[PATCH rtems-release] Add termios changes to rtems-notes-5
Christian MAUDERER christian.mauderer at embedded-brains.de
Tue Feb 8 14:04:40 UTC 2022
Hello Joel,
Am 08.02.22 um 14:59 schrieb Joel Sherrill:
> Looks good to me.
Thanks.
> Is there anything in the bsp.and device drivers guide about this?
I haven't found anything about the line discipline or about the l_start
function in the docs. rtems_termios_tty is mentioned in three examples
in the BSP howto. But it's only used as an anonymous pointer so the
fields of the structure are not relevant.
> On Tue, Feb 8, 2022, 6:54 AM Christian Mauderer
> <christian.mauderer at embedded-brains.de
> <mailto:christian.mauderer at embedded-brains.de>> wrote:
>     Update #4494
>     This adds a paragraph to the release notes like discussed here:
>     https://lists.rtems.org/pipermail/devel/2022-February/070455.html
>     <https://lists.rtems.org/pipermail/devel/2022-February/070455.html>
>     Is that OK. Should I add more details?
>       rtems-notes-5.txt | 8 ++++++++
>       1 file changed, 8 insertions(+)
>     diff --git a/rtems-notes-5.txt b/rtems-notes-5.txt
>     index 96dc151..1d9cb43 100644
>     --- a/rtems-notes-5.txt
>     +++ b/rtems-notes-5.txt
>     @@ -2,6 +2,14 @@
>       ### API Changes
>     +* Termios
>     +  * `txTaskCharsDequeued` has been added to `struct
>     rtems_termios_tty`. With
>     +    that the size of the structure changed. Libraries and
>     applications that use
>     +    the structure should be recompiled.
>     +  * The `l_start` line discipline function now receives the number
>     of characters
>     +    that have been sent. It is save to ignore the extra parameter for
>     +    applications that don't need it.
>       #### API Additions
>       * NTP support
>     2.31.1
>     _______________________________________________
>     devel mailing list
>     devel at rtems.org <mailto:devel at rtems.org>
>     http://lists.rtems.org/mailman/listinfo/devel
>     <http://lists.rtems.org/mailman/listinfo/devel>
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 18
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
