New Defects reported by Coverity Scan for RTEMS
Tue Aug 30 13:44:22 UTC 2022
On 30/08/2022 15:40, Joel Sherrill wrote:
> On Tue, Aug 30, 2022 at 12:05 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     On 30/08/2022 00:56, scan-admin at coverity.com
>     <mailto:scan-admin at coverity.com> wrote:
>      > ** CID 1512552:  High impact quality  (Y2K38_SAFETY)
>      > /cpukit/score/src/kern_tc.c: 1804 in _Timecounter_Windup()
>     ________________________________________________________________________________________________________
>      > *** CID 1512552:  High impact quality  (Y2K38_SAFETY)
>      > 1798          /* Go live with the new struct timehands. */
>      > 1799     #ifdef FFCLOCK
>      > 1800          switch (sysclock_active) {
>      > 1801          case SYSCLOCK_FBCK:
>      > 1802     #endif
>      > 1803                  time_second = th->th_microtime.tv_sec;
>      >>>>      A "time_t" value is stored in an integer with too few
>     bits to accommodate it.  The expression "th->th_offset.sec" is cast
>     to "int32_t".
>      > 1804                  time_uptime = th->th_offset.sec;
>      > 1805     #ifdef FFCLOCK
>      > 1806                  break;
>      > 1807          case SYSCLOCK_FFWD:
>      > 1808                  time_second = fftimehands->tick_time_lerp.sec;
>      > 1809                  time_uptime =
>     fftimehands->tick_time_lerp.sec - ffclock_boottime.sec;
>      > ** CID 1512551:    (Y2K38_SAFETY)
>     This seems to be a new Coverity feature. The Newlib time_t
>     definition is:
>     #if defined(_USE_LONG_TIME_T) || __LONG_MAX__ > 0x7fffffffL
>     #define _TIME_T_ long
>     #else
>     #define _TIME_T_ __int_least64_t
>     #endif
>     typedef _TIME_T_        __time_t;
>     Does Coverity use the Newlib header files? The _USE_LONG_TIME_T should
>     be undefined for RTEMS.
> Yes it should. It works by doing something like this:
> cov-build waf|make
> And looking at the newlib headers, I agree everything looks like it should
> be defined to _int_least64_t. And preprocessing a simple file that includes
> <sys/time.h> shows that it is typed to that.
> But.... something else is going on. time_uptime is defined to
> _Timecounter_Time_uptime
> which is an int32_t.
Oh, sorry, I didn't notice this. Then this is a false positive. Using an
int32_t for uptime seconds is enough.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
