[PATCH 2/2] kern_ntptime.c: Port to RTEMS
Sebastian Huber
Tue Feb 8 15:16:22 UTC 2022
Remove previous adjtime() implementation.
Update #2348.
cpukit/include/rtems/score/timecounter.h | 9 ++
cpukit/include/sys/timex.h | 4 +-
cpukit/posix/src/adjtime.c | 93 ---------------
cpukit/score/src/kern_ntptime.c | 138 ++++++++++++++++++++++
cpukit/score/src/kern_tc.c | 6 +-
spec/build/cpukit/librtemscpu.yml | 2 +-
spec/build/testsuites/sptests/grp.yml | 2 +
spec/build/testsuites/sptests/spntp01.yml | 19 +++
testsuites/psxtests/psxtime/test.c | 10 +-
testsuites/sptests/spntp01/init.c | 111 +++++++++++++++++
10 files changed, 289 insertions(+), 105 deletions(-)
delete mode 100644 cpukit/posix/src/adjtime.c
create mode 100644 spec/build/testsuites/sptests/spntp01.yml
create mode 100644 testsuites/sptests/spntp01/init.c
diff --git a/cpukit/include/rtems/score/timecounter.h b/cpukit/include/rtems/score/timecounter.h
index 39f0dc353e..954da65676 100644
--- a/cpukit/include/rtems/score/timecounter.h
+++ b/cpukit/include/rtems/score/timecounter.h
@@ -270,6 +270,15 @@ void _Timecounter_Set_NTP_update_second(
Timecounter_NTP_update_second handler
+ * @brief Updates the time adjustment and seconds according to the NTP state.
+ * @param[in, out] adjustment is the NTP time adjustment.
+ * @param[in, out] newsec is the number of seconds since Unix epoch.
+void _Timecounter_NTP_update_second(int64_t *adjustment, time_t *newsec);
#ifdef __cplusplus
diff --git a/cpukit/include/sys/timex.h b/cpukit/include/sys/timex.h
index d2d2012ff5..8e763bb30f 100644
--- a/cpukit/include/sys/timex.h
+++ b/cpukit/include/sys/timex.h
@@ -37,7 +37,7 @@
#define NTP_API 4 /* NTP API version */
-#ifdef __FreeBSD__
+#if defined(__FreeBSD__) || defined(__rtems__)
#include <sys/_timespec.h>
#endif /* __FreeBSD__ */
@@ -153,7 +153,7 @@ struct timex {
long stbcnt; /* stability limit exceeded (ro) */
-#ifdef __FreeBSD__
#ifdef _KERNEL
void ntp_update_second(int64_t *adjustment, time_t *newsec);
diff --git a/cpukit/posix/src/adjtime.c b/cpukit/posix/src/adjtime.c
deleted file mode 100644
index ec8cb19a2e..0000000000
--- a/cpukit/posix/src/adjtime.c
+++ /dev/null
@@ -1,93 +0,0 @@
- * @file
- * @brief Adjust the Time to Synchronize the System Clock
- * @ingroup POSIXAPI
- * COPYRIGHT (c) 1989-2014.
- * On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-#ifdef HAVE_CONFIG_H
-#include "config.h"
-#endif
-#define _BSD_SOURCE
-#include <time.h>
-#include <sys/time.h>
-#include <errno.h>
-#include <rtems/score/timespec.h>
-#include <rtems/score/threaddispatch.h>
-#include <rtems/score/todimpl.h>
-#include <rtems/config.h>
-#include <rtems/seterr.h>
- * This method was initially added as part of porting NTP to RTEMS.
- * It is a BSD compatability function and now is available on
- * GNU/Linux.
- * At one point there was a static variable named adjustment
- * used by this implementation. I don't see any reason for it
- * to be here based upon the GNU/Linux documentation.
-int adjtime(
- const struct timeval *delta,
- struct timeval *olddelta
- struct timespec delta_as_timespec;
- Status_Control status;
- * Simple validations
- if ( !delta )
- rtems_set_errno_and_return_minus_one( EINVAL );
- if ( delta->tv_usec >= TOD_MICROSECONDS_PER_SECOND )
- * An adjustment of zero is pretty easy.
- if ( delta->tv_sec == 0 && delta->tv_usec == 0 )
- return 0;
- * Currently, RTEMS does the adjustment in one movement so there
- * is no way an adjustment was currently underway.
- * Given interest, requirements, and sponsorship, a future
- * enhancement would be to adjust the time in smaller increments
- * at each clock tick. Until then, there is no outstanding
- * adjustment.
