[PATCH] bsps: Move ZynqMP-specific info into the BSP
Kinsey Moore
kinsey.moore at oarcorp.com
Wed Dec 28 19:17:55 UTC 2022
The address of the nandpsu peripheral is specific to the ZynqMP SoC and
not relevant to other devices that might have one or more instances of
this peripheral.
bsps/aarch64/xilinx-zynqmp/include/bsp.h | 2 +
bsps/shared/dev/nand/xnandpsu_g.c | 47 ---------------
bsps/shared/dev/nand/xnandpsu_sinit.c | 70 ----------------------
spec/build/bsps/objnandpsu.yml | 6 --
spec/build/bsps/optnandpsu0baseaddress.yml | 18 ------
spec/build/bsps/optnandpsunuminstances.yml | 18 ------
6 files changed, 2 insertions(+), 159 deletions(-)
delete mode 100644 bsps/shared/dev/nand/xnandpsu_g.c
delete mode 100644 bsps/shared/dev/nand/xnandpsu_sinit.c
delete mode 100644 spec/build/bsps/optnandpsu0baseaddress.yml
delete mode 100644 spec/build/bsps/optnandpsunuminstances.yml
diff --git a/bsps/aarch64/xilinx-zynqmp/include/bsp.h b/bsps/aarch64/xilinx-zynqmp/include/bsp.h
index bb7df94fd1..572963af4c 100644
--- a/bsps/aarch64/xilinx-zynqmp/include/bsp.h
+++ b/bsps/aarch64/xilinx-zynqmp/include/bsp.h
@@ -67,6 +67,8 @@ extern "C" {
extern unsigned int zynqmp_dtb_len;
extern unsigned char zynqmp_dtb[];
+#define NANDPSU_BASEADDR 0xFF100000
* @brief Zynq UltraScale+ MPSoC specific set up of the MMU.
diff --git a/bsps/shared/dev/nand/xnandpsu_g.c b/bsps/shared/dev/nand/xnandpsu_g.c
deleted file mode 100644
index 2fb2a2a26e..0000000000
--- a/bsps/shared/dev/nand/xnandpsu_g.c
+++ /dev/null
@@ -1,47 +0,0 @@
-* Copyright (C) 2015 - 2022 Xilinx, Inc. All rights reserved.
-* SPDX-License-Identifier: MIT
-* @file xnandpsu_g.c
-* @addtogroup nandpsu_v1_10
-* This file contains a configuration table where each entry is a configuration
-* structure for an XNandPsu device in the system.
-* <pre>
-* MODIFICATION HISTORY:
-* Ver Who Date Changes
-* 1.0 nm 05/06/2014 First release
-* 1.0 nm 06/02/2014 Changed the copyright to new copyright
-* </pre>
-/***************************** Include Files ********************************/
-#include "xparameters.h"
-#include "xnandpsu.h"
-/************************** Constant Definitions ****************************/
-/**************************** Type Definitions ******************************/
-/***************** Macros (Inline Functions) Definitions ********************/
-/************************** Variable Definitions ****************************/
- * Each XNandPsu device in the system has an entry in this table.
-XNandPsu_Config XNandPsu_ConfigTable[] = {
- 0U,
- (u32)XPAR_XNANDPSU_0_BASEADDR
diff --git a/bsps/shared/dev/nand/xnandpsu_sinit.c b/bsps/shared/dev/nand/xnandpsu_sinit.c
index dd6b14ef10..0000000000
--- a/bsps/shared/dev/nand/xnandpsu_sinit.c
+++ /dev/null
@@ -1,70 +0,0 @@
-* @file xnandpsu_sinit.c
-* The implementation of the XNandPsu driver's static initialization
-* functionality.
-* <pre>
-* </pre>
-#include "xstatus.h"
-extern XNandPsu_Config XNandPsu_ConfigTable[];
-/************************** Function Prototypes *****************************/
-* Looks up the controller configuration based on the unique controller ID. A
-* table contains the configuration info for each controller in the system.
-* @param DevID is the ID of the controller to look up the
-* configuration for.
-* @return
-* A pointer to the configuration found or NULL if the specified
-* controller ID was not found.
-XNandPsu_Config *XNandPsu_LookupConfig(u16 DevID)
- XNandPsu_Config *CfgPtr = NULL;
- u32 Index;
- for (Index = 0U; Index < (u32)XPAR_XNANDPSU_NUM_INSTANCES; Index++) {
- if (XNandPsu_ConfigTable[Index].DeviceId == DevID) {
- CfgPtr = &XNandPsu_ConfigTable[Index];
- break;
- return (XNandPsu_Config *)CfgPtr;
diff --git a/spec/build/bsps/objnandpsu.yml b/spec/build/bsps/objnandpsu.yml
index 60dc8f67cc..ebed80326a 100644
--- a/spec/build/bsps/objnandpsu.yml
+++ b/spec/build/bsps/objnandpsu.yml
@@ -20,14 +20,8 @@ install:
links:
- role: build-dependency
uid: objxilinxsupport
-- role: build-dependency
- uid: optnandpsu0baseaddress
- uid: optnandpsunuminstances
source:
- bsps/shared/dev/nand/xnandpsu_bbm.c
- bsps/shared/dev/nand/xnandpsu.c
-- bsps/shared/dev/nand/xnandpsu_g.c
- bsps/shared/dev/nand/xnandpsu_onfi.c
-- bsps/shared/dev/nand/xnandpsu_sinit.c
type: build
diff --git a/spec/build/bsps/optnandpsu0baseaddress.yml b/spec/build/bsps/optnandpsu0baseaddress.yml
index 34668a39de..0000000000
--- a/spec/build/bsps/optnandpsu0baseaddress.yml
+++ /dev/null
@@ -1,18 +0,0 @@
-SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
-actions:
-- get-integer: null
-- assert-uint32: null
-- env-assign: null
-- format-and-define: null
-build-type: option
-copyrights:
-- Copyright (C) 2022 On-Line Applications Research Corporation (OAR)
-default: 0xFF100000
-default-by-variant: []
-description: |
- base address of NAND PSU 0
-enabled-by: true
-format: '{:#010x}'
-links: []
-name: XPAR_XNANDPSU_0_BASEADDR
-type: build
\ No newline at end of file
diff --git a/spec/build/bsps/optnandpsunuminstances.yml b/spec/build/bsps/optnandpsunuminstances.yml
index 4d8cfa6b05..0000000000
--- a/spec/build/bsps/optnandpsunuminstances.yml
+++ /dev/null
@@ -1,18 +0,0 @@
-actions:
-- env-assign: null
-build-type: option
-copyrights:
-default: 1
-description: |
- Number of nand instances
-enabled-by: true
-format: '{:#010x}'
-links: []
-name: XPAR_XNANDPSU_NUM_INSTANCES
-type: build
2.30.2
