[PATCH 1/2] testsuites/libtests/can01: Serialize CAN write and read messages among the tasks
Wed Dec 14 21:27:13 UTC 2022
On Sat, Dec 3, 2022 at 2:02 AM Prashanth S <fishesprashanth at gmail.com> wrote:
> The CAN framework has minimal Rx implementation, so to test loopback
> driver the test application is modified to write and read atomically
>  testsuites/libtests/can01/init.c | 71 ++++++++++++++------------------
>  1 file changed, 31 insertions(+), 40 deletions(-)
> diff --git a/testsuites/libtests/can01/init.c b/testsuites/libtests/can01/init.c
> index 0675fe606f..f70e68fb51 100644
> --- a/testsuites/libtests/can01/init.c
> +++ b/testsuites/libtests/can01/init.c
> @@ -48,7 +48,7 @@
>                     if (c3 == '9') {     \
>                       if (c2 == 'z') {   \
>                         if (c1 == 'z') { \
> -                         printf("not enough task letters for names !!!\n"); \
> +                         CAN_ERR("not enough task letters for names !!!\n"); \
I don't think the print statements need to be macro'd in your test, so
long as they only get printed when the test fails. When it's passing,
then we would prefer it be quiet.
>                           exit( 1 );     \
>                         } else           \
>                           c1++;          \
> @@ -63,6 +63,10 @@
>                   else                   \
>                     c4++                 \
> +struct test_thread {
> +  rtems_mutex mutex;
>  static void test_task(rtems_task_argument);
>  int can_loopback_init(const char *);
>  int create_task(int);
> @@ -70,60 +74,54 @@ int create_task(int);
>  static rtems_id task_id[TASKS];
>  static rtems_id task_test_status[TASKS] = {[0 ... (TASKS - 1)] = false};
> +static struct test_thread thread;
>  const char rtems_test_name[] = "CAN test TX, RX with CAN loopback driver";
> -/*FIXME: Should Implement one more test application for the
> - * RTR support
> - * For testing, the number of successful read and write
> - * count is verified.
>  static void test_task(rtems_task_argument data)
> -  //sleep so that other tasks will be created.
>    sleep(1);
>    int fd, task_num = (uint32_t)data;
>    uint32_t count = 0, msg_size;
> -  struct can_msg msg;
> +  struct can_msg send_msg, recv_msg;
>    printf("CAN tx and rx for %s\n", CAN_DEV_FILE);
>    fd = open(CAN_DEV_FILE, O_RDWR);
>    if (fd < 0) {
> -    printf("open error: task = %u %s: %s\n", task_num, CAN_DEV_FILE, strerror(errno));
> +    CAN_ERR("open error: task = %u %s: %s\n", task_num, CAN_DEV_FILE, strerror(errno));
>    rtems_test_assert(fd >= 0);
>    for (int i = 0; i < NUM_TEST_MSGS; i++) {
> -    printf("test_task %u\n", task_num);
> -    msg.id = task_num;
> -    //FIXME: Implement Test cases for other flags also.
> -    msg.flags = 0;
> -    msg.len = (i + 1) % 9;
> +    send_msg.id = task_num;
> +    send_msg.flags = 0;
> +    send_msg.len = (i + 1) % 9;
> -    for (int j = 0; j < msg.len; j++) {
> -      msg.data[j] = 'a' + j;
> +    for (int j = 0; j < send_msg.len; j++) {
> +      send_msg.data[j] = 'a' + j;
> -    msg_size = ((char *)&msg.data[msg.len] - (char *)&msg);
> +    msg_size = ((char *)&send_msg.data[send_msg.len] - (char *)&send_msg);
> -    printf("calling write task = %u\n", task_num);
> +    rtems_mutex_lock(&thread.mutex);
> -    count = write(fd, &msg, sizeof(msg));
> +    count = write(fd, &send_msg, sizeof(send_msg));
>      rtems_test_assert(count == msg_size);
> -    printf("task = %u write count = %u\n", task_num, count);
> -    printf("calling read task = %u\n", task_num);
> -    count = read(fd, &msg, sizeof(msg));
> -    rtems_test_assert(count > 0);
> -    printf("task = %u read count = %u\n", task_num, count);
> +    count = read(fd, &recv_msg, sizeof(recv_msg));
> +    rtems_test_assert(send_msg.len == recv_msg.len);
> +    for (int i = 0; i < recv_msg.len; i++) {
> +      rtems_test_assert(send_msg.data[i] == recv_msg.data[i]);
> -    printf("received message\n");
> -    can_print_msg(&msg);
> +    rtems_mutex_unlock(&thread.mutex);
> +    can_print_msg(&recv_msg);
>      sleep(1);
> @@ -131,14 +129,11 @@ static void test_task(rtems_task_argument data)
>    task_test_status[task_num] = true;
> -  printf("task exited = %u\n", task_num);
>    rtems_task_exit();
>  int create_task(int i)
> -  printf("Creating task %d\n", i);
>    rtems_status_code result;
>    rtems_name name;
> @@ -156,21 +151,18 @@ int create_task(int i)
>                               RTEMS_FIFO | RTEMS_FLOATING_POINT,
>                               &task_id[i]);
>    if (result != RTEMS_SUCCESSFUL) {
> -    printf("rtems_task_create error: %s\n", rtems_status_text(result));
> +    CAN_ERR("rtems_task_create error: %s\n", rtems_status_text(result));
>      rtems_test_assert(result == RTEMS_SUCCESSFUL);
> -  printf("number = %3" PRIi32 ", id = %08" PRIxrtems_id ", starting, ", i, task_id[i]);
>    fflush(stdout);
> -  printf("starting task\n");
>    result = rtems_task_start(task_id[i],
>                              test_task,
>                              (rtems_task_argument)i);
> -    printf("rtems_task_start failed %s\n", rtems_status_text(result));
> +    CAN_ERR("rtems_task_start failed %s\n", rtems_status_text(result));
> @@ -183,8 +175,6 @@ static rtems_task Init(
>    rtems_task_argument ignored
> -  printf("Init\n");
>    int ret;
>    rtems_print_printer_fprintf_putc(&rtems_test_printer);
> @@ -199,10 +189,12 @@ static rtems_task Init(
>    ret = can_loopback_init(CAN_DEV_FILE);
>    if (ret != RTEMS_SUCCESSFUL) {
> -    printf("%s failed\n", rtems_test_name);
> +    CAN_ERR("%s failed\n", rtems_test_name);
>      rtems_test_assert(ret == RTEMS_SUCCESSFUL);
> +  rtems_mutex_init(&thread.mutex, "CAN test");
>    for (int i = 0; i < TASKS; i++) {
>      create_task(i);
> @@ -212,7 +204,6 @@ static rtems_task Init(
>      int flag = 0;
>        if (task_test_status[i] == false) {
> -        printf("task not exited = %d\n", i);
>          sleep(1);
>          flag = 1;
>          break;
> 2.25.1
> devel mailing list
> devel at rtems.org