- if ( olddelta ) {
- olddelta->tv_sec = 0;
- olddelta->tv_usec = 0;
- * convert delta timeval to timespec
- delta_as_timespec.tv_sec = delta->tv_sec;
- delta_as_timespec.tv_nsec = delta->tv_usec * 1000;
- * Now apply the adjustment
- status = _TOD_Adjust( &delta_as_timespec );
- if ( status != STATUS_SUCCESSFUL ) {
- rtems_set_errno_and_return_minus_one( STATUS_GET_POSIX( status ) );
- return 0;
diff --git a/cpukit/score/src/kern_ntptime.c b/cpukit/score/src/kern_ntptime.c
index 96f14a408b..cb39133408 100644
--- a/cpukit/score/src/kern_ntptime.c
+++ b/cpukit/score/src/kern_ntptime.c
@@ -1,3 +1,12 @@
+ * @file
+ * @ingroup RTEMSScoreTimecounter
+ * @brief This source file contains the implementation of ntp_gettime(),
+ * ntp_adjtime(), adjtime(), and _Timecounter_NTP_update_second().
@@ -36,6 +45,7 @@ __FBSDID("$FreeBSD$");
#include "opt_ntp.h"
#include <sys/param.h>
+#ifndef __rtems__
#include <sys/systm.h>
#include <sys/sysproto.h>
#include <sys/eventhandler.h>
@@ -44,12 +54,24 @@ __FBSDID("$FreeBSD$");
#include <sys/proc.h>
#include <sys/lock.h>
#include <sys/mutex.h>
+#endif /* __rtems__ */
#include <sys/timex.h>
#include <sys/timetc.h>
#include <sys/timepps.h>
+#ifndef __rtems__
#include <sys/syscallsubr.h>
#include <sys/sysctl.h>
+#else /* __rtems__ */
+#include <rtems/sysinit.h>
+#include <rtems/score/timecounter.h>
+#include <errno.h>
+#include <string.h>
+#define nanotime(_tsp) _Timecounter_Nanotime(_tsp)
+#define ntp_update_second _Timecounter_NTP_update_second
+#define time_uptime _Timecounter_Time_uptime
+struct thread;
#ifdef PPS_SYNC
FEATURE(pps_sync, "Support usage of external PPS signal by kernel PLL");
@@ -148,12 +170,18 @@ typedef int64_t l_fp;
#define SHIFT_FLL 2 /* FLL loop gain (shift) */
static int time_state = TIME_OK; /* clock state */
+#ifdef __rtems__
+static
int time_status = STA_UNSYNC; /* clock status bits */
static long time_tai; /* TAI offset (s) */
static long time_monitor; /* last time offset scaled (ns) */
static long time_constant; /* poll interval (shift) (s) */
static long time_precision = 1; /* clock precision (ns) */
static long time_maxerror = MAXPHASE / 1000; /* maximum error (us) */
+#ifdef __rtems__
+static
long time_esterror = MAXPHASE / 1000; /* estimated error (us) */
static long time_reftime; /* uptime at last adjustment (s) */
static l_fp time_offset; /* time offset (ns) */
@@ -162,12 +190,24 @@ static l_fp time_adj; /* tick adjust (ns/s) */
static int64_t time_adjtime; /* correction from adjtime(2) (usec) */
+#ifndef __rtems__
static struct mtx ntp_lock;
MTX_SYSINIT(ntp, &ntp_lock, "ntp", MTX_SPIN);
#define NTP_LOCK() mtx_lock_spin(&ntp_lock)
#define NTP_UNLOCK() mtx_unlock_spin(&ntp_lock)
#define NTP_ASSERT_LOCKED() mtx_assert(&ntp_lock, MA_OWNED)
+#define NTP_LOCK() \
+ do { \
+ ISR_lock_Context lock_context; \
+ _Timecounter_Acquire(&lock_context);
+#define NTP_UNLOCK() \
+ _Timecounter_Release(&lock_context); \
+ } while (0)
+#define NTP_ASSERT_LOCKED() \
+ _Assert(_ISR_lock_Is_owner(&_Timecounter_Lock))
#ifdef PPS_SYNC
@@ -273,6 +313,7 @@ ntp_gettime1(struct ntptimeval *ntvp)
* See the timex.h header file for synopsis and API description. Note that
* the TAI offset is returned in the ntvtimeval.tai structure member.
