[PATCH rtems 1/3] bsps/atsam: Fix unidirectional SPI transfers
Christian Mauderer christian.mauderer at embedded-brains.de
Fri Dec 9 09:20:16 UTC 2022
A SPI transfer where the Rx or Tx buffer is set to NULL currently
transfers or overwrites data starting from address 0x00000000 via DMA.
This patch changes the DMA setup so that dummy transfers are done.
Just reading / writing to a single location is simpler than changing the
whole logic of the transfer depending on the passed buffers.
 bsps/arm/atsam/spi/atsam_spi_bus.c | 188 ++++++++++++++++++++---------
 1 file changed, 131 insertions(+), 57 deletions(-)
diff --git a/bsps/arm/atsam/spi/atsam_spi_bus.c b/bsps/arm/atsam/spi/atsam_spi_bus.c
index 53c1fe4827..dcf1397043 100644
--- a/bsps/arm/atsam/spi/atsam_spi_bus.c
+++ b/bsps/arm/atsam/spi/atsam_spi_bus.c
@@ -41,8 +41,8 @@
 #define MAX_SPI_FREQUENCY 50000000
 typedef struct {
-  volatile LinkedListDescriporView0 tx_desc;
-  volatile LinkedListDescriporView0 rx_desc[3];
+  volatile LinkedListDescriporView2 tx_desc;
+  volatile LinkedListDescriporView2 rx_desc[3];
   uint8_t rx_bounce_head_buf[CPU_CACHE_LINE_BYTES];
   uint8_t rx_bounce_tail_buf[CPU_CACHE_LINE_BYTES];
 } atsam_spi_dma;
@@ -67,6 +67,8 @@ typedef struct {
   uint32_t spi_csr[4];
 } atsam_spi_bus;
+static const uint32_t atsam_spi_dummy_write_data = 0xffffffff;
 static void atsam_spi_wakeup_task(atsam_spi_bus *bus)
   rtems_binary_semaphore_post(&bus->sem);
@@ -181,14 +183,14 @@ static void atsam_spi_copy_rx_bounce_bufs(
-static void atsam_spi_setup_rx_dma_desc(
+static void atsam_spi_setup_real_rx_dma_desc(
   atsam_spi_bus *bus,
   atsam_spi_dma *dma,
   const uint8_t *buf,
   size_t n
-  volatile LinkedListDescriporView0 *desc;
+  volatile LinkedListDescriporView2 *desc;
   uintptr_t m;
   uintptr_t b;
   uintptr_t a;
@@ -202,53 +204,56 @@ static void atsam_spi_setup_rx_dma_desc(
   a = (b + m) & ~m;
   ae = e & ~m;
+  /* An earlier dummy read maybe has set the DAM to FIXED_AM. Reset it. */
+  desc[0].mbr_cfg =
+      (desc[0].mbr_cfg & ~XDMAC_CC_DAM_Msk) | XDMAC_CC_DAM_INCREMENTED_AM;
   if (n <= m) {
     bus->rx_bounce_head_len = n;
     bus->rx_bounce_tail_len = 0;
-    desc[0].mbr_ta = (uint32_t) dma->rx_bounce_head_buf;
-    desc[0].mbr_ubc = n;
+    desc[0].mbr_da = (uint32_t) dma->rx_bounce_head_buf;
+    desc[0].mbr_ubc = n | XDMA_UBC_NVIEW_NDV2;
   } else {
     bus->rx_bounce_head_len = a - b;
     bus->rx_bounce_tail_len = e & m;
     if ((b & m) == 0) {
       if ((n & m) == 0) {
-        desc[0].mbr_ta = a;
+        desc[0].mbr_da = a;
       } else {
         desc[0].mbr_ubc = (ae - a) | XDMA_UBC_NDEN_UPDATED
-          | XDMA_UBC_NVIEW_NDV0
+          | XDMA_UBC_NVIEW_NDV2
