[PATCH 1/2] bsps: Import xilinx support code
Kinsey Moore kinsey.moore at oarcorp.com
Wed Dec 21 20:54:55 UTC 2022
This support code is necessary for many Xilinx-provided bare metal device
drivers supported on ARM, AArch64, and MicroBlaze platforms. Support for
all of these architectures is kept under bsps/include due to multiple
architecture variants being supported which requires complex logic in
the build system. The imported files are and should be able to remain
unmodified.
 .../arm/ARMv8/32bit/xil_cache.h               |  60 ++
 .../arm/ARMv8/32bit/xpseudo_asm.h             |  53 ++
 .../arm/ARMv8/32bit/xreg_cortexa53.h          | 394 ++++++++++
 .../arm/ARMv8/64bit/xil_cache.h               |  75 ++
 .../arm/ARMv8/64bit/xpseudo_asm.h             |  56 ++
 .../arm/ARMv8/64bit/xreg_cortexa53.h          | 163 ++++
 .../xilinx_support/arm/cortexa9/xil_cache.h   | 105 +++
 .../xilinx_support/arm/cortexa9/xpseudo_asm.h |  60 ++
 .../arm/cortexa9/xreg_cortexa9.h              | 573 ++++++++++++++
 .../xilinx_support/arm/cortexr5/xil_cache.h   |  95 +++
 .../xilinx_support/arm/cortexr5/xpseudo_asm.h |  60 ++
 .../arm/cortexr5/xreg_cortexr5.h              | 429 ++++++++++
 bsps/include/xilinx_support/bspconfig.h       |   1 +
 .../xilinx_support/microblaze/xil_cache.h     | 392 ++++++++++
 bsps/include/xilinx_support/sleep.h           |  99 +++
 bsps/include/xilinx_support/xbasic_types.h    | 113 +++
 bsps/include/xilinx_support/xil_assert.h      | 176 +++++
 bsps/include/xilinx_support/xil_exception.h   |   1 +
 bsps/include/xilinx_support/xil_io.h          | 412 ++++++++++
 bsps/include/xilinx_support/xil_mem.h         |  47 ++
 bsps/include/xilinx_support/xil_printf.h      |  44 ++
 bsps/include/xilinx_support/xil_smc.h         |   1 +
 bsps/include/xilinx_support/xil_types.h       | 203 +++++
 bsps/include/xilinx_support/xparameters.h     |  44 ++
 bsps/include/xilinx_support/xpseudo_asm_gcc.h | 240 ++++++
 bsps/include/xilinx_support/xstatus.h         | 522 +++++++++++++
 bsps/shared/xilinx_support/xil_assert.c       | 126 +++
 bsps/shared/xilinx_support/xil_cache.c        | 732 ++++++++++++++++++
 bsps/shared/xilinx_support/xil_mem.c          |  70 ++
 spec/build/bsps/objxilinxsupport.yml          |  45 ++
 spec/build/bsps/objxilinxsupporta9.yml        |  20 +
 spec/build/bsps/objxilinxsupportilp32.yml     |  20 +
 spec/build/bsps/objxilinxsupportlp64.yml      |  22 +
 spec/build/bsps/objxilinxsupportmb.yml        |  17 +
 spec/build/bsps/objxilinxsupportr5.yml        |  18 +
 spec/build/bsps/optxilsupportpath.yml         |  34 +
 36 files changed, 5522 insertions(+)
 create mode 100644 bsps/include/xilinx_support/arm/ARMv8/32bit/xil_cache.h
 create mode 100644 bsps/include/xilinx_support/arm/ARMv8/32bit/xpseudo_asm.h
 create mode 100644 bsps/include/xilinx_support/arm/ARMv8/32bit/xreg_cortexa53.h
 create mode 100644 bsps/include/xilinx_support/arm/ARMv8/64bit/xil_cache.h
 create mode 100644 bsps/include/xilinx_support/arm/ARMv8/64bit/xpseudo_asm.h
 create mode 100644 bsps/include/xilinx_support/arm/ARMv8/64bit/xreg_cortexa53.h
 create mode 100644 bsps/include/xilinx_support/arm/cortexa9/xil_cache.h
 create mode 100644 bsps/include/xilinx_support/arm/cortexa9/xpseudo_asm.h
 create mode 100644 bsps/include/xilinx_support/arm/cortexa9/xreg_cortexa9.h
 create mode 100644 bsps/include/xilinx_support/arm/cortexr5/xil_cache.h
 create mode 100644 bsps/include/xilinx_support/arm/cortexr5/xpseudo_asm.h
 create mode 100644 bsps/include/xilinx_support/arm/cortexr5/xreg_cortexr5.h
 create mode 100644 bsps/include/xilinx_support/bspconfig.h
 create mode 100644 bsps/include/xilinx_support/microblaze/xil_cache.h
 create mode 100644 bsps/include/xilinx_support/sleep.h
 create mode 100644 bsps/include/xilinx_support/xbasic_types.h
 create mode 100644 bsps/include/xilinx_support/xil_assert.h
 create mode 100644 bsps/include/xilinx_support/xil_exception.h
 create mode 100644 bsps/include/xilinx_support/xil_io.h
 create mode 100644 bsps/include/xilinx_support/xil_mem.h
 create mode 100644 bsps/include/xilinx_support/xil_printf.h
 create mode 100644 bsps/include/xilinx_support/xil_smc.h
 create mode 100644 bsps/include/xilinx_support/xil_types.h
 create mode 100644 bsps/include/xilinx_support/xparameters.h
 create mode 100644 bsps/include/xilinx_support/xpseudo_asm_gcc.h
 create mode 100644 bsps/include/xilinx_support/xstatus.h
 create mode 100644 bsps/shared/xilinx_support/xil_assert.c
 create mode 100644 bsps/shared/xilinx_support/xil_cache.c
 create mode 100644 bsps/shared/xilinx_support/xil_mem.c
 create mode 100644 spec/build/bsps/objxilinxsupport.yml
 create mode 100644 spec/build/bsps/objxilinxsupporta9.yml
 create mode 100644 spec/build/bsps/objxilinxsupportilp32.yml
 create mode 100644 spec/build/bsps/objxilinxsupportlp64.yml
 create mode 100644 spec/build/bsps/objxilinxsupportmb.yml
 create mode 100644 spec/build/bsps/objxilinxsupportr5.yml
 create mode 100644 spec/build/bsps/optxilsupportpath.yml
diff --git a/bsps/include/xilinx_support/arm/ARMv8/32bit/xil_cache.h b/bsps/include/xilinx_support/arm/ARMv8/32bit/xil_cache.h
new file mode 100644
index 0000000000..0fe994b093
--- /dev/null
+++ b/bsps/include/xilinx_support/arm/ARMv8/32bit/xil_cache.h
@@ -0,0 +1,60 @@
+* Copyright (c) 2015 - 2020 Xilinx, Inc.  All rights reserved.
+* SPDX-License-Identifier: MIT
+* @file xil_cache.h
+* @addtogroup a53_32_cache_apis Cortex A53 32bit Processor Cache Functions
+* Cache functions provide access to cache related operations such as flush
+* and invalidate for instruction and data caches. It gives option to perform
+* the cache operations on a single cacheline, a range of memory and an entire
+* cache.
+* <pre>
+* MODIFICATION HISTORY:
+* Ver   Who  Date     Changes
+* 5.2	pkp  28/05/15 First release
+* </pre>
+#ifndef XIL_CACHE_H
+#define XIL_CACHE_H
+#include "xil_types.h"
+#ifdef __cplusplus
+extern "C" {
+#endif
+void Xil_DCacheEnable(void);
+void Xil_DCacheDisable(void);
+void Xil_DCacheInvalidate(void);
+void Xil_DCacheInvalidateRange(INTPTR adr, u32 len);
+void Xil_DCacheFlush(void);
+void Xil_DCacheFlushRange(INTPTR adr, u32 len);
+void Xil_DCacheInvalidateLine(u32 adr);
+void Xil_DCacheFlushLine(u32 adr);
+void Xil_ICacheInvalidateLine(u32 adr);
+void Xil_ICacheEnable(void);
+void Xil_ICacheDisable(void);
+void Xil_ICacheInvalidate(void);
+void Xil_ICacheInvalidateRange(INTPTR adr, u32 len);
+#ifdef __cplusplus
+#endif
+#endif
+* @} End of "addtogroup a53_64_cache_apis".
diff --git a/bsps/include/xilinx_support/arm/ARMv8/32bit/xpseudo_asm.h b/bsps/include/xilinx_support/arm/ARMv8/32bit/xpseudo_asm.h
index 0000000000..41c9c9c944
--- /dev/null
+++ b/bsps/include/xilinx_support/arm/ARMv8/32bit/xpseudo_asm.h
@@ -0,0 +1,53 @@
+* @file xpseudo_asm.h
+* @addtogroup a53_32_specific Cortex A53 32bit Processor Specific Include Files
+* The xpseudo_asm.h includes xreg_cortexa53.h and xpseudo_asm_gcc.h.
+* The xreg_cortexa53.h file contains definitions for inline assembler code.
+* It provides inline definitions for Cortex A53 GPRs, SPRs, co-processor
+* registers and floating point registers.
+* The xpseudo_asm_gcc.h contains the definitions for the most often used inline
+* assembler instructions, available as macros. These can be very useful for
+* tasks such as setting or getting special purpose registers, synchronization,
+* or cache manipulation etc. These inline assembler instructions can be used
+* from drivers and user applications written in C.
+* <pre>
+* </pre>
+#ifndef XPSEUDO_ASM_H
+#define XPSEUDO_ASM_H
+#ifdef __cplusplus
+extern "C" {
+#endif
+#include "xreg_cortexa53.h"
+#include "xpseudo_asm_gcc.h"
+#ifdef __cplusplus
+#endif
+#endif /* XPSEUDO_ASM_H */
+* @} End of "addtogroup a53_32_specific".
diff --git a/bsps/include/xilinx_support/arm/ARMv8/32bit/xreg_cortexa53.h b/bsps/include/xilinx_support/arm/ARMv8/32bit/xreg_cortexa53.h
index 0000000000..e811686fe5
--- /dev/null
+++ b/bsps/include/xilinx_support/arm/ARMv8/32bit/xreg_cortexa53.h
@@ -0,0 +1,394 @@
+* Copyright (c) 2015 - 2021 Xilinx, Inc.  All rights reserved.
+* @file xreg_cortexa53.h
+* This header file contains definitions for using inline assembler code. It is
+* written specifically for the GNU.
+* All of the ARM Cortex A53 GPRs, SPRs, and Debug Registers are defined along
+* with the positions of the bits within the registers.
+* <pre>
+* </pre>
+#ifndef XREG_CORTEXA53_H
+#define XREG_CORTEXA53_H
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+ *@cond nocomments
+/* GPRs */
+#define XREG_GPR0				r0
+#define XREG_GPR1				r1
+#define XREG_GPR2				r2
+#define XREG_GPR3				r3
+#define XREG_GPR4				r4
+#define XREG_GPR5				r5
+#define XREG_GPR6				r6
+#define XREG_GPR7				r7
+#define XREG_GPR8				r8
+#define XREG_GPR9				r9
+#define XREG_GPR10				r10
+#define XREG_GPR11				r11
+#define XREG_GPR12				r12
+#define XREG_GPR13				r13
+#define XREG_GPR14				r14
+#define XREG_GPR15				r15
+#define XREG_CPSR				cpsr
+/* Coprocessor number defines */
+#define XREG_CP0				0
+#define XREG_CP1				1
+#define XREG_CP2				2
+#define XREG_CP3				3
+#define XREG_CP4				4
+#define XREG_CP5				5
+#define XREG_CP6				6
+#define XREG_CP7				7
+#define XREG_CP8				8
+#define XREG_CP9				9
+#define XREG_CP10				10
+#define XREG_CP11				11
+#define XREG_CP12				12
+#define XREG_CP13				13
+#define XREG_CP14				14
+#define XREG_CP15				15
+/* Coprocessor control register defines */
+#define XREG_CR0				cr0
+#define XREG_CR1				cr1
+#define XREG_CR2				cr2
+#define XREG_CR3				cr3
+#define XREG_CR4				cr4
+#define XREG_CR5				cr5
+#define XREG_CR6				cr6
+#define XREG_CR7				cr7
+#define XREG_CR8				cr8
+#define XREG_CR9				cr9
+#define XREG_CR10				cr10
+#define XREG_CR11				cr11
+#define XREG_CR12				cr12
+#define XREG_CR13				cr13
+#define XREG_CR14				cr14
+#define XREG_CR15				cr15
+/* Current Processor Status Register (CPSR) Bits */
+#define XREG_CPSR_THUMB_MODE			0x20
+#define XREG_CPSR_MODE_BITS			0x1F
+#define XREG_CPSR_SYSTEM_MODE			0x1F
+#define XREG_CPSR_UNDEFINED_MODE		0x1B
+#define XREG_CPSR_DATA_ABORT_MODE		0x17
+#define XREG_CPSR_SVC_MODE			0x13
+#define XREG_CPSR_IRQ_MODE			0x12
+#define XREG_CPSR_FIQ_MODE			0x11
+#define XREG_CPSR_USER_MODE			0x10
+#define XREG_CPSR_IRQ_ENABLE			0x80
+#define XREG_CPSR_FIQ_ENABLE			0x40
+#define XREG_CPSR_N_BIT				0x80000000
+#define XREG_CPSR_Z_BIT				0x40000000
+#define XREG_CPSR_C_BIT				0x20000000
+#define XREG_CPSR_V_BIT				0x10000000
+/* CP15 defines */
+/* C0 Register defines */
+#define XREG_CP15_MAIN_ID			"p15, 0, %0,  c0,  c0, 0"
+#define XREG_CP15_CACHE_TYPE			"p15, 0, %0,  c0,  c0, 1"
+#define XREG_CP15_TCM_TYPE			"p15, 0, %0,  c0,  c0, 2"
+#define XREG_CP15_TLB_TYPE			"p15, 0, %0,  c0,  c0, 3"
+#define XREG_CP15_MULTI_PROC_AFFINITY		"p15, 0, %0,  c0,  c0, 5"
+#define XREG_CP15_PROC_FEATURE_0		"p15, 0, %0,  c0,  c1, 0"
+#define XREG_CP15_PROC_FEATURE_1		"p15, 0, %0,  c0,  c1, 1"
+#define XREG_CP15_DEBUG_FEATURE_0		"p15, 0, %0,  c0,  c1, 2"
+#define XREG_CP15_MEMORY_FEATURE_0		"p15, 0, %0,  c0,  c1, 4"
+#define XREG_CP15_MEMORY_FEATURE_1		"p15, 0, %0,  c0,  c1, 5"
+#define XREG_CP15_MEMORY_FEATURE_2		"p15, 0, %0,  c0,  c1, 6"
+#define XREG_CP15_MEMORY_FEATURE_3		"p15, 0, %0,  c0,  c1, 7"
+#define XREG_CP15_INST_FEATURE_0		"p15, 0, %0,  c0,  c2, 0"
+#define XREG_CP15_INST_FEATURE_1		"p15, 0, %0,  c0,  c2, 1"
+#define XREG_CP15_INST_FEATURE_2		"p15, 0, %0,  c0,  c2, 2"
+#define XREG_CP15_INST_FEATURE_3		"p15, 0, %0,  c0,  c2, 3"
+#define XREG_CP15_INST_FEATURE_4		"p15, 0, %0,  c0,  c2, 4"
+#define XREG_CP15_CACHE_SIZE_ID			"p15, 1, %0,  c0,  c0, 0"
+#define XREG_CP15_CACHE_LEVEL_ID		"p15, 1, %0,  c0,  c0, 1"
+#define XREG_CP15_AUXILARY_ID			"p15, 1, %0,  c0,  c0, 7"
+#define XREG_CP15_CACHE_SIZE_SEL		"p15, 2, %0,  c0,  c0, 0"
+/* C1 Register Defines */
+#define XREG_CP15_SYS_CONTROL			"p15, 0, %0,  c1,  c0, 0"
+#define XREG_CP15_AUX_CONTROL			"p15, 0, %0,  c1,  c0, 1"
+#define XREG_CP15_CP_ACCESS_CONTROL		"p15, 0, %0,  c1,  c0, 2"
+#define XREG_CP15_SECURE_CONFIG			"p15, 0, %0,  c1,  c1, 0"
+#define XREG_CP15_SECURE_DEBUG_ENABLE		"p15, 0, %0,  c1,  c1, 1"
+#define XREG_CP15_NS_ACCESS_CONTROL		"p15, 0, %0,  c1,  c1, 2"
+#define XREG_CP15_VIRTUAL_CONTROL		"p15, 0, %0,  c1,  c1, 3"
+/* XREG_CP15_CONTROL bit defines */
+#define XREG_CP15_CONTROL_TE_BIT		0x40000000U
+#define XREG_CP15_CONTROL_AFE_BIT		0x20000000U
+#define XREG_CP15_CONTROL_TRE_BIT		0x10000000U
+#define XREG_CP15_CONTROL_NMFI_BIT		0x08000000U
+#define XREG_CP15_CONTROL_EE_BIT		0x02000000U
+#define XREG_CP15_CONTROL_HA_BIT		0x00020000U
+#define XREG_CP15_CONTROL_RR_BIT		0x00004000U
+#define XREG_CP15_CONTROL_V_BIT			0x00002000U
+#define XREG_CP15_CONTROL_I_BIT			0x00001000U
+#define XREG_CP15_CONTROL_Z_BIT			0x00000800U
+#define XREG_CP15_CONTROL_SW_BIT		0x00000400U
+#define XREG_CP15_CONTROL_B_BIT			0x00000080U
+#define XREG_CP15_CONTROL_C_BIT			0x00000004U
+#define XREG_CP15_CONTROL_A_BIT			0x00000002U
+#define XREG_CP15_CONTROL_M_BIT			0x00000001U
+/* C2 Register Defines */
+#define XREG_CP15_TTBR0				"p15, 0, %0,  c2,  c0, 0"
+#define XREG_CP15_TTBR1				"p15, 0, %0,  c2,  c0, 1"
+#define XREG_CP15_TTB_CONTROL			"p15, 0, %0,  c2,  c0, 2"
+/* C3 Register Defines */
+#define XREG_CP15_DOMAIN_ACCESS_CTRL		"p15, 0, %0,  c3,  c0, 0"
+/* C4 Register Defines */
+/* Not Used */
+/* C5 Register Defines */
+#define XREG_CP15_DATA_FAULT_STATUS		"p15, 0, %0,  c5,  c0, 0"
+#define XREG_CP15_INST_FAULT_STATUS		"p15, 0, %0,  c5,  c0, 1"
+#define XREG_CP15_AUX_DATA_FAULT_STATUS		"p15, 0, %0,  c5,  c1, 0"
+#define XREG_CP15_AUX_INST_FAULT_STATUS		"p15, 0, %0,  c5,  c1, 1"
+/* C6 Register Defines */
+#define XREG_CP15_DATA_FAULT_ADDRESS		"p15, 0, %0,  c6,  c0, 0"
+#define XREG_CP15_INST_FAULT_ADDRESS		"p15, 0, %0,  c6,  c0, 2"
+/* C7 Register Defines */
+#define XREG_CP15_NOP				"p15, 0, %0,  c7,  c0, 4"
+#define XREG_CP15_INVAL_IC_POU_IS		"p15, 0, %0,  c7,  c1, 0"
+#define XREG_CP15_INVAL_BRANCH_ARRAY_IS		"p15, 0, %0,  c7,  c1, 6"
+#define XREG_CP15_PHYS_ADDR			"p15, 0, %0,  c7,  c4, 0"
+#define XREG_CP15_INVAL_IC_POU			"p15, 0, %0,  c7,  c5, 0"
+#define XREG_CP15_INVAL_IC_LINE_MVA_POU		"p15, 0, %0,  c7,  c5, 1"
+/* The CP15 register access below has been deprecated in favor of the new
+ * isb instruction in Cortex A53.
