  rtems_bsd_extension_index = rtems_object_id_get_index(ext_id);
+static struct rtems_bsd_program_control **
+rtems_bsd_get_bsd_extension_ptr(void)
+  Thread_Control *executing = _Thread_Get_executing();
+  return ( struct rtems_bsd_program_control ** )&executing->extensions[rtems_bsd_extension_index];
+struct rtems_bsd_program_control *
+rtems_bsd_program_get_control_or_null(void)
+  return *rtems_bsd_get_bsd_extension_ptr();
+int
+rtems_bsd_program_set_control(struct rtems_bsd_program_control *prog_ctrl)
+  *rtems_bsd_get_bsd_extension_ptr() = prog_ctrl;
+  return 0;
diff --git a/rtemslwip/bsd_compat_include/arpa/nameser.h b/rtemslwip/bsd_compat_include/arpa/nameser.h
index 0000000..e69de29
diff --git a/rtemslwip/bsd_compat_include/bsd_compat.h b/rtemslwip/bsd_compat_include/bsd_compat.h
index 0000000..f6691d2
--- /dev/null
+++ b/rtemslwip/bsd_compat_include/bsd_compat.h
@@ -0,0 +1,36 @@
+ * are met:
+#ifndef _RTEMSLWIP_BSD_COMPAT_H
+#define _RTEMSLWIP_BSD_COMPAT_H
+ * Initializes the BSD compatibility layer required for using BSD functionality
+ * under lwIP. Must be called from Init().
+void rtems_bsd_compat_initialize(void);
+#endif
diff --git a/rtemslwip/bsd_compat_include/ifaddrs.h b/rtemslwip/bsd_compat_include/ifaddrs.h
index 0000000..f1be700
--- /dev/null
+++ b/rtemslwip/bsd_compat_include/ifaddrs.h
@@ -0,0 +1,41 @@
+ * are met:
+#ifndef _RTEMSLWIP_IFADDRS_H
+#define _RTEMSLWIP_IFADDRS_H
+struct ifaddrs {
+	struct ifaddrs  *ifa_next;
+	char		*ifa_name;
+	unsigned int	 ifa_flags;
+	struct sockaddr	*ifa_addr;
+	struct sockaddr	*ifa_netmask;
+	struct sockaddr	*ifa_dstaddr;
+#define	ifa_broadaddr	ifa_dstaddr	/* broadcast address interface */
+int getifaddrs(struct ifaddrs **);
+void freeifaddrs(struct ifaddrs *);
+#endif
diff --git a/rtemslwip/bsd_compat_include/machine/rtems-bsd-kernel-space.h b/rtemslwip/bsd_compat_include/machine/rtems-bsd-kernel-space.h
diff --git a/rtemslwip/bsd_compat_include/machine/rtems-bsd-thread.h b/rtemslwip/bsd_compat_include/machine/rtems-bsd-thread.h
index 0000000..7408d1c
--- /dev/null
+++ b/rtemslwip/bsd_compat_include/machine/rtems-bsd-thread.h
@@ -0,0 +1,33 @@
+ * are met:
+#ifndef _RTEMSLWIP_RTEMS_BSD_THREAD_H
+#define _RTEMSLWIP_RTEMS_BSD_THREAD_H
+#include <rtems.h>
+#define BSD_TASK_NAME rtems_build_name('_', 'B', 'S', 'D')
+#endif
diff --git a/rtemslwip/bsd_compat_include/machine/rtems-bsd-user-space.h b/rtemslwip/bsd_compat_include/machine/rtems-bsd-user-space.h
diff --git a/rtemslwip/bsd_compat_include/net/if_var.h b/rtemslwip/bsd_compat_include/net/if_var.h
diff --git a/rtemslwip/bsd_compat_include/net/route.h b/rtemslwip/bsd_compat_include/net/route.h
index 0000000..9948aef
--- /dev/null
+++ b/rtemslwip/bsd_compat_include/net/route.h
@@ -0,0 +1,38 @@
+ * are met:
+#ifndef _RTEMSLWIP_ROUTE_H
+#define _RTEMSLWIP_ROUTE_H
+struct rt_metrics {};
+struct rt_msghdr {
+  uint16_t rtm_msglen;
+  uint8_t rtm_version;
+  uint8_t rtm_type;
+#define RTM_VERSION     5
+#endif
diff --git a/rtemslwip/bsd_compat_include/netinet/in_systm.h b/rtemslwip/bsd_compat_include/netinet/in_systm.h
diff --git a/rtemslwip/bsd_compat_include/netinet/in_var.h b/rtemslwip/bsd_compat_include/netinet/in_var.h
diff --git a/rtemslwip/bsd_compat_include/netinet/ip.h b/rtemslwip/bsd_compat_include/netinet/ip.h
diff --git a/rtemslwip/bsd_compat_include/resolv.h b/rtemslwip/bsd_compat_include/resolv.h
index 0000000..ef729fa
--- /dev/null
+++ b/rtemslwip/bsd_compat_include/resolv.h
@@ -0,0 +1,32 @@
+ * are met:
+#ifndef _RTEMSLWIP_RESOLV_H
