New Defects reported by Coverity Scan for RTEMS
Tue Aug 30 18:56:13 UTC 2022
On 30/08/2022 19:48, Joel Sherrill wrote:
> On Tue, Aug 30, 2022 at 9:53 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     On 30/08/2022 16:37, Joel Sherrill wrote:
>      > On Tue, Aug 30, 2022 at 8:44 AM Sebastian Huber
>     <mailto:sebastian.huber at embedded-brains.de>>> wrote:
>      >     On 30/08/2022 15:40, Joel Sherrill wrote:
>      >      > On Tue, Aug 30, 2022 at 12:05 AM Sebastian Huber
>      >      > <sebastian.huber at embedded-brains.de
>      >      > <mailto:sebastian.huber at embedded-brains.de
>     <mailto:sebastian.huber at embedded-brains.de>>>> wrote:
>      >      >     On 30/08/2022 00:56, scan-admin at coverity.com
>     <mailto:scan-admin at coverity.com>
>      >     <mailto:scan-admin at coverity.com <mailto:scan-admin at coverity.com>>
>      >      >     <mailto:scan-admin at coverity.com
>     <mailto:scan-admin at coverity.com>>> wrote:
>      >      >      > ** CID 1512552:  High impact quality  (Y2K38_SAFETY)
>      >      >      > /cpukit/score/src/kern_tc.c: 1804 in
>     _Timecounter_Windup()
>       ________________________________________________________________________________________________________
>      >      >      > *** CID 1512552:  High impact quality  (Y2K38_SAFETY)
>      >      >      > 1798          /* Go live with the new struct
>     timehands. */
>      >      >      > 1799     #ifdef FFCLOCK
>      >      >      > 1800          switch (sysclock_active) {
>      >      >      > 1801          case SYSCLOCK_FBCK:
>      >      >      > 1802     #endif
>      >      >      > 1803                  time_second =
>     th->th_microtime.tv_sec;
>      >      >      >>>>      CID 1512552:  High impact quality
>     (Y2K38_SAFETY)
>      >      >      >>>>      A "time_t" value is stored in an integer
>     with too few
>      >      >     bits to accommodate it.  The expression
>     "th->th_offset.sec"
>      >     is cast
>      >      >     to "int32_t".
>      >      >      > 1804                  time_uptime = th->th_offset.sec;
>      >      >      > 1805     #ifdef FFCLOCK
>      >      >      > 1806                  break;
>      >      >      > 1807          case SYSCLOCK_FFWD:
>      >      >      > 1808                  time_second =
>      >     fftimehands->tick_time_lerp.sec;
>      >      >      > 1809                  time_uptime =
>      >      >     fftimehands->tick_time_lerp.sec - ffclock_boottime.sec;
>      >      >      > ** CID 1512551:    (Y2K38_SAFETY)
>      >      >     This seems to be a new Coverity feature. The Newlib time_t
>      >      >     definition is:
>      >      >     #if defined(_USE_LONG_TIME_T) || __LONG_MAX__ >
>     0x7fffffffL
>      >      >     #define _TIME_T_ long
>      >      >     #else
>      >      >     #define _TIME_T_ __int_least64_t
>      >      >     #endif
>      >      >     typedef _TIME_T_        __time_t;
>      >      >     Does Coverity use the Newlib header files? The
>      >     _USE_LONG_TIME_T should
>      >      >     be undefined for RTEMS.
>      >      > Yes it should. It works by doing something like this:
>      >      > cov-build waf|make
>      >      > And looking at the newlib headers, I agree everything
>     looks like
>      >     it should
>      >      > be defined to _int_least64_t. And preprocessing a simple file
>      >     that includes
>      >      > <sys/time.h> shows that it is typed to that.
>      >      > But.... something else is going on. time_uptime is defined to
>      >      > _Timecounter_Time_uptime
>      >      > which is an int32_t.
>      >     Oh, sorry, I didn't notice this. Then this is a false positive.
>      >     Using an
>      >     int32_t for uptime seconds is enough.
>      > The variable  time_uptime is still defined as two separate types. The
>      > prototype and the declaration do not match.
>     I think this is all right:
>     #ifndef __rtems__
>     volatile time_t time_second = 1;
>     volatile time_t time_uptime = 1;
>     #else /* __rtems__ */
>     volatile time_t time_second = TOD_SECONDS_1970_THROUGH_1988;
>     volatile int32_t time_uptime = 1;
>     #endif /* __rtems__ */
>      > Even if int32_t is wide enough for seconds of uptime, it is an
>     assignment
>      > that narrows types. Casting to make this narrowing intentional
>     would at
>      > least hint this was intentional.
>       From looking at the other Y2K38_SAFETY reports, a cast probably
>     doesn't
>     help to get rid of it.
>      > But better would be to use the proper type and just make it
>     time_t like
>      > FreeBSD.
>     The time_uptime is used in the libbsd. This is a performance
>     optimization.
> And the declaration you show is mismatched because of these:
> cpukit/include/machine/_kernel_time.h:#define   time_uptime
> cpukit/include/rtems/score/timecounter.h:extern volatile int32_t
> _Timecounter_Time_uptime;
> This is inconsistent with the declaration of time_uptime above.
Sorry, I still don't see the issue with:
#ifndef __rtems__
>     There is also an unsolved issue with the time_second. On 32-bit targets
>     you can't reliably read this value.
> I assume you mean because it will take two accesses?
Yes, there are two loads in arbitrary order and this is an issue if bit
32 increments.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
