AW: [PATCH 4/4] kern_ntptime: sys_ntp_adjtime() does not return error when modes is 0 or MOD_TAI
Mon Feb 7 13:25:05 UTC 2022
On 04/02/2022 09:12, Gabriel.Moyano at dlr.de wrote:
>> What is the reason for this patch?
> This change is something I would like to have a second opinion. So, thanks for the question.
> Originally at the end of sys_ntp_adjtime(), if the function copyout() doesn't return an error, the value returned by ntp_is_time_error(), which variable name is retval, is saved in td->td_retval[0]. Chris modified this, being retval saved in the variable error, which is the one returned by sys_ntp_adjtime().
In libbsd, copyout() is just a memcpy() which returns 0.
> Under some situations, ntp_adjtime() is called with modes = 0 just for retrieving some values (for example herehttps://github.com/ptpd/ptpd/blob/master/src/dep/sys.c#L2036, please notice that here adjtimex() is ntp_adjtime()). In those cases, returning retval may not be meaningful. Other similar situation happens when mode is MOD_TAI (https://github.com/ptpd/ptpd/blob/master/src/dep/sys.c#L2070).
> This is more or less the reason. If there is better way to solve this, is welcome.
I don't think the changes make sense. The td->td_retval[0] is the return
value of the system call if it is successful.  The "error" indicates if
the system call was successful (== 0), otherwise it returns -1 with
errno set to "error".
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