+#define _RTEMSLWIP_RESOLV_H
+int res_init( void );
+#endif
diff --git a/rtemslwip/bsd_compat_include/sys/kernel.h b/rtemslwip/bsd_compat_include/sys/kernel.h
diff --git a/rtemslwip/bsd_compat_include/sysexits.h b/rtemslwip/bsd_compat_include/sysexits.h
diff --git a/rtemslwip/common/network_compat.c b/rtemslwip/common/network_compat.c
index 0000000..e13c56a
--- /dev/null
+++ b/rtemslwip/common/network_compat.c
@@ -0,0 +1,57 @@
+ * are met:
+#include <sys/socket.h>
+#include <arpa/inet.h>
+#include <lwip/ip4_addr.h>
+#include <lwip/ip6_addr.h>
+in_addr_t inet_addr(const char *cp)
+  return ipaddr_addr(cp);
+int inet_aton(const char *cp, struct in_addr *addr)
+  return ip4addr_aton(cp, (ip4_addr_t*)addr);
+char *inet_ntoa(struct in_addr addr)
+  return ip4addr_ntoa((const ip4_addr_t*)&(addr));
+char *inet_ntoa_r(struct in_addr addr, char *buf, socklen_t buflen)
+  return ip4addr_ntoa_r((const ip4_addr_t*)&(addr), buf, buflen);
+#undef htons
+uint16_t htons(uint16_t x)
+  return lwip_htons(x);
diff --git a/rtemslwip/common/rtems_lwip_io.c b/rtemslwip/common/rtems_lwip_io.c
index 8aa28b5..ee34774 100644
--- a/rtemslwip/common/rtems_lwip_io.c
+++ b/rtemslwip/common/rtems_lwip_io.c
@@ -77,8 +77,6 @@
 #include "lwip/sockets.h"
 #include "lwip/sys.h"
-#include "rtems_lwip_int.h"
 static const rtems_filesystem_file_handlers_r rtems_lwip_socket_handlers;
 static rtems_recursive_mutex rtems_lwip_mutex =
@@ -173,45 +171,106 @@ int socket(
   int fd;
   int lwipfd;
-  if ( domain == rtems_lwip_sysdefs_PF_UNSPEC ) {
-    domain = PF_UNSPEC;
-  } else if ( domain == rtems_lwip_sysdefs_PF_INET ) {
-    domain = PF_INET;
-  } else if ( domain == rtems_lwip_sysdefs_PF_INET6 ) {
-    domain = PF_INET6;
-  } else {
-    errno = EINVAL;
+  rtems_lwip_semaphore_obtain();
+  lwipfd = lwip_socket( domain, type, 0 );
+  if ( lwipfd < 0 ) {
     return -1;
-  if ( type == rtems_lwip_sysdefs_SOCK_STREAM ) {
-    type = SOCK_STREAM;
-  } else if ( type == rtems_lwip_sysdefs_SOCK_DGRAM ) {
-    type = SOCK_DGRAM;
-  } else {
-    errno = EINVAL;
+  fd = rtems_lwip_make_sysfd_from_lwipfd( lwipfd );
-    return -1;
+  if ( fd < 0 ) {
+    lwip_close( lwipfd );
-  rtems_lwip_semaphore_obtain();
+  rtems_lwip_semaphore_release();
-  lwipfd = lwip_socket( domain, type, 0 );
+  return fd;
-  if ( lwipfd < 0 ) {
-    fd = -1;
-  } else {
-    fd = rtems_lwip_make_sysfd_from_lwipfd( lwipfd );
+static int setup_socketpair(int listener, int *socket_vector)
+  union {
+    struct sockaddr addr;
+    struct sockaddr_in inaddr;
+  } a;
+  int reuse = 1;
+  socklen_t addrlen = sizeof(a.inaddr);
+  memset(&a, 0, sizeof(a));
+  a.inaddr.sin_family = AF_INET;
+  a.inaddr.sin_addr.s_addr = htonl(INADDR_LOOPBACK);
+  a.inaddr.sin_port = 0;
+  if (setsockopt(listener, SOL_SOCKET, SO_REUSEADDR,
+       (char*) &reuse, (socklen_t) sizeof(reuse)) == -1) {
+    return 1;
-    if ( fd < 0 ) {
-      lwip_close( lwipfd );
+  if  (bind(listener, &a.addr, sizeof(a.inaddr)) == -1) {
+    return 1;
-  rtems_lwip_semaphore_release();
+  if  (getsockname(listener, &a.addr, &addrlen) == -1) {
+    return 1;
-  return fd;
+  if (listen(listener, 1) == -1) {
+    return 1;
+  socket_vector[0] = socket(AF_INET, SOCK_STREAM, IPPROTO_TCP);
+  if (socket_vector[0] == -1) {
+    return 1;
+  if (connect(socket_vector[0], &a.addr, sizeof(a.inaddr)) == -1) {
+    return 1;
+  socket_vector[1] = accept(listener, NULL, NULL);
+  if (socket_vector[1] == -1) {
+    return 1;
+  close(listener);
+  return 0;
+/* Fake socketpair() support with a loopback TCP socket */