+#ifndef __rtems__
#ifndef _SYS_SYSPROTO_H_
struct ntp_gettime_args {
struct ntptimeval *ntvp;
@@ -293,7 +334,27 @@ sys_ntp_gettime(struct thread *td, struct ntp_gettime_args *uap)
td->td_retval[0] = ntv.time_state;
return (copyout(&ntv, uap->ntvp, sizeof(ntv)));
+int
+ntp_gettime(struct ntptimeval *ntv)
+ if (ntv == NULL) {
+ errno = EFAULT;
+ return (-1);
+ ntv = memset(ntv, 0, sizeof(*ntv));
+ NTP_LOCK();
+ ntp_gettime1(ntv);
+ NTP_UNLOCK();
+ return (ntv->time_state);
+#ifndef __rtems__
static int
ntp_sysctl(SYSCTL_HANDLER_ARGS)
@@ -313,6 +374,7 @@ SYSCTL_NODE(_kern, OID_AUTO, ntp_pll, CTLFLAG_RW | CTLFLAG_MPSAFE, 0,
SYSCTL_PROC(_kern_ntp_pll, OID_AUTO, gettime, CTLTYPE_OPAQUE | CTLFLAG_RD |
CTLFLAG_MPSAFE, 0, sizeof(struct ntptimeval) , ntp_sysctl, "S,ntptimeval",
#ifdef PPS_SYNC
SYSCTL_INT(_kern_ntp_pll, OID_AUTO, pps_shiftmax, CTLFLAG_RW,
@@ -337,12 +399,19 @@ SYSCTL_S64(_kern_ntp_pll, OID_AUTO, time_freq, CTLFLAG_RD | CTLFLAG_MPSAFE,
* the timex.constant structure member has a dual purpose to set the time
* constant and to set the TAI offset.
+#ifdef __rtems__
+static
int
kern_ntp_adjtime(struct thread *td, struct timex *ntv, int *retvalp)
long freq; /* frequency ns/s) */
int modes; /* mode bits from structure */
+#ifndef __rtems__
int error, retval;
+ int retval;
* Update selected clock variables - only the superuser can
@@ -354,11 +423,13 @@ kern_ntp_adjtime(struct thread *td, struct timex *ntv, int *retvalp)
* status words are reset to the initial values at boot.
modes = ntv->modes;
+#ifndef __rtems__
error = 0;
if (modes)
error = priv_check(td, PRIV_NTP_ADJTIME);
if (error != 0)
return (error);
NTP_LOCK();
if (modes & MOD_MAXERROR)
time_maxerror = ntv->maxerror;
@@ -460,6 +531,16 @@ kern_ntp_adjtime(struct thread *td, struct timex *ntv, int *retvalp)
ntv->jitcnt = pps_jitcnt;
ntv->stbcnt = pps_stbcnt;
#endif /* PPS_SYNC */
+#ifdef __rtems__
+ ntv->ppsfreq = 0;
+ ntv->jitter = 0;
+ ntv->shift = 0;
+ ntv->stabil = 0;
+ ntv->jitcnt = 0;
+ ntv->calcnt = 0;
+ ntv->errcnt = 0;
+ ntv->stbcnt = 0;
retval = ntp_is_time_error(time_status) ? TIME_ERROR : time_state;
NTP_UNLOCK();
@@ -473,6 +554,7 @@ struct ntp_adjtime_args {
#endif
+#ifndef __rtems__
int
sys_ntp_adjtime(struct thread *td, struct ntp_adjtime_args *uap)
@@ -490,6 +572,23 @@ sys_ntp_adjtime(struct thread *td, struct ntp_adjtime_args *uap)
return (error);
+int
+ntp_adjtime(struct timex *ntv)
+ int error;
+ int retval;
+ errno = EFAULT;
+ return (-1);
+ error = kern_ntp_adjtime(NULL, ntv, &retval);
+ _Assert_Unused_variable_equals(error, 0);
+ return (retval);
* second_overflow() - called after ntp_tick_adjust()
@@ -505,7 +604,11 @@ ntp_update_second(int64_t *adjustment, time_t *newsec)
int tickrate;
l_fp ftemp; /* 32/64-bit temporary */
+#ifndef __rtems__
NTP_LOCK();
+ NTP_ASSERT_LOCKED();
* On rollover of the second both the nanosecond and microsecond
@@ -628,9 +731,22 @@ ntp_update_second(int64_t *adjustment, time_t *newsec)
time_status &= ~STA_PPSSIGNAL;
+#ifndef __rtems__
NTP_UNLOCK();
+#ifdef __rtems__
+static void
+_NTP_Initialize(void)
+ _Timecounter_Set_NTP_update_second(ntp_update_second);
+RTEMS_SYSINIT_ITEM(_NTP_Initialize, RTEMS_SYSINIT_DEVICE_DRIVERS,
+ RTEMS_SYSINIT_ORDER_FOURTH);
