[PATCH RTEMS v2] Add i2c command
chrisj at rtems.org chrisj at rtems.org
Mon Aug 29 04:36:42 UTC 2022
The patch adds an i2c command. It is a single command to test and
explore I2C buses on hardware. The command lets you string together
reads and writes on a single command line to access a number of devices
so you can script basic functionality simply.
This command adds to the existing i2cdetect, i2cset and i2cget. I have
left those command as they are and we can decide on their future once
this patch is merged.
v2:
- Switch the detect to a zero length write. Add `-rw` option to detect
  as a fallback option to use reads and then writes.