+int
+socketpair(int domain, int type, int protocol, int *socket_vector)
+  int listener;
+  int saved_errno;
+  if (socket_vector == NULL) {
+    errno = EINVAL;
+    return -1;
+  socket_vector[0] = socket_vector[1] = -1;
+  listener = socket(AF_INET, SOCK_STREAM, IPPROTO_TCP);
+  if (listener == -1)
+    return -1;
+  if (setup_socketpair(listener, socket_vector) == 0) {
+    return 0;
+  saved_errno = errno;
+  close(listener);
+  close(socket_vector[0]);
+  close(socket_vector[1]);
+  errno = saved_errno;
+  return -1;
 int bind(
@@ -220,59 +279,17 @@ int bind(
   socklen_t              namelen
-  int                ret = -1;
   int                lwipfd;
-  int                family;
-  struct sockaddr   *lwipname;
-  socklen_t          lwipnamelen;
-  struct sockaddr_in so_in;
- #if LWIP_IPV6
-  struct sockaddr_in6 so_in6;
- #endif
-  family = rtems_lwip_sysdefs_sockaddr_get_family( name );
-  if ( ( family == rtems_lwip_sysdefs_AF_INET ) &&
-       ( namelen >= rtems_lwip_sysdefs_sockaddr_in_size ) ) {
-    so_in.sin_len = sizeof( so_in );
-    so_in.sin_family = PF_INET;
-    so_in.sin_port = rtems_lwip_sysdefs_sockaddr_in_get_sin_port( name );
-    so_in.sin_addr.s_addr =
-      rtems_lwip_sysdefs_sockaddr_in_get_sin_addr( name );
-    lwipname = (struct sockaddr *) &so_in;
-    lwipnamelen = so_in.sin_len;
- #if LWIP_IPV6
-  } else if ( ( family == rtems_lwip_sysdefs_AF_INET6 ) &&
-              ( namelen >= rtems_lwip_sysdefs_sockaddr_in6_size ) ) {
-    so_in6.sin6_len = sizeof( so_in6 );
-    so_in6.sin6_family = PF_INET6;
-    so_in6.sin6_port = rtems_lwip_sysdefs_sockaddr_in6_get_sin6_port( name );
-    memcpy( &so_in6.sin6_addr,
-      rtems_lwip_sysdefs_sockaddr_in6_get_sin6_addr_ptr_const( name ),
-      sizeof( so_in6.sin6_addr ) );
-    so_in6.sin6_flowinfo = rtems_lwip_sysdefs_sockaddr_in6_get_sin6_flowinfo(
-      name );
-    so_in6.sin6_scope_id = rtems_lwip_sysdefs_sockaddr_in6_get_sin6_scope_id(
-      name );
-    lwipname = (struct sockaddr *) &so_in6;
-    lwipnamelen = so_in6.sin6_len;
- #endif
-  } else {
-    errno = EINVAL;
-    return -1;
+  lwipfd = rtems_lwip_sysfd_to_lwipfd( s );
-  if ( ( lwipfd = rtems_lwip_sysfd_to_lwipfd( s ) ) >= 0 ) {
-    ret = lwip_bind( lwipfd, lwipname, lwipnamelen );
+    return -1;
-  return ret;
+  return lwip_bind( lwipfd, name, namelen );
 int connect(
@@ -281,59 +298,17 @@ int connect(
   socklen_t              namelen
-  int                ret = -1;
   int                lwipfd;
-  int                family;
- #if LWIP_IPV6
- #endif
-    so_in.sin_family = AF_INET;
- #if LWIP_IPV6
-    so_in6.sin6_family = AF_INET6;
-      name );
-      name );
- #endif
-  } else {
-    errno = EINVAL;
-    return -1;
-    ret = lwip_connect( lwipfd, lwipname, lwipnamelen );
+    return -1;
-  return ret;
+  return lwip_connect( lwipfd, name, namelen );
 int listen(
@@ -341,18 +316,17 @@ int listen(
   int backlog
-  int ret = -1;
   int lwipfd;
-    ret = lwip_listen( lwipfd, backlog );
+    return -1;
-  return ret;
+  return lwip_listen( lwipfd, backlog );
 int accept(
@@ -363,72 +337,25 @@ int accept(
   int                ret = -1;
   int                lwipfd;
-  struct sockaddr   *lwipname = name;
-  socklen_t          lwipnamelen = *namelen;
- #if LWIP_IPV6
- #endif
-    lwipfd = lwip_accept( lwipfd, lwipname, &lwipnamelen );
-  if ( lwipfd < 0 )
-    return lwipfd;
-  if ( lwipname->sa_family == AF_INET ) {
-    memcpy( &so_in, lwipname, sizeof( so_in ) );
