[PATCH v1 2/5] cpukit/microblaze: Add debug vector and handler
Kinsey Moore kinsey.moore at oarcorp.com
Tue Feb 1 15:25:55 UTC 2022
This patch adds a vector for debug events along with a hook similar to
the exception framework. The debug vector generates an exception frame
for use by libdebugger.
 .../start/_debug_sw_break_handler.S           | 106 ++++++++++++++++++
 bsps/microblaze/shared/start/start.S          |   7 +-
 cpukit/score/cpu/microblaze/cpu.c             |  26 +++++
 .../cpu/microblaze/include/rtems/score/cpu.h  |   9 ++
 .../bsps/microblaze/microblaze_fpga/obj.yml   |   1 +
 5 files changed, 148 insertions(+), 1 deletion(-)
 create mode 100644 bsps/microblaze/microblaze_fpga/start/_debug_sw_break_handler.S
diff --git a/bsps/microblaze/microblaze_fpga/start/_debug_sw_break_handler.S b/bsps/microblaze/microblaze_fpga/start/_debug_sw_break_handler.S
new file mode 100644
index 0000000000..ebf69f6d53
--- /dev/null
+++ b/bsps/microblaze/microblaze_fpga/start/_debug_sw_break_handler.S
@@ -0,0 +1,106 @@
+ * @file
+ * @ingroup RTEMSBSPsMicroblaze
+ * @brief MicroBlaze debug trap handler implementation
+ * Copyright (C) 2022 On-Line Applications Research Corporation (OAR)
+ * are met:
+#include <rtems/score/cpu.h>
+	.text
+	.globl _debug_sw_break_handler    # HW Exception Handler Label
+	.extern _CPU_Debug_handle
+	.align 2
+	_debug_sw_break_handler:
+	/* The stack used here does not matter since debug cannot recurse */
+	/* Subtract exception frame */
+	addik r1, r1, -(CPU_EXCEPTION_FRAME_SIZE)
+	/* Store program state */
+	swi  r2, r1, MICROBLAZE_EXCEPTION_FRAME_R2
+	swi  r3, r1, MICROBLAZE_EXCEPTION_FRAME_R3
+	swi  r4, r1, MICROBLAZE_EXCEPTION_FRAME_R4
+	swi  r5, r1, MICROBLAZE_EXCEPTION_FRAME_R5
+	swi  r6, r1, MICROBLAZE_EXCEPTION_FRAME_R6
+	swi  r7, r1, MICROBLAZE_EXCEPTION_FRAME_R7
+	swi  r8, r1, MICROBLAZE_EXCEPTION_FRAME_R8
+	swi  r9, r1, MICROBLAZE_EXCEPTION_FRAME_R9
+	swi r10, r1, MICROBLAZE_EXCEPTION_FRAME_R10
+	swi r11, r1, MICROBLAZE_EXCEPTION_FRAME_R11
+	swi r12, r1, MICROBLAZE_EXCEPTION_FRAME_R12
+	swi r13, r1, MICROBLAZE_EXCEPTION_FRAME_R13
+	swi r14, r1, MICROBLAZE_EXCEPTION_FRAME_R14
+	swi r15, r1, MICROBLAZE_EXCEPTION_FRAME_R15
+	swi r16, r1, MICROBLAZE_EXCEPTION_FRAME_R16
+	swi r17, r1, MICROBLAZE_EXCEPTION_FRAME_R17
+	swi r18, r1, MICROBLAZE_EXCEPTION_FRAME_R18
+	swi r19, r1, MICROBLAZE_EXCEPTION_FRAME_R19
+	swi r20, r1, MICROBLAZE_EXCEPTION_FRAME_R20
+	swi r21, r1, MICROBLAZE_EXCEPTION_FRAME_R21
+	swi r22, r1, MICROBLAZE_EXCEPTION_FRAME_R22
+	swi r23, r1, MICROBLAZE_EXCEPTION_FRAME_R23
+	swi r24, r1, MICROBLAZE_EXCEPTION_FRAME_R24
+	swi r25, r1, MICROBLAZE_EXCEPTION_FRAME_R25
+	swi r26, r1, MICROBLAZE_EXCEPTION_FRAME_R26
+	swi r27, r1, MICROBLAZE_EXCEPTION_FRAME_R27
+	swi r28, r1, MICROBLAZE_EXCEPTION_FRAME_R28
+	swi r29, r1, MICROBLAZE_EXCEPTION_FRAME_R29
+	swi r30, r1, MICROBLAZE_EXCEPTION_FRAME_R30
+	swi r31, r1, MICROBLAZE_EXCEPTION_FRAME_R31
+	/* Retrieve and store MSR */
+	mfs r3, rmsr
+	swi r3, r1, MICROBLAZE_EXCEPTION_FRAME_MSR
+	/* Retrieve and store EAR */
+	mfs r3, rear
+	swi r3, r1, MICROBLAZE_EXCEPTION_FRAME_EAR
+	/* Retrieve and store ESR */
+	mfs r3, resr
+	swi r3, r1, MICROBLAZE_EXCEPTION_FRAME_ESR
+	/* Retrieve and store BTR */
