[PATCH RSB] Remove aarch64 and microblaze from RSB 5 branch.
Tue Dec 20 23:07:36 UTC 2022
OK to push
Thanks
On 21/12/2022 3:37 am, Joel Sherrill wrote:
> The ports did not get contributed until during 6 development and are
> not on this release branch.
> Closes #4555.
>  rtems/config/5/rtems-aarch64.bset    | 4 ----
>  rtems/config/5/rtems-all.bset        | 2 --
>  rtems/config/5/rtems-microblaze.bset | 3 ---
>  3 files changed, 9 deletions(-)
>  delete mode 100644 rtems/config/5/rtems-aarch64.bset
>  delete mode 100644 rtems/config/5/rtems-microblaze.bset
> diff --git a/rtems/config/5/rtems-aarch64.bset b/rtems/config/5/rtems-aarch64.bset
> deleted file mode 100644
> index f38aff3..0000000
> --- a/rtems/config/5/rtems-aarch64.bset
> +++ /dev/null
> @@ -1,4 +0,0 @@
> -%define release 1
> -%define rtems_arch aarch64
> -%define with_libgomp
> -%include 5/rtems-default.bset
> diff --git a/rtems/config/5/rtems-all.bset b/rtems/config/5/rtems-all.bset
> index 00ccfae..81076e4 100644
> --- a/rtems/config/5/rtems-all.bset
> +++ b/rtems/config/5/rtems-all.bset
> @@ -1,11 +1,9 @@
> -5/rtems-aarch64
>  5/rtems-arm
>  5/rtems-bfin
>  5/rtems-epiphany
>  5/rtems-i386
>  5/rtems-lm32
>  5/rtems-m68k
> -5/rtems-microblaze
>  5/rtems-mips
>  5/rtems-moxie
>  5/rtems-nios2
> diff --git a/rtems/config/5/rtems-microblaze.bset b/rtems/config/5/rtems-microblaze.bset
> index e5c23af..0000000
> --- a/rtems/config/5/rtems-microblaze.bset
> +++ /dev/null
> @@ -1,3 +0,0 @@
> -%define release 1
> -%define rtems_arch microblaze
