[PATCH] Revert "test.h: Add pragma for gcc 12 warning"
Mon Aug 29 07:02:46 UTC 2022
This reverts commit 9e2289785b7a12684d96c72e219523e2810f0f10.
There is no issue with the T_flags_not_null() macro.  The uninitialized
use warnings must be fixed at the caller side of the macro.
 cpukit/include/rtems/test.h | 7 -------
 1 file changed, 7 deletions(-)
diff --git a/cpukit/include/rtems/test.h b/cpukit/include/rtems/test.h
index e0823394d1..c283be7860 100644
--- a/cpukit/include/rtems/test.h
+++ b/cpukit/include/rtems/test.h
@@ -218,19 +218,12 @@ void T_check_null(const T_check_context_msg *, const void *);
 void T_check_not_null(const T_check_context_msg *, const void *);
- * This was added to address the following warning.
- * warning: 'a' may be used uninitialized
-#pragma GCC diagnostic push
-#pragma GCC diagnostic ignored "-Wmaybe-uninitialized"
 #define T_flags_not_null(a, flags, sa)					\
 	static const T_check_context_msg T_check_instance = {		\
 	    { T_FILE_NAME, __LINE__, (flags) | T_CHECK_FMT }, sa };	\
 	T_check_not_null(&T_check_instance, a);				\
-#pragma GCC diagnostic pop
 void T_check_eq_mem(const T_check_context_msg *, const void *, const void *,
     size_t);
2.35.3
