[PATCH] Document CONFIGURE_RECORD_INTERRUPTS_ENABLED
Thu Dec 1 12:11:24 UTC 2022
Close #4769.
 c-user/config/event-record.rst  | 43 +++++++++++++++++++++-
 user/tracing/eventrecording.rst | 65 +++------------------------------
 2 files changed, 47 insertions(+), 61 deletions(-)
diff --git a/c-user/config/event-record.rst b/c-user/config/event-record.rst
index 31a4fa9..f1e7969 100644
--- a/c-user/config/event-record.rst
+++ b/c-user/config/event-record.rst
@@ -1,6 +1,6 @@
 .. SPDX-License-Identifier: CC-BY-SA-4.0
-.. Copyright (C) 2019, 2021 embedded brains GmbH (http://www.embedded-brains.de)
+.. Copyright (C) 2019, 2022 embedded brains GmbH (http://www.embedded-brains.de)
 .. This file is part of the RTEMS quality process and was automatically
 .. generated.  If you find something that needs to be fixed or
@@ -150,6 +150,47 @@ in a fatal error extension (see :ref:`Terminate`).
 The zlib compression needs about 512KiB of RAM.  This extension can be used
 to produce crash dumps.
+.. Generated from spec:/acfg/if/record-interrupts-enabled
+.. raw:: latex
+    \clearpage
+.. index:: CONFIGURE_RECORD_INTERRUPTS_ENABLED
+.. _CONFIGURE_RECORD_INTERRUPTS_ENABLED:
+CONFIGURE_RECORD_INTERRUPTS_ENABLED
+.. rubric:: CONSTANT:
+``CONFIGURE_RECORD_INTERRUPTS_ENABLED``
+.. rubric:: OPTION TYPE:
+This configuration option is a boolean feature define.
+.. rubric:: DEFAULT CONFIGURATION:
+If this configuration option is undefined, then the described feature is not
+enabled.
+.. rubric:: DESCRIPTION:
+In case
+* this configuration option is defined
+* and :ref:`CONFIGURE_RECORD_PER_PROCESSOR_ITEMS` is properly defined,
+then the interrupt event recording is enabled.
+.. rubric:: NOTES:
+The interrupt event recording generates interrupt entry and exit events when
+interrupt entries are dispatched.
 .. Generated from spec:/acfg/if/record-per-processor-items
 .. raw:: latex
diff --git a/user/tracing/eventrecording.rst b/user/tracing/eventrecording.rst
index 7130658..b5561cc 100644
--- a/user/tracing/eventrecording.rst
+++ b/user/tracing/eventrecording.rst
@@ -48,8 +48,11 @@ The application enables the event recording support via the configuration
 option :c:macro:`CONFIGURE_RECORD_PER_PROCESSOR_ITEMS`.  The configuration
 option :c:macro:`CONFIGURE_RECORD_EXTENSIONS_ENABLED` enables the generation of
 thread create, start, restart, delete, switch, begin, exitted and terminate
-events.  Dumps of the event records in a fatal error handler can be enabled by
-the mutually exclusive :c:macro:`CONFIGURE_RECORD_FATAL_DUMP_BASE64` and
+events.  The configuration option
+:c:macro:`CONFIGURE_RECORD_INTERRUPTS_ENABLED` enables the generation of
+interrupt entry and exit events.  Dumps of the event records in a fatal error
+handler can be enabled by the mutually exclusive
+:c:macro:`CONFIGURE_RECORD_FATAL_DUMP_BASE64` and
 :c:macro:`CONFIGURE_RECORD_FATAL_DUMP_BASE64_ZLIB` configuration options.
 Custom events can be recorded for example with the
@@ -98,64 +101,6 @@ instrumented functions:
-To generate interrupt handler entry/exit events, the following patch can be
-used:
-.. code-block:: diff
-    diff --git a/bsps/arm/shared/clock/clock-armv7m.c b/bsps/arm/shared/clock/clock-armv7m.c
-    index 255de1ca42..0d37c63ac6 100644
-    --- a/bsps/arm/shared/clock/clock-armv7m.c
-    +++ b/bsps/arm/shared/clock/clock-armv7m.c
-    @@ -29,6 +29,7 @@
-     #include <bsp/clock-armv7m.h>
-     #include <rtems.h>
-    +#include <rtems/record.h>
-     #include <rtems/sysinit.h>
-     #ifdef ARM_MULTILIB_ARCH_V7M
-    @@ -45,9 +46,11 @@ static uint32_t _ARMV7M_TC_get_timecount(struct timecounter *base)
-     void _ARMV7M_Clock_handler(void)
-    +  rtems_record_produce(RTEMS_RECORD_INTERRUPT_ENTRY, ARMV7M_VECTOR_SYSTICK);
-       _ARMV7M_Interrupt_service_enter();
-       Clock_isr(NULL);
-       _ARMV7M_Interrupt_service_leave();
-    +  rtems_record_produce(RTEMS_RECORD_INTERRUPT_EXIT, ARMV7M_VECTOR_SYSTICK);
-     static void _ARMV7M_Clock_handler_install(void)
-    diff --git a/bsps/include/bsp/irq-generic.h b/bsps/include/bsp/irq-generic.h
-    index 31835d07ba..2ab2f78b65 100644
-    --- a/bsps/include/bsp/irq-generic.h
-    +++ b/bsps/include/bsp/irq-generic.h
-    @@ -30,6 +30,7 @@
-     #include <stdbool.h>
-     #include <rtems/irq-extension.h>
-     #include <rtems/score/assert.h>
-     #ifdef RTEMS_SMP
-    @@ -258,6 +259,7 @@ void bsp_interrupt_vector_disable(rtems_vector_number vector);
-     static inline void bsp_interrupt_handler_dispatch(rtems_vector_number vector)
-    +  rtems_record_produce(RTEMS_RECORD_INTERRUPT_ENTRY, vector);
-       if (bsp_interrupt_is_valid_vector(vector)) {
-         const bsp_interrupt_handler_entry *e =
-           &bsp_interrupt_handler_table [bsp_interrupt_handler_index(vector)];
-    @@ -276,6 +278,7 @@ static inline void bsp_interrupt_handler_dispatch(rtems_vector_number vector)
-       } else {
-         bsp_interrupt_handler_default(vector);
-    +  rtems_record_produce(RTEMS_RECORD_INTERRUPT_EXIT, vector);
 Transfer of Event Records to the Host Computer
2.35.3
