[PATCH 0/4] NTP support (master)
Sebastian Huber
Mon Feb 7 14:12:34 UTC 2022
Hello Gabriel,
I reviewed the patch set and the kern_ntptime.c. Changes in FreeBSD in
kern_ntptime.c are infrequently. The module is pretty self contained. I
suggest to import this file into the RTEMS sources due to the coupling
with kern_tc.c which is already present in RTEMS.
The ntp_update_second() is called by _Timecounter_Windup() under
protection of the _Timecounter_Lock. I don't think we need the extra
ntp_lock.
I will work on a patch which includes the current kern_ntptime.c to
RTEMS. It should be ready by end of next week.
Do you have plans to enable the PPS_SYNC option?
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
