Update of STM32h7 BSP HAL.
Karel Gardas karel at functional.vision
Sun Feb 6 22:24:30 UTC 2022
On 1/17/22 9:11 AM, Sebastian Huber wrote:
> On 16/01/2022 21:59, Karel Gardas wrote:
>> I think that the most clean merge may simply replace all HAL files with
>> a new version and then try to apply all accumulated RTEMS changes on top
>> of those and hope nothing breaks in current support. I tested simply
>> just replacing files and when doing git diff -b to ignore line endings
>> changes the resulting diff was ~117k lines long. I'm afraid even if I
>> try to do that job myself I would not be able to push that to you
>> thorough the mailing list limits, would I?
> You publish your changes in a github repository. I can pick up the
> patches from it an push them to the RTEMS repository.
Done! Thanks for review. See #4580.