+#define XREG_CP15_INST_SYNC_BARRIER		"p15, 0, %0,  c7,  c5, 4"
+#define XREG_CP15_INVAL_BRANCH_ARRAY		"p15, 0, %0,  c7,  c5, 6"
+#define XREG_CP15_INVAL_DC_LINE_MVA_POC		"p15, 0, %0,  c7,  c6, 1"
+#define XREG_CP15_INVAL_DC_LINE_SW		"p15, 0, %0,  c7,  c6, 2"
+#define XREG_CP15_VA_TO_PA_CURRENT_0		"p15, 0, %0,  c7,  c8, 0"
+#define XREG_CP15_VA_TO_PA_CURRENT_1		"p15, 0, %0,  c7,  c8, 1"
+#define XREG_CP15_VA_TO_PA_CURRENT_2		"p15, 0, %0,  c7,  c8, 2"
+#define XREG_CP15_VA_TO_PA_CURRENT_3		"p15, 0, %0,  c7,  c8, 3"
+#define XREG_CP15_VA_TO_PA_OTHER_0		"p15, 0, %0,  c7,  c8, 4"
+#define XREG_CP15_VA_TO_PA_OTHER_1		"p15, 0, %0,  c7,  c8, 5"
+#define XREG_CP15_VA_TO_PA_OTHER_2		"p15, 0, %0,  c7,  c8, 6"
+#define XREG_CP15_VA_TO_PA_OTHER_3		"p15, 0, %0,  c7,  c8, 7"
+#define XREG_CP15_CLEAN_DC_LINE_MVA_POC		"p15, 0, %0,  c7, c10, 1"
+#define XREG_CP15_CLEAN_DC_LINE_SW		"p15, 0, %0,  c7, c10, 2"
+/* The next two CP15 register accesses below have been deprecated in favor
+ * of the new dsb and dmb instructions in Cortex A53.
+#define XREG_CP15_DATA_SYNC_BARRIER		"p15, 0, %0,  c7, c10, 4"
+#define XREG_CP15_DATA_MEMORY_BARRIER		"p15, 0, %0,  c7, c10, 5"
+#define XREG_CP15_CLEAN_DC_LINE_MVA_POU		"p15, 0, %0,  c7, c11, 1"
+#define XREG_CP15_NOP2				"p15, 0, %0,  c7, c13, 1"
+#define XREG_CP15_CLEAN_INVAL_DC_LINE_MVA_POC	"p15, 0, %0,  c7, c14, 1"
+#define XREG_CP15_CLEAN_INVAL_DC_LINE_SW	"p15, 0, %0,  c7, c14, 2"
+/* C8 Register Defines */
+#define XREG_CP15_INVAL_TLB_IS			"p15, 0, %0,  c8,  c3, 0"
+#define XREG_CP15_INVAL_TLB_MVA_IS		"p15, 0, %0,  c8,  c3, 1"
+#define XREG_CP15_INVAL_TLB_ASID_IS		"p15, 0, %0,  c8,  c3, 2"
+#define XREG_CP15_INVAL_TLB_MVA_ASID_IS		"p15, 0, %0,  c8,  c3, 3"
+#define XREG_CP15_INVAL_ITLB_UNLOCKED		"p15, 0, %0,  c8,  c5, 0"
+#define XREG_CP15_INVAL_ITLB_MVA		"p15, 0, %0,  c8,  c5, 1"
+#define XREG_CP15_INVAL_ITLB_ASID		"p15, 0, %0,  c8,  c5, 2"
+#define XREG_CP15_INVAL_DTLB_UNLOCKED		"p15, 0, %0,  c8,  c6, 0"
+#define XREG_CP15_INVAL_DTLB_MVA		"p15, 0, %0,  c8,  c6, 1"
+#define XREG_CP15_INVAL_DTLB_ASID		"p15, 0, %0,  c8,  c6, 2"
+#define XREG_CP15_INVAL_UTLB_UNLOCKED		"p15, 0, %0,  c8,  c7, 0"
+#define XREG_CP15_INVAL_UTLB_MVA		"p15, 0, %0,  c8,  c7, 1"
+#define XREG_CP15_INVAL_UTLB_ASID		"p15, 0, %0,  c8,  c7, 2"
+#define XREG_CP15_INVAL_UTLB_MVA_ASID		"p15, 0, %0,  c8,  c7, 3"
+/* C9 Register Defines */
+#define XREG_CP15_PERF_MONITOR_CTRL		"p15, 0, %0,  c9, c12, 0"
+#define XREG_CP15_COUNT_ENABLE_SET		"p15, 0, %0,  c9, c12, 1"
+#define XREG_CP15_COUNT_ENABLE_CLR		"p15, 0, %0,  c9, c12, 2"
+#define XREG_CP15_V_FLAG_STATUS			"p15, 0, %0,  c9, c12, 3"
+#define XREG_CP15_SW_INC			"p15, 0, %0,  c9, c12, 4"
+#define XREG_CP15_EVENT_CNTR_SEL		"p15, 0, %0,  c9, c12, 5"
+#define XREG_CP15_PERF_CYCLE_COUNTER		"p15, 0, %0,  c9, c13, 0"
+#define XREG_CP15_EVENT_TYPE_SEL		"p15, 0, %0,  c9, c13, 1"
+#define XREG_CP15_PERF_MONITOR_COUNT		"p15, 0, %0,  c9, c13, 2"
+#define XREG_CP15_USER_ENABLE			"p15, 0, %0,  c9, c14, 0"
+#define XREG_CP15_INTR_ENABLE_SET		"p15, 0, %0,  c9, c14, 1"
+#define XREG_CP15_INTR_ENABLE_CLR		"p15, 0, %0,  c9, c14, 2"
+/* C10 Register Defines */
+#define XREG_CP15_TLB_LOCKDWN			"p15, 0, %0, c10,  c0, 0"
+#define XREG_CP15_PRI_MEM_REMAP			"p15, 0, %0, c10,  c2, 0"
+#define XREG_CP15_NORM_MEM_REMAP		"p15, 0, %0, c10,  c2, 1"
+/* C11 Register Defines */
+/* Not used */
+/* C12 Register Defines */
+#define XREG_CP15_VEC_BASE_ADDR			"p15, 0, %0, c12,  c0, 0"
+#define XREG_CP15_MONITOR_VEC_BASE_ADDR		"p15, 0, %0, c12,  c0, 1"
+#define XREG_CP15_INTERRUPT_STATUS		"p15, 0, %0, c12,  c1, 0"
+#define XREG_CP15_VIRTUALIZATION_INTR		"p15, 0, %0, c12,  c1, 1"
+/* C13 Register Defines */
+#define XREG_CP15_CONTEXT_ID			"p15, 0, %0, c13,  c0, 1"
+#define USER_RW_THREAD_PID			"p15, 0, %0, c13,  c0, 2"
+#define USER_RO_THREAD_PID			"p15, 0, %0, c13,  c0, 3"
+#define USER_PRIV_THREAD_PID			"p15, 0, %0, c13,  c0, 4"
+/* C14 Register Defines */
+/* not used */
+/* C15 Register Defines */
+#define XREG_CP15_POWER_CTRL			"p15, 0, %0, c15,  c0, 0"
+#define XREG_CP15_CONFIG_BASE_ADDR		"p15, 4, %0, c15,  c0, 0"
+#define XREG_CP15_READ_TLB_ENTRY		"p15, 5, %0, c15,  c4, 2"
+#define XREG_CP15_WRITE_TLB_ENTRY		"p15, 5, %0, c15,  c4, 4"
+#define XREG_CP15_MAIN_TLB_VA			"p15, 5, %0, c15,  c5, 2"
+#define XREG_CP15_MAIN_TLB_PA			"p15, 5, %0, c15,  c6, 2"
+#define XREG_CP15_MAIN_TLB_ATTR			"p15, 5, %0, c15,  c7, 2"
+/* MPE register definitions */
+#define XREG_FPSID				c0
+#define XREG_FPSCR				c1
+#define XREG_MVFR1				c6
+#define XREG_MVFR0				c7
+#define XREG_FPEXC				c8
+#define XREG_FPINST				c9
+#define XREG_FPINST2				c10
+/* FPSID bits */
+#define XREG_FPSID_IMPLEMENTER_BIT	(24)
+#define XREG_FPSID_IMPLEMENTER_MASK	(0xFF << FPSID_IMPLEMENTER_BIT)
+#define XREG_FPSID_SOFTWARE		(1<<23)
+#define XREG_FPSID_ARCH_BIT		(16)
+#define XREG_FPSID_ARCH_MASK		(0xF  << FPSID_ARCH_BIT)
+#define XREG_FPSID_PART_BIT		(8)
+#define XREG_FPSID_PART_MASK		(0xFF << FPSID_PART_BIT)
+#define XREG_FPSID_VARIANT_BIT		(4)
+#define XREG_FPSID_VARIANT_MASK		(0xF  << FPSID_VARIANT_BIT)
+#define XREG_FPSID_REV_BIT		(0)
+#define XREG_FPSID_REV_MASK		(0xF  << FPSID_REV_BIT)
+/* FPSCR bits */
+#define XREG_FPSCR_N_BIT		(1 << 31)
+#define XREG_FPSCR_Z_BIT		(1 << 30)
+#define XREG_FPSCR_C_BIT		(1 << 29)
+#define XREG_FPSCR_V_BIT		(1 << 28)
+#define XREG_FPSCR_QC			(1 << 27)
+#define XREG_FPSCR_AHP			(1 << 26)
+#define XREG_FPSCR_DEFAULT_NAN		(1 << 25)
+#define XREG_FPSCR_FLUSHTOZERO		(1 << 24)
+#define XREG_FPSCR_ROUND_NEAREST	(0 << 22)
+#define XREG_FPSCR_ROUND_PLUSINF	(1 << 22)
+#define XREG_FPSCR_ROUND_MINUSINF	(2 << 22)
+#define XREG_FPSCR_ROUND_TOZERO		(3 << 22)
+#define XREG_FPSCR_RMODE_BIT		(22)
+#define XREG_FPSCR_RMODE_MASK		(3 << FPSCR_RMODE_BIT)
+#define XREG_FPSCR_STRIDE_BIT		(20)
+#define XREG_FPSCR_STRIDE_MASK		(3 << FPSCR_STRIDE_BIT)
+#define XREG_FPSCR_LENGTH_BIT		(16)
+#define XREG_FPSCR_LENGTH_MASK		(7 << FPSCR_LENGTH_BIT)
+#define XREG_FPSCR_IDC			(1 << 7)
+#define XREG_FPSCR_IXC			(1 << 4)
+#define XREG_FPSCR_UFC			(1 << 3)
+#define XREG_FPSCR_OFC			(1 << 2)
+#define XREG_FPSCR_DZC			(1 << 1)
+#define XREG_FPSCR_IOC			(1 << 0)
+/* MVFR0 bits */
+#define XREG_MVFR0_RMODE_BIT		(28)
+#define XREG_MVFR0_RMODE_MASK		(0xF << XREG_MVFR0_RMODE_BIT)
+#define XREG_MVFR0_SHORT_VEC_BIT	(24)
+#define XREG_MVFR0_SHORT_VEC_MASK	(0xF << XREG_MVFR0_SHORT_VEC_BIT)
+#define XREG_MVFR0_SQRT_BIT		(20)
+#define XREG_MVFR0_SQRT_MASK		(0xF << XREG_MVFR0_SQRT_BIT)
+#define XREG_MVFR0_DIVIDE_BIT		(16)
+#define XREG_MVFR0_DIVIDE_MASK		(0xF << XREG_MVFR0_DIVIDE_BIT)
+#define XREG_MVFR0_EXEC_TRAP_BIT	(12)
+#define XREG_MVFR0_EXEC_TRAP_MASK	(0xF << XREG_MVFR0_EXEC_TRAP_BIT)
+#define XREG_MVFR0_DP_BIT		(8)
+#define XREG_MVFR0_DP_MASK		(0xF << XREG_MVFR0_DP_BIT)
+#define XREG_MVFR0_SP_BIT		(4)
+#define XREG_MVFR0_SP_MASK		(0xF << XREG_MVFR0_SP_BIT)
+#define XREG_MVFR0_A_SIMD_BIT		(0)
+#define XREG_MVFR0_A_SIMD_MASK		(0xF << MVFR0_A_SIMD_BIT)
+/* FPEXC bits */
+#define XREG_FPEXC_EX			(1 << 31)
+#define XREG_FPEXC_EN			(1 << 30)
+#define XREG_FPEXC_DEX			(1 << 29)
+#define XREG_CONTROL_DCACHE_BIT	(0X00000001U<<2U)
+#define XREG_CONTROL_ICACHE_BIT	(0X00000001U<<12U)
+ *@endcond
+#ifdef __cplusplus
+#endif /* XREG_CORTEXA53_H */
diff --git a/bsps/include/xilinx_support/arm/ARMv8/64bit/xil_cache.h b/bsps/include/xilinx_support/arm/ARMv8/64bit/xil_cache.h
index 0000000000..b878d05299
--- /dev/null
+++ b/bsps/include/xilinx_support/arm/ARMv8/64bit/xil_cache.h
@@ -0,0 +1,75 @@
+* Copyright (c) 2014 - 2021 Xilinx, Inc.  All rights reserved.
+* @addtogroup a53_64_cache_apis Cortex A53 64bit Processor Cache Functions
+* cache.
+* <pre>
+* 5.00 	pkp  05/29/14 First release
+* </pre>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ *@cond nocomments
+/************************** Constant Definitions *****************************/
+#define L1_DATA_PREFETCH_CONTROL_MASK  0xE000
+#define L1_DATA_PREFETCH_CONTROL_SHIFT  13
+ *@endcond
+/***************** Macros (Inline Functions) Definitions *********************/
+#define Xil_DCacheFlushRange Xil_DCacheInvalidateRange
+/************************** Function Prototypes ******************************/
+void Xil_DCacheInvalidateRange(INTPTR adr, INTPTR len);
+void Xil_DCacheInvalidateLine(INTPTR adr);
+void Xil_DCacheFlushLine(INTPTR adr);
+void Xil_ICacheInvalidateRange(INTPTR adr, INTPTR len);
+void Xil_ICacheInvalidateLine(INTPTR adr);
+void Xil_ConfigureL1Prefetch(u8 num);
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/bsps/include/xilinx_support/arm/ARMv8/64bit/xpseudo_asm.h b/bsps/include/xilinx_support/arm/ARMv8/64bit/xpseudo_asm.h
index 0000000000..3c79b0b991
--- /dev/null
+++ b/bsps/include/xilinx_support/arm/ARMv8/64bit/xpseudo_asm.h
@@ -0,0 +1,56 @@
+* Copyright (c) 2014 - 2020 Xilinx, Inc.  All rights reserved.
+* @addtogroup a53_64_specific Cortex A53 64bit Processor Specific Include Files
+* It provides inline definitions for Cortex A53 GPRs, SPRs and floating point
+* registers.
+* <pre>
+* </pre>
+#ifdef __cplusplus
+extern "C" {
+#endif
+#ifdef __clang__
+#include "xpseudo_asm_armclang.h"
+#else
+#endif
+#ifdef __cplusplus
+#endif
+* @} End of "addtogroup a53_64_specific".
diff --git a/bsps/include/xilinx_support/arm/ARMv8/64bit/xreg_cortexa53.h b/bsps/include/xilinx_support/arm/ARMv8/64bit/xreg_cortexa53.h
index 0000000000..b8ea1eac72
--- /dev/null
+++ b/bsps/include/xilinx_support/arm/ARMv8/64bit/xreg_cortexa53.h
@@ -0,0 +1,163 @@
+* written specifically for the GNU compiler.