           | XDMA_UBC_NDE_FETCH_EN;
-        desc[1].mbr_ta = (uint32_t) dma->rx_bounce_tail_buf;
-        desc[1].mbr_ubc = n & m;
+        desc[1].mbr_da = (uint32_t) dma->rx_bounce_tail_buf;
+        desc[1].mbr_ubc = n & m | XDMA_UBC_NVIEW_NDV2;
     } else {
       if ((e & m) == 0) {
         desc[0].mbr_ubc = (a - b) | XDMA_UBC_NDEN_UPDATED
-        desc[1].mbr_ta = a;
-        desc[1].mbr_ubc = ae - a;
+        desc[1].mbr_da = a;
+        desc[1].mbr_ubc = ae - a | XDMA_UBC_NVIEW_NDV2;
       } else if ((ae - a) == 0) {
       } else {
         desc[1].mbr_ubc = (ae - a) | XDMA_UBC_NDEN_UPDATED
-        desc[2].mbr_ta = (uint32_t) dma->rx_bounce_tail_buf;
-        desc[2].mbr_ubc = e - ae;
+        desc[2].mbr_da = (uint32_t) dma->rx_bounce_tail_buf;
+        desc[2].mbr_ubc = e - ae | XDMA_UBC_NVIEW_NDV2;
@@ -256,19 +261,61 @@ static void atsam_spi_setup_rx_dma_desc(
+static void atsam_spi_setup_dummy_rx_dma_desc(
+  atsam_spi_bus *bus,
+  atsam_spi_dma *dma,
+  size_t n
+  desc = &dma->rx_desc[0];
+  /* Avoid copying bounce buffers after receive. */
+  bus->rx_bounce_head_len = 0;
+  bus->rx_bounce_tail_len = 0;
+  /* But use one of the bounce buffers to write dummy data to. */
+  desc[0].mbr_cfg =
+      (desc[0].mbr_cfg & ~XDMAC_CC_DAM_Msk) | XDMAC_CC_DAM_FIXED_AM;
+static void atsam_spi_setup_rx_dma_desc(
+  const uint8_t *buf,
+  size_t n
+  if (buf != NULL) {
+    atsam_spi_setup_real_rx_dma_desc(bus, dma, buf, n);
+  } else {
+    atsam_spi_setup_dummy_rx_dma_desc(bus, dma, n);
 static void atsam_spi_setup_tx_dma_desc(
   atsam_spi_dma *dma,
   const uint8_t *buf,
   size_t n
   desc = &dma->tx_desc;
-  desc->mbr_ta = (uint32_t) buf;
-  desc->mbr_ubc = n;
-  rtems_cache_flush_multiple_data_lines(buf, n);
+  desc->mbr_ubc = n | XDMA_UBC_NVIEW_NDV2;
+    desc->mbr_sa = (uint32_t) buf;
+    desc->mbr_cfg =
+        (desc->mbr_cfg & ~XDMAC_CC_SAM_Msk) | XDMAC_CC_SAM_INCREMENTED_AM;
+    rtems_cache_flush_multiple_data_lines(buf, n);
+  } else {
+    desc->mbr_sa = (uint32_t)&atsam_spi_dummy_write_data;
+    desc->mbr_cfg =
+        (desc->mbr_cfg & ~XDMAC_CC_SAM_Msk) | XDMAC_CC_SAM_FIXED_AM;
 static void atsam_spi_start_dma_transfer(
@@ -296,8 +343,9 @@ static void atsam_spi_start_dma_transfer(
   XDMAC_SetDescriptorControl(
     pXdmac,
     bus->dma_rx_channel,
-    XDMAC_CNDC_NDVIEW_NDV0 |
+    XDMAC_CNDC_NDVIEW_NDV2 |
     XDMAC_CNDC_NDDUP_DST_PARAMS_UPDATED |
+    XDMAC_CNDC_NDSUP_SRC_PARAMS_UPDATED |
     XDMAC_CNDC_NDE_DSCR_FETCH_EN
   XDMAC_SetDescriptorAddr(
@@ -309,7 +357,8 @@ static void atsam_spi_start_dma_transfer(
     pXdmac,
     bus->dma_tx_channel,
+    XDMAC_CNDC_NDDUP_DST_PARAMS_UPDATED |