-    rtems_lwip_sysdefs_sockaddr_set_len( name,
-      rtems_lwip_sysdefs_sockaddr_in_size );
-    rtems_lwip_sysdefs_sockaddr_set_family( name, rtems_lwip_sysdefs_AF_INET );
-    rtems_lwip_sysdefs_sockaddr_in_set_sin_port( name, so_in.sin_port );
-    rtems_lwip_sysdefs_sockaddr_in_set_sin_addr( name, so_in.sin_addr.s_addr );
- #if LWIP_IPV6
-  } else if ( lwipname->sa_family == AF_INET6 ) {
-    memcpy( &so_in6, lwipname, sizeof( so_in6 ) );
-      rtems_lwip_sysdefs_sockaddr_in6_size );
-      rtems_lwip_sysdefs_AF_INET6 );
-    rtems_lwip_sysdefs_sockaddr_in6_set_sin6_port( name, so_in6.sin6_port );
-    memcpy( rtems_lwip_sysdefs_sockaddr_in6_get_sin6_addr_ptr( name ),
-      &so_in6.sin6_addr,
-    rtems_lwip_sysdefs_sockaddr_in6_set_sin6_flowinfo( name,
-      so_in6.sin6_flowinfo );
-    rtems_lwip_sysdefs_sockaddr_in6_set_sin6_scope_id( name,
-      so_in6.sin6_scope_id );
- #endif
-  } else {
-    errno = EINVAL;
     return -1;
+  lwipfd = lwip_accept( lwipfd, name, namelen );
   ret = rtems_lwip_make_sysfd_from_lwipfd( lwipfd );
   if ( ret < 0 ) {
-  *namelen = rtems_lwip_sysdefs_sockaddr_get_len( name );
   return ret;
@@ -441,20 +368,17 @@ int shutdown(
   int how
-  int ret = -1;
   int lwipfd;
-    ret = lwip_shutdown( lwipfd, how );
+    return -1;
-  return ret;
+  return lwip_shutdown( lwipfd, how );
 ssize_t recv(
@@ -464,20 +388,17 @@ ssize_t recv(
   int    flags
-  int ret = -1;
   int lwipfd;
-    ret = lwip_recv( lwipfd, buf, len, flags );
+    return -1;
-  return ret;
+  return lwip_recv( lwipfd, buf, len, flags );
 ssize_t send(
@@ -487,20 +408,17 @@ ssize_t send(
   int         flags
-  int ret = -1;
   int lwipfd;
-    ret = lwip_send( lwipfd, buf, len, flags );
+    return -1;
-  return ret;
+  return lwip_send( lwipfd, buf, len, flags );
 ssize_t recvfrom(
@@ -512,75 +430,20 @@ ssize_t recvfrom(
   socklen_t       *namelen
-  int                ret = -1;
   int                lwipfd;
- #if LWIP_IPV6
- #endif
   if ( name == NULL )
     return recv( s, buf, len, flags );
-    lwipfd = lwip_recvfrom( lwipfd, buf, len, flags, lwipname, &lwipnamelen );
-  if ( lwipfd < 0 )
-    return lwipfd;
- #if LWIP_IPV6
- #endif
-  } else {
-    errno = EINVAL;
     return -1;
-  ret = rtems_lwip_make_sysfd_from_lwipfd( lwipfd );
-  if ( ret < 0 ) {
-  return ret;
+  return lwip_recvfrom( lwipfd, buf, len, flags, name, namelen );
 ssize_t sendto(
@@ -592,61 +455,118 @@ ssize_t sendto(
   socklen_t              namelen
-  int                ret = -1;
   int                lwipfd;
-  int                family;
- #if LWIP_IPV6
- #endif
   if ( name == NULL )
     return send( s, buf, len, flags );
- #if LWIP_IPV6
-      name );
-      name );
- #endif
-  } else {
-    errno = EINVAL;
     return -1;
+  return lwip_sendto( lwipfd, buf, len, flags, name, namelen );
+static int fdset_sysfd_to_lwipfd( int maxfdp1, fd_set *orig_set, fd_set *mapped_set )
+  int new_max = 0;
+  FD_ZERO( mapped_set );
+  if ( orig_set == NULL ) {
+    return new_max;
+  for ( int sysfd = 0; sysfd < maxfdp1; sysfd++ ) {
+    int lwipfd;
+    if ( FD_ISSET( sysfd, orig_set ) == 0 ) {
+      continue;
+    lwipfd = rtems_lwip_sysfd_to_lwipfd( sysfd );
+      return -1;
+    if ( lwipfd > (new_max - 1) ) {
+        new_max = lwipfd + 1;
+    FD_SET( lwipfd, mapped_set );
+  return new_max;
+static void fdset_lwipfd_to_sysfd( int maxfdp1, fd_set *orig_set, fd_set *mapped_set )
+  fd_set new_orig_set;
+  FD_ZERO( &new_orig_set );
+    return;
+    int lwipfd;
+      continue;