+* <pre>
+* </pre>
+#ifdef __cplusplus
+extern "C" {
+ *@cond nocomments
+/* GPRs */
+#define XREG_GPR0				x0
+#define XREG_GPR1				x1
+#define XREG_GPR2				x2
+#define XREG_GPR3				x3
+#define XREG_GPR4				x4
+#define XREG_GPR5				x5
+#define XREG_GPR6				x6
+#define XREG_GPR7				x7
+#define XREG_GPR8				x8
+#define XREG_GPR9				x9
+#define XREG_GPR10				x10
+#define XREG_GPR11				x11
+#define XREG_GPR12				x12
+#define XREG_GPR13				x13
+#define XREG_GPR14				x14
+#define XREG_GPR15				x15
+#define XREG_GPR16				x16
+#define XREG_GPR17				x17
+#define XREG_GPR18				x18
+#define XREG_GPR19				x19
+#define XREG_GPR20				x20
+#define XREG_GPR21				x21
+#define XREG_GPR22				x22
+#define XREG_GPR23				x23
+#define XREG_GPR24				x24
+#define XREG_GPR25				x25
+#define XREG_GPR26				x26
+#define XREG_GPR27				x27
+#define XREG_GPR28				x28
+#define XREG_GPR29				x29
+#define XREG_GPR30				x30
+#define XREG_CPSR_MODE_BITS			0x1FU
+#define XREG_CPSR_EL3h_MODE			0xDU
+#define XREG_CPSR_EL3t_MODE			0xCU
+#define XREG_CPSR_EL2h_MODE			0x9U
+#define XREG_CPSR_EL2t_MODE			0x8U
+#define XREG_CPSR_EL1h_MODE			0x5U
+#define XREG_CPSR_EL1t_MODE			0x4U
+#define XREG_CPSR_EL0t_MODE			0x0U
+#define XREG_CPSR_IRQ_ENABLE		0x80U
+#define XREG_CPSR_FIQ_ENABLE		0x40U
+#define XREG_CPSR_N_BIT				0x80000000U
+#define XREG_CPSR_Z_BIT				0x40000000U
+#define XREG_CPSR_C_BIT				0x20000000U
+#define XREG_CPSR_V_BIT				0x10000000U
+/* FPSID bits */
+#define XREG_FPSID_IMPLEMENTER_BIT	(24U)
+#define XREG_FPSID_IMPLEMENTER_MASK	(0x000000FFU << FPSID_IMPLEMENTER_BIT)
+#define XREG_FPSID_SOFTWARE		(0X00000001U<<23U)
+#define XREG_FPSID_ARCH_BIT		(16U)
+#define XREG_FPSID_ARCH_MASK		(0x0000000FU  << FPSID_ARCH_BIT)
+#define XREG_FPSID_PART_BIT		(8U)
+#define XREG_FPSID_PART_MASK		(0x000000FFU << FPSID_PART_BIT)
+#define XREG_FPSID_VARIANT_BIT		(4U)
+#define XREG_FPSID_VARIANT_MASK		(0x0000000FU  << FPSID_VARIANT_BIT)
+#define XREG_FPSID_REV_BIT		(0U)
+#define XREG_FPSID_REV_MASK		(0x0000000FU  << FPSID_REV_BIT)
+/* FPSCR bits */
+#define XREG_FPSCR_N_BIT		(0X00000001U << 31U)
+#define XREG_FPSCR_Z_BIT		(0X00000001U << 30U)
+#define XREG_FPSCR_C_BIT		(0X00000001U << 29U)
+#define XREG_FPSCR_V_BIT		(0X00000001U << 28U)
+#define XREG_FPSCR_QC			(0X00000001U << 27U)
+#define XREG_FPSCR_AHP			(0X00000001U << 26U)
+#define XREG_FPSCR_DEFAULT_NAN		(0X00000001U << 25U)
+#define XREG_FPSCR_FLUSHTOZERO		(0X00000001U << 24U)
+#define XREG_FPSCR_ROUND_NEAREST	(0X00000000U << 22U)
+#define XREG_FPSCR_ROUND_PLUSINF	(0X00000001U << 22U)
+#define XREG_FPSCR_ROUND_MINUSINF	(0X00000002U << 22U)
+#define XREG_FPSCR_ROUND_TOZERO		(0X00000003U << 22U)
+#define XREG_FPSCR_RMODE_BIT		(22U)
+#define XREG_FPSCR_RMODE_MASK		(0X00000003U << FPSCR_RMODE_BIT)
+#define XREG_FPSCR_STRIDE_BIT		(20U)
+#define XREG_FPSCR_STRIDE_MASK		(0X00000003U << FPSCR_STRIDE_BIT)
+#define XREG_FPSCR_LENGTH_BIT		(16U)
+#define XREG_FPSCR_LENGTH_MASK		(0X00000007U << FPSCR_LENGTH_BIT)
+#define XREG_FPSCR_IDC			(0X00000001U << 7U)
+#define XREG_FPSCR_IXC			(0X00000001U << 4U)
+#define XREG_FPSCR_UFC			(0X00000001U << 3U)
+#define XREG_FPSCR_OFC			(0X00000001U << 2U)
+#define XREG_FPSCR_DZC			(0X00000001U << 1U)
+#define XREG_FPSCR_IOC			(0X00000001U << 0U)
+/* MVFR0 bits */
+#define XREG_MVFR0_RMODE_BIT		(28U)
+#define XREG_MVFR0_RMODE_MASK		(0x0000000FU << XREG_MVFR0_RMODE_BIT)
+#define XREG_MVFR0_SHORT_VEC_BIT	(24U)
+#define XREG_MVFR0_SHORT_VEC_MASK	(0x0000000FU << XREG_MVFR0_SHORT_VEC_BIT)
+#define XREG_MVFR0_SQRT_BIT		(20U)
+#define XREG_MVFR0_SQRT_MASK		(0x0000000FU << XREG_MVFR0_SQRT_BIT)
+#define XREG_MVFR0_DIVIDE_BIT		(16U)
+#define XREG_MVFR0_DIVIDE_MASK		(0x0000000FU << XREG_MVFR0_DIVIDE_BIT)
+#define XREG_MVFR0_EXEC_TRAP_BIT	(0X00000012U)
+#define XREG_MVFR0_EXEC_TRAP_MASK	(0X0000000FU << XREG_MVFR0_EXEC_TRAP_BIT)
+#define XREG_MVFR0_DP_BIT		(8U)
+#define XREG_MVFR0_DP_MASK		(0x0000000FU << XREG_MVFR0_DP_BIT)
+#define XREG_MVFR0_SP_BIT		(4U)
+#define XREG_MVFR0_SP_MASK		(0x0000000FU << XREG_MVFR0_SP_BIT)
+#define XREG_MVFR0_A_SIMD_BIT		(0U)
+#define XREG_MVFR0_A_SIMD_MASK		(0x0000000FU << MVFR0_A_SIMD_BIT)
+/* FPEXC bits */
+#define XREG_FPEXC_EX			(0X00000001U << 31U)
+#define XREG_FPEXC_EN			(0X00000001U << 30U)
+#define XREG_FPEXC_DEX			(0X00000001U << 29U)
+ *@endcond
+#ifdef __cplusplus
diff --git a/bsps/include/xilinx_support/arm/cortexa9/xil_cache.h b/bsps/include/xilinx_support/arm/cortexa9/xil_cache.h
index 0000000000..75cd6f6a8b
--- /dev/null
+++ b/bsps/include/xilinx_support/arm/cortexa9/xil_cache.h
@@ -0,0 +1,105 @@
+* Copyright (c) 2010 - 2021 Xilinx, Inc.  All rights reserved.
+* @addtogroup a9_cache_apis Cortex A9 Processor Cache Functions
+* cache.
+* <pre>
+* 1.00a ecm  01/29/10 First release
+* 3.04a sdm  01/02/12 Remove redundant dsb/dmb instructions in cache maintenance
+*		      APIs.
+* 6.8   aru  09/06/18 Removed compilation warnings for ARMCC toolchain.
+* </pre>
+*@cond nocomments
+#ifdef __cplusplus
+extern "C" {
+#endif
+#ifdef __GNUC__
+#define asm_cp15_inval_dc_line_mva_poc(param) __asm__ __volatile__("mcr " \
+			XREG_CP15_INVAL_DC_LINE_MVA_POC :: "r" (param));
+#define asm_cp15_clean_inval_dc_line_mva_poc(param) __asm__ __volatile__("mcr " \
+			XREG_CP15_CLEAN_INVAL_DC_LINE_MVA_POC :: "r" (param));
+#define asm_cp15_inval_ic_line_mva_pou(param) __asm__ __volatile__("mcr " \
+			XREG_CP15_INVAL_IC_LINE_MVA_POU :: "r" (param));
+#define asm_cp15_inval_dc_line_sw(param) __asm__ __volatile__("mcr " \
+			XREG_CP15_INVAL_DC_LINE_SW :: "r" (param));
+#define asm_cp15_clean_inval_dc_line_sw(param) __asm__ __volatile__("mcr " \
+			XREG_CP15_CLEAN_INVAL_DC_LINE_SW :: "r" (param));
+#elif defined (__ICCARM__)
+#define asm_cp15_inval_dc_line_mva_poc(param) __asm volatile ("mcr " \
+#define asm_cp15_clean_inval_dc_line_mva_poc(param) __asm volatile ("mcr " \
+#define asm_cp15_inval_ic_line_mva_pou(param) __asm volatile ("mcr " \
+#define asm_cp15_inval_dc_line_sw(param) __asm volatile ("mcr " \
+#define asm_cp15_clean_inval_dc_line_sw(param) __asm volatile ("mcr " \
+#endif
+*@endcond
+#ifdef __cplusplus
+#endif
+#endif
+* @} End of "addtogroup a9_cache_apis".
diff --git a/bsps/include/xilinx_support/arm/cortexa9/xpseudo_asm.h b/bsps/include/xilinx_support/arm/cortexa9/xpseudo_asm.h
index 0000000000..6d07851fa6
--- /dev/null
+++ b/bsps/include/xilinx_support/arm/cortexa9/xpseudo_asm.h
@@ -0,0 +1,60 @@
+* Copyright (c) 2009 - 2020 Xilinx, Inc.  All rights reserved.
+* @addtogroup a9_specific Cortex A9 Processor Specific Include Files
+* The xpseudo_asm.h includes xreg_cortexa9.h and xpseudo_asm_gcc.h.
+* The xreg_cortexa9.h file contains definitions for inline assembler code.
+* It provides inline definitions for Cortex A9 GPRs, SPRs, MPE registers,
+* co-processor registers and Debug registers.
+* <pre>
+* 1.00a ecm  10/18/09 First release
+* 3.04a sdm  01/02/12 Remove redundant dsb in mcr instruction.
+* </pre>
+#ifdef __cplusplus
+extern "C" {
+#endif
+#include "xreg_cortexa9.h"
+#ifdef __GNUC__
+ #include "xpseudo_asm_gcc.h"
+ #include "xpseudo_asm_iccarm.h"
+#else
+ #include "xpseudo_asm_rvct.h"
+#endif
+#ifdef __cplusplus
+#endif
+* @} End of "addtogroup a9_specific".
diff --git a/bsps/include/xilinx_support/arm/cortexa9/xreg_cortexa9.h b/bsps/include/xilinx_support/arm/cortexa9/xreg_cortexa9.h
index 0000000000..2a4fff23f0
--- /dev/null
+++ b/bsps/include/xilinx_support/arm/cortexa9/xreg_cortexa9.h
@@ -0,0 +1,573 @@
+* Copyright (c) 2009 - 2021 Xilinx, Inc.  All rights reserved.
+* @file xreg_cortexa9.h
+* written specifically for the GNU, ARMCC compiler.
+* All of the ARM Cortex A9 GPRs, SPRs, and Debug Registers are defined along
+* <pre>
+* 1.00a ecm/sdm  10/20/09 First release
+* </pre>
+#ifndef XREG_CORTEXA9_H
+#define XREG_CORTEXA9_H
+#ifdef __cplusplus
+extern "C" {
+ *@cond nocomments
+/* GPRs */
+#define XREG_CP0				0
+#define XREG_CP1				1
+#define XREG_CP2				2
+#define XREG_CP3				3
+#define XREG_CP4				4
+#define XREG_CP5				5
+#define XREG_CP6				6
+#define XREG_CP7				7
+#define XREG_CP8				8
+#define XREG_CP9				9
+/* CP15 defines */
+#if defined (__GNUC__) || defined (__ICCARM__)
+#else /* RVCT */
+#define XREG_CP15_MAIN_ID			"cp15:0:c0:c0:0"
+#define XREG_CP15_CACHE_TYPE			"cp15:0:c0:c0:1"
+#define XREG_CP15_TCM_TYPE			"cp15:0:c0:c0:2"
+#define XREG_CP15_TLB_TYPE			"cp15:0:c0:c0:3"
+#define XREG_CP15_MULTI_PROC_AFFINITY		"cp15:0:c0:c0:5"
+#define XREG_CP15_PROC_FEATURE_0		"cp15:0:c0:c1:0"
+#define XREG_CP15_PROC_FEATURE_1		"cp15:0:c0:c1:1"
+#define XREG_CP15_DEBUG_FEATURE_0		"cp15:0:c0:c1:2"
+#define XREG_CP15_MEMORY_FEATURE_0		"cp15:0:c0:c1:4"
+#define XREG_CP15_MEMORY_FEATURE_1		"cp15:0:c0:c1:5"
+#define XREG_CP15_MEMORY_FEATURE_2		"cp15:0:c0:c1:6"
+#define XREG_CP15_MEMORY_FEATURE_3		"cp15:0:c0:c1:7"
+#define XREG_CP15_INST_FEATURE_0		"cp15:0:c0:c2:0"
+#define XREG_CP15_INST_FEATURE_1		"cp15:0:c0:c2:1"
+#define XREG_CP15_INST_FEATURE_2		"cp15:0:c0:c2:2"
+#define XREG_CP15_INST_FEATURE_3		"cp15:0:c0:c2:3"
+#define XREG_CP15_INST_FEATURE_4		"cp15:0:c0:c2:4"
+#define XREG_CP15_CACHE_SIZE_ID			"cp15:1:c0:c0:0"
+#define XREG_CP15_CACHE_LEVEL_ID		"cp15:1:c0:c0:1"
+#define XREG_CP15_AUXILARY_ID			"cp15:1:c0:c0:7"
+#define XREG_CP15_CACHE_SIZE_SEL		"cp15:2:c0:c0:0"
+#define XREG_CP15_SYS_CONTROL			"cp15:0:c1:c0:0"
+#define XREG_CP15_AUX_CONTROL			"cp15:0:c1:c0:1"
+#define XREG_CP15_CP_ACCESS_CONTROL		"cp15:0:c1:c0:2"
+#define XREG_CP15_SECURE_CONFIG			"cp15:0:c1:c1:0"
+#define XREG_CP15_SECURE_DEBUG_ENABLE		"cp15:0:c1:c1:1"
+#define XREG_CP15_NS_ACCESS_CONTROL		"cp15:0:c1:c1:2"
+#define XREG_CP15_VIRTUAL_CONTROL		"cp15:0:c1:c1:3"
+#endif
+/* Not Used */
+ * isb instruction in Cortex A9.
+ * of the new dsb and dmb instructions in Cortex A9.
+/* Not used */
+/* not used */
+#else
+#define XREG_CP15_TTBR0				"cp15:0:c2:c0:0"
+#define XREG_CP15_TTBR1				"cp15:0:c2:c0:1"
+#define XREG_CP15_TTB_CONTROL			"cp15:0:c2:c0:2"
+#define XREG_CP15_DOMAIN_ACCESS_CTRL		"cp15:0:c3:c0:0"
+/* Not Used */
+#define XREG_CP15_DATA_FAULT_STATUS		"cp15:0:c5:c0:0"
+#define XREG_CP15_INST_FAULT_STATUS		"cp15:0:c5:c0:1"
+#define XREG_CP15_AUX_DATA_FAULT_STATUS		"cp15:0:c5:c1:0"
+#define XREG_CP15_AUX_INST_FAULT_STATUS		"cp15:0:c5:c1:1"
+#define XREG_CP15_DATA_FAULT_ADDRESS		"cp15:0:c6:c0:0"
+#define XREG_CP15_INST_FAULT_ADDRESS		"cp15:0:c6:c0:2"
+#define XREG_CP15_NOP				"cp15:0:c7:c0:4"
+#define XREG_CP15_INVAL_IC_POU_IS		"cp15:0:c7:c1:0"
+#define XREG_CP15_INVAL_BRANCH_ARRAY_IS		"cp15:0:c7:c1:6"
+#define XREG_CP15_PHYS_ADDR			"cp15:0:c7:c4:0"
+#define XREG_CP15_INVAL_IC_POU			"cp15:0:c7:c5:0"
+#define XREG_CP15_INVAL_IC_LINE_MVA_POU		"cp15:0:c7:c5:1"
+#define XREG_CP15_INST_SYNC_BARRIER		"cp15:0:c7:c5:4"
+#define XREG_CP15_INVAL_BRANCH_ARRAY		"cp15:0:c7:c5:6"
+#define XREG_CP15_INVAL_DC_LINE_MVA_POC		"cp15:0:c7:c6:1"
+#define XREG_CP15_INVAL_DC_LINE_SW		"cp15:0:c7:c6:2"
+#define XREG_CP15_VA_TO_PA_CURRENT_0		"cp15:0:c7:c8:0"
+#define XREG_CP15_VA_TO_PA_CURRENT_1		"cp15:0:c7:c8:1"
+#define XREG_CP15_VA_TO_PA_CURRENT_2		"cp15:0:c7:c8:2"
+#define XREG_CP15_VA_TO_PA_CURRENT_3		"cp15:0:c7:c8:3"
+#define XREG_CP15_VA_TO_PA_OTHER_0		"cp15:0:c7:c8:4"
+#define XREG_CP15_VA_TO_PA_OTHER_1		"cp15:0:c7:c8:5"
+#define XREG_CP15_VA_TO_PA_OTHER_2		"cp15:0:c7:c8:6"
+#define XREG_CP15_VA_TO_PA_OTHER_3		"cp15:0:c7:c8:7"
+#define XREG_CP15_CLEAN_DC_LINE_MVA_POC		"cp15:0:c7:c10:1"
+#define XREG_CP15_CLEAN_DC_LINE_SW		"cp15:0:c7:c10:2"
+#define XREG_CP15_DATA_SYNC_BARRIER		"cp15:0:c7:c10:4"
+#define XREG_CP15_DATA_MEMORY_BARRIER		"cp15:0:c7:c10:5"
+#define XREG_CP15_CLEAN_DC_LINE_MVA_POU		"cp15:0:c7:c11:1"
+#define XREG_CP15_NOP2				"cp15:0:c7:c13:1"
+#define XREG_CP15_CLEAN_INVAL_DC_LINE_MVA_POC	"cp15:0:c7:c14:1"
+#define XREG_CP15_CLEAN_INVAL_DC_LINE_SW	"cp15:0:c7:c14:2"
+#define XREG_CP15_INVAL_TLB_IS			"cp15:0:c8:c3:0"
+#define XREG_CP15_INVAL_TLB_MVA_IS		"cp15:0:c8:c3:1"
+#define XREG_CP15_INVAL_TLB_ASID_IS		"cp15:0:c8:c3:2"
+#define XREG_CP15_INVAL_TLB_MVA_ASID_IS		"cp15:0:c8:c3:3"
+#define XREG_CP15_INVAL_ITLB_UNLOCKED		"cp15:0:c8:c5:0"
+#define XREG_CP15_INVAL_ITLB_MVA		"cp15:0:c8:c5:1"
+#define XREG_CP15_INVAL_ITLB_ASID		"cp15:0:c8:c5:2"
+#define XREG_CP15_INVAL_DTLB_UNLOCKED		"cp15:0:c8:c6:0"
+#define XREG_CP15_INVAL_DTLB_MVA		"cp15:0:c8:c6:1"
+#define XREG_CP15_INVAL_DTLB_ASID		"cp15:0:c8:c6:2"
+#define XREG_CP15_INVAL_UTLB_UNLOCKED		"cp15:0:c8:c7:0"
+#define XREG_CP15_INVAL_UTLB_MVA		"cp15:0:c8:c7:1"
+#define XREG_CP15_INVAL_UTLB_ASID		"cp15:0:c8:c7:2"
+#define XREG_CP15_INVAL_UTLB_MVA_ASID		"cp15:0:c8:c7:3"
+#define XREG_CP15_PERF_MONITOR_CTRL		"cp15:0:c9:c12:0"
+#define XREG_CP15_COUNT_ENABLE_SET		"cp15:0:c9:c12:1"
+#define XREG_CP15_COUNT_ENABLE_CLR		"cp15:0:c9:c12:2"
+#define XREG_CP15_V_FLAG_STATUS			"cp15:0:c9:c12:3"
+#define XREG_CP15_SW_INC			"cp15:0:c9:c12:4"
+#define XREG_CP15_EVENT_CNTR_SEL		"cp15:0:c9:c12:5"
+#define XREG_CP15_PERF_CYCLE_COUNTER		"cp15:0:c9:c13:0"
+#define XREG_CP15_EVENT_TYPE_SEL		"cp15:0:c9:c13:1"
+#define XREG_CP15_PERF_MONITOR_COUNT		"cp15:0:c9:c13:2"
+#define XREG_CP15_USER_ENABLE			"cp15:0:c9:c14:0"
+#define XREG_CP15_INTR_ENABLE_SET		"cp15:0:c9:c14:1"
+#define XREG_CP15_INTR_ENABLE_CLR		"cp15:0:c9:c14:2"
+#define XREG_CP15_TLB_LOCKDWN			"cp15:0:c10:c0:0"
+#define XREG_CP15_PRI_MEM_REMAP			"cp15:0:c10:c2:0"
+#define XREG_CP15_NORM_MEM_REMAP		"cp15:0:c10:c2:1"
+/* Not used */
+#define XREG_CP15_VEC_BASE_ADDR			"cp15:0:c12:c0:0"
+#define XREG_CP15_MONITOR_VEC_BASE_ADDR		"cp15:0:c12:c0:1"
+#define XREG_CP15_INTERRUPT_STATUS		"cp15:0:c12:c1:0"
+#define XREG_CP15_VIRTUALIZATION_INTR		"cp15:0:c12:c1:1"
+#define XREG_CP15_CONTEXT_ID			"cp15:0:c13:c0:1"
+#define USER_RW_THREAD_PID			"cp15:0:c13:c0:2"
+#define USER_RO_THREAD_PID			"cp15:0:c13:c0:3"
+#define USER_PRIV_THREAD_PID			"cp15:0:c13:c0:4"
+/* not used */
+#define XREG_CP15_POWER_CTRL			"cp15:0:c15:c0:0"
+#define XREG_CP15_CONFIG_BASE_ADDR		"cp15:4:c15:c0:0"
+#define XREG_CP15_READ_TLB_ENTRY		"cp15:5:c15:c4:2"
+#define XREG_CP15_WRITE_TLB_ENTRY		"cp15:5:c15:c4:4"
+#define XREG_CP15_MAIN_TLB_VA			"cp15:5:c15:c5:2"
+#define XREG_CP15_MAIN_TLB_PA			"cp15:5:c15:c6:2"
+#define XREG_CP15_MAIN_TLB_ATTR			"cp15:5:c15:c7:2"
+#endif
+/* FPSID bits */
+/* FPSCR bits */
+/* MVFR0 bits */
+/* FPEXC bits */
+ *@endcond
+#ifdef __cplusplus
+#endif /* XREG_CORTEXA9_H */
diff --git a/bsps/include/xilinx_support/arm/cortexr5/xil_cache.h b/bsps/include/xilinx_support/arm/cortexr5/xil_cache.h
index 0000000000..fcc74504db
--- /dev/null
+++ b/bsps/include/xilinx_support/arm/cortexr5/xil_cache.h
@@ -0,0 +1,95 @@
+* @addtogroup r5_cache_apis Cortex R5 Processor Cache Functions
+* cache.
