[PATCH 3/5] bsp/qoriq: Support message signaled interrupts
Sebastian Huber
Thu Dec 22 10:23:40 UTC 2022
bsps/powerpc/qoriq/include/bsp/irq.h | 48 ++++--
bsps/powerpc/qoriq/irq/irq.c | 233 +++++++++++++++++++++++++--
2 files changed, 255 insertions(+), 26 deletions(-)
diff --git a/bsps/powerpc/qoriq/include/bsp/irq.h b/bsps/powerpc/qoriq/include/bsp/irq.h
index 0f1581542e..8f73c6f3de 100644
--- a/bsps/powerpc/qoriq/include/bsp/irq.h
+++ b/bsps/powerpc/qoriq/include/bsp/irq.h
@@ -331,15 +331,15 @@ extern "C" {
-#define QORIQ_IRQ_MSI_BASE (QORIQ_IRQ_MI_7 + 1)
-#define QORIQ_IRQ_MSI_0 (QORIQ_IRQ_MSI_BASE + 0)
-#define QORIQ_IRQ_MSI_1 (QORIQ_IRQ_MSI_BASE + 1)
-#define QORIQ_IRQ_MSI_2 (QORIQ_IRQ_MSI_BASE + 2)
-#define QORIQ_IRQ_MSI_3 (QORIQ_IRQ_MSI_BASE + 3)
-#define QORIQ_IRQ_MSI_4 (QORIQ_IRQ_MSI_BASE + 4)
-#define QORIQ_IRQ_MSI_5 (QORIQ_IRQ_MSI_BASE + 5)
-#define QORIQ_IRQ_MSI_6 (QORIQ_IRQ_MSI_BASE + 6)
-#define QORIQ_IRQ_MSI_7 (QORIQ_IRQ_MSI_BASE + 7)
+#define QORIQ_IRQ_MSI_MULTIPLEX_BASE (QORIQ_IRQ_MI_7 + 1)
+#define QORIQ_IRQ_MSI_0 (QORIQ_IRQ_MSI_MULTIPLEX_BASE + 0)
+#define QORIQ_IRQ_MSI_1 (QORIQ_IRQ_MSI_MULTIPLEX_BASE + 1)
+#define QORIQ_IRQ_MSI_2 (QORIQ_IRQ_MSI_MULTIPLEX_BASE + 2)
+#define QORIQ_IRQ_MSI_3 (QORIQ_IRQ_MSI_MULTIPLEX_BASE + 3)
+#define QORIQ_IRQ_MSI_4 (QORIQ_IRQ_MSI_MULTIPLEX_BASE + 4)
+#define QORIQ_IRQ_MSI_5 (QORIQ_IRQ_MSI_MULTIPLEX_BASE + 5)
+#define QORIQ_IRQ_MSI_6 (QORIQ_IRQ_MSI_MULTIPLEX_BASE + 6)
+#define QORIQ_IRQ_MSI_7 (QORIQ_IRQ_MSI_MULTIPLEX_BASE + 7)
@@ -363,7 +363,25 @@ extern "C" {
#define QORIQ_IRQ_GT_B_2 (QORIQ_IRQ_GT_BASE + 6)
#define QORIQ_IRQ_GT_B_3 (QORIQ_IRQ_GT_BASE + 7)
-#define BSP_INTERRUPT_VECTOR_COUNT (QORIQ_IRQ_GT_B_3 + 1)
+#define QORIQ_INTERRUPT_SOURCE_COUNT (QORIQ_IRQ_GT_B_3 + 1)
+#define QORIQ_IS_INTERRUPT_SOURCE(vector) \
+ (((rtems_vector_number) (vector)) < QORIQ_INTERRUPT_SOURCE_COUNT)
+#define QORIQ_IRQ_MSI_BASE QORIQ_INTERRUPT_SOURCE_COUNT
+#define QORIQ_IRQ_MSI_COUNT 256
+#define QORIQ_IRQ_MSI_INDEX(vector) ((vector) - QORIQ_IRQ_MSI_BASE)
+#define QORIQ_IRQ_MSI_VECTOR(index) (QORIQ_IRQ_MSI_BASE + (index))
+#define QORIQ_IRQ_MSI_REGISTER(vector) (QORIQ_IRQ_MSI_INDEX(vector) / 32)
+#define QORIQ_IRQ_IS_MSI(vector) \
+ (QORIQ_IRQ_MSI_INDEX(vector) < QORIQ_IRQ_MSI_COUNT)
+#define BSP_INTERRUPT_VECTOR_COUNT QORIQ_IRQ_MSI_VECTOR(QORIQ_IRQ_MSI_COUNT)
@@ -403,6 +421,16 @@ rtems_status_code bsp_interrupt_get_affinity(
Processor_mask *affinity
+rtems_status_code qoriq_pic_msi_allocate(rtems_vector_number *vector);
+rtems_status_code qoriq_pic_msi_free(rtems_vector_number vector);
+rtems_status_code qoriq_pic_msi_map(
+ rtems_vector_number vector,
+ uint64_t *addr,
+ uint32_t *data
#ifdef __cplusplus
diff --git a/bsps/powerpc/qoriq/irq/irq.c b/bsps/powerpc/qoriq/irq/irq.c
index f33b7c24ae..81eb742b5d 100644
--- a/bsps/powerpc/qoriq/irq/irq.c
+++ b/bsps/powerpc/qoriq/irq/irq.c
@@ -34,6 +34,7 @@
#include <sys/param.h>
+#include <sys/bitset.h>
