New Defects reported by Coverity Scan for RTEMS
Sebastian Huber
Tue Aug 30 05:05:49 UTC 2022
On 30/08/2022 00:56, scan-admin at coverity.com wrote:
> ** CID 1512552: High impact quality (Y2K38_SAFETY)
> /cpukit/score/src/kern_tc.c: 1804 in _Timecounter_Windup()
> ________________________________________________________________________________________________________
> *** CID 1512552: High impact quality (Y2K38_SAFETY)
> 1798 /* Go live with the new struct timehands. */
> 1799 #ifdef FFCLOCK
> 1800 switch (sysclock_active) {
> 1801 case SYSCLOCK_FBCK:
> 1802 #endif
> 1803 time_second = th->th_microtime.tv_sec;
>>>> A "time_t" value is stored in an integer with too few bits to accommodate it. The expression "th->th_offset.sec" is cast to "int32_t".
> 1804 time_uptime = th->th_offset.sec;
> 1805 #ifdef FFCLOCK
> 1806 break;
> 1807 case SYSCLOCK_FFWD:
> 1808 time_second = fftimehands->tick_time_lerp.sec;
> 1809 time_uptime = fftimehands->tick_time_lerp.sec - ffclock_boottime.sec;
> ** CID 1512551: (Y2K38_SAFETY)
This seems to be a new Coverity feature. The Newlib time_t definition is:
#if defined(_USE_LONG_TIME_T) || __LONG_MAX__ > 0x7fffffffL
#define _TIME_T_ long
#else
#define _TIME_T_ __int_least64_t
#endif
typedef _TIME_T_ __time_t;
Does Coverity use the Newlib header files? The _USE_LONG_TIME_T should
be undefined for RTEMS.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