+* <pre>
+* 5.00 	pkp  02/20/14 First release
+* 6.2   mus  01/27/17 Updated to support IAR compiler
+* </pre>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ *@cond nocomments
+#define asm_inval_dc_line_mva_poc(param) __asm__ __volatile__("mcr " \
+#define asm_clean_inval_dc_line_sw(param) __asm__ __volatile__("mcr " \
+#define asm_clean_inval_dc_line_mva_poc(param) __asm__ __volatile__("mcr " \
+#define asm_inval_ic_line_mva_pou(param) __asm__ __volatile__("mcr " \
+#define asm_inval_dc_line_mva_poc(param) __asm volatile("mcr " \
+#define asm_clean_inval_dc_line_sw(param) __asm volatile("mcr " \
+#define asm_clean_inval_dc_line_mva_poc(param) __asm volatile("mcr " \
+#define asm_inval_ic_line_mva_pou(param) __asm volatile("mcr " \
+#endif
+ *@endcond
+void Xil_DCacheStoreLine(INTPTR adr);
+#ifdef __cplusplus
+#endif
+#endif
+* @} End of "addtogroup r5_cache_apis".
diff --git a/bsps/include/xilinx_support/arm/cortexr5/xpseudo_asm.h b/bsps/include/xilinx_support/arm/cortexr5/xpseudo_asm.h
index 0000000000..46b704539c
--- /dev/null
+++ b/bsps/include/xilinx_support/arm/cortexr5/xpseudo_asm.h
@@ -0,0 +1,60 @@
+* @addtogroup r5_specific Cortex R5 Processor Specific Include Files
+* The xpseudo_asm.h includes xreg_cortexr5.h and xpseudo_asm_gcc.h.
+* The xreg_cortexr5.h file contains definitions for inline assembler code.
+* It provides inline definitions for Cortex R5 GPRs, SPRs,co-processor
+* registers and Debug register
+* inline assembler instructions, available as macros. These can be very
+* useful for tasks such as setting or getting special purpose registers,
+* synchronization,or cache manipulation. These inline assembler instructions
+* can be used from drivers and user applications written in C.
+* <pre>
+* 5.00  pkp  02/10/14 Initial version
+* 7.3   dp   06/25/20 Initial version for armclang
+* </pre>
+#ifndef XPSEUDO_ASM_H /* prevent circular inclusions */
+#define XPSEUDO_ASM_H /* by using protection macros */
+#ifdef __cplusplus
+extern "C" {
+#endif
+#include "xreg_cortexr5.h"
+#if defined (__clang__)
+#elif defined (__GNUC__)
+#include "xpseudo_asm_iccarm.h"
+#endif
+#ifdef __cplusplus
+#endif
+* @} End of "addtogroup r5_specific".
diff --git a/bsps/include/xilinx_support/arm/cortexr5/xreg_cortexr5.h b/bsps/include/xilinx_support/arm/cortexr5/xreg_cortexr5.h
index 0000000000..8034672636
--- /dev/null
+++ b/bsps/include/xilinx_support/arm/cortexr5/xreg_cortexr5.h
@@ -0,0 +1,429 @@
+* Copyright (c) 2014 - 2022 Xilinx, Inc.  All rights reserved.
+* @file xreg_cortexr5.h
+* written specifically for the GNU, IAR, ARMCC compiler.
+* All of the ARM Cortex R5 GPRs, SPRs, and Debug Registers are defined along
+* <pre>
+* 7.7	sk   01/10/22 Update PRIV_RW_USER_RW macro from unsigned to unsigned
+* 		      long to fix misra_c_2012_rule_12_2 violation.
+* </pre>
+ *@cond nocomments
+#ifndef XREG_CORTEXR5_H	/* prevent circular inclusions */
+#define XREG_CORTEXR5_H	/* by using protection macros */
+#ifdef __cplusplus
+extern "C" {
+/* GPRs */
+#define XREG_CP0				0
+#define XREG_CP1				1
+#define XREG_CP2				2
+#define XREG_CP3				3
+#define XREG_CP4				4
+#define XREG_CP5				5
+#define XREG_CP6				6
+#define XREG_CP7				7
+#define XREG_CP8				8
+#define XREG_CP9				9
+#define XREG_CPSR_THUMB_MODE			0x20U
+#define XREG_CPSR_SYSTEM_MODE			0x1FU
+#define XREG_CPSR_UNDEFINED_MODE		0x1BU
+#define XREG_CPSR_DATA_ABORT_MODE		0x17U
+#define XREG_CPSR_SVC_MODE			0x13U
+#define XREG_CPSR_IRQ_MODE			0x12U
+#define XREG_CPSR_FIQ_MODE			0x11U
+#define XREG_CPSR_USER_MODE			0x10U
+/*MPU region definitions*/
+#define REGION_32B     0x00000004U
+#define REGION_64B     0x00000005U
+#define REGION_128B    0x00000006U
+#define REGION_256B    0x00000007U
+#define REGION_512B    0x00000008U
+#define REGION_1K      0x00000009U
+#define REGION_2K      0x0000000AU
+#define REGION_4K      0x0000000BU
+#define REGION_8K      0x0000000CU
+#define REGION_16K     0x0000000DU
+#define REGION_32K     0x0000000EU
+#define REGION_64K     0x0000000FU
+#define REGION_128K    0x00000010U
+#define REGION_256K    0x00000011U
+#define REGION_512K    0x00000012U
+#define REGION_1M      0x00000013U
+#define REGION_2M      0x00000014U
+#define REGION_4M      0x00000015U
+#define REGION_8M      0x00000016U
+#define REGION_16M     0x00000017U
+#define REGION_32M     0x00000018U
+#define REGION_64M     0x00000019U
+#define REGION_128M    0x0000001AU
+#define REGION_256M    0x0000001BU
+#define REGION_512M    0x0000001CU
+#define REGION_1G      0x0000001DU
+#define REGION_2G      0x0000001EU
+#define REGION_4G      0x0000001FU
+#define REGION_EN  0x00000001U
+#define SHAREABLE				0x00000004U 	/*shareable */
+#define STRONG_ORDERD_SHARED	0x00000000U	/*strongly ordered, always shareable*/
+#define DEVICE_SHARED			0x00000001U	/*device, shareable*/
+#define DEVICE_NONSHARED		0x00000010U	/*device, non shareable*/
+#define NORM_NSHARED_WT_NWA		0x00000002U 	/*Outer and Inner write-through, no write-allocate non-shareable*/
+#define NORM_SHARED_WT_NWA		0x00000006U 	/*Outer and Inner write-through, no write-allocate shareable*/
+#define NORM_NSHARED_WB_NWA 	0x00000003U 	/*Outer and Inner write-back, no write-allocate non shareable*/
+#define NORM_SHARED_WB_NWA 		0x00000007U 	/*Outer and Inner write-back, no write-allocate shareable*/
+#define NORM_NSHARED_NCACHE 	0x00000008U 	/*Outer and Inner Non cacheable  non shareable*/
+#define NORM_SHARED_NCACHE 		0x0000000CU 	/*Outer and Inner Non cacheable shareable*/
+#define NORM_NSHARED_WB_WA 		0x0000000BU 	/*Outer and Inner write-back non shared*/
+#define NORM_SHARED_WB_WA 		0x0000000FU 	/*Outer and Inner write-back shared*/
+/* inner and outer cache policies can be combined for different combinations */
+#define NORM_IN_POLICY_NCACHE	0x00000020U	/*inner non cacheable*/
+#define NORM_IN_POLICY_WB_WA	0x00000021U	/*inner write back write allocate*/
+#define NORM_IN_POLICY_WT_NWA	0x00000022U	/*inner write through no write allocate*/
+#define NORM_IN_POLICY_WB_NWA	0x00000023U	/*inner write back no write allocate*/
+#define NORM_OUT_POLICY_NCACHE	0x00000020U	/*outer non cacheable*/
+#define NORM_OUT_POLICY_WB_WA	0x00000028U	/*outer write back write allocate*/
+#define NORM_OUT_POLICY_WT_NWA	0x00000030U	/*outer write through no write allocate*/
+#define NORM_OUT_POLICY_WB_NWA	0x00000038U	/*outer write back no write allocate*/
+#define NO_ACCESS				(0x00000000U<<8U)	/*No access*/
+#define PRIV_RW_USER_NA			(0x00000001U<<8U) /*Privileged access only*/
+#define PRIV_RW_USER_RO			(0x00000002U<<8U) /*Writes in User mode generate permission faults*/
+#define	PRIV_RW_USER_RW			(0x00000003UL<<8U)	/*Full Access*/
+#define PRIV_RO_USER_NA			(0x00000005U<<8U) /*Privileged eead only*/
+#define PRIV_RO_USER_RO			(0x00000006U<<8U) /*Privileged/User read-only*/
+#define EXECUTE_NEVER  			(0x00000001U<<12U)  /* Bit 12*/
+/* CP15 defines */
+#define XREG_CP15_MPU_TYPE			"p15, 0, %0,  c0,  c0, 4"
+#define XREG_CP15_INST_FEATURE_5		"p15, 0, %0,  c0,  c2, 5"
+/* Not Used */
+/* Not Used */
+/* Not Used */
+#define XREG_CP15_MPU_REG_BASEADDR			"p15, 0, %0,  c6,  c1, 0"
+#define XREG_CP15_MPU_REG_SIZE_EN			"p15, 0, %0,  c6,  c1, 2"
+#define XREG_CP15_MPU_REG_ACCESS_CTRL		"p15, 0, %0,  c6,  c1, 4"
+#define XREG_CP15_MPU_MEMORY_REG_NUMBER			"p15, 0, %0,  c6,  c2, 0"
+ * isb instruction in Cortex R5.
+#define XREG_CP15_INVAL_BRANCH_ARRAY_LINE		"p15, 0, %0,  c7,  c5, 7"
+#define XREG_CP15_INVAL_DC_ALL		"p15, 0, %0,  c15, c5, 0"
+ * of the new dsb and dmb instructions in Cortex R5.
+/* Not Used */
+#define XREG_CP15_ATCM_REG_SIZE_ADDR		"p15, 0, %0,  c9, c1, 1"
+#define XREG_CP15_BTCM_REG_SIZE_ADDR		"p15, 0, %0,  c9, c1, 0"
+#define XREG_CP15_TCM_SELECTION				"p15, 0, %0,  c9, c2, 0"
+/* Not used */
+/* Not used */
+/* Not used */
+/* not used */
+#define XREG_CP15_SEC_AUX_CTRL			"p15, 0, %0, c15,  c0, 0"
+/* FPSID bits */
+#define XREG_FPSID_SOFTWARE		(0X00000001U << 23U)
+/* FPSCR bits */
+/* MVFR0 bits */
+#define XREG_MVFR0_EXEC_TRAP_BIT	(12U)
+#define XREG_MVFR0_EXEC_TRAP_MASK	(0x0000000FU << XREG_MVFR0_EXEC_TRAP_BIT)
+/* FPEXC bits */
+#ifdef __cplusplus
+#endif /* XREG_CORTEXR5_H */
+ *@endcond
diff --git a/bsps/include/xilinx_support/bspconfig.h b/bsps/include/xilinx_support/bspconfig.h
index 0000000000..55a8df3add
--- /dev/null
+++ b/bsps/include/xilinx_support/bspconfig.h
@@ -0,0 +1 @@
+/* Intentional blank stub file for Xilinx driver compatibility. */
diff --git a/bsps/include/xilinx_support/microblaze/xil_cache.h b/bsps/include/xilinx_support/microblaze/xil_cache.h
index 0000000000..d279665751
--- /dev/null
+++ b/bsps/include/xilinx_support/microblaze/xil_cache.h
@@ -0,0 +1,392 @@
+* @addtogroup microblaze_cache_apis Microblaze Cache APIs
+* The xil_cache.h file contains cache related driver functions (or macros)
+* that can be used to access the device.  The user should refer to the
+* hardware device specification for more details of the device operation.
+* The functions in this header file can be used across all Xilinx supported
+* processors.
+* <pre>
+* 1.00  hbm  07/28/09 Initial release
+* 3.02a sdm  10/24/11 Updated the file to include xparameters.h so that
+*                     the correct cache flush routines are used based on
+*                     whether the write-back or write-through caches are
+*                     used (cr #630532).
+* 3.10a asa  05/04/13 This version of MicroBlaze BSP adds support for system
+*					  cache/L2 cache. The existing/old APIs/macros in this
+*					  file are renamed to imply that they deal with L1 cache.
+*					  New macros/APIs are added to address similar features for
+*					  L2 cache. Users can include this file in their application
+*					  to use the various cache related APIs. These changes are
+*					  done for implementing PR #697214.
+* </pre>
+#if defined XENV_VXWORKS
+/* VxWorks environment */
+#error "Unknown processor / architecture. Must be PPC for VxWorks."
+#else
+/* standalone environment */
+#include "mb_interface.h"
+#include "xparameters.h"
+#ifdef __cplusplus
+extern "C" {
+#endif
+* @brief    Invalidate the entire L1 data cache. If the cacheline is modified
+*            (dirty), the modified contents are lost.
+* @return   None.
+* @note		Processor must be in real mode.
+#define Xil_L1DCacheInvalidate() microblaze_invalidate_dcache()
+* @brief    Invalidate the entire L2 data cache. If the cacheline is modified
+*           (dirty),the modified contents are lost.
+* @return   None.
+#define Xil_L2CacheInvalidate() microblaze_invalidate_cache_ext()
+* @brief    Invalidate the L1 data cache for the given address range.
+*           If the bytes specified by the address (Addr) are cached by the L1
+*           data cache, the cacheline containing that byte is invalidated.If
+*           the cacheline is modified (dirty), the modified contents are lost.
+* @param    Addr is address of range to be invalidated.
+* @param    Len is the length in bytes to be invalidated.
+* @return   None.
+#define Xil_L1DCacheInvalidateRange(Addr, Len) \
+			microblaze_invalidate_dcache_range((Addr), (Len))
+*           L1 data cache, the cacheline containing that byte is invalidated.
+*           If the cacheline is modified (dirty), the modified contents are lost.
+* @param    Addr: address of range to be invalidated.
+* @param    Len: length in bytes to be invalidated.
+* @return   None.
+#define Xil_L2CacheInvalidateRange(Addr, Len) \
+		microblaze_invalidate_cache_ext_range((Addr), (Len))
+* @brief   Flush the L1 data cache for the given address range.
+*          data cache, and is modified (dirty), the cacheline will be written
+*          to system memory.The cacheline will also be invalidated.
+* @param    Addr: the starting address of the range to be flushed.
+* @param    Len: length in byte to be flushed.
+* @return   None.
+#if (XPAR_MICROBLAZE_DCACHE_USE_WRITEBACK == 1)
+#   define Xil_L1DCacheFlushRange(Addr, Len) \
+		microblaze_flush_dcache_range((Addr), (Len))
+#else
+#endif /* XPAR_MICROBLAZE_DCACHE_USE_WRITEBACK */
+* @brief    Flush the L2 data cache for the given address range.
+*           written to system memory. The cacheline will also be invalidated.
+* @return   None.
+#define Xil_L2CacheFlushRange(Addr, Len) \
+		microblaze_flush_cache_ext_range((Addr), (Len))
+* @brief    Flush the entire L1 data cache. If any cacheline is dirty, the
+*           cacheline will be written to system memory. The entire data cache
+*           will be invalidated.
+* @return   None.
+#   define Xil_L1DCacheFlush() microblaze_flush_dcache()
+#else
+#   define Xil_L1DCacheFlush() microblaze_invalidate_dcache()
+* @brief    Flush the entire L2 data cache. If any cacheline is dirty, the
+* @return   None.
+#define Xil_L2CacheFlush() microblaze_flush_cache_ext()
+* @brief    Invalidate the instruction cache for the given address range.
+* @param    Addr is address of ragne to be invalidated.
+* @return   None.
+#define Xil_L1ICacheInvalidateRange(Addr, Len) \
+			microblaze_invalidate_icache_range((Addr), (Len))
+* @brief    Invalidate the entire instruction cache.
+* @return   None.
+#define Xil_L1ICacheInvalidate() \
+			microblaze_invalidate_icache()
+* @brief    Enable the L1 data cache.
+* @return   None.
+* @note     This is processor specific.
+#define Xil_L1DCacheEnable() \
+			microblaze_enable_dcache()
+* @brief    Disable the L1 data cache.
+* @return   None.
+#define Xil_L1DCacheDisable() \
+			microblaze_disable_dcache()
+* @brief    Enable the instruction cache.
+* @return   None.
+#define Xil_L1ICacheEnable() \
+			microblaze_enable_icache()
+* @brief    Disable the L1 Instruction cache.
+* @return   None.
+#define Xil_L1ICacheDisable() \
+			microblaze_disable_icache()
+* @brief    Enable the data cache.
+* @return   None.
+#define Xil_DCacheEnable() Xil_L1DCacheEnable()
+* @return   None.
+#define Xil_ICacheEnable() Xil_L1ICacheEnable()
+* @brief    Invalidate the entire Data cache.
+* @return	None.
+#define Xil_DCacheInvalidate() \
+	Xil_L2CacheInvalidate(); \
+	Xil_L1DCacheInvalidate();
+* @brief    Invalidate the Data cache for the given address range.
+*           If the bytes specified by the address (adr) are cached by the
+*           Data cache, the cacheline containing that byte is invalidated.
+*           lost and are NOT written to system memory before the line is
+*           invalidated.
+* @param	Addr: Start address of range to be invalidated.
+* @param	Len: Length of range to be invalidated in bytes.
+* @return	None.
+#define Xil_DCacheInvalidateRange(Addr, Len) \
+	Xil_L2CacheInvalidateRange((Addr), (Len)); \
+	Xil_L1DCacheInvalidateRange((Addr), (Len));
+* @brief    Flush the entire Data cache.
+* @return	None.
+#define Xil_DCacheFlush() \
+	Xil_L2CacheFlush(); \
+	Xil_L1DCacheFlush();
+* @brief     Flush the Data cache for the given address range.
+*            If the cacheline is modified (dirty), the written to system
+*            memory first before the before the line is invalidated.
+* @param	Addr: Start address of range to be flushed.
+* @param	Len: Length of range to be flushed in bytes.
+* @return	None.
+#define Xil_DCacheFlushRange(Addr, Len) \
+	Xil_L2CacheFlushRange((Addr), (Len)); \
+	Xil_L1DCacheFlushRange((Addr), (Len));
+* @return	None.