@@ -307,6 +308,10 @@ rtems_status_code qoriq_pic_set_priority(
rtems_status_code sc = RTEMS_SUCCESSFUL;
uint32_t old_vpr = 0;
+ if (QORIQ_IRQ_IS_MSI(vector)) {
+ return RTEMS_UNSATISFIED;
if (bsp_interrupt_is_valid_vector(vector)) {
volatile qoriq_pic_src_cfg *src_cfg = get_src_cfg(vector);
@@ -344,6 +349,10 @@ rtems_status_code bsp_interrupt_set_affinity(
src_cfg->dr = _Processor_mask_To_uint32_t(affinity, 0);
return RTEMS_SUCCESSFUL;
@@ -360,22 +369,34 @@ rtems_status_code bsp_interrupt_get_affinity(
_Processor_mask_From_uint32_t(affinity, src_cfg->dr, 0);
-static void pic_vector_enable(rtems_vector_number vector, uint32_t msk)
+static rtems_status_code pic_vector_set_mask(
+ uint32_t msk
volatile qoriq_pic_src_cfg *src_cfg;
rtems_interrupt_lock_context lock_context;
bsp_interrupt_assert(bsp_interrupt_is_valid_vector(vector));
rtems_interrupt_lock_acquire(&lock, &lock_context);
src_cfg->vpr = (src_cfg->vpr & ~VPR_MSK) | msk;
rtems_interrupt_lock_release(&lock, &lock_context);
+ return RTEMS_SUCCESSFUL;
rtems_status_code bsp_interrupt_get_attributes(
@@ -383,17 +404,25 @@ rtems_status_code bsp_interrupt_get_attributes(
rtems_interrupt_attributes *attributes
- bool vector_is_ipi = pic_is_ipi(vector);
+ bool is_ipi = pic_is_ipi(vector);
+ bool is_msi_x = QORIQ_IRQ_IS_MSI(vector);
attributes->is_maskable = true;
- attributes->can_enable = true;
- attributes->maybe_enable = true;
- attributes->can_disable = true;
- attributes->maybe_disable = true;
+ attributes->can_enable = !is_msi_x;
+ attributes->maybe_enable = !is_msi_x;
+ attributes->can_disable = !is_msi_x;
+ attributes->maybe_disable = !is_msi_x;
attributes->cleared_by_acknowledge = true;
- attributes->can_get_affinity = !vector_is_ipi;
- attributes->can_set_affinity = !vector_is_ipi;
- attributes->can_raise = vector_is_ipi;
- attributes->can_raise_on = vector_is_ipi;
+ attributes->can_get_affinity = !(is_ipi || is_msi_x);
+ attributes->can_set_affinity = !(is_ipi || is_msi_x);
+ attributes->can_raise = is_ipi;
+ attributes->can_raise_on = is_ipi;
+ if (is_msi_x) {
+ attributes->can_be_triggered_by_message = true;
+ attributes->trigger_signal = RTEMS_INTERRUPT_NO_SIGNAL;
@@ -407,6 +436,11 @@ rtems_status_code bsp_interrupt_is_pending(
bsp_interrupt_assert(pending != NULL);
+ *pending = false;
*pending = (src_cfg->vpr & VPR_A) != 0;
@@ -463,6 +497,10 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
bsp_interrupt_assert(enabled != NULL);
+ vector = QORIQ_IRQ_MSI_0 + QORIQ_IRQ_MSI_REGISTER(vector);
*enabled = (src_cfg->vpr & VPR_MSK) == 0;
@@ -470,14 +508,12 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector)
- pic_vector_enable(vector, 0);
- return RTEMS_SUCCESSFUL;
+ return pic_vector_set_mask(vector, 0);
rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
- pic_vector_enable(vector, VPR_MSK);
+ return pic_vector_set_mask(vector, VPR_MSK);
void bsp_interrupt_dispatch(uintptr_t exception_number)
