[PATCH v2 2/5] cpukit/microblaze: Add debug vector and handler
Kinsey Moore
kinsey.moore at oarcorp.com
Wed Feb 2 19:15:17 UTC 2022
This patch adds a vector for debug events along with a hook similar to
the exception framework. The debug vector generates an exception frame
for use by libdebugger.
.../start/_debug_sw_break_handler.S | 106 ++++++++++++++++++
bsps/microblaze/shared/start/start.S | 7 +-
cpukit/score/cpu/microblaze/cpu.c | 26 +++++
.../cpu/microblaze/include/rtems/score/cpu.h | 9 ++
.../bsps/microblaze/microblaze_fpga/obj.yml | 1 +
5 files changed, 148 insertions(+), 1 deletion(-)
create mode 100644 bsps/microblaze/microblaze_fpga/start/_debug_sw_break_handler.S
diff --git a/bsps/microblaze/microblaze_fpga/start/_debug_sw_break_handler.S b/bsps/microblaze/microblaze_fpga/start/_debug_sw_break_handler.S
new file mode 100644
index 0000000000..872f488889
--- /dev/null
+++ b/bsps/microblaze/microblaze_fpga/start/_debug_sw_break_handler.S
@@ -0,0 +1,106 @@
+ * @file
+ * @ingroup RTEMSBSPsMicroBlaze
+ * @brief MicroBlaze debug trap handler implementation
+ * Copyright (C) 2022 On-Line Applications Research Corporation (OAR)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#include <rtems/score/cpu.h>
+ .text
+ .globl _debug_sw_break_handler # HW Exception Handler Label
+ .extern _MicroBlaze_Debug_handle
+ .align 2
+ _debug_sw_break_handler:
+ /* The stack used here does not matter since debug cannot recurse */
+ /* Subtract exception frame */
+ addik r1, r1, -(CPU_EXCEPTION_FRAME_SIZE)
+ /* Store program state */
+ swi r2, r1, MICROBLAZE_EXCEPTION_FRAME_R2
+ swi r3, r1, MICROBLAZE_EXCEPTION_FRAME_R3
+ swi r4, r1, MICROBLAZE_EXCEPTION_FRAME_R4
+ swi r5, r1, MICROBLAZE_EXCEPTION_FRAME_R5
+ swi r6, r1, MICROBLAZE_EXCEPTION_FRAME_R6
+ swi r7, r1, MICROBLAZE_EXCEPTION_FRAME_R7
+ swi r8, r1, MICROBLAZE_EXCEPTION_FRAME_R8
+ swi r9, r1, MICROBLAZE_EXCEPTION_FRAME_R9
+ swi r10, r1, MICROBLAZE_EXCEPTION_FRAME_R10
+ swi r11, r1, MICROBLAZE_EXCEPTION_FRAME_R11
+ swi r12, r1, MICROBLAZE_EXCEPTION_FRAME_R12
+ swi r13, r1, MICROBLAZE_EXCEPTION_FRAME_R13
+ swi r14, r1, MICROBLAZE_EXCEPTION_FRAME_R14
+ swi r15, r1, MICROBLAZE_EXCEPTION_FRAME_R15
+ swi r16, r1, MICROBLAZE_EXCEPTION_FRAME_R16
+ swi r17, r1, MICROBLAZE_EXCEPTION_FRAME_R17
+ swi r18, r1, MICROBLAZE_EXCEPTION_FRAME_R18
+ swi r19, r1, MICROBLAZE_EXCEPTION_FRAME_R19
+ swi r20, r1, MICROBLAZE_EXCEPTION_FRAME_R20
+ swi r21, r1, MICROBLAZE_EXCEPTION_FRAME_R21
+ swi r22, r1, MICROBLAZE_EXCEPTION_FRAME_R22
+ swi r23, r1, MICROBLAZE_EXCEPTION_FRAME_R23
+ swi r24, r1, MICROBLAZE_EXCEPTION_FRAME_R24
+ swi r25, r1, MICROBLAZE_EXCEPTION_FRAME_R25
+ swi r26, r1, MICROBLAZE_EXCEPTION_FRAME_R26
+ swi r27, r1, MICROBLAZE_EXCEPTION_FRAME_R27
+ swi r28, r1, MICROBLAZE_EXCEPTION_FRAME_R28
+ swi r29, r1, MICROBLAZE_EXCEPTION_FRAME_R29
+ swi r30, r1, MICROBLAZE_EXCEPTION_FRAME_R30
+ swi r31, r1, MICROBLAZE_EXCEPTION_FRAME_R31
+ /* Retrieve and store MSR */
+ mfs r3, rmsr
+ swi r3, r1, MICROBLAZE_EXCEPTION_FRAME_MSR
+ /* Retrieve and store EAR */
+ mfs r3, rear
+ swi r3, r1, MICROBLAZE_EXCEPTION_FRAME_EAR
+ /* Retrieve and store ESR */
+ mfs r3, resr
+ swi r3, r1, MICROBLAZE_EXCEPTION_FRAME_ESR