+#define Xil_ICacheInvalidate() \
+	Xil_L1ICacheInvalidate();
+*            invalidated.
+* @param	Addr: Start address of ragne to be invalidated.
+* @return	None.
+#define Xil_ICacheInvalidateRange(Addr, Len) \
+	Xil_L1ICacheInvalidateRange((Addr), (Len));
+#ifdef __cplusplus
+#endif
+#endif
+#endif
+* @} End of "addtogroup microblaze_cache_apis".
diff --git a/bsps/include/xilinx_support/sleep.h b/bsps/include/xilinx_support/sleep.h
index 0000000000..73b2ea026d
--- /dev/null
+++ b/bsps/include/xilinx_support/sleep.h
@@ -0,0 +1,99 @@
+* @file sleep.h
+*  This header file contains ARM Cortex A53,A9,R5,Microblaze specific sleep
+*  related APIs.
+* <pre>
+* MODIFICATION HISTORY :
+* 6.6   srm  11/02/17 Added processor specific sleep routines
+*								 function prototypes.
+* 7.7	sk   01/10/22 Typecast sleep declaration argument from unsigned int to
+* 		      u32 to fix misra_c_2012_directive_4_6 violation.
+* 7.7	sk   01/10/22 Modify the return type of sleep_R5 and usleep_R5 from
+* 		      unsigned to void to fix misra_c_2012_rule_17_7 violation.
+* 7.7	sk   03/02/22 Update usleep_R5 and usleep parameter types to fix misra_
+*		      c_2012_directive_4_6 violation.
+* </pre>
+#ifndef SLEEP_H
+#define SLEEP_H
+#include "xil_io.h"
+#ifdef __cplusplus
+extern "C" {
+#endif
+* This macro polls an address periodically until a condition is met or till the
+* timeout occurs.
+* The minimum timeout for calling this macro is 100us. If the timeout is less
+* than 100us, it still waits for 100us. Also the unit for the timeout is 100us.
+* If the timeout is not a multiple of 100us, it waits for a timeout of
+* the next usec value which is a multiple of 100us.
+* @param            IO_func - accessor function to read the register contents.
+*                   Depends on the register width.
+* @param            ADDR - Address to be polled
+* @param            VALUE - variable to read the value
+* @param            COND - Condition to checked (usually involves VALUE)
+* @param            TIMEOUT_US - timeout in micro seconds
+* @return           0 - when the condition is met
+*                   -1 - when the condition is not met till the timeout period
+* @note             none
+#define Xil_poll_timeout(IO_func, ADDR, VALUE, COND, TIMEOUT_US) \
+	u64 timeout = TIMEOUT_US/100;    \
+	if(TIMEOUT_US%100!=0)	\
+		timeout++;   \
+	for(;;) { \
+		VALUE = IO_func(ADDR); \
+		if(COND) \
+			break; \
+		else {    \
+			usleep(100);  \
+			timeout--; \
+			if(timeout==0) \
+			break;  \
+	(timeout>0) ? 0 : -1;  \
+void usleep(ULONG useconds);
+void sleep(u32 seconds);
+void usleep_R5(ULONG useconds);
+void sleep_R5(u32 seconds);
+int usleep_MB(unsigned long useconds);
+unsigned sleep_MB(unsigned int seconds);
+int usleep_A53(unsigned long useconds);
+unsigned sleep_A53(unsigned int seconds);
+int usleep_A9(unsigned long useconds);
+unsigned sleep_A9(unsigned int seconds);
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/bsps/include/xilinx_support/xbasic_types.h b/bsps/include/xilinx_support/xbasic_types.h
index 0000000000..99b137503e
--- /dev/null
+++ b/bsps/include/xilinx_support/xbasic_types.h
@@ -0,0 +1,113 @@
+* @file xbasic_types.h
+* @note  Dummy File for backwards compatibility
+* <pre>
+* 1.00a adk   1/31/14  Added in bsp common folder for backward compatibility
+* 7.0   aru   01/21/19 Modified the typedef of u32,u16,u8
+* 7.0 	aru   02/06/19 Included stdint.h and stddef.h
+* </pre>
+ *@cond nocomments
+#ifndef XBASIC_TYPES_H	/* prevent circular inclusions */
+#define XBASIC_TYPES_H	/* by using protection macros */
+#ifdef __cplusplus
+extern "C" {
+#endif
+#include <stdint.h>
+#include <stddef.h>
+/** @name Legacy types
+ * Deprecated legacy types.
+typedef uint8_t	Xuint8;		/**< unsigned 8-bit */
+typedef char		Xint8;		/**< signed 8-bit */
+typedef uint16_t	Xuint16;	/**< unsigned 16-bit */
+typedef short		Xint16;		/**< signed 16-bit */
+typedef uint32_t	Xuint32;	/**< unsigned 32-bit */
+typedef long		Xint32;		/**< signed 32-bit */
+typedef float		Xfloat32;	/**< 32-bit floating point */
+typedef double		Xfloat64;	/**< 64-bit double precision FP */
+typedef unsigned long	Xboolean;	/**< boolean (XTRUE or XFALSE) */
+#if !defined __XUINT64__
+typedef struct
+	Xuint32 Upper;
+	Xuint32 Lower;
+} Xuint64;
+#endif
+/** @name New types
+ * New simple types.
+#ifndef __KERNEL__
+#ifndef XIL_TYPES_H
+typedef Xuint32         u32;
+typedef Xuint16         u16;
+typedef Xuint8          u8;
+#endif
+#else
+#include <linux/types.h>
+#endif
+#ifndef TRUE
+#  define TRUE		1U
+#endif
+#ifndef FALSE
+#  define FALSE		0U
+#endif
+#ifndef NULL
+#define NULL		0U
+#endif
+ * Xilinx NULL, TRUE and FALSE legacy support. Deprecated.
+ * Please use NULL, TRUE and FALSE
+#define XNULL		NULL
+#define XTRUE		TRUE
+#define XFALSE		FALSE
+ * This file is deprecated and users
+ * should use xil_types.h and xil_assert.h\n\r
+#warning  The xbasics_type.h file is deprecated and users should use xil_types.h and xil_assert.
+#warning  Please refer the Standalone BSP UG647 for further details
+#ifdef __cplusplus
+#endif
+#endif	/* end of protection macro */
+ *@endcond
diff --git a/bsps/include/xilinx_support/xil_assert.h b/bsps/include/xilinx_support/xil_assert.h
index 0000000000..e8b87b59f2
--- /dev/null
+++ b/bsps/include/xilinx_support/xil_assert.h
@@ -0,0 +1,176 @@
+* @file xil_assert.h
+* @addtogroup common_assert_apis Assert APIs and Macros
+* The xil_assert.h file contains assert related functions and macros.
+* Assert APIs/Macros specifies that a application program satisfies certain
+* conditions at particular points in its execution. These function can be
+* used by application programs to ensure that, application code is satisfying
+* certain conditions.
+* <pre>
+* 1.00a hbm  07/14/09 First release
+* 6.0   kvn  05/31/16 Make Xil_AsserWait a global variable
+* </pre>
+ *@cond nocomments
+#ifndef XIL_ASSERT_H	/* prevent circular inclusions */
+#define XIL_ASSERT_H	/* by using protection macros */
+#ifdef __cplusplus
+extern "C" {
+#endif
+/***************************** Include Files *********************************/
+#define XIL_ASSERT_NONE     0U
+#define XIL_ASSERT_OCCURRED 1U
+#define XNULL NULL
+extern u32 Xil_AssertStatus;
+extern s32 Xil_AssertWait;
+extern void Xil_Assert(const char8 *File, s32 Line);
+ *@endcond
+void XNullHandler(void *NullParameter);
+ * This data type defines a callback to be invoked when an
+ * assert occurs. The callback is invoked only when asserts are enabled
+typedef void (*Xil_AssertCallback) (const char8 *File, s32 Line);
+#ifndef NDEBUG
+* @brief    This assert macro is to be used for void functions. This in
+*           conjunction with the Xil_AssertWait boolean can be used to
+*           accommodate tests so that asserts which fail allow execution to
+*           continue.
+* @param    Expression: expression to be evaluated. If it evaluates to
+*           false, the assert occurs.
+* @return   Returns void unless the Xil_AssertWait variable is true, in which
+*           case no return is made and an infinite loop is entered.
+#define Xil_AssertVoid(Expression)                \
+    if (Expression) {                              \
+        Xil_AssertStatus = XIL_ASSERT_NONE;       \
+    } else {                                       \
+        Xil_Assert(__FILE__, __LINE__);            \
+        Xil_AssertStatus = XIL_ASSERT_OCCURRED;   \
+        return;                                    \
+* @brief    This assert macro is to be used for functions that do return a
+*           value. This in conjunction with the Xil_AssertWait boolean can be
+*           used to accommodate tests so that asserts which fail allow execution
+*           to continue.
+* @param    Expression: expression to be evaluated. If it evaluates to false,
+*           the assert occurs.
+* @return   Returns 0 unless the Xil_AssertWait variable is true, in which
+#define Xil_AssertNonvoid(Expression)             \
+    } else {                                       \
+        return 0;                                  \
+* @brief     Always assert. This assert macro is to be used for void functions.
+*            Use for instances where an assert should always occur.
+#define Xil_AssertVoidAlways()                   \
+   return;                                         \
+* @brief   Always assert. This assert macro is to be used for functions that
+*          do return a value. Use for instances where an assert should always
+*          occur.
+#define Xil_AssertNonvoidAlways()                \
+   return 0;                                       \
+#else
+#endif
+void Xil_AssertSetCallback(Xil_AssertCallback Routine);
+#ifdef __cplusplus
+#endif
+* @} End of "addtogroup common_assert_apis".
diff --git a/bsps/include/xilinx_support/xil_exception.h b/bsps/include/xilinx_support/xil_exception.h
--- /dev/null
+++ b/bsps/include/xilinx_support/xil_exception.h
@@ -0,0 +1 @@
diff --git a/bsps/include/xilinx_support/xil_io.h b/bsps/include/xilinx_support/xil_io.h
index 0000000000..853ef6bc76
--- /dev/null
+++ b/bsps/include/xilinx_support/xil_io.h
@@ -0,0 +1,412 @@
+* @file xil_io.h
+* @addtogroup common_io_interfacing_apis Register IO interfacing APIs
+* The xil_io.h file contains the interface for the general I/O component, which
+* encapsulates the Input/Output functions for the processors that do not
+* require any special I/O handling.
+* <pre>
+* 6.00  mus      08/19/16 Remove checking of __LITTLE_ENDIAN__ flag for
+*                         ARM processors
+* 7.20  har      01/03/20 Added Xil_SecureOut32 for avoiding blindwrite for
+*                         CR-1049218
+* 7.30  kpt      09/21/20 Moved Xil_EndianSwap16 and Xil_EndianSwap32 to
+*                         xil_io.h and made them as static inline
+*       am       10/13/20 Changed the return type of Xil_SecureOut32 function
+*                         from u32 to int
+* 7.50  dp       02/12/21 Fix compilation error in Xil_EndianSwap32() that occur
+*                         when -Werror=conversion compiler flag is enabled
+* 7.5   mus      05/17/21 Update the functions with comments. It fixes CR#1067739.
+* </pre>
+#ifndef XIL_IO_H           /* prevent circular inclusions */
+#define XIL_IO_H           /* by using protection macros */
+#ifdef __cplusplus
+extern "C" {
+#endif
+#include "xil_printf.h"
+#include "xstatus.h"
+#if defined (__MICROBLAZE__)
+#else
+#include "xpseudo_asm.h"
+#endif
+#ifdef ENABLE_SAFETY
+extern u32 XStl_RegUpdate(u32 RegAddr, u32 RegVal);
+#endif
+#if defined __GNUC__
+#  define INST_SYNC		mbar(0)
+#  define DATA_SYNC		mbar(1)
+# else
+#  define SYNCHRONIZE_IO	dmb()
+#  define INST_SYNC		isb()
+#  define DATA_SYNC		dsb()
+# endif
+#else
+# define INST_SYNC
+# define DATA_SYNC
+# define INST_SYNC
+# define DATA_SYNC
+#endif
+#if defined (__GNUC__) || defined (__ICCARM__) || defined (__MICROBLAZE__)
+#define INLINE inline
+#else
+#define INLINE __inline
+#endif
+* @brief    Performs an input operation for a memory location by reading
+*           from the specified address and returning the 8 bit Value read from
+*            that address.
+* @param	Addr: contains the address to perform the input operation
+* @return	The 8 bit Value read from the specified input address.
+static INLINE u8 Xil_In8(UINTPTR Addr)
+	return *(volatile u8 *) Addr;
+* @brief    Performs an input operation for a memory location by reading from
+*           the specified address and returning the 16 bit Value read from that
+*           address.
+* @return	The 16 bit Value read from the specified input address.
+static INLINE u16 Xil_In16(UINTPTR Addr)
+	return *(volatile u16 *) Addr;
+*           reading from the specified address and returning the 32 bit Value
+*           read  from that address.
+* @return	The 32 bit Value read from the specified input address.
+static INLINE u32 Xil_In32(UINTPTR Addr)
+	return *(volatile u32 *) Addr;
+* @brief     Performs an input operation for a memory location by reading the
+*            64 bit Value read  from that address.
+* @return	The 64 bit Value read from the specified input address.
+static INLINE u64 Xil_In64(UINTPTR Addr)
+	return *(volatile u64 *) Addr;
+* @brief    Performs an output operation for an memory location by
+*           writing the 8 bit Value to the the specified address.
+* @param	Addr: contains the address to perform the output operation
+* @param	Value: contains the 8 bit Value to be written at the specified
+*           address.
+* @return	None.
+static INLINE void Xil_Out8(UINTPTR Addr, u8 Value)
+	/* write 8 bit value to specified address */
+	volatile u8 *LocalAddr = (volatile u8 *)Addr;
+	*LocalAddr = Value;
+* @brief    Performs an output operation for a memory location by writing the
+*            16 bit Value to the the specified address.
+* @param	Addr contains the address to perform the output operation
+* @param	Value contains the Value to be written at the specified address.
+* @return	None.
+static INLINE void Xil_Out16(UINTPTR Addr, u16 Value)
+	/* write 16 bit value to specified address */
+	volatile u16 *LocalAddr = (volatile u16 *)Addr;
+*           32 bit Value to the the specified address.
+* @param	Value contains the 32 bit Value to be written at the specified
+*           address.
+* @return	None.
+static INLINE void Xil_Out32(UINTPTR Addr, u32 Value)
+	/* write 32 bit value to specified address */
+#ifndef ENABLE_SAFETY
+	volatile u32 *LocalAddr = (volatile u32 *)Addr;
+#else
+	XStl_RegUpdate(Addr, Value);
+#endif
+*           64 bit Value to the the specified address.
+* @param	Value contains 64 bit Value to be written at the specified address.
+* @return	None.
+static INLINE void Xil_Out64(UINTPTR Addr, u64 Value)
+	/* write 64 bit value to specified address */
+	volatile u64 *LocalAddr = (volatile u64 *)Addr;
+ * @brief	Performs an output operation for a memory location by writing the
+ *       	32 bit Value to the the specified address and then reading it
+ *       	back to verify the value written in the register.
+ * @param	Addr contains the address to perform the output operation
+ * @param	Value contains 32 bit Value to be written at the specified address
+ * @return	Returns Status
+ *        	- XST_SUCCESS on success
+ *        	- XST_FAILURE on failure
+static INLINE int Xil_SecureOut32(UINTPTR Addr, u32 Value)
+	int Status = XST_FAILURE;
+	u32 ReadReg;
+	u32 ReadRegTemp;
+	/* writing 32 bit value to specified address */
+	Xil_Out32(Addr, Value);
+	/* verify value written to specified address with multiple reads */
+	ReadReg = Xil_In32(Addr);
+	ReadRegTemp = Xil_In32(Addr);
+	if( (ReadReg == Value) && (ReadRegTemp == Value) ) {
+		Status = XST_SUCCESS;
+	return Status;
+* @brief    Perform a 16-bit endian conversion.
+* @param	Data: 16 bit value to be converted
+* @return	16 bit Data with converted endianness
+static INLINE __attribute__((always_inline)) u16 Xil_EndianSwap16(u16 Data)
+	return (u16) (((Data & 0xFF00U) >> 8U) | ((Data & 0x00FFU) << 8U));
+* @brief    Perform a 32-bit endian conversion.
+* @param	Data: 32 bit value to be converted
+* @return	32 bit data with converted endianness
+static INLINE __attribute__((always_inline)) u32 Xil_EndianSwap32(u32 Data)
+	u16 LoWord;
+	u16 HiWord;
+	/* get each of the half words from the 32 bit word */
+	LoWord = (u16) (Data & 0x0000FFFFU);
+	HiWord = (u16) ((Data & 0xFFFF0000U) >> 16U);
+	/* byte swap each of the 16 bit half words */
+	LoWord = (u16)(((LoWord & 0xFF00U) >> 8U) | ((LoWord & 0x00FFU) << 8U));
+	HiWord = (u16)(((HiWord & 0xFF00U) >> 8U) | ((HiWord & 0x00FFU) << 8U));
+	/* swap the half words before returning the value */
+	return ((((u32)LoWord) << (u32)16U) | (u32)HiWord);
+#ifdef __LITTLE_ENDIAN__
+# define Xil_In16LE	Xil_In16
+# define Xil_In32LE	Xil_In32
+# define Xil_Out16LE	Xil_Out16
+# define Xil_Out32LE	Xil_Out32
+# define Xil_Htons	Xil_EndianSwap16
+# define Xil_Htonl	Xil_EndianSwap32
+# define Xil_Ntohs	Xil_EndianSwap16
+# define Xil_Ntohl	Xil_EndianSwap32
+# else
+# define Xil_In16BE	Xil_In16
+# define Xil_In32BE	Xil_In32
+# define Xil_Out16BE	Xil_Out16
+# define Xil_Out32BE	Xil_Out32
+# define Xil_Htons(Data) (Data)
+# define Xil_Htonl(Data) (Data)
+# define Xil_Ntohs(Data) (Data)
+# define Xil_Ntohl(Data) (Data)
+#endif
+#else
+#endif
+static INLINE u16 Xil_In16BE(UINTPTR Addr)
+#else
+static INLINE u16 Xil_In16LE(UINTPTR Addr)
+#endif
+#else
+#endif
+	u16 value = Xil_In16(Addr);
+	return Xil_EndianSwap16(value);
+static INLINE u32 Xil_In32BE(UINTPTR Addr)
+#else
+static INLINE u32 Xil_In32LE(UINTPTR Addr)
+#endif
+#else
+#endif
+	u32 value = Xil_In32(Addr);
+	return Xil_EndianSwap32(value);
+static INLINE void Xil_Out16BE(UINTPTR Addr, u16 Value)
+#else
+static INLINE void Xil_Out16LE(UINTPTR Addr, u16 Value)
+#endif
+#else
+#endif
+	Value = Xil_EndianSwap16(Value);
+	Xil_Out16(Addr, Value);
+static INLINE void Xil_Out32BE(UINTPTR Addr, u32 Value)
+#else
+static INLINE void Xil_Out32LE(UINTPTR Addr, u32 Value)
+#endif
+#else
+#endif
+	Value = Xil_EndianSwap32(Value);
+#ifdef __cplusplus
+#endif
+* @} End of "addtogroup common_io_interfacing_apis".
diff --git a/bsps/include/xilinx_support/xil_mem.h b/bsps/include/xilinx_support/xil_mem.h
new file mode 100644
index 0000000000..d6bc637a94
--- /dev/null
+++ b/bsps/include/xilinx_support/xil_mem.h
@@ -0,0 +1,47 @@
+* Copyright (c) 2015 - 2020 Xilinx, Inc.  All rights reserved.
