[PATCH] Fix pedanic warnings without a storage increase
Sebastian Huber
Tue Aug 30 18:59:07 UTC 2022
On 30/08/2022 19:45, Joel Sherrill wrote:
> On Tue, Aug 30, 2022 at 9:40 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> On 30/08/2022 16:38, Joel Sherrill wrote:
> > + * Ignore these warnings:
> > + * - invalid use of structure with flexible array member
> > + * - struct has no members
> > + #pragma GCC diagnostic push
> > + #pragma GCC diagnostic ignored "-Wpedantic"
> > This is heavy handed. -Warray-bounds should be enough.
> There is no array bounds warning. There are only the above two
> -Wpedantic warnings.
> OK I was suggesting that because -Wzero-length-bounds which should be
> the precise warning was turned on by -Warray-bounds.
> How about just -Wzero-length-bounds?
The patch changes Ready to a flexible array member, so the
-Wzero-length-bounds should not be applicable.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
