[PATCH rtems-lwip v1 7/8] lwip.py: Add NTP library build
Kinsey Moore kinsey.moore at oarcorp.com
Wed Aug 24 12:25:00 UTC 2022
On 8/23/2022 21:30, Chris Johns wrote:
> On 24/8/2022 5:47 am, Kinsey Moore wrote:
>> diff --git a/ntp-file-import.yaml b/ntp-file-import.yaml
>> new file mode 100644
>> index 0000000..5e4e8a4
>> --- /dev/null
>> +++ b/ntp-file-import.yaml
> Sorry the existing YAML support has to be removed or maybe you could merge into
> the repo https://git.rtems.org/rtems/tree/yaml? I am fine with either option.
> Chris
I'll transition to JSON and move the remainder of the YAML usage in
rtems-lwip to JSON as well.
Kinsey