+* SPDX-License-Identifier: MIT
+* @file xil_mem.h
+* @addtogroup common_mem_operation_api Customized APIs for Memory Operations
+* The xil_mem.h file contains prototype for functions related
+* to memory operations. These APIs are applicable for all processors supported
+* by Xilinx.
+* <pre>
+* MODIFICATION HISTORY:
+* Ver   Who      Date     Changes
+* 6.1   nsk      11/07/16 First release.
+* 7.0   mus      01/07/19 Add cpp extern macro
+* </pre>
+#ifndef XIL_MEM_H		/* prevent circular inclusions */
+#define XIL_MEM_H		/* by using protection macros */
+#ifdef __cplusplus
+extern "C" {
+#endif
+/************************** Function Prototypes *****************************/
+void Xil_MemCpy(void* dst, const void* src, u32 cnt);
+#ifdef __cplusplus
+#endif
+#endif /* XIL_MEM_H */
+* @} End of "addtogroup common_mem_operation_api".
\ No newline at end of file
diff --git a/bsps/include/xilinx_support/xil_printf.h b/bsps/include/xilinx_support/xil_printf.h
index 0000000000..462b7c50db
--- /dev/null
+++ b/bsps/include/xilinx_support/xil_printf.h
@@ -0,0 +1,44 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2022 On-Line Applications Research Corporation (OAR)
+ * are met:
+#ifndef XIL_PRINTF_H
+#define XIL_PRINTF_H
+#ifdef __cplusplus
+extern "C" {
+#endif
+#include <stdio.h>
+#define xil_printf(args...) printf(args)
+#define print(args...) printf(args)
+#ifdef __cplusplus
+#endif
+#endif	/* XIL_PRINTF_H */
diff --git a/bsps/include/xilinx_support/xil_smc.h b/bsps/include/xilinx_support/xil_smc.h
--- /dev/null
+++ b/bsps/include/xilinx_support/xil_smc.h
@@ -0,0 +1 @@
diff --git a/bsps/include/xilinx_support/xil_types.h b/bsps/include/xilinx_support/xil_types.h
index 0000000000..1d18bfbbca
--- /dev/null
+++ b/bsps/include/xilinx_support/xil_types.h
@@ -0,0 +1,203 @@
+* @file xil_types.h
+* @addtogroup common_types Basic Data types for Xilinx® Software IP
+* The xil_types.h file contains basic types for Xilinx software IP. These data types
+* are applicable for all processors supported by Xilinx.
+* <pre>
+* 3.03a sdm  05/30/11 Added Xuint64 typedef and XUINT64_MSW/XUINT64_LSW macros
+* 5.00 	pkp  05/29/14 Made changes for 64 bit architecture
+*	srt  07/14/14 Use standard definitions from stdint.h and stddef.h
+*		      Define LONG and ULONG datatypes and mask values
+* 7.00  mus  01/07/19 Add cpp extern macro
+* 7.1   aru  08/19/19 Shift the value in UPPER_32_BITS only if it
+*                     is 64-bit processor
+* </pre>
+ *@cond nocomments
+#ifndef XIL_TYPES_H	/* prevent circular inclusions */
+#define XIL_TYPES_H	/* by using protection macros */
+#ifdef __cplusplus
+extern "C" {
+#endif
+#ifndef TRUE
+#  define TRUE		1U
+#endif
+#ifndef FALSE
+#  define FALSE		0U
+#endif
+#ifndef NULL
+#define NULL		0U
+#endif
+#define XIL_COMPONENT_IS_READY     0x11111111U  /**< In device drivers, This macro will be
+                                                 assigend to "IsReady" member of driver
+												 instance to indicate that driver
+												 instance is initialized and ready to use. */
+#define XIL_COMPONENT_IS_STARTED   0x22222222U  /**< In device drivers, This macro will be assigend to
+                                                 "IsStarted" member of driver instance
+												 to indicate that driver instance is
+												 started and it can be enabled. */
+/* @name New types
+#ifndef __KERNEL__
+ * guarded against xbasic_types.h.
+typedef uint8_t u8;
+typedef uint16_t u16;
+typedef uint32_t u32;
+#define __XUINT64__
+typedef struct
+	u32 Upper;
+	u32 Lower;
+} Xuint64;
+* @brief    Return the most significant half of the 64 bit data type.
+* @param    x is the 64 bit word.
+* @return   The upper 32 bits of the 64 bit word.
+#define XUINT64_MSW(x) ((x).Upper)
+* @brief    Return the least significant half of the 64 bit data type.
+* @return   The lower 32 bits of the 64 bit word.
+#define XUINT64_LSW(x) ((x).Lower)
+#endif /* XBASIC_TYPES_H */
+ * xbasic_types.h does not typedef s* or u64
+typedef char char8;
+typedef int8_t s8;
+typedef int16_t s16;
+typedef int32_t s32;
+typedef int64_t s64;
+typedef uint64_t u64;
+typedef int sint32;
+typedef intptr_t INTPTR;
+typedef uintptr_t UINTPTR;
+typedef ptrdiff_t PTRDIFF;
+#if !defined(LONG) || !defined(ULONG)
+typedef long LONG;
+typedef unsigned long ULONG;
+#endif
+#define ULONG64_HI_MASK	0xFFFFFFFF00000000U
+#define ULONG64_LO_MASK	~ULONG64_HI_MASK
+#else
+#endif
+ * This data type defines an interrupt handler for a device.
+ * The argument points to the instance of the component
+typedef void (*XInterruptHandler) (void *InstancePtr);
+ * This data type defines an exception handler for a processor.
+typedef void (*XExceptionHandler) (void *InstancePtr);
+ * @brief  Returns 32-63 bits of a number.
+ * @param  n : Number being accessed.
+ * @return Bits 32-63 of number.
+ * @note    A basic shift-right of a 64- or 32-bit quantity.
+ *          Use this to suppress the "right shift count >= width of type"
+ *          warning when that quantity is 32-bits.
+#if defined (__aarch64__) || defined (__arch64__)
+#define UPPER_32_BITS(n) ((u32)(((n) >> 16) >> 16))
+#else
+#define UPPER_32_BITS(n) 0U
+#endif
+ * @brief  Returns 0-31 bits of a number
+ * @return Bits 0-31 of number
+#define LOWER_32_BITS(n) ((u32)(n))
+#ifndef TRUE
+#define TRUE		1U
+#endif
+#ifndef FALSE
+#define FALSE		0U
+#endif
+#ifndef NULL
+#define NULL		0U
+#endif
+#ifdef __cplusplus
+#endif
+ *@endcond
+* @} End of "addtogroup common_types".
diff --git a/bsps/include/xilinx_support/xparameters.h b/bsps/include/xilinx_support/xparameters.h
index 0000000000..b665810643
--- /dev/null
+++ b/bsps/include/xilinx_support/xparameters.h
@@ -0,0 +1,44 @@
+ * are met:
+#ifndef XPARAMETERS_H
+#define XPARAMETERS_H
+#ifdef __cplusplus
+extern "C" {
+#endif
+#include <bspopts.h>
+#define EL3 1
+#define EL1_NONSECURE 0
+#ifdef __cplusplus
+#endif
diff --git a/bsps/include/xilinx_support/xpseudo_asm_gcc.h b/bsps/include/xilinx_support/xpseudo_asm_gcc.h
index 0000000000..d986349072
--- /dev/null
+++ b/bsps/include/xilinx_support/xpseudo_asm_gcc.h
@@ -0,0 +1,240 @@
+* @file xpseudo_asm_gcc.h
+* This header file contains macros for using inline assembler code. It is
+* <pre>
+* 5.00 	pkp		 05/21/14 First release
+* 6.0   mus      07/27/16 Consolidated file for a53,a9 and r5 processors
+* 7.2   asa      04/03/20 Renamed the str macro to strw.
+* 7.2   dp       04/30/20 Added clobber "cc" to mtcpsr for aarch32 processors
+* </pre>
+ *@cond nocomments
+#ifndef XPSEUDO_ASM_GCC_H  /* prevent circular inclusions */
+#define XPSEUDO_ASM_GCC_H  /* by using protection macros */
+/***************************** Include Files ********************************/
+#include "xil_types.h"
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+/************************** Constant Definitions ****************************/
+/**************************** Type Definitions ******************************/
+/***************** Macros (Inline Functions) Definitions ********************/
+/* necessary for pre-processor */
+#define stringify(s)	tostring(s)
+#define tostring(s)	#s
+/* pseudo assembler instructions */
+#define mfcpsr()	({u32 rval = 0U; \
+			   asm volatile("mrs %0,  DAIF" : "=r" (rval));\
+			  rval;\
+#define mtcpsr(v) __asm__ __volatile__ ("msr DAIF, %0" : : "r" (v))
+#define cpsiei()	//__asm__ __volatile__("cpsie	i\n")
+#define cpsidi()	//__asm__ __volatile__("cpsid	i\n")
+#define cpsief()	//__asm__ __volatile__("cpsie	f\n")
+#define cpsidf()	//__asm__ __volatile__("cpsid	f\n")
+#define mtgpr(rn, v)	/*__asm__ __volatile__(\
+			  "mov r" stringify(rn) ", %0 \n"\
+			  : : "r" (v)\
+#define mfgpr(rn)	/*({u32 rval; \
+			  __asm__ __volatile__(\
+			    "mov %0,r" stringify(rn) "\n"\
+			    : "=r" (rval)\
+			  rval;\
+/* memory synchronization operations */
+/* Instruction Synchronization Barrier */
+#define isb() __asm__ __volatile__ ("isb sy")
+/* Data Synchronization Barrier */
+#define dsb() __asm__ __volatile__("dsb sy")
+/* Data Memory Barrier */
+#define dmb() __asm__ __volatile__("dmb sy")
+/* Memory Operations */
+#define ldr(adr)	({u64 rval; \
+			    "ldr	%0,[%1]"\
+			    : "=r" (rval) : "r" (adr)\
+			  rval;\
+#define mfelrel3() ({u64 rval = 0U; \
+                   asm volatile("mrs %0,  ELR_EL3" : "=r" (rval));\
+                  rval;\
+#define mtelrel3(v) __asm__ __volatile__ ("msr ELR_EL3, %0" : : "r" (v))
+#else
+			    "mrs	%0, cpsr\n"\
+			    : "=r" (rval)\
+			  rval;\
+#define mtcpsr(v)	__asm__ __volatile__(\
+			  "msr	cpsr,%0\n"\
+			  : : "r" (v) : "cc" \
+#define cpsiei()	__asm__ __volatile__("cpsie	i\n")
+#define cpsidi()	__asm__ __volatile__("cpsid	i\n")
+#define cpsief()	__asm__ __volatile__("cpsie	f\n")
+#define cpsidf()	__asm__ __volatile__("cpsid	f\n")
+#define mtgpr(rn, v)	__asm__ __volatile__(\
+			  : : "r" (v)\
+#define mfgpr(rn)	({u32 rval; \
+			    : "=r" (rval)\
+			  rval;\
+#define isb() __asm__ __volatile__ ("isb" : : : "memory")
+#define dsb() __asm__ __volatile__ ("dsb" : : : "memory")
+#define dmb() __asm__ __volatile__ ("dmb" : : : "memory")
+#define ldr(adr)	({u32 rval; \
+			    "ldr	%0,[%1]"\
+			  rval;\
+#endif
+#define ldrb(adr)	({u8 rval; \
+			    "ldrb	%0,[%1]"\
+			  rval;\
+#define strw(adr, val)	__asm__ __volatile__(\
+			  "str	%0,[%1]\n"\
+			  : : "r" (val), "r" (adr)\
+#define strb(adr, val)	__asm__ __volatile__(\
+			  "strb	%0,[%1]\n"\
+/* Count leading zeroes (clz) */
+#define clz(arg)	({u8 rval; \
+			    "clz	%0,%1"\
+			    : "=r" (rval) : "r" (arg)\
+			  rval;\
+#define mtcpdc(reg,val)	__asm__ __volatile__("dc " #reg ",%0"  : : "r" (val))
+#define mtcpic(reg,val)	__asm__ __volatile__("ic " #reg ",%0"  : : "r" (val))
+#define mtcpicall(reg)	__asm__ __volatile__("ic " #reg)
+#define mtcptlbi(reg)	__asm__ __volatile__("tlbi " #reg)
+#define mtcpat(reg,val)	__asm__ __volatile__("at " #reg ",%0"  : : "r" (val))
+/* CP15 operations */
+#define mfcp(reg)	({u64 rval = 0U;\
+			__asm__ __volatile__("mrs	%0, " #reg : "=r" (rval));\
+			rval;\
+#define mtcp(reg,val)	__asm__ __volatile__("msr " #reg ",%0"  : : "r" (val))
+#else
+#define mtcp(rn, v)	__asm__ __volatile__(\
+			 "mcr " rn "\n"\
+			 : : "r" (v)\
+#define mfcp(rn)	({u32 rval = 0U; \
+			   "mrc " rn "\n"\
+			   : "=r" (rval)\
+			 rval;\
+#endif
+/************************** Variable Definitions ****************************/
+#ifdef __cplusplus
+ *@endcond
+#endif /* XPSEUDO_ASM_GCC_H */
diff --git a/bsps/include/xilinx_support/xstatus.h b/bsps/include/xilinx_support/xstatus.h
index 0000000000..1e9e6fbffc
--- /dev/null
+++ b/bsps/include/xilinx_support/xstatus.h
@@ -0,0 +1,522 @@
+* Copyright (c) 2002 - 2021 Xilinx, Inc.  All rights reserved.
+* @file xstatus.h
+* @addtogroup common_status_codes Xilinx software status codes
+* The xstatus.h file contains the Xilinx software status codes.These codes are
+* used throughout the Xilinx device drivers.
+ *@cond nocomments
+#ifndef XSTATUS_H		/* prevent circular inclusions */
+#define XSTATUS_H		/* by using protection macros */
+#ifdef __cplusplus
+extern "C" {
+#endif
+#include "xil_assert.h"
+/*********************** Common statuses 0 - 500 *****************************/
+ at name Common Status Codes for All Device Drivers
+#define XST_SUCCESS                     0L
+#define XST_FAILURE                     1L
+#define XST_DEVICE_NOT_FOUND            2L
+#define XST_DEVICE_BLOCK_NOT_FOUND      3L
+#define XST_INVALID_VERSION             4L
+#define XST_DEVICE_IS_STARTED           5L
+#define XST_DEVICE_IS_STOPPED           6L
+#define XST_FIFO_ERROR                  7L	/*!< An error occurred during an
+						   operation with a FIFO such as
+						   an underrun or overrun, this
+						   error requires the device to
+						   be reset */
+#define XST_RESET_ERROR                 8L	/*!< An error occurred which requires
+						   the device to be reset */
+#define XST_DMA_ERROR                   9L	/*!< A DMA error occurred, this error
+						   typically requires the device
+						   using the DMA to be reset */
+#define XST_NOT_POLLED                  10L	/*!< The device is not configured for
+						   polled mode operation */
+#define XST_FIFO_NO_ROOM                11L	/*!< A FIFO did not have room to put
+						   the specified data into */
+#define XST_BUFFER_TOO_SMALL            12L	/*!< The buffer is not large enough
+						   to hold the expected data */
+#define XST_NO_DATA                     13L	/*!< There was no data available */
+#define XST_REGISTER_ERROR              14L	/*!< A register did not contain the
+						   expected value */
+#define XST_INVALID_PARAM               15L	/*!< An invalid parameter was passed
+						   into the function */
+#define XST_NOT_SGDMA                   16L	/*!< The device is not configured for
+						   scatter-gather DMA operation */
+#define XST_LOOPBACK_ERROR              17L	/*!< A loopback test failed */
+#define XST_NO_CALLBACK                 18L	/*!< A callback has not yet been
+						   registered */
+#define XST_NO_FEATURE                  19L	/*!< Device is not configured with
+						   the requested feature */
+#define XST_NOT_INTERRUPT               20L	/*!< Device is not configured for
+						   interrupt mode operation */
+#define XST_DEVICE_BUSY                 21L	/*!< Device is busy */
+#define XST_ERROR_COUNT_MAX             22L	/*!< The error counters of a device
+						   have maxed out */
+#define XST_IS_STARTED                  23L	/*!< Used when part of device is
+						   already started i.e.
+						   sub channel */
+#define XST_IS_STOPPED                  24L	/*!< Used when part of device is
+						   already stopped i.e.
