[PATCH] microblaze: Change fdt code license to BSD 2-Clause
Alex White
alex.white at oarcorp.com
Wed Feb 2 17:04:21 UTC 2022
bsps/microblaze/microblaze_fpga/fdt/bsp_fdt.c | 28 +++++++++++++++----
1 file changed, 23 insertions(+), 5 deletions(-)
diff --git a/bsps/microblaze/microblaze_fpga/fdt/bsp_fdt.c b/bsps/microblaze/microblaze_fpga/fdt/bsp_fdt.c
index 2b766ece0c..4725af40e0 100644
--- a/bsps/microblaze/microblaze_fpga/fdt/bsp_fdt.c
+++ b/bsps/microblaze/microblaze_fpga/fdt/bsp_fdt.c
@@ -1,10 +1,28 @@
- * COPYRIGHT (c) 2021.
- * On-Line Applications Research Corporation (OAR).
+ * Copyright (C) 2021 On-Line Applications Research Corporation (OAR)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
#include <bsp.h>
2.30.2