+    if ( FD_ISSET( lwipfd, mapped_set ) == 0 ) {
+      continue;
+    FD_SET( sysfd, &new_orig_set );
+  *orig_set = new_orig_set;
+int select(int maxfdp1, fd_set *readset, fd_set *writeset, fd_set *exceptset,
+                struct timeval *timeout)
+  int rmaxp1;
+  int wmaxp1;
+  int emaxp1;
+  int newmaxfdp1;
+  int ret;
+  fd_set newread, newwrite, newexcept;
+  /* Save original FD sets,  */
+  rmaxp1 = fdset_sysfd_to_lwipfd( maxfdp1, readset, &newread );
+  wmaxp1 = fdset_sysfd_to_lwipfd( maxfdp1, writeset, &newwrite );
+  emaxp1 = fdset_sysfd_to_lwipfd( maxfdp1, exceptset, &newexcept );
-    ret = lwip_sendto( lwipfd, buf, len, flags, lwipname, lwipnamelen );
+  if ( rmaxp1 < 0 || wmaxp1 < 0 || emaxp1 < 0 ) {
+    errno = ENOSYS;
+    return -1;
+  newmaxfdp1 = rmaxp1;
+  if ( wmaxp1 > newmaxfdp1 ) {
+    newmaxfdp1 = wmaxp1;
+  if ( emaxp1 > newmaxfdp1 ) {
+    newmaxfdp1 = emaxp1;
+  ret = lwip_select( newmaxfdp1, &newread, &newwrite, &newexcept, timeout );
+  fdset_lwipfd_to_sysfd( maxfdp1, readset, &newread );
+  fdset_lwipfd_to_sysfd( maxfdp1, writeset, &newwrite );
+  fdset_lwipfd_to_sysfd( maxfdp1, exceptset, &newexcept );
   return ret;
@@ -750,6 +670,8 @@ ssize_t sendmsg(
   return ( ret );
+#endif
  * All `receive' operations end up calling this routine.
@@ -759,113 +681,19 @@ ssize_t recvmsg(
   int            flags
-  int           ret = -1;
-  int           error;
-  struct uio    auio;
-  struct iovec *iov;
-  int           lwipfd;
-  struct mbuf  *from = NULL, *control = NULL;
-  int           i;
-  int           len;
+  int lwipfd;
-  if ( ( so = rtems_lwip_sysfd_to_lwipfd( s ) ) == NULL ) {
     return -1;
-  auio.uio_iov = mp->msg_iov;
-  auio.uio_iovcnt = mp->msg_iovlen;
-  auio.uio_segflg = UIO_USERSPACE;
-  auio.uio_rw = UIO_READ;
-  auio.uio_offset = 0;
-  auio.uio_resid = 0;
-  iov = mp->msg_iov;
-  for ( i = 0; i < mp->msg_iovlen; i++, iov++ ) {
-    if ( ( auio.uio_resid += iov->iov_len ) < 0 ) {
-      errno = EINVAL;
-      return -1;
-  len = auio.uio_resid;
-  mp->msg_flags = flags;
-  error = soreceive( so, &from, &auio, (struct mbuf **) NULL,
-    mp->msg_control ? &control : (struct mbuf **) NULL,
-    &mp->msg_flags );
-  if ( error ) {
-    if ( auio.uio_resid != len && ( error == EINTR || error == EWOULDBLOCK ) )
-      error = 0;
-  if ( error ) {
-    errno = error;
-  } else {
-    ret = len - auio.uio_resid;
-    if ( mp->msg_name ) {
-      len = mp->msg_namelen;
-      if ( ( len <= 0 ) || ( from == NULL ) ) {
-        len = 0;
-      } else {
-        if ( len > from->m_len )
-          len = from->m_len;
-        memcpy( mp->msg_name, mtod( from, caddr_t ), len );
-      mp->msg_namelen = len;
-    if ( mp->msg_control ) {
-      struct mbuf *m;
-      void        *ctlbuf;
-      len = mp->msg_controllen;
-      m = control;
-      mp->msg_controllen = 0;
-      ctlbuf = mp->msg_control;
-      while ( m && ( len > 0 ) ) {
-        unsigned int tocopy;
-        if ( len >= m->m_len )
-          tocopy = m->m_len;
-        else {
-          mp->msg_flags |= MSG_CTRUNC;
-          tocopy = len;
-        memcpy( ctlbuf, mtod( m, caddr_t ), tocopy );
-        ctlbuf += tocopy;
-        len -= tocopy;
-        m = m->m_next;
-      mp->msg_controllen = ctlbuf - mp->msg_control;
-  if ( from )
-    m_freem( from );
-  if ( control )
-    m_freem( control );
-  return ( ret );
+  return lwip_recvmsg( lwipfd, mp, flags );
-#endif
 int setsockopt(
   int         s,
   int         level,
@@ -874,54 +702,19 @@ int setsockopt(