+ /* Retrieve and store BTR */
+ mfs r3, rbtr
+ swi r3, r1, MICROBLAZE_EXCEPTION_FRAME_BTR
+ /* Calculate and store original stack pointer */
+ addik r3, r1, CPU_EXCEPTION_FRAME_SIZE
+ swi r3, r1, MICROBLAZE_EXCEPTION_FRAME_R1
+ /* set parameter 1 to CPU Exception frame */
+ addi r5, r1, 0
+ /* call into the debug framework */
+ braid _MicroBlaze_Debug_handle
+ nop
diff --git a/bsps/microblaze/shared/start/start.S b/bsps/microblaze/shared/start/start.S
index bd50fe0d24..e9aaa706e5 100644
--- a/bsps/microblaze/shared/start/start.S
+++ b/bsps/microblaze/shared/start/start.S
@@ -46,7 +46,7 @@
# 0x14 # Hardware Interrupt _interrupt_handler
# 0x18 # (-- IMM --)
- # 0x1C # Breakpoint Exception (-- Don't Care --)
+ # 0x1C # Breakpoint Exception _debug_sw_break_handler
# 0x20 # (-- IMM --)
# 0x24 # Hardware Exception _hw_exception_handler
@@ -73,6 +73,11 @@ _vector_sw_exception:
_vector_interrupt:
brai _interrupt_handler
+ .section .vectors.debug_sw_break, "ax"
+ .align 2
+_vector_debug_sw_break:
+ brai _debug_sw_break_handler
.section .vectors.hw_exception, "ax"
.align 2
_vector_hw_exception:
diff --git a/cpukit/score/cpu/microblaze/cpu.c b/cpukit/score/cpu/microblaze/cpu.c
index 7ff8ca3071..fe55ef5546 100644
--- a/cpukit/score/cpu/microblaze/cpu.c
+++ b/cpukit/score/cpu/microblaze/cpu.c
@@ -203,3 +203,29 @@ void _MicroBlaze_Exception_handle( CPU_Exception_frame *ef )
rtems_fatal( RTEMS_FATAL_SOURCE_EXCEPTION, (rtems_fatal_code) ef );
+MicroBlaze_Exception_handler installed_debug_handler = NULL;
+void _MicroBlaze_Debug_install_handler(
+ MicroBlaze_Exception_handler new_handler,
+ MicroBlaze_Exception_handler *old_handler
+ if ( old_handler != NULL ) {
+ *old_handler = installed_debug_handler;
+ installed_debug_handler = new_handler;
+void _MicroBlaze_Debug_handle( CPU_Exception_frame *ef )
+ /* BiP is not set for software debug events, set it here */
+ ef->msr |= MICROBLAZE_MSR_BIP;
+ if ( installed_debug_handler != NULL ) {
+ installed_debug_handler( ef );
+ rtems_fatal( RTEMS_FATAL_SOURCE_EXCEPTION, (rtems_fatal_code) ef );
diff --git a/cpukit/score/cpu/microblaze/include/rtems/score/cpu.h b/cpukit/score/cpu/microblaze/include/rtems/score/cpu.h
index a9c5066399..fe0d9a8996 100644
--- a/cpukit/score/cpu/microblaze/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/microblaze/include/rtems/score/cpu.h
@@ -344,6 +344,15 @@ void _MicroBlaze_Exception_handle(
+ CPU_Exception_frame *ef
void _CPU_Context_switch(
Context_Control *run,
Context_Control *heir
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/obj.yml b/spec/build/bsps/microblaze/microblaze_fpga/obj.yml
index 0757fe2d53..37096cdc84 100644
--- a/spec/build/bsps/microblaze/microblaze_fpga/obj.yml
+++ b/spec/build/bsps/microblaze/microblaze_fpga/obj.yml
@@ -25,6 +25,7 @@ source:
- bsps/microblaze/microblaze_fpga/console/debug-io.c
- bsps/microblaze/microblaze_fpga/fdt/bsp_fdt.c
- bsps/microblaze/microblaze_fpga/irq/irq.c
+- bsps/microblaze/microblaze_fpga/start/_debug_sw_break_handler.S
- bsps/microblaze/microblaze_fpga/start/_exception_handler.S
- bsps/microblaze/microblaze_fpga/start/_interrupt_handler.S
- bsps/microblaze/microblaze_fpga/start/bspreset.c
2.30.2