* hardupdate() - local clock update
@@ -930,6 +1046,7 @@ out:
+#ifndef __rtems__
struct adjtime_args {
struct timeval *delta;
@@ -958,15 +1075,23 @@ sys_adjtime(struct thread *td, struct adjtime_args *uap)
int
kern_adjtime(struct thread *td, struct timeval *delta, struct timeval *olddelta)
+static int
+kern_adjtime(const struct timeval *delta, struct timeval *olddelta)
struct timeval atv;
int64_t ltr, ltw;
+#ifndef __rtems__
int error;
if (delta != NULL) {
+#ifndef __rtems__
error = priv_check(td, PRIV_ADJTIME);
if (error != 0)
return (error);
ltw = (int64_t)delta->tv_sec * 1000000 + delta->tv_usec;
NTP_LOCK();
@@ -985,7 +1110,19 @@ kern_adjtime(struct thread *td, struct timeval *delta, struct timeval *olddelta)
return (0);
+#ifdef __rtems__
+int
+adjtime(const struct timeval *delta, struct timeval *olddelta)
+ int error;
+ error = kern_adjtime(delta, olddelta);
+ return (0);
+#ifndef __rtems__
static struct callout resettodr_callout;
static int resettodr_period = 1800;
@@ -1051,3 +1188,4 @@ start_periodic_resettodr(void *arg __unused)
SYSINIT(periodic_resettodr, SI_SUB_LAST, SI_ORDER_MIDDLE,
start_periodic_resettodr, NULL);
diff --git a/cpukit/score/src/kern_tc.c b/cpukit/score/src/kern_tc.c
index ea7d9ec953..a2b20a18b2 100644
--- a/cpukit/score/src/kern_tc.c
+++ b/cpukit/score/src/kern_tc.c
@@ -135,13 +135,13 @@ atomic_load_ptr(void *ptr)
return ((void *)_Atomic_Load_uintptr(ptr, ATOMIC_ORDER_RELAXED));
-static Timecounter_NTP_update_second _Timecounter_NTP_update_second;
+static Timecounter_NTP_update_second _Timecounter_NTP_update_second_handler;
void
_Timecounter_Set_NTP_update_second(Timecounter_NTP_update_second handler)
- _Timecounter_NTP_update_second = handler;
+ _Timecounter_NTP_update_second_handler = handler;
#define ntp_update_second(a, b) (*ntp_update_second_handler)(a, b)
@@ -1722,7 +1722,7 @@ _Timecounter_Windup(struct bintime *new_boottimebin,
bt = th->th_offset;
bintime_add(&bt, &th->th_boottime);
#ifdef __rtems__
- ntp_update_second_handler = _Timecounter_NTP_update_second;
+ ntp_update_second_handler = _Timecounter_NTP_update_second_handler;
if (ntp_update_second_handler != NULL) {
i = bt.sec - tho->th_microtime.tv_sec;
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index 7d6dbae0db..c224937348 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -983,7 +983,6 @@ source:
- cpukit/libtrace/record/record-util.c
- cpukit/libtrace/record/record.c
- cpukit/posix/src/_execve.c
-- cpukit/posix/src/adjtime.c
- cpukit/posix/src/aio_suspend.c
- cpukit/posix/src/barrierattrdestroy.c
- cpukit/posix/src/barrierattrgetpshared.c
@@ -1424,6 +1423,7 @@ source:
- cpukit/score/src/isrisinprogress.c
- cpukit/score/src/isrvectortable.c
- cpukit/score/src/iterateoverthreads.c
+- cpukit/score/src/kern_ntptime.c
- cpukit/score/src/kern_tc.c
- cpukit/score/src/libatomic.c
- cpukit/score/src/log2table.c
diff --git a/spec/build/testsuites/sptests/grp.yml b/spec/build/testsuites/sptests/grp.yml
index 740684a0e4..a69a4d20f7 100644
--- a/spec/build/testsuites/sptests/grp.yml
+++ b/spec/build/testsuites/sptests/grp.yml
@@ -337,6 +337,8 @@ links:
uid: spmutex01
- role: build-dependency
uid: spnsext01
+- role: build-dependency
+ uid: spntp01
uid: spobjgetnext
