[PATCH rtems-docs] Add option --build-manuals to build multiple specific manuals.
Shashvat shashvatjain2002 at gmail.com
Fri Feb 11 16:37:52 UTC 2022
Hi Gedare!!
Is there a ticket associated with this, or any feature request? Or
> just something you thought of doing?
I am sorry I should have mentioned the motive behind the option.
I was planning to work on ticket #3333 which works on a specific
posix-users manual afaik. I wanted waf to build only this particular manual
so asked Chris on discord if it is possible and he told me how it was
broken, and that it would be good to add an option that enables this.
> I don't think an extra blank line is needed here.
This was my fault.
> >    $ ./waf
> > @@ -448,8 +450,10 @@ verbose level:
> >    $ ./waf configure --sphinx-options "-V -V"
> >    $ ./waf clean build
> > -You can enter a manual's directory and run the same configure command
> and
> > build
> > -just that manual.
> > +If you wish to build only some specific manuals,
> > +use the '--build-manuals=<manual-name-1>,<manual-name-2>' option with
> > +configure to build only those specific manuals.
> >  Documentation Standard
> > diff --git a/common/waf.py b/common/waf.py
> > index fa9aecb..e6ae059 100644
> > --- a/common/waf.py
> > +++ b/common/waf.py
> > @@ -240,6 +240,11 @@ def cmd_configure(ctx):
> >          check_sphinx_extension(ctx, 'sphinxcontrib.bibtex')
> > + # Build specific manuals.
> This spacing looks wrong.
> > + if ctx.options.build_manuals!="":
> Follow the coding style of the surrounding text. For Python code, we
> generally follow
> https://docs.rtems.org/branches/master/eng/python-devel.html
Thanks, I will take a look.
> > + ctx.env.MANUALS = ctx.options.build_manuals.split(',')
> Probably want a blank line here. None of the other options take
> multiple values. I wonder if there is any value to having a multiple
> option here, versus building just one manual selectively? You could
> still have an 'all' option as the default. That will reduce the
> complexity of the command line argument processing.
> I guess by default this will not build any manuals? The principle of
> least surprise suggests that by default the behavior should be what it
> used to be if you omit the argument, so build everything. otherwise,
> you break existing workflows and scripts.
This does has the action of building all manuals by default.
> This is not good python, no indent after 'if', so there's nothing in
> the conditional code block, you just always set building to
> ctx.env.MANUALS.
> > + print("Building the following manuals:-")
> > + for manual in building:
> > + print(manual)
> missing indent here too. But the print statements seem to be
> inconsistent with other printed output for this code. You generally
> want to keep that consistent.
This is my first time submitting a patch by mail and looks like I messed
something up up while copying the diff, should have checked by applying the
diff before submitting. Looks like the indents are missing :)
Thanks
Shashvat
