[PATCH v1 5/5] cpukit/microblaze: Simplify dispatch assembly
Kinsey Moore
kinsey.moore at oarcorp.com
Tue Feb 1 15:25:58 UTC 2022
The dispatch code was unnecessarily saving and restoring an extra
interrupt frame. This avoids the extra frame and folds the dispatch call
into a fallthrough to the interrupt frame restoration code.
cpukit/score/cpu/microblaze/cpu_asm.S | 48 ++-------------------------
1 file changed, 2 insertions(+), 46 deletions(-)
diff --git a/cpukit/score/cpu/microblaze/cpu_asm.S b/cpukit/score/cpu/microblaze/cpu_asm.S
index 62bb8075bd..e7861b5f91 100644
--- a/cpukit/score/cpu/microblaze/cpu_asm.S
+++ b/cpukit/score/cpu/microblaze/cpu_asm.S
@@ -118,9 +118,9 @@ after_stack_switch:
beqi r3, quick_exit
/* Return to interrupted thread and make it do a dispatch */
- addik r14, r0, thread_dispatch
- rtid r14, 0
+ bralid r15, _Thread_Dispatch
nop
+ /* Fall through to quick exit */
quick_exit:
/* Simple return from nested interrupt */
@@ -147,50 +147,6 @@ quick_exit:
rtid r14, 0
nop
-thread_dispatch:
- /* Reserve stack */
- addik r1, r1, -(CPU_INTERRUPT_FRAME_SIZE)
- /* Save scratch registers */
- swi r3, r1, MICROBLAZE_INTERRUPT_FRAME_R3
- swi r4, r1, MICROBLAZE_INTERRUPT_FRAME_R4
- swi r5, r1, MICROBLAZE_INTERRUPT_FRAME_R5
- swi r6, r1, MICROBLAZE_INTERRUPT_FRAME_R6
- swi r7, r1, MICROBLAZE_INTERRUPT_FRAME_R7
- swi r8, r1, MICROBLAZE_INTERRUPT_FRAME_R8
- swi r9, r1, MICROBLAZE_INTERRUPT_FRAME_R9
- swi r10, r1, MICROBLAZE_INTERRUPT_FRAME_R10
- swi r11, r1, MICROBLAZE_INTERRUPT_FRAME_R11
- swi r12, r1, MICROBLAZE_INTERRUPT_FRAME_R12
- swi r14, r1, MICROBLAZE_INTERRUPT_FRAME_R14
- swi r15, r1, MICROBLAZE_INTERRUPT_FRAME_R15
- swi r18, r1, MICROBLAZE_INTERRUPT_FRAME_R18
- mfs r3, rmsr
- swi r3, r1, MICROBLAZE_INTERRUPT_FRAME_RMS
- bralid r15, _Thread_Dispatch
- nop
- /* Restore scratch registers */
- lwi r3, r1, MICROBLAZE_INTERRUPT_FRAME_RMS
- mts rmsr, r3
- lwi r3, r1, MICROBLAZE_INTERRUPT_FRAME_R3
- lwi r4, r1, MICROBLAZE_INTERRUPT_FRAME_R4
- lwi r5, r1, MICROBLAZE_INTERRUPT_FRAME_R5
- lwi r6, r1, MICROBLAZE_INTERRUPT_FRAME_R6
- lwi r7, r1, MICROBLAZE_INTERRUPT_FRAME_R7
- lwi r8, r1, MICROBLAZE_INTERRUPT_FRAME_R8
- lwi r9, r1, MICROBLAZE_INTERRUPT_FRAME_R9
- lwi r10, r1, MICROBLAZE_INTERRUPT_FRAME_R10
- lwi r11, r1, MICROBLAZE_INTERRUPT_FRAME_R11
- lwi r12, r1, MICROBLAZE_INTERRUPT_FRAME_R12
- lwi r14, r1, MICROBLAZE_INTERRUPT_FRAME_R14
- lwi r15, r1, MICROBLAZE_INTERRUPT_FRAME_R15
- lwi r18, r1, MICROBLAZE_INTERRUPT_FRAME_R18
- /* Free stack space */
- addik r1, r1, CPU_INTERRUPT_FRAME_SIZE
- bri quick_exit
_CPU_Exception_dispatch_and_resume:
/* Subtract 1 from ISR_NEST_LEVEL */
lwi r3, r0, _Per_CPU_Information + 8
2.30.2
