[PATCH 3/4] testsuites/libtests/can01: Serialize CAN write and read messages among the tasks
Prashanth S fishesprashanth at gmail.com
Fri Dec 16 13:27:51 UTC 2022
The CAN framework has minimal Rx implementation, so to test loopback
driver the test application is modified to write and read atomically
 testsuites/libtests/can01/init.c | 69 ++++++++++++++------------------
 1 file changed, 30 insertions(+), 39 deletions(-)
diff --git a/testsuites/libtests/can01/init.c b/testsuites/libtests/can01/init.c
index 0675fe606f..235651d06d 100644
--- a/testsuites/libtests/can01/init.c
+++ b/testsuites/libtests/can01/init.c
@@ -63,6 +63,10 @@
                  else                   \
                    c4++                 \
+struct test_thread {
+  rtems_mutex mutex;
 static void test_task(rtems_task_argument);
 int can_loopback_init(const char *);
 int create_task(int);
@@ -70,60 +74,54 @@ int create_task(int);
 static rtems_id task_id[TASKS];
 static rtems_id task_test_status[TASKS] = {[0 ... (TASKS - 1)] = false};
+static struct test_thread thread;
 const char rtems_test_name[] = "CAN test TX, RX with CAN loopback driver";
-/*FIXME: Should Implement one more test application for the
- * RTR support
- * For testing, the number of successful read and write
- * count is verified.
 static void test_task(rtems_task_argument data)
-  //sleep so that other tasks will be created.
   sleep(1);
   int fd, task_num = (uint32_t)data;
   uint32_t count = 0, msg_size;
-  struct can_msg msg;
+  struct can_msg send_msg, recv_msg;
   printf("CAN tx and rx for %s\n", CAN_DEV_FILE);
   fd = open(CAN_DEV_FILE, O_RDWR);
   if (fd < 0) {
-    printf("open error: task = %u %s: %s\n", task_num, CAN_DEV_FILE, strerror(errno));
+    printf("error: open task = %u %s: %s\n", task_num, CAN_DEV_FILE, strerror(errno));
   rtems_test_assert(fd >= 0);
   for (int i = 0; i < NUM_TEST_MSGS; i++) {
-    printf("test_task %u\n", task_num);
-    msg.id = task_num;
-    //FIXME: Implement Test cases for other flags also.
-    msg.flags = 0;
-    msg.len = (i + 1) % 9;
+    send_msg.id = task_num;
+    send_msg.flags = 0;
+    send_msg.len = (i + 1) % 9;
-    for (int j = 0; j < msg.len; j++) {
-      msg.data[j] = 'a' + j;
+    for (int j = 0; j < send_msg.len; j++) {
+      send_msg.data[j] = 'a' + j;
-    msg_size = ((char *)&msg.data[msg.len] - (char *)&msg);
+    msg_size = ((char *)&send_msg.data[send_msg.len] - (char *)&send_msg);
-    printf("calling write task = %u\n", task_num);
+    rtems_mutex_lock(&thread.mutex);
-    count = write(fd, &msg, sizeof(msg));
+    count = write(fd, &send_msg, sizeof(send_msg));
     rtems_test_assert(count == msg_size);
-    printf("task = %u write count = %u\n", task_num, count);
-    printf("calling read task = %u\n", task_num);
-    count = read(fd, &msg, sizeof(msg));
-    rtems_test_assert(count > 0);
-    printf("task = %u read count = %u\n", task_num, count);
+    count = read(fd, &recv_msg, sizeof(recv_msg));
+    rtems_test_assert(send_msg.len == recv_msg.len);
+    for (int i = 0; i < recv_msg.len; i++) {
+      rtems_test_assert(send_msg.data[i] == recv_msg.data[i]);
-    printf("received message\n");
-    can_print_msg(&msg);
+    rtems_mutex_unlock(&thread.mutex);
+    can_print_msg(&recv_msg);
     sleep(1);
@@ -131,14 +129,11 @@ static void test_task(rtems_task_argument data)
   task_test_status[task_num] = true;
-  printf("task exited = %u\n", task_num);
   rtems_task_exit();
 int create_task(int i)
-  printf("Creating task %d\n", i);
   rtems_status_code result;
   rtems_name name;
@@ -156,21 +151,18 @@ int create_task(int i)
                              RTEMS_FIFO | RTEMS_FLOATING_POINT,
                              &task_id[i]);
   if (result != RTEMS_SUCCESSFUL) {
-    printf("rtems_task_create error: %s\n", rtems_status_text(result));
+    printf("error rtems_task_create: %s\n", rtems_status_text(result));
     rtems_test_assert(result == RTEMS_SUCCESSFUL);
-  printf("number = %3" PRIi32 ", id = %08" PRIxrtems_id ", starting, ", i, task_id[i]);
   fflush(stdout);
-  printf("starting task\n");
   result = rtems_task_start(task_id[i],
                             test_task,
                             (rtems_task_argument)i);
-    printf("rtems_task_start failed %s\n", rtems_status_text(result));
+    printf("error rtems_task_start: %s\n", rtems_status_text(result));
@@ -183,8 +175,6 @@ static rtems_task Init(
   rtems_task_argument ignored
-  printf("Init\n");
   int ret;
   rtems_print_printer_fprintf_putc(&rtems_test_printer);
@@ -199,10 +189,12 @@ static rtems_task Init(
   ret = can_loopback_init(CAN_DEV_FILE);
   if (ret != RTEMS_SUCCESSFUL) {
-    printf("%s failed\n", rtems_test_name);
+    printf("error: %s failed\n", rtems_test_name);
     rtems_test_assert(ret == RTEMS_SUCCESSFUL);
+  rtems_mutex_init(&thread.mutex, "CAN test");
   for (int i = 0; i < TASKS; i++) {
     create_task(i);
@@ -212,7 +204,6 @@ static rtems_task Init(
     int flag = 0;
       if (task_test_status[i] == false) {
-        printf("task not exited = %d\n", i);
         sleep(1);
         flag = 1;
         break;
2.25.1
