[PATCH rtems-lwip v1 1/5] lwip-to-rtems.py: Add support for reverse changes
Kinsey Moore
kinsey.moore at oarcorp.com
Thu Aug 25 19:43:28 UTC 2022
This adds the necessary support for moving changes back and forth to the
upstream repository.
lwip-to-rtems.py | 16 ++++++++++------
1 file changed, 10 insertions(+), 6 deletions(-)
diff --git a/lwip-to-rtems.py b/lwip-to-rtems.py
index acd6922..1be2628 100755
--- a/lwip-to-rtems.py
+++ b/lwip-to-rtems.py
@@ -86,8 +86,8 @@ print("Direction: %s" % (("reverse", "forward")[isForward]))
def copyFiles(isforward):
+ files = json.load(open('file-import.json', 'r'))
if (isforward):
- files = json.load(open('file-import.json', 'r'))
src_dir = os.path.abspath(LWIP_UPSTREAM_DIR)
print("Files Imported:")
for f in files['files-to-import']:
@@ -95,10 +95,14 @@ def copyFiles(isforward):
dst_file = os.path.join(dst_dir, f.split('/')[-1])
if not os.path.exists(dst_dir):
os.makedirs(dst_dir)
- if not os.path.exists(dst_file):
- Path(dst_file).touch()
- print(dst_file)
- copyfile(str(os.path.join(src_dir, f)),
- str(dst_file))
+ Path(dst_file).touch()
+ print(dst_file)
+ copyfile(str(os.path.join(src_dir, f)),
+ str(dst_file))
+ else:
+ for f in files['files-to-import']:
+ src_file = os.path.join(os.path.abspath(LWIP_DIR), f)
+ dst_file = os.path.join(os.path.abspath(LWIP_UPSTREAM_DIR), f)
+ copyfile(str(src_file), str(dst_file))
copyFiles(isForward)
2.30.2