@@ -485,15 +534,60 @@ static void atsam_spi_init_xdma(atsam_spi_bus *bus)
   uint8_t channel;
   eXdmadRC rc;
   uint32_t xdma_cndc;
+  uint32_t tx_da;
+  uint32_t rx_sa;
+  uint32_t tx_cfg;
+  uint32_t rx_cfg;
+  tx_da = (uint32_t)&bus->spi_regs->SPI_TDR;
+  rx_sa = (uint32_t)&bus->spi_regs->SPI_RDR;
+  channel = XDMAIF_Get_ChannelNumber(bus->spi_id, XDMAD_TRANSFER_TX);
+  tx_cfg =
+    XDMAC_CC_TYPE_PER_TRAN |
+    XDMAC_CC_MBSIZE_SINGLE |
+    XDMAC_CC_DSYNC_MEM2PER |
+    XDMAC_CC_CSIZE_CHK_1 |
+    XDMAC_CC_DWIDTH_BYTE |
+    XDMAC_CC_SIF_AHB_IF1 |
+    XDMAC_CC_DIF_AHB_IF1 |
+    XDMAC_CC_SAM_INCREMENTED_AM |
+    XDMAC_CC_DAM_FIXED_AM |
+    XDMAC_CC_PERID(channel);
+  channel = XDMAIF_Get_ChannelNumber(bus->spi_id, XDMAD_TRANSFER_RX);
+  rx_cfg =
+    XDMAC_CC_DSYNC_PER2MEM |
+    XDMAC_CC_SAM_FIXED_AM |
+    XDMAC_CC_DAM_INCREMENTED_AM |
   dma = rtems_cache_coherent_allocate(sizeof(*dma), 0, 0);
   assert(dma != NULL);
   bus->dma = dma;
   dma->tx_desc.mbr_nda = 0;
+  dma->tx_desc.mbr_sa = 0;
+  dma->tx_desc.mbr_da = tx_da;
+  dma->tx_desc.mbr_cfg = tx_cfg;
   dma->rx_desc[0].mbr_nda = (uint32_t) &dma->rx_desc[1];
+  dma->rx_desc[0].mbr_sa = rx_sa;
+  dma->rx_desc[0].mbr_da = 0;
+  dma->rx_desc[0].mbr_cfg = rx_cfg;
   dma->rx_desc[1].mbr_nda = (uint32_t) &dma->rx_desc[2];
+  dma->rx_desc[1].mbr_sa = rx_sa;
+  dma->rx_desc[1].mbr_da = 0;
+  dma->rx_desc[1].mbr_cfg = rx_cfg;
   dma->rx_desc[2].mbr_nda = 0;
+  dma->rx_desc[2].mbr_sa = rx_sa;
+  dma->rx_desc[2].mbr_da = 0;
+  dma->rx_desc[2].mbr_cfg = rx_cfg;
   bus->dma_tx_channel = XDMAD_AllocateChannel(
     &XDMAD_Instance,
@@ -538,19 +632,9 @@ static void atsam_spi_init_xdma(atsam_spi_bus *bus)
   /* Setup RX */
   memset(&cfg, 0, sizeof(cfg));
-  cfg.mbr_sa = (uint32_t)&bus->spi_regs->SPI_RDR;
-  cfg.mbr_cfg =
-    XDMAC_CC_TYPE_PER_TRAN |
-    XDMAC_CC_MBSIZE_SINGLE |
-    XDMAC_CC_DSYNC_PER2MEM |
-    XDMAC_CC_CSIZE_CHK_1 |
-    XDMAC_CC_DWIDTH_BYTE |
-    XDMAC_CC_SIF_AHB_IF1 |
-    XDMAC_CC_DIF_AHB_IF1 |
-    XDMAC_CC_SAM_FIXED_AM |
-    XDMAC_CC_DAM_INCREMENTED_AM |
-    XDMAC_CC_PERID(channel);
-  xdma_cndc = XDMAC_CNDC_NDVIEW_NDV0 |
+  cfg.mbr_sa = rx_sa;
+  cfg.mbr_cfg = rx_cfg;
+  xdma_cndc = XDMAC_CNDC_NDVIEW_NDV2 |
     XDMAC_CNDC_NDE_DSCR_FETCH_EN |
     XDMAC_CNDC_NDSUP_SRC_PARAMS_UNCHANGED;
@@ -567,19 +651,9 @@ static void atsam_spi_init_xdma(atsam_spi_bus *bus)
   /* Setup TX  */
-  cfg.mbr_da = (uint32_t)&bus->spi_regs->SPI_TDR;
-  cfg.mbr_cfg =
-    XDMAC_CC_DSYNC_MEM2PER |
-    XDMAC_CC_SAM_INCREMENTED_AM |
-    XDMAC_CC_DAM_FIXED_AM |
+  cfg.mbr_da = tx_da;
+  cfg.mbr_cfg = tx_cfg;
     XDMAC_CNDC_NDDUP_DST_PARAMS_UNCHANGED |
     XDMAC_CNDC_NDSUP_SRC_PARAMS_UPDATED;
2.35.3
