[PATCH] bsp/atsam: Improve UART / USART tx performance
Christian Mauderer
christian.mauderer at embedded-brains.de
Fri Feb 11 08:06:51 UTC 2022
Put the next character into the send buffer if the buffer is empty and
not when the last character has been sent out to the line. This improves
the performance slightly.
Before that patch, the receive path was faster than the transmit path.
Therefore a simple echo could drop characters on a busy connection.
With this patch sending and receiving has about the same performance so
that no characters are lost.
Fixes #4610
Note: The problem exists on 5 and master. The ticket for 5 is #4611. I would
like to push this patch to both branches.
bsps/arm/atsam/console/console.c | 9 +++++----
1 file changed, 5 insertions(+), 4 deletions(-)
diff --git a/bsps/arm/atsam/console/console.c b/bsps/arm/atsam/console/console.c
index 5ef4327e11..0802ca2155 100644
--- a/bsps/arm/atsam/console/console.c
+++ b/bsps/arm/atsam/console/console.c
@@ -145,8 +145,9 @@ static void atsam_uart_interrupt(void *arg)
- if (ctx->transmitting && (sr & UART_SR_TXEMPTY) != 0) {
+ while (ctx->transmitting && (sr & UART_SR_TXRDY) != 0) {
rtems_termios_dequeue_characters(tty, 1);
+ sr = regs->UART_SR;
#endif
@@ -408,16 +409,16 @@ static void atsam_uart_write(
if (len > 0) {
ctx->transmitting = true;
regs->UART_THR = buf[0];
- regs->UART_IER = UART_IDR_TXEMPTY;
+ regs->UART_IER = UART_IDR_TXRDY;
} else {
ctx->transmitting = false;
- regs->UART_IDR = UART_IDR_TXEMPTY;
+ regs->UART_IDR = UART_IDR_TXRDY;
#else
size_t i;
for (i = 0; i < len; ++i) {
- while ((regs->UART_SR & UART_SR_TXEMPTY) == 0) {
+ while ((regs->UART_SR & UART_SR_TXRDY) == 0) {
/* Wait */
2.31.1