diff --git a/spec/build/testsuites/sptests/spntp01.yml b/spec/build/testsuites/sptests/spntp01.yml
new file mode 100644
index 0000000000..1b6a16f1a1
--- /dev/null
+++ b/spec/build/testsuites/sptests/spntp01.yml
@@ -0,0 +1,19 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: test-program
+cflags: []
+copyrights:
+- Copyright (C) 2022 embedded brains GmbH (http://www.embedded-brains.de)
+cppflags: []
+cxxflags: []
+enabled-by: true
+features: c cprogram
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/sptests/spntp01/init.c
+stlib: []
+target: testsuites/sptests/spntp01.exe
+type: build
+use-after: []
+use-before: []
diff --git a/testsuites/psxtests/psxtime/test.c b/testsuites/psxtests/psxtime/test.c
index d9f5537152..f5544b19dd 100644
--- a/testsuites/psxtests/psxtime/test.c
+++ b/testsuites/psxtests/psxtime/test.c
@@ -122,17 +122,15 @@ void test_adjtime(void)
olddelta.tv_sec = 0;
olddelta.tv_usec = 0;
- puts( "adjtime - NULL delta - EINVAL" );
+ puts( "adjtime - NULL delta - OK" );
sc = adjtime( NULL, &olddelta );
- rtems_test_assert( sc == -1 );
- rtems_test_assert( errno == EINVAL );
+ rtems_test_assert( sc == 0 );
- puts( "adjtime - delta out of range - EINVAL" );
+ puts( "adjtime - large us delta - OK" );
delta.tv_sec = 0;
delta.tv_usec = 1000000000; /* 100 seconds worth */
sc = adjtime( &delta, &olddelta );
puts( "adjtime - delta range of 0 - OK" );
delta.tv_sec = 0;
diff --git a/testsuites/sptests/spntp01/init.c b/testsuites/sptests/spntp01/init.c
index 0000000000..eeee472e9d
--- /dev/null
+++ b/testsuites/sptests/spntp01/init.c
@@ -0,0 +1,111 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2022 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <sys/time.h>
+#include <sys/timex.h>
+#include <errno.h>
+#include <rtems/test.h>
+#include <rtems/test-info.h>
+const char rtems_test_name[] = "SPNTP 1";
+T_TEST_CASE( NTP )
+ struct ntptimeval ntv;
+ struct timex tx;
+ int status;
+ errno = 0;
+ status = ntp_gettime( NULL );
+ T_eq_int( status, -1 );
+ T_eq_int( errno, EFAULT );
+ memset( &ntv, 0xff, sizeof( ntv ) );
+ status = ntp_gettime( &ntv );
+ T_eq_int( status, TIME_ERROR );
+ T_eq_i64( ntv.time.tv_sec, 567993600 );
+ T_eq_long( ntv.time.tv_nsec, 0 );
+ T_eq_long( ntv.maxerror, 500000 );
+ T_eq_long( ntv.esterror, 500000 );
+ T_eq_long( ntv.tai, 0 );
+ T_eq_long( ntv.time_state, TIME_ERROR );
+ errno = 0;
+ status = ntp_adjtime( NULL );
+ memset( &tx, 0xff, sizeof( tx ) );
+ tx.modes = 0;
+ status = ntp_adjtime( &tx );
+ T_eq_uint( tx.modes, 0 );
+ T_eq_long( tx.offset, 0 );
+ T_eq_long( tx.freq, 0 );
+ T_eq_long( tx.maxerror, 500000 );
+ T_eq_long( tx.esterror, 500000 );
+ T_eq_int( tx.status, STA_UNSYNC );
+ T_eq_long( tx.constant, 0 );
+ T_eq_long( tx.precision, 0 );
+ T_eq_long( tx.tolerance, 32500000 );
+ T_eq_long( tx.ppsfreq, 0 );
+ T_eq_long( tx.jitter, 0 );
+ T_eq_int( tx.shift, 0 );
+ T_eq_long( tx.stabil, 0 );
+ T_eq_long( tx.jitcnt, 0 );
+ T_eq_long( tx.calcnt, 0 );
+ T_eq_long( tx.errcnt, 0 );
+ T_eq_long( tx.stbcnt, 0 );
+ status = adjtime( NULL, NULL );
+ T_eq_int( status, 0 );
+static rtems_task Init( rtems_task_argument argument )
+ rtems_test_run( argument, TEST_STATE );
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
2.26.2