+						   sub channel */
+#define XST_DATA_LOST                   26L	/*!< Driver defined error */
+#define XST_RECV_ERROR                  27L	/*!< Generic receive error */
+#define XST_SEND_ERROR                  28L	/*!< Generic transmit error */
+#define XST_NOT_ENABLED                 29L	/*!< A requested service is not
+						   available because it has not
+						   been enabled */
+#define XST_NO_ACCESS			30L	/* Generic access error */
+#define XST_TIMEOUT                     31L	/*!< Event timeout occurred */
+/***************** Utility Component statuses 401 - 500  *********************/
+ at name Utility Component Status Codes 401 - 500
+#define XST_MEMTEST_FAILED              401L	/*!< Memory test failed */
+/***************** Common Components statuses 501 - 1000 *********************/
+ at name Packet Fifo Status Codes 501 - 510
+/********************* Packet Fifo statuses 501 - 510 ************************/
+#define XST_PFIFO_LACK_OF_DATA          501L	/*!< Not enough data in FIFO   */
+#define XST_PFIFO_NO_ROOM               502L	/*!< Not enough room in FIFO   */
+#define XST_PFIFO_BAD_REG_VALUE         503L	/*!< Self test, a register value
+						   was invalid after reset */
+#define XST_PFIFO_ERROR                 504L	/*!< Generic packet FIFO error */
+#define XST_PFIFO_DEADLOCK              505L	/*!< Packet FIFO is reporting
+						 * empty and full simultaneously
+ at name DMA Status Codes 511 - 530
+/************************** DMA statuses 511 - 530 ***************************/
+#define XST_DMA_TRANSFER_ERROR          511L	/*!< Self test, DMA transfer
+						   failed */
+#define XST_DMA_RESET_REGISTER_ERROR    512L	/*!< Self test, a register value
+#define XST_DMA_SG_LIST_EMPTY           513L	/*!< Scatter gather list contains
+						   no buffer descriptors ready
+						   to be processed */
+#define XST_DMA_SG_IS_STARTED           514L	/*!< Scatter gather not stopped */
+#define XST_DMA_SG_IS_STOPPED           515L	/*!< Scatter gather not running */
+#define XST_DMA_SG_LIST_FULL            517L	/*!< All the buffer descriptors of
+						   the scatter gather list are
+						   being used */
+#define XST_DMA_SG_BD_LOCKED            518L	/*!< The scatter gather buffer
+						   descriptor which is to be
+						   copied over in the scatter
+						   list is locked */
+#define XST_DMA_SG_NOTHING_TO_COMMIT    519L	/*!< No buffer descriptors have been
+						   put into the scatter gather
+						   list to be committed */
+#define XST_DMA_SG_COUNT_EXCEEDED       521L	/*!< The packet count threshold
+						   specified was larger than the
+						   total # of buffer descriptors
+						   in the scatter gather list */
+#define XST_DMA_SG_LIST_EXISTS          522L	/*!< The scatter gather list has
+						   already been created */
+#define XST_DMA_SG_NO_LIST              523L	/*!< No scatter gather list has
+						   been created */
+#define XST_DMA_SG_BD_NOT_COMMITTED     524L	/*!< The buffer descriptor which was
+						   being started was not committed
+						   to the list */
+#define XST_DMA_SG_NO_DATA              525L	/*!< The buffer descriptor to start
+						   has already been used by the
+						   hardware so it can't be reused
+#define XST_DMA_SG_LIST_ERROR           526L	/*!< General purpose list access
+						   error */
+#define XST_DMA_BD_ERROR                527L	/*!< General buffer descriptor
+						   error */
+ at name IPIF Status Codes Codes 531 - 550
+/************************** IPIF statuses 531 - 550 ***************************/
+#define XST_IPIF_REG_WIDTH_ERROR        531L	/*!< An invalid register width
+						   was passed into the function */
+#define XST_IPIF_RESET_REGISTER_ERROR   532L	/*!< The value of a register at
+						   reset was not valid */
+#define XST_IPIF_DEVICE_STATUS_ERROR    533L	/*!< A write to the device interrupt
+						   status register did not read
+						   back correctly */
+#define XST_IPIF_DEVICE_ACK_ERROR       534L	/*!< The device interrupt status
+						   register did not reset when
+						   acked */
+#define XST_IPIF_DEVICE_ENABLE_ERROR    535L	/*!< The device interrupt enable
+						   register was not updated when
+						   other registers changed */
+#define XST_IPIF_IP_STATUS_ERROR        536L	/*!< A write to the IP interrupt
+						   back correctly */
+#define XST_IPIF_IP_ACK_ERROR           537L	/*!< The IP interrupt status register
+						   did not reset when acked */
+#define XST_IPIF_IP_ENABLE_ERROR        538L	/*!< IP interrupt enable register was
+						   not updated correctly when other
+						   registers changed */
+#define XST_IPIF_DEVICE_PENDING_ERROR   539L	/*!< The device interrupt pending
+						   register did not indicate the
+						   expected value */
+#define XST_IPIF_DEVICE_ID_ERROR        540L	/*!< The device interrupt ID register
+						   did not indicate the expected
+						   value */
+#define XST_IPIF_ERROR                  541L	/*!< Generic ipif error */
+/****************** Device specific statuses 1001 - 4095 *********************/
+ at name Ethernet Status Codes 1001 - 1050
+/********************* Ethernet statuses 1001 - 1050 *************************/
+#define XST_EMAC_MEMORY_SIZE_ERROR  1001L	/*!< Memory space is not big enough
+						 * to hold the minimum number of
+						 * buffers or descriptors */
+#define XST_EMAC_MEMORY_ALLOC_ERROR 1002L	/*!< Memory allocation failed */
+#define XST_EMAC_MII_READ_ERROR     1003L	/*!< MII read error */
+#define XST_EMAC_MII_BUSY           1004L	/*!< An MII operation is in progress */
+#define XST_EMAC_OUT_OF_BUFFERS     1005L	/*!< Driver is out of buffers */
+#define XST_EMAC_PARSE_ERROR        1006L	/*!< Invalid driver init string */
+#define XST_EMAC_COLLISION_ERROR    1007L	/*!< Excess deferral or late
+						 * collision on polled send */
+ at name UART Status Codes 1051 - 1075
+/*********************** UART statuses 1051 - 1075 ***************************/
+#define XST_UART
+#define XST_UART_INIT_ERROR         1051L
+#define XST_UART_START_ERROR        1052L
+#define XST_UART_CONFIG_ERROR       1053L
+#define XST_UART_TEST_FAIL          1054L
+#define XST_UART_BAUD_ERROR         1055L
+#define XST_UART_BAUD_RANGE         1056L
+ at name IIC Status Codes 1076 - 1100
+/************************ IIC statuses 1076 - 1100 ***************************/
+#define XST_IIC_SELFTEST_FAILED         1076	/*!< self test failed            */
+#define XST_IIC_BUS_BUSY                1077	/*!< bus found busy              */
+#define XST_IIC_GENERAL_CALL_ADDRESS    1078	/*!< mastersend attempted with   */
+					     /* general call address        */
+#define XST_IIC_STAND_REG_RESET_ERROR   1079	/*!< A non parameterizable reg   */
+					     /* value after reset not valid */
+#define XST_IIC_TX_FIFO_REG_RESET_ERROR 1080	/*!< Tx fifo included in design  */
+#define XST_IIC_RX_FIFO_REG_RESET_ERROR 1081	/*!< Rx fifo included in design  */
+#define XST_IIC_TBA_REG_RESET_ERROR     1082	/*!< 10 bit addr incl in design  */
+#define XST_IIC_CR_READBACK_ERROR       1083	/*!< Read of the control register */
+					     /* didn't return value written */
+#define XST_IIC_DTR_READBACK_ERROR      1084	/*!< Read of the data Tx reg     */
+#define XST_IIC_DRR_READBACK_ERROR      1085	/*!< Read of the data Receive reg */
+#define XST_IIC_ADR_READBACK_ERROR      1086	/*!< Read of the data Tx reg     */
+#define XST_IIC_TBA_READBACK_ERROR      1087	/*!< Read of the 10 bit addr reg */
+					     /* didn't return written value */
+#define XST_IIC_NOT_SLAVE               1088	/*!< The device isn't a slave    */
+#define XST_IIC_ARB_LOST 				1089 	/*!< Arbitration lost for master	*/
+ at name ATMC Status Codes 1101 - 1125
+/*********************** ATMC statuses 1101 - 1125 ***************************/
+#define XST_ATMC_ERROR_COUNT_MAX    1101L	/*!< the error counters in the ATM
+						   controller hit the max value
+						   which requires the statistics
+						   to be cleared */
+ at name Flash Status Codes 1126 - 1150
+/*********************** Flash statuses 1126 - 1150 **************************/
+#define XST_FLASH_BUSY                1126L	/*!< Flash is erasing or programming
+#define XST_FLASH_READY               1127L	/*!< Flash is ready for commands */
+#define XST_FLASH_ERROR               1128L	/*!< Flash had detected an internal
+						   error. Use XFlash_DeviceControl
+						   to retrieve device specific codes
+#define XST_FLASH_ERASE_SUSPENDED     1129L	/*!< Flash is in suspended erase state
+#define XST_FLASH_WRITE_SUSPENDED     1130L	/*!< Flash is in suspended write state
+#define XST_FLASH_PART_NOT_SUPPORTED  1131L	/*!< Flash type not supported by
+						   driver */
+#define XST_FLASH_NOT_SUPPORTED       1132L	/*!< Operation not supported */
+#define XST_FLASH_TOO_MANY_REGIONS    1133L	/*!< Too many erase regions */
+#define XST_FLASH_TIMEOUT_ERROR       1134L	/*!< Programming or erase operation
+						   aborted due to a timeout */
+#define XST_FLASH_ADDRESS_ERROR       1135L	/*!< Accessed flash outside its
+						   addressible range */
+#define XST_FLASH_ALIGNMENT_ERROR     1136L	/*!< Write alignment error */
+#define XST_FLASH_BLOCKING_CALL_ERROR 1137L	/*!< Couldn't return immediately from
+						   write/erase function with
+						   XFL_NON_BLOCKING_WRITE/ERASE
+						   option cleared */
+#define XST_FLASH_CFI_QUERY_ERROR     1138L	/*!< Failed to query the device */
+ at name SPI Status Codes 1151 - 1175
+/*********************** SPI statuses 1151 - 1175 ****************************/
+#define XST_SPI_MODE_FAULT          1151	/*!< master was selected as slave */
+#define XST_SPI_TRANSFER_DONE       1152	/*!< data transfer is complete */
+#define XST_SPI_TRANSMIT_UNDERRUN   1153	/*!< slave underruns transmit register */
+#define XST_SPI_RECEIVE_OVERRUN     1154	/*!< device overruns receive register */
+#define XST_SPI_NO_SLAVE            1155	/*!< no slave has been selected yet */
+#define XST_SPI_TOO_MANY_SLAVES     1156	/*!< more than one slave is being
+						 * selected */
+#define XST_SPI_NOT_MASTER          1157	/*!< operation is valid only as master */
+#define XST_SPI_SLAVE_ONLY          1158	/*!< device is configured as slave-only
+#define XST_SPI_SLAVE_MODE_FAULT    1159	/*!< slave was selected while disabled */
+#define XST_SPI_SLAVE_MODE          1160	/*!< device has been addressed as slave */
+#define XST_SPI_RECEIVE_NOT_EMPTY   1161	/*!< device received data in slave mode */
+#define XST_SPI_COMMAND_ERROR       1162	/*!< unrecognised command - qspi only */
+#define XST_SPI_POLL_DONE           1163        /*!< controller completed polling the
+						   device for status */
+ at name OPB Arbiter Status Codes 1176 - 1200
+/********************** OPB Arbiter statuses 1176 - 1200 *********************/
+#define XST_OPBARB_INVALID_PRIORITY  1176	/*!< the priority registers have either
+						 * one master assigned to two or more
+						 * priorities, or one master not
+						 * assigned to any priority
+#define XST_OPBARB_NOT_SUSPENDED     1177	/*!< an attempt was made to modify the
+						 * priority levels without first
+						 * suspending the use of priority
+						 * levels
+#define XST_OPBARB_PARK_NOT_ENABLED  1178	/*!< bus parking by id was enabled but
+						 * bus parking was not enabled
+#define XST_OPBARB_NOT_FIXED_PRIORITY 1179	/*!< the arbiter must be in fixed
+						 * priority mode to allow the
+						 * priorities to be changed
+ at name INTC Status Codes 1201 - 1225
+/************************ Intc statuses 1201 - 1225 **************************/
+#define XST_INTC_FAIL_SELFTEST      1201	/*!< self test failed */
+#define XST_INTC_CONNECT_ERROR      1202	/*!< interrupt already in use */
+ at name TmrCtr Status Codes 1226 - 1250
+/********************** TmrCtr statuses 1226 - 1250 **************************/
+#define XST_TMRCTR_TIMER_FAILED     1226	/*!< self test failed */
+ at name WdtTb Status Codes 1251 - 1275
+/********************** WdtTb statuses 1251 - 1275 ***************************/
+#define XST_WDTTB_TIMER_FAILED      1251L
+ at name PlbArb status Codes 1276 - 1300
+/********************** PlbArb statuses 1276 - 1300 **************************/
+#define XST_PLBARB_FAIL_SELFTEST    1276L
+ at name Plb2Opb Status Codes 1301 - 1325
+/********************** Plb2Opb statuses 1301 - 1325 *************************/
+#define XST_PLB2OPB_FAIL_SELFTEST   1301L
+ at name Opb2Plb Status 1326 - 1350
+/********************** Opb2Plb statuses 1326 - 1350 *************************/
+#define XST_OPB2PLB_FAIL_SELFTEST   1326L
+ at name SysAce Status Codes 1351 - 1360
+/********************** SysAce statuses 1351 - 1360 **************************/
+#define XST_SYSACE_NO_LOCK          1351L	/*!< No MPU lock has been granted */
+ at name PCI Bridge Status Codes 1361 - 1375
+/********************** PCI Bridge statuses 1361 - 1375 **********************/
+#define XST_PCI_INVALID_ADDRESS     1361L
+ at name FlexRay Constants 1400 - 1409
+/********************** FlexRay constants 1400 - 1409 *************************/
+#define XST_FR_TX_ERROR			1400
+#define XST_FR_TX_BUSY			1401
+#define XST_FR_BUF_LOCKED		1402
+#define XST_FR_NO_BUF			1403
+ at name USB constants 1410 - 1420
+/****************** USB constants 1410 - 1420  *******************************/
+#define XST_USB_ALREADY_CONFIGURED	1410
+#define XST_USB_BUF_ALIGN_ERROR		1411
+#define XST_USB_NO_DESC_AVAILABLE	1412
+#define XST_USB_BUF_TOO_BIG		1413
+#define XST_USB_NO_BUF			1414
+ at name HWICAP constants 1421 - 1429
+/****************** HWICAP constants 1421 - 1429  *****************************/
+#define XST_HWICAP_WRITE_DONE		1421
+ at name AXI VDMA constants 1430 - 1440
+/****************** AXI VDMA constants 1430 - 1440  *****************************/
+#define XST_VDMA_MISMATCH_ERROR		1430
+ at name NAND Flash Status Codes 1441 - 1459
+/*********************** NAND Flash statuses 1441 - 1459  *********************/
+#define XST_NAND_BUSY			1441L	/*!< Flash is erasing or
+						 * programming
+#define XST_NAND_READY			1442L	/*!< Flash is ready for commands
+#define XST_NAND_ERROR			1443L	/*!< Flash had detected an
+						 * internal error.
+#define XST_NAND_PART_NOT_SUPPORTED	1444L	/*!< Flash type not supported by
+						 * driver
+#define XST_NAND_OPT_NOT_SUPPORTED	1445L	/*!< Operation not supported
+#define XST_NAND_TIMEOUT_ERROR		1446L	/*!< Programming or erase
+						 * operation aborted due to a
+						 * timeout
+#define XST_NAND_ADDRESS_ERROR		1447L	/*!< Accessed flash outside its
+						 * addressible range
+#define XST_NAND_ALIGNMENT_ERROR	1448L	/*!< Write alignment error
+#define XST_NAND_PARAM_PAGE_ERROR	1449L	/*!< Failed to read parameter
+						 * page of the device
+#define XST_NAND_CACHE_ERROR		1450L	/*!< Flash page buffer error
+#define XST_NAND_WRITE_PROTECTED	1451L	/*!< Flash is write protected
+/**************************** Type Definitions *******************************/
+typedef s32 XStatus;
+/***************** Macros (Inline Functions) Definitions *********************/
+/************************** Function Prototypes ******************************/
+#ifdef __cplusplus
+#endif
+ *@endcond
+* @} End of "addtogroup common_status_codes".
diff --git a/bsps/shared/xilinx_support/xil_assert.c b/bsps/shared/xilinx_support/xil_assert.c
index 0000000000..b3dd7e9718
--- /dev/null
+++ b/bsps/shared/xilinx_support/xil_assert.c
@@ -0,0 +1,126 @@
+* Copyright (c) 2009 - 2021 Xilinx, Inc.  All rights reserved.
+* @file xil_assert.c
+* This file contains basic assert related functions for Xilinx software IP.
+* <pre>
+* 1.00a hbm  07/14/09 Initial release
+* </pre>
+/************************** Constant Definitions *****************************/
+/************************** Variable Definitions *****************************/
+ * @brief This variable allows testing to be done easier with asserts. An assert
+ * sets this variable such that a driver can evaluate this variable
+ * to determine if an assert occurred.
+u32 Xil_AssertStatus;
+ * @brief This variable allows the assert functionality to be changed for testing
+ * such that it does not wait infinitely. Use the debugger to disable the
+ * waiting during testing of asserts.
+s32 Xil_AssertWait = 1;
+/* The callback function to be invoked when an assert is taken */
+static Xil_AssertCallback Xil_AssertCallbackRoutine = NULL;
+* @brief    Implement assert. Currently, it calls a user-defined callback
+*           function if one has been set.  Then, it potentially enters an
+*           infinite loop depending on the value of the Xil_AssertWait
+*           variable.
+* @param    File: filename of the source
+* @param    Line: linenumber within File
+* @return   None.
+* @note     None.
+void Xil_Assert(const char8 *File, s32 Line)
+	/* if the callback has been set then invoke it */
+	if (Xil_AssertCallbackRoutine != 0) {
+		(*Xil_AssertCallbackRoutine)(File, Line);
+	/* if specified, wait indefinitely such that the assert will show up
+	 * in testing
+	while (Xil_AssertWait != 0) {
+* @brief    Set up a callback function to be invoked when an assert occurs.
+*           If a callback is already installed, then it will be replaced.
+* @param    Routine: callback to be invoked when an assert is taken
+* @return   None.
+* @note     This function has no effect if NDEBUG is set
+	Xil_AssertCallbackRoutine = Routine;
+* @brief    Null handler function. This follows the XInterruptHandler
+*           signature for interrupt handlers. It can be used to assign a null
+*           handler (a stub) to an interrupt controller vector table.
+* @param    NullParameter: arbitrary void pointer and not used.
+* @return   None.
+* @note     None.
+	(void) NullParameter;
diff --git a/bsps/shared/xilinx_support/xil_cache.c b/bsps/shared/xilinx_support/xil_cache.c
index 0000000000..01b5ba61e4
--- /dev/null
+++ b/bsps/shared/xilinx_support/xil_cache.c
@@ -0,0 +1,732 @@
+* Copyright (c) 2014 - 2021 Xilinx, Inc.  All rights reserved.
+* @file xil_cache.c
+* Contains required functions for the ARM cache functionality.
+* <pre>
+* 5.0 	pkp  05/29/14 First release
+* 5.5	pkp	 04/15/16 Updated the Xil_DCacheInvalidate,
+*					  Xil_DCacheInvalidateLine and Xil_DCacheInvalidateRange
+*					  functions description for proper explanation
+* 6.2   pkp	 01/22/17 Added support for EL1 non-secure
+* 6.2   asa  01/31/17 The existing Xil_DCacheDisable API first flushes the
+*					  D caches and then disables it. The problem with that is,
+*					  potentially there will be a small window after the cache
+*					  flush operation and before the we disable D caches where
+*					  we might have valid data in cache lines. In such a
+*					  scenario disabling the D cache can lead to unknown behavior.
+*					  The ideal solution to this is to use assembly code for
+*					  the complete API and avoid any memory accesses. But with
+*					  that we will end up having a huge amount on assembly code
+*					  which is not maintainable. Changes are done to use a mix
+*					  of assembly and C code. All local variables are put in
+*					  registers. Also function calls are avoided in the API to
+*					  avoid using stack memory.
+*					  These changes fix CR#966220.
+* 6.2  mus  02/13/17  The new api Xil_ConfigureL1Prefetch is added to disable pre-fetching/configure
+*                     the maximum number of outstanding data prefetches allowed in
+*                     L1 cache system.It fixes CR#967864.
+* 6.6  mus  02/27/18  Updated Xil_DCacheInvalidateRange and
+*					  Xil_ICacheInvalidateRange APIs to change the data type of
+*					  "cacheline" variable as "INTPTR", This change has been done
+*					  to avoid the truncation of upper DDR addresses to 32 bit.It
+*					  fixes CR#995581.
+* 6.6  mus  03/15/18  By default CPUACTLR_EL1 is accessible only from EL3, it
+*					  results into abort if accessed from EL1 non secure privilege
+*					  level. Updated Xil_ConfigureL1Prefetch function to access
+*					  CPUACTLR_EL1 only for EL3.
+* 6.8  mn   08/01/18  Optimize the Xil_DCacheInvalidateRange() function to remove
+*                     redundant operations
+* 6.8  asa  09/15/18  Fix bug in the Xil_DCacheInvalidateRange API introduced while
+*                     making optimizations in the previous patch. This change fixes
+*                     CR-1008926.
+* 7.0 mus  10/12/18  Updated Xil_DCacheInvalidateLine and Xil_DCacheInvalidateRange
+*                    APIs to replace IVAC instruction with CIVAC. So that, these
+*                    APIs will always do flush + invalidate in case of Cortexa53 as
+*                    well as Cortexa72 processor.
+* 7.1 mus  09/17/19  Xil_DCacheFlushRange and Xil_DCacheInvalidateRange are executing
+*                    same functionality (clean + validate). Removed
+*                    Xil_DCacheFlushRange function implementation and defined it as
+*                    macro. Xil_DCacheFlushRange macro points to the
+*                    Xil_DCacheInvalidateRange API to avoid code duplication.