@@ -529,7 +565,7 @@ void bsp_interrupt_facility_initialize(void)
pic_reset();
- for (i = 0; i < BSP_INTERRUPT_VECTOR_COUNT; ++i) {
+ for (i = 0; i < QORIQ_INTERRUPT_SOURCE_COUNT; ++i) {
volatile qoriq_pic_src_cfg *src_cfg = get_src_cfg(i);
src_cfg->vpr = VPR_MSK | VPR_P
@@ -555,11 +591,176 @@ void bsp_interrupt_facility_initialize(void)
qoriq.pic.ctpr = 0;
qoriq.pic.iack;
qoriq.pic.eoi = 0;
qoriq.pic.whoami;
+typedef __BITSET_DEFINE(pic_msi_bitset, QORIQ_IRQ_MSI_COUNT) pic_msi_bitset;
+static pic_msi_bitset pic_msi_available =
+ __BITSET_T_INITIALIZER(__BITSET_FSET(__bitset_words(QORIQ_IRQ_MSI_COUNT)));
+static uint32_t pic_msi_bitset_to_uint32_t(
+ const pic_msi_bitset *bitset,
+ uint32_t index
+ long bits = bitset->__bits[index / _BITSET_BITS];
+ return (uint32_t) (bits >> (32 * ((index % _BITSET_BITS) / 32)));
+static void pic_msi_dispatch(void *arg)
+ uintptr_t reg = (uintptr_t) arg;
+ uint32_t msir = qoriq.pic.msir[reg].reg;
+ while (msir != 0) {
+ uint32_t index = 31 - __builtin_clz(msir);
+ const rtems_interrupt_entry *entry;
+ msir &= ~(UINT32_C(1) << index);
+ entry = bsp_interrupt_entry_load_first(
+ QORIQ_IRQ_MSI_VECTOR(32 * reg + index)
+ if (entry != NULL) {
+ bsp_interrupt_dispatch_entries(entry);
+static rtems_status_code pic_msi_allocate(rtems_vector_number *vector)
+ pic_msi_bitset *available = &pic_msi_available;
+ long found = __BIT_FFS(QORIQ_IRQ_MSI_COUNT, available);
+ rtems_vector_number index;
+ uint32_t subset;
+ if (found == 0) {
+ index = (rtems_vector_number) found - 1;
+ subset = pic_msi_bitset_to_uint32_t(available, index);
+ if (subset == 0xffffffff) {
+ uintptr_t reg = index / 32;
+ rtems_status_code sc;
+ sc = rtems_interrupt_handler_install(
+ QORIQ_IRQ_MSI_0 + reg,
+ "MSI",
+ RTEMS_INTERRUPT_UNIQUE,
+ pic_msi_dispatch,
+ (void *) reg
+ if (sc != RTEMS_SUCCESSFUL) {
+ return sc;
+ __BIT_CLR(QORIQ_IRQ_MSI_COUNT, index, available);
+ *vector = QORIQ_IRQ_MSI_VECTOR(index);
+static rtems_status_code pic_msi_free(rtems_vector_number vector)
+ rtems_vector_number index = QORIQ_IRQ_MSI_INDEX(vector);
+ uint32_t subset;
+ if (__BIT_ISSET(QORIQ_IRQ_MSI_COUNT, index, available)) {
+ return RTEMS_NOT_DEFINED;
+ __BIT_SET(QORIQ_IRQ_MSI_COUNT, index, available);
+ return rtems_interrupt_handler_remove(
+ pic_msi_dispatch,
+ (void *) reg
+ if (!bsp_interrupt_is_initialized()) {
+ return RTEMS_INCORRECT_STATE;
+ if (vector == NULL) {
+ return RTEMS_INVALID_ADDRESS;
+ if (rtems_interrupt_is_in_progress()) {
+ return RTEMS_CALLED_FROM_ISR;
+ bsp_interrupt_lock();
+ sc = pic_msi_allocate(vector);
+ bsp_interrupt_unlock();
+ return sc;
+ if (!QORIQ_IRQ_IS_MSI(vector) ) {
+ return RTEMS_INVALID_ID;
+ sc = pic_msi_free(vector);
+ return sc;
+ uint64_t *addr,
+ uint32_t *data
+ if (addr == NULL) {
+ if (data == NULL) {
+ *addr = (uint64_t)(uintptr_t) &qoriq.pic.msiir;
+ *data = QORIQ_IRQ_MSI_INDEX(vector) << 24;
#endif /* QORIQ_IS_HYPERVISOR_GUEST */
2.35.3