   socklen_t   len
-#if 0
-  int          lwipfd;
-  struct mbuf *m = NULL;
-  int          error;
+  int lwipfd;
-    return -1;
-  if ( len > MLEN ) {
-    errno = EINVAL;
-    return -1;
-  if ( val ) {
-    error = sockargstombuf( &m, val, len, MT_SOOPTS );
-    if ( error ) {
-      errno = error;
-      return -1;
-  error = sosetopt( so, level, name, m );
-  if ( error ) {
-    errno = error;
     return -1;
-#endif
-  return 0;
+  return lwip_setsockopt( lwipfd, level, name, val, len );
-#if 0
 int getsockopt(
   int        s,
   int        level,
@@ -930,61 +723,21 @@ int getsockopt(
   socklen_t *avalsize
-  int          lwipfd;
-  struct mbuf *m = NULL, *m0;
-  char        *val = aval;
-  int          i, op, valsize;
-  int          error;
+  int lwipfd;
-    return -1;
-  if ( val )
-    valsize = *avalsize;
-  else
-    valsize = 0;
-  if ( ( ( error =
-             sogetopt( so, level, name,
-               &m ) ) == 0 ) && val && valsize && m ) {
-    op = 0;
-    while ( m && op < valsize ) {
-      i = valsize - op;
-      if ( i > m->m_len )
-        i = m->m_len;
-      memcpy( val, mtod( m, caddr_t ), i );
-      op += i;
-      val += i;
-      m0 = m;
-      MFREE( m0, m );
-    *avalsize = op;
-  if ( m != NULL )
-    (void) m_free( m );
-  if ( error ) {
-    errno = error;
     return -1;
-  return 0;
+  return lwip_getsockopt( lwipfd, level, name, aval, avalsize );
+#if 0
 static int getpeersockname(
   int              s,
   struct sockaddr *name,
@@ -1047,35 +800,40 @@ int getpeername(
   socklen_t       *namelen
-  int          lwipfd;
-  int          error;
+  int lwipfd;
-  if ( ( lwipfd = rtems_lwip_sysfd_to_lwipfd( s ) ) < 0 ) {
     return -1;
-  error = lwip_getpeername(lwipfd, name, namelen);
-  return error;
+  return lwip_getpeername(lwipfd, name, namelen);
-#if 0
 int getsockname(
   int              s,
   socklen_t       *namelen
-  return getpeersockname( s, name, namelen, 0 );
+  int lwipfd;
+    return -1;
+  return lwip_getsockname( lwipfd, name, namelen );
+#if 0
 int sysctl(
   const int  *name,
   u_int       namelen,
@@ -1115,22 +873,16 @@ int sysctl(
 static int rtems_lwip_close( rtems_libio_t *iop )
   int lwipfd;
-  int ret;
   lwipfd = rtems_lwip_iop_to_lwipfd( iop );
   if ( lwipfd < 0 ) {
-    ret = -1;
-  } else {
-    ret = lwip_close( lwipfd );
+    return -1;
-  return ret;
+  return lwip_close( lwipfd );
 static ssize_t rtems_lwip_read(
@@ -1140,22 +892,16 @@ static ssize_t rtems_lwip_read(
   int lwipfd;
-  int ret;
   if ( lwipfd < 0 ) {
-    ret = -1;
-  } else {
-    ret = lwip_read( lwipfd, buffer, count );
+    return -1;
-  return ret;
+  return lwip_read( lwipfd, buffer, count );
 static ssize_t rtems_lwip_write(
@@ -1165,22 +911,16 @@ static ssize_t rtems_lwip_write(
   int lwipfd;
-  int ret;
   if ( lwipfd < 0 ) {
-    ret = -1;
-  } else {
-    ret = lwip_write( lwipfd, buffer, count );
+    return -1;
-  return ret;
+  return lwip_write( lwipfd, buffer, count );
 int so_ioctl(
@@ -1262,30 +1002,25 @@ static int rtems_lwip_fcntl(
   int            cmd
-#if 0
   int lwipfd;
-  if ( cmd == F_SETFL ) {
-    if ( ( so = iop->data1 ) == NULL ) {
-      return EBADF;
-    if ( rtems_libio_iop_is_no_delay( iop ) )
-      so->so_state |= SS_NBIO;
-    else
-      so->so_state &= ~SS_NBIO;
+  lwipfd = rtems_lwip_iop_to_lwipfd( iop );
+    return -1;
-  return 0;
-#endif
+   * Returning non-zero here for F_GETFL results in the call failing instead of
+   * passing back the value retrieved in the libio layer.
