[PATCH RTEMS] Add i2c command
    chrisj at rtems.org
    chrisj at rtems.org
    Thu Aug 25 05:45:17 UTC 2022
The patch adds the i2c command. It is a single command to test and
explore I2C buses on hardware. The command lets you string together
reads and writes on a single command line to access a number of devices
so you can script basic functionality simply.
This ocommand adds to the existing i2cdetect, i2cset and i2cget however
those commands did not work cleanly on the vck-190 or did not read and
write directly at the bus level.