+* </pre>
+#include "xil_cache.h"
+#include "xreg_cortexa53.h"
+#include "xil_exception.h"
+#include "bspconfig.h"
+#define IRQ_FIQ_MASK 0xC0U	/* Mask IRQ and FIQ interrupts in cpsr */
+* @brief	Enable the Data cache.
+* @return	None.
+void Xil_DCacheEnable(void)
+	u32 CtrlReg;
+	if (EL3 == 1) {
+		CtrlReg = mfcp(SCTLR_EL3);
+	} else if (EL1_NONSECURE == 1) {
+		CtrlReg = mfcp(SCTLR_EL1);
+	} else {
+		CtrlReg = 0U;
+	/* enable caches only if they are disabled */
+	if((CtrlReg & XREG_CONTROL_DCACHE_BIT) == 0X00000000U){
+		/* invalidate the Data cache */
+		Xil_DCacheInvalidate();
+		CtrlReg |= XREG_CONTROL_DCACHE_BIT;
+		if (EL3 == 1) {
+			/* enable the Data cache for el3*/
+			mtcp(SCTLR_EL3,CtrlReg);
+			/* enable the Data cache for el1*/
+			mtcp(SCTLR_EL1,CtrlReg);
+* @brief	Disable the Data cache.
+* @return	None.
+void Xil_DCacheDisable(void)
+	register u32 CsidReg;
+	register u32 C7Reg;
+	register u32 LineSize;
+	register u32 NumWays;
+	register u32 Way;
+	register u32 WayIndex;
+	register u32 WayAdjust;
+	register u32 Set;
+	register u32 SetIndex;
+	register u32 NumSet;
+	register u32 CacheLevel;
+	dsb();
+	asm(
+	"mov 	x0, #0\n\t"
+#if EL3==1
+	"mrs	x0, sctlr_el3 \n\t"
+	"and	w0, w0, #0xfffffffb\n\t"
+	"msr	sctlr_el3, x0\n\t"
+#elif EL1_NONSECURE==1
+	"mrs	x0, sctlr_el1 \n\t"
+	"msr	sctlr_el1, x0\n\t"
+#endif
+	"dsb sy\n\t"
+	/* Number of level of cache*/
+	CacheLevel = 0U;
+	/* Select cache level 0 and D cache in CSSR */
+	mtcp(CSSELR_EL1,CacheLevel);
+	isb();
+	CsidReg = mfcp(CCSIDR_EL1);
+	/* Get the cacheline size, way size, index size from csidr */
+	LineSize = (CsidReg & 0x00000007U) + 0x00000004U;
+	/* Number of Ways */
+	NumWays = (CsidReg & 0x00001FFFU) >> 3U;
+	NumWays += 0x00000001U;
+	/*Number of Set*/
+	NumSet = (CsidReg >> 13U) & 0x00007FFFU;
+	NumSet += 0x00000001U;
+	WayAdjust = clz(NumWays) - (u32)0x0000001FU;
+	Way = 0U;
+	Set = 0U;
+	/* Flush all the cachelines */
+	for (WayIndex = 0U; WayIndex < NumWays; WayIndex++) {
+		for (SetIndex = 0U; SetIndex < NumSet; SetIndex++) {
+			C7Reg = Way | Set | CacheLevel;
+			mtcpdc(CISW,C7Reg);
+			Set += (0x00000001U << LineSize);
+		Set = 0U;
+		Way += (0x00000001U << WayAdjust);
+	/* Wait for Flush to complete */
+	dsb();
+	/* Select cache level 1 and D cache in CSSR */
+	CacheLevel += (0x00000001U << 1U);
+	isb();
+	/* Number of Sets */
+	WayAdjust=clz(NumWays) - (u32)0x0000001FU;
+	Way = 0U;
+	Set = 0U;
+	for (WayIndex =0U; WayIndex < NumWays; WayIndex++) {
+		for (SetIndex =0U; SetIndex < NumSet; SetIndex++) {
+		Set=0U;
+		Way += (0x00000001U<<WayAdjust);
+	dsb();
+	asm(
+#if EL3==1
+		"tlbi 	ALLE3\n\t"
+		"tlbi 	VMALLE1\n\t"
+#endif
+		"dsb sy\r\n"
+		"isb\n\t"
+* @brief	Invalidate the Data cache. The contents present in the cache are
+* 			cleaned and invalidated.
+* @return	None.
+* @note		In Cortex-A53, functionality to simply invalid the cachelines
+*  			is not present. Such operations are a problem for an environment
+* 			that supports virtualisation. It would allow one OS to invalidate
+* 			a line belonging to another OS. This could lead to the other OS
+* 			crashing because of the loss of essential data. Hence, such
+* 			operations are promoted to clean and invalidate which avoids such
+*			corruption.
+void Xil_DCacheInvalidate(void)
+	register u32 CsidReg, C7Reg;
+	u32 LineSize, NumWays;
+	u32 Way, WayIndex,WayAdjust, Set, SetIndex, NumSet, CacheLevel;
+	u32 currmask;
+	currmask = mfcpsr();
+	mtcpsr(currmask | IRQ_FIQ_MASK);
+	CacheLevel=0U;
+	isb();
+	NumWays += 0X00000001U;
+	/*Number of Set*/
+	NumSet += 0X00000001U;
+	Way = 0U;
+	Set = 0U;
+	/* Invalidate all the cachelines */
+			mtcpdc(ISW,C7Reg);
+		Set = 0U;
+	/* Wait for invalidate to complete */
+	dsb();
+	CacheLevel += (0x00000001U<<1U) ;
+	isb();
+	Way = 0U;
+	Set = 0U;
+		Set = 0U;
+	dsb();
+	mtcpsr(currmask);
+* @brief	Invalidate a Data cache line. The cacheline is cleaned and
+*			invalidated.
+* @param	adr: 64bit address of the data to be flushed.
+* @return	None.
+*			corruption.
+void Xil_DCacheInvalidateLine(INTPTR adr)
+	u32 currmask;
+	mtcp(CSSELR_EL1,0x0);
+	mtcpdc(CIVAC,(adr & (~0x3F)));
+	dsb();
+	mtcp(CSSELR_EL1,0x2);
+	mtcpdc(IVAC,(adr & (~0x3F)));
+	dsb();
+	mtcpsr(currmask);
+* 			The cachelines present in the adderss range are cleaned and
+*			invalidated
+* @param	adr: 64bit start address of the range to be invalidated.
+* @param	len: Length of the range to be invalidated in bytes.
+* @return	None.
+*			corruption.
+void Xil_DCacheInvalidateRange(INTPTR  adr, INTPTR len)
+	const INTPTR cacheline = 64U;
+	INTPTR end = adr + len;
+	adr = adr & (~0x3F);
+	u32 currmask = mfcpsr();
+	if (len != 0U) {
+		while (adr < end) {
+			mtcpdc(CIVAC,adr);
+			adr += cacheline;
+	dsb();
+	mtcpsr(currmask);
+* @brief	Flush the Data cache.
+* @return	None.
+void Xil_DCacheFlush(void)
+	u32 currmask;
+	CacheLevel = 0U;
+	isb();
+	/*Number of Set*/
+	Way = 0U;
+	Set = 0U;
+		Set = 0U;
+	dsb();
+	isb();
+	Way = 0U;
+	Set = 0U;
+		Set=0U;
+	dsb();
+	mtcpsr(currmask);
+* @brief	Flush a Data cache line. If the byte specified by the address (adr)
+* 			is cached by the Data cache, the cacheline containing that byte is
+*			invalidated. If the cacheline is modified (dirty), the entire
+*			contents of the cacheline are written to system memory before the
+* 			line is invalidated.
+* @return	None.
+* @note		The bottom 6 bits are set to 0, forced by architecture.
+void Xil_DCacheFlushLine(INTPTR  adr)
+	u32 currmask;
+	/* Wait for flush to complete */
+	dsb();
+	dsb();
+	mtcpsr(currmask);
+* @return	None.
+void Xil_ICacheEnable(void)
+	u32 CtrlReg;
+	if (EL3 == 1) {
+	} else {
+		CtrlReg = 0U;
+	if((CtrlReg & XREG_CONTROL_ICACHE_BIT)==0x00000000U){
+		/* invalidate the instruction cache */
+		Xil_ICacheInvalidate();
+		CtrlReg |= XREG_CONTROL_ICACHE_BIT;
+		if (EL3 == 1) {
+			/* enable the instruction cache for el3*/
+			/* enable the instruction cache for el1*/
+* @brief	Disable the instruction cache.
+* @return	None.
+void Xil_ICacheDisable(void)
+	u32 CtrlReg;
+	if (EL3 == 1) {
+	} else {
+		CtrlReg = 0U;
+	CtrlReg &= ~(XREG_CONTROL_ICACHE_BIT);
+	if (EL3 == 1) {
+		/* disable the instruction cache */
+* @return	None.
+void Xil_ICacheInvalidate(void)
+	unsigned int currmask;
+	mtcp(CSSELR_EL1,0x1);
+	dsb();
+	mtcpicall(IALLU);
+	dsb();
+	mtcpsr(currmask);
+* @brief	Invalidate an instruction cache line. If the instruction specified
+*			by the parameter adr is cached by the instruction cache, the
+*			cacheline containing that instruction is invalidated.
+* @param	adr: 64bit address of the instruction to be invalidated.
+* @return	None.
+void Xil_ICacheInvalidateLine(INTPTR  adr)
+	u32 currmask;
+	/*Invalidate I Cache line*/
+	mtcpic(IVAU,adr & (~0x3F));
+	dsb();
+	mtcpsr(currmask);
+* 			If the instructions specified by the address range are cached by
+* 			the instrunction cache, the cachelines containing those
+*			instructions are invalidated.
+* @return	None.
+void Xil_ICacheInvalidateRange(INTPTR  adr, INTPTR len)
+	INTPTR end;
+	INTPTR tempadr = adr;
+	INTPTR tempend;
+	u32 currmask;
+	if (len != 0x00000000U) {
+		end = tempadr + len;
+		tempend = end;
+		tempadr &= ~(cacheline - 0x00000001U);
+		/* Select cache Level 0 I-cache in CSSR */
+		while (tempadr < tempend) {
+			tempadr += cacheline;
+/* Wait for invalidate to complete */
+	dsb();
+	mtcpsr(currmask);
+* @brief	Configure the maximum number of outstanding data prefetches
+*               allowed in L1 cache.
+* @param	num: maximum number of outstanding data prefetches allowed,
+*                    valid values are 0-7.
+* @return	None.
+* @note		This function is implemented only for EL3 privilege level.
+void Xil_ConfigureL1Prefetch (u8 num) {
+#if EL3
+       u64 val=0;
+       val= mfcp(S3_1_C15_C2_0 );
+       val &= ~(L1_DATA_PREFETCH_CONTROL_MASK);
+       val |=  (num << L1_DATA_PREFETCH_CONTROL_SHIFT);
+       mtcp(S3_1_C15_C2_0,val);
+#endif
diff --git a/bsps/shared/xilinx_support/xil_mem.c b/bsps/shared/xilinx_support/xil_mem.c
index 0000000000..44e7d9a0c4
--- /dev/null
+++ b/bsps/shared/xilinx_support/xil_mem.c
@@ -0,0 +1,70 @@
+* Copyright (c) 2015 - 2022 Xilinx, Inc.  All rights reserved.
+* @file xil_mem.c
+* This file contains xil mem copy function to use in case of word aligned
+* data copies.
+* <pre>
+* 7.7	sk	 01/10/22 Update Xil_MemCpy functions variables typecast
+* 			  from int to s32 to fix misra_c_2012_directive_4_6
+* 			  violations.
+* 7.7	sk	 01/10/22 Include xil_mem.h header file to fix Xil_MemCpy
+* 			  prototype misra_c_2012_rule_8_4 violation.
+* </pre>
+#include "xil_mem.h"
+/***************** Inline Functions Definitions ********************/
+* @brief       This  function copies memory from once location to other.
+* @param       dst: pointer pointing to destination memory
+* @param       src: pointer pointing to source memory
+* @param       cnt: 32 bit length of bytes to be copied
+	char *d = (char*)(void *)dst;
+	const char *s = src;
+	while (cnt >= sizeof (s32)) {
+		*(s32*)d = *(s32*)s;
+		d += sizeof (s32);
+		s += sizeof (s32);
+		cnt -= sizeof (s32);
+	while (cnt >= sizeof (u16)) {
+		*(u16*)d = *(u16*)s;
+		d += sizeof (u16);
+		s += sizeof (u16);
+		cnt -= sizeof (u16);
+	while ((cnt) > 0U){
+		*d = *s;
+		d += 1U;
+		s += 1U;
+		cnt -= 1U;
diff --git a/spec/build/bsps/objxilinxsupport.yml b/spec/build/bsps/objxilinxsupport.yml
index 0000000000..10320b38a9
--- /dev/null
+++ b/spec/build/bsps/objxilinxsupport.yml
@@ -0,0 +1,45 @@
+SPDX-License-Identifier: CC-BY-SA-5.0 OR BSD-2-Clause
+build-type: objects
+cflags: []
+copyrights:
+- Copyright (C) 2022 On-Line Applications Research (OAR)
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+- bsps/include/xilinx_support/
+- bsps/include/xilinx_support/${XIL_SUPPORT_PATH}/
+install:
+- destination: ${BSP_INCLUDEDIR}
+  source:
+  - bsps/include/xilinx_support/bspconfig.h
+  - bsps/include/xilinx_support/sleep.h
+  - bsps/include/xilinx_support/xbasic_types.h
+  - bsps/include/xilinx_support/xil_assert.h
+  - bsps/include/xilinx_support/xil_exception.h
+  - bsps/include/xilinx_support/xil_io.h
+  - bsps/include/xilinx_support/xil_mem.h
+  - bsps/include/xilinx_support/xil_printf.h
+  - bsps/include/xilinx_support/xil_smc.h
+  - bsps/include/xilinx_support/xil_types.h
+  - bsps/include/xilinx_support/xparameters.h
+  - bsps/include/xilinx_support/xpseudo_asm_gcc.h
+  - bsps/include/xilinx_support/xstatus.h
+links:
+- role: build-dependency
+  uid: objxilinxsupportmb
+  uid: objxilinxsupportr5
+  uid: objxilinxsupporta9
+  uid: objxilinxsupportilp32
+  uid: objxilinxsupportlp64
+  uid: optxilsupportpath
+source:
+- bsps/shared/xilinx_support/xil_cache.c
+- bsps/shared/xilinx_support/xil_assert.c
+- bsps/shared/xilinx_support/xil_mem.c
+type: build
diff --git a/spec/build/bsps/objxilinxsupporta9.yml b/spec/build/bsps/objxilinxsupporta9.yml
index 0000000000..4d86208f4c
--- /dev/null
+++ b/spec/build/bsps/objxilinxsupporta9.yml
@@ -0,0 +1,20 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+- bsps/arm/xilinx-zynq
+- bsps/arm/xilinx-zynqmp
+includes: []
+install:
+  source:
+  - bsps/include/xilinx_support/arm/cortexa9/xil_cache.h
+  - bsps/include/xilinx_support/arm/cortexa9/xpseudo_asm.h
+  - bsps/include/xilinx_support/arm/cortexa9/xreg_cortexa9.h
+links: []
+source: []
+type: build
diff --git a/spec/build/bsps/objxilinxsupportilp32.yml b/spec/build/bsps/objxilinxsupportilp32.yml
index 0000000000..96bd737a8f
--- /dev/null
+++ b/spec/build/bsps/objxilinxsupportilp32.yml
@@ -0,0 +1,20 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+- aarch64/xilinx_zynqmp_ilp32_qemu
+- aarch64/xilinx_zynqmp_ilp32_zu3eg
+includes: []
+install:
+  source:
+  - bsps/include/xilinx_support/arm/ARMv8/32bit/xil_cache.h
+  - bsps/include/xilinx_support/arm/ARMv8/32bit/xpseudo_asm.h
+  - bsps/include/xilinx_support/arm/ARMv8/32bit/xreg_cortexa53.h
+links: []
+source: []
+type: build
diff --git a/spec/build/bsps/objxilinxsupportlp64.yml b/spec/build/bsps/objxilinxsupportlp64.yml
index 0000000000..cf45a0efe0
--- /dev/null
+++ b/spec/build/bsps/objxilinxsupportlp64.yml
@@ -0,0 +1,22 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+- bsps/aarch64/xilinx_versal
+- aarch64/xilinx_zynqmp_lp64_cfc400x
+- aarch64/xilinx_zynqmp_lp64_qemu
+- aarch64/xilinx_zynqmp_lp64_zu3eg
+includes: []
+install:
+  source:
+  - bsps/include/xilinx_support/arm/ARMv8/64bit/xil_cache.h
+  - bsps/include/xilinx_support/arm/ARMv8/64bit/xpseudo_asm.h
+  - bsps/include/xilinx_support/arm/ARMv8/64bit/xreg_cortexa53.h
+links: []
+source: []
+type: build
diff --git a/spec/build/bsps/objxilinxsupportmb.yml b/spec/build/bsps/objxilinxsupportmb.yml
index 0000000000..d4294d3ecb
--- /dev/null
+++ b/spec/build/bsps/objxilinxsupportmb.yml
@@ -0,0 +1,17 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+- microblaze
+includes: []
+install:
+  source:
+  - bsps/include/xilinx_support/microblaze/xil_cache.h
+links: []
+source: []
+type: build
diff --git a/spec/build/bsps/objxilinxsupportr5.yml b/spec/build/bsps/objxilinxsupportr5.yml
index 0000000000..0045b65e81
--- /dev/null
+++ b/spec/build/bsps/objxilinxsupportr5.yml
@@ -0,0 +1,18 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: false
+includes: []
+install:
+  source:
+  - bsps/include/xilinx_support/arm/cortexr5/xil_cache.h
+  - bsps/include/xilinx_support/arm/cortexr5/xpseudo_asm.h
+  - bsps/include/xilinx_support/arm/cortexr5/xreg_cortexr5.h
+links: []
+source: []
+type: build
diff --git a/spec/build/bsps/optxilsupportpath.yml b/spec/build/bsps/optxilsupportpath.yml
index 0000000000..5ddf3d1cd5
--- /dev/null
+++ b/spec/build/bsps/optxilsupportpath.yml
@@ -0,0 +1,34 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+actions:
+- get-string: null
+- env-assign: null
+build-type: option
+copyrights:
+default: null
+default-by-variant:
+- value: arm/cortexr5
+  variants: []
+- value: microblaze
+  variants:
+  - bsps/microblaze/microblaze_fpga
+- value: arm/cortexa9
+  variants:
+  - bsps/arm/xilinx_zynq
+  - bsps/arm/xilinx_zynqmp
+- value: arm/ARMv8/32bit
+  variants:
+  - aarch64/xilinx_zynqmp_ilp32_qemu
+  - aarch64/xilinx_zynqmp_ilp32_zu3eg
+- value: arm/ARMv8/64bit
+  variants:
+  - bsps/aarch64/xilinx_versal
+  - aarch64/xilinx_zynqmp_lp64_cfc400x
+  - aarch64/xilinx_zynqmp_lp64_qemu
+  - aarch64/xilinx_zynqmp_lp64_zu3eg
+description: 'Set the Xilinx support path'
+enabled-by: true
+format: '{}'
+links: []
+name: XIL_SUPPORT_PATH
+type: build
2.30.2