+  if (cmd == F_GETFL) {
+    return 0;
-  return -1;
+  return lwip_fcntl( lwipfd, cmd, O_NONBLOCK );
 static int rtems_lwip_fstat(
@@ -1321,3 +1056,8 @@ const char *
 inet_ntop(int af, const void *src, char *dst, socklen_t size){
 	    return lwip_inet_ntop(af, src, dst, size);
+int inet_pton(int af, const char *src, void *dst)
+  return lwip_inet_pton(af, src, dst);
diff --git a/rtemslwip/common/rtems_lwip_sysdefs.c b/rtemslwip/common/rtems_lwip_sysdefs.c
deleted file mode 100644
index 3877811..0000000
--- a/rtemslwip/common/rtems_lwip_sysdefs.c
+++ /dev/null
@@ -1,185 +0,0 @@
- * RTEMS Project (https://www.rtems.org/)
- * Copyright (c) 2021 Vijay Kumar Banerjee <vijay at rtems.org>.
- * All rights reserved.
- *  Redistribution and use in source and binary forms, with or without
- *  modification, are permitted provided that the following conditions
- *  are met:
- *  1. Redistributions of source code must retain the above copyright
- *     notice, this list of conditions and the following disclaimer.
- *  2. Redistributions in binary form must reproduce the above copyright
- *     notice, this list of conditions and the following disclaimer in the
- *     documentation and/or other materials provided with the distribution.
- *  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
- *  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
- *  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
- *  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
- *  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
- *  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
- *  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
- *  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
- *  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
- *  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
- *  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
-#include <stdint.h>
-#include <sys/socket.h>
-#include <netinet/in.h>
-int rtems_lwip_sysdefs_AF_UNSPEC = AF_UNSPEC;
-int rtems_lwip_sysdefs_AF_UNIX = AF_UNIX;
-int rtems_lwip_sysdefs_AF_INET = AF_INET;
-int rtems_lwip_sysdefs_AF_INET6 = AF_INET6;
-int rtems_lwip_sysdefs_PF_UNSPEC = PF_UNSPEC;
-int rtems_lwip_sysdefs_PF_UNIX = PF_UNIX;
-int rtems_lwip_sysdefs_PF_INET = PF_INET;
-int rtems_lwip_sysdefs_PF_INET6 = PF_INET6;
-int rtems_lwip_sysdefs_SOCK_STREAM = SOCK_STREAM;
-int rtems_lwip_sysdefs_SOCK_DGRAM = SOCK_DGRAM;
-int rtems_lwip_sysdefs_SOCK_RAW = SOCK_RAW;
-int rtems_lwip_sysdefs_sockaddr_in_size = sizeof( struct sockaddr_in );
-int rtems_lwip_sysdefs_sockaddr_in6_size = sizeof( struct sockaddr_in6 );
-int rtems_lwip_sysdefs_sockaddr_get_len( const void *sockaddr )
-  const struct sockaddr *so = sockaddr;
-  return so->sa_len;
-int rtems_lwip_sysdefs_sockaddr_get_family( const void *sockaddr )
-  return so->sa_family;
-uint16_t rtems_lwip_sysdefs_sockaddr_in_get_sin_port( const void *sockaddr )
-  const struct sockaddr_in *so = sockaddr;
-  return so->sin_port;
-uint32_t rtems_lwip_sysdefs_sockaddr_in_get_sin_addr( const void *sockaddr )
-  return so->sin_addr.s_addr;
-uint16_t rtems_lwip_sysdefs_sockaddr_in6_get_sin6_port( const void *sockaddr )
-  const struct sockaddr_in6 *so = sockaddr;
-  return so->sin6_port;
-const uint8_t *rtems_lwip_sysdefs_sockaddr_in6_get_sin6_addr_ptr_const(
-  const void *sockaddr )
-  return (uint8_t *) &so->sin6_addr;
-uint8_t *rtems_lwip_sysdefs_sockaddr_in6_get_sin6_addr_ptr(