+	mfs r3, rbtr
+	swi r3, r1, MICROBLAZE_EXCEPTION_FRAME_BTR
+	/* Calculate and store original stack pointer */
+	addik r3, r1, CPU_EXCEPTION_FRAME_SIZE
+	swi r3, r1, MICROBLAZE_EXCEPTION_FRAME_R1
+	/* set parameter 1 to CPU Exception frame */
+	addi r5, r1, 0
+	/* call into the debug framework */
+	braid _CPU_Debug_handle
+	nop
diff --git a/bsps/microblaze/shared/start/start.S b/bsps/microblaze/shared/start/start.S
index bd50fe0d24..e9aaa706e5 100644
--- a/bsps/microblaze/shared/start/start.S
+++ b/bsps/microblaze/shared/start/start.S
@@ -46,7 +46,7 @@
 		# 0x14 #				Hardware Interrupt          _interrupt_handler
 		# 0x18 #				(-- IMM --)
-		# 0x1C #				Breakpoint Exception        (-- Don't Care --)
+		# 0x1C #				Breakpoint Exception        _debug_sw_break_handler
 		# 0x20 #				(-- IMM --)
 		# 0x24 #				Hardware Exception          _hw_exception_handler
@@ -73,6 +73,11 @@ _vector_sw_exception:
 _vector_interrupt:
 	brai _interrupt_handler
+	.section .vectors.debug_sw_break, "ax"
+	.align 2
+_vector_debug_sw_break:
+	brai _debug_sw_break_handler
 	.section .vectors.hw_exception, "ax"
 	.align 2
 _vector_hw_exception:
diff --git a/cpukit/score/cpu/microblaze/cpu.c b/cpukit/score/cpu/microblaze/cpu.c
index 84b85c44e0..c75aa0f147 100644
--- a/cpukit/score/cpu/microblaze/cpu.c
+++ b/cpukit/score/cpu/microblaze/cpu.c
@@ -204,3 +204,29 @@ void _CPU_Exception_handle( CPU_Exception_frame *ef )
   rtems_fatal( RTEMS_FATAL_SOURCE_EXCEPTION, (rtems_fatal_code) ef );
+CPU_Exception_handler installed_debug_handler = NULL;
+void _CPU_Debug_install_handler(
+  CPU_Exception_handler  new_handler,
+  CPU_Exception_handler *old_handler
+  if ( old_handler != NULL ) {
+    *old_handler = installed_debug_handler;
+  installed_debug_handler = new_handler;
+void _CPU_Debug_handle( CPU_Exception_frame *ef )
+  /* BiP is not set for software debug events, set it here */
+  ef->msr |= MICROBLAZE_MSR_BIP;
+  if ( installed_debug_handler != NULL ) {
+    installed_debug_handler( ef );
+  rtems_fatal( RTEMS_FATAL_SOURCE_EXCEPTION, (rtems_fatal_code) ef );
diff --git a/cpukit/score/cpu/microblaze/include/rtems/score/cpu.h b/cpukit/score/cpu/microblaze/include/rtems/score/cpu.h
index 91839a18ab..37b6779481 100644
--- a/cpukit/score/cpu/microblaze/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/microblaze/include/rtems/score/cpu.h
@@ -344,6 +344,15 @@ void _CPU_Exception_handle(
+  CPU_Exception_frame *ef
 void _CPU_Context_switch(
   Context_Control  *run,
   Context_Control  *heir
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/obj.yml b/spec/build/bsps/microblaze/microblaze_fpga/obj.yml
index 0635a06f0c..f7e9bd7cc3 100644
--- a/spec/build/bsps/microblaze/microblaze_fpga/obj.yml
+++ b/spec/build/bsps/microblaze/microblaze_fpga/obj.yml
@@ -24,6 +24,7 @@ source:
 - bsps/microblaze/microblaze_fpga/console/console-io.c
 - bsps/microblaze/microblaze_fpga/console/debug-io.c
 - bsps/microblaze/microblaze_fpga/irq/irq.c
+- bsps/microblaze/microblaze_fpga/start/_debug_sw_break_handler.S
 - bsps/microblaze/microblaze_fpga/start/_exception_handler.S
 - bsps/microblaze/microblaze_fpga/start/_interrupt_handler.S
 - bsps/microblaze/microblaze_fpga/start/bspreset.c
2.30.2