-  void *sockaddr )
-  struct sockaddr_in6 *so = sockaddr;
-uint32_t rtems_lwip_sysdefs_sockaddr_in6_get_sin6_flowinfo(
-  return so->sin6_flowinfo;
-uint32_t rtems_lwip_sysdefs_sockaddr_in6_get_sin6_scope_id(
-  return so->sin6_scope_id;
-void rtems_lwip_sysdefs_sockaddr_set_len(
-  void *sockaddr,
-  int   len
-  struct sockaddr *so = sockaddr;
-  so->sa_len = len;
-void rtems_lwip_sysdefs_sockaddr_set_family(
-  void *sockaddr,
-  int   family
-  so->sa_family = family;
-void rtems_lwip_sysdefs_sockaddr_in_set_sin_port(
-  void    *sockaddr,
-  uint16_t port
-  struct sockaddr_in *so = sockaddr;
-  so->sin_port = port;
-void rtems_lwip_sysdefs_sockaddr_in_set_sin_addr(
-  void    *sockaddr,
-  uint32_t addr
-  so->sin_addr.s_addr = addr;
-void rtems_lwip_sysdefs_sockaddr_in6_set_sin6_port(
-  void    *sockaddr,
-  uint16_t port
-  so->sin6_port = port;
-void rtems_lwip_sysdefs_sockaddr_in6_set_sin6_flowinfo(
-  void    *sockaddr,
-  uint32_t flowinfo
-  so->sin6_flowinfo = flowinfo;
-void rtems_lwip_sysdefs_sockaddr_in6_set_sin6_scope_id(
-  void    *sockaddr,
-  uint32_t scope_id
-  so->sin6_scope_id = scope_id;
diff --git a/rtemslwip/common/syslog.c b/rtemslwip/common/syslog.c
index 4da911e..658b4da 100644
--- a/rtemslwip/common/syslog.c
+++ b/rtemslwip/common/syslog.c
@@ -90,3 +90,9 @@ setlogmask (int pmask)
 		LogMask = pmask;
 	return (omask);
+void
+openlog(const char *ident, int option, int facility)
+	/* Do nothing */
diff --git a/rtemslwip/include/rtems_lwip_int.h b/rtemslwip/include/rtems_lwip_int.h
index 9d3d548..0000000
--- a/rtemslwip/include/rtems_lwip_int.h
+++ /dev/null
@@ -1,92 +0,0 @@
- *  are met:
-#ifndef RTEMS_LWIP_INT_H
-#define RTEMS_LWIP_INT_H
-extern int rtems_lwip_sysdefs_AF_UNSPEC;
-extern int rtems_lwip_sysdefs_AF_UNIX;
-extern int rtems_lwip_sysdefs_AF_INET;
-extern int rtems_lwip_sysdefs_AF_INET6;
-extern int rtems_lwip_sysdefs_PF_UNSPEC;
-extern int rtems_lwip_sysdefs_PF_UNIX;
-extern int rtems_lwip_sysdefs_PF_INET;
-extern int rtems_lwip_sysdefs_PF_INET6;
-extern int rtems_lwip_sysdefs_SOCK_STREAM;
-extern int rtems_lwip_sysdefs_SOCK_DGRAM;
-extern int rtems_lwip_sysdefs_SOCK_RAW;
-extern int rtems_lwip_sysdefs_sockaddr_in_size;
-extern int rtems_lwip_sysdefs_sockaddr_in6_size;
-int rtems_lwip_sysdefs_sockaddr_get_len( const void *sockaddr );
-int rtems_lwip_sysdefs_sockaddr_get_family( const void *sockaddr );
-uint16_t rtems_lwip_sysdefs_sockaddr_in_get_sin_port( const void *sockaddr );
-uint32_t rtems_lwip_sysdefs_sockaddr_in_get_sin_addr( const void *sockaddr );
-uint16_t rtems_lwip_sysdefs_sockaddr_in6_get_sin6_port( const void *sockaddr );
-  const void *sockaddr );
-  void *sockaddr );
-  void *sockaddr,
-  int   len
-  void *sockaddr,
-  int   family
-  void    *sockaddr,
-  uint16_t port
-  void    *sockaddr,
-  uint32_t addr
-  void    *sockaddr,
-  uint16_t port
-  void    *sockaddr,
-  uint32_t flowinfo
-  void    *sockaddr,
-  uint32_t scope_id
-#endif /*RTEMS_LWIP_INT_H*/
diff --git a/rtemslwip/zynqmp/lwipopts.h b/rtemslwip/zynqmp/lwipopts.h
index a939ea2..2d358a3 100644
--- a/rtemslwip/zynqmp/lwipopts.h
+++ b/rtemslwip/zynqmp/lwipopts.h
@@ -36,6 +36,8 @@
 #define LWIP_ARP 1
 #define LWIP_NETIF_API 1
+/* Required for socketpair implementation */
+#define LWIP_NETIF_LOOPBACK 1
 #define LWIP_IPV6                       1
 #define LWIP_IPV4                       1
 #define LWIP_TIMEVAL_PRIVATE 0
2.30.2
