[PATCH rtems-docs] Add option --build-manuals to build multiple specific manuals.
Shashvat shashvatjain2002 at gmail.com
Fri Feb 11 17:43:17 UTC 2022
Here is the patch, I ran yapf on it and it didn't introduce any changes.
Please take a
look and let me know what you think.
On Fri, 11 Feb 2022, 10:31 pm Gedare Bloom, <gedare at rtems.org> wrote:
> On Fri, Feb 11, 2022 at 9:38 AM Shashvat <shashvatjain2002 at gmail.com>
> wrote:
> > Hi Gedare!!
> >> Is there a ticket associated with this, or any feature request? Or
> >> just something you thought of doing?
> > I am sorry I should have mentioned the motive behind the option.
> > I was planning to work on ticket #3333 which works on a specific
> posix-users manual afaik. I wanted waf to build only this particular manual
> so asked Chris on discord if it is possible and he told me how it was
> broken, and that it would be good to add an option that enables this.
> >> I don't think an extra blank line is needed here.
> > This was my fault.
> >> >    $ ./waf
> >> > @@ -448,8 +450,10 @@ verbose level:
> >> >    $ ./waf configure --sphinx-options "-V -V"
> >> >    $ ./waf clean build
> >> > -You can enter a manual's directory and run the same configure
> command and
> >> > build
> >> > -just that manual.
> >> > +If you wish to build only some specific manuals,
> >> > +use the '--build-manuals=<manual-name-1>,<manual-name-2>' option with
> >> > +configure to build only those specific manuals.
> >> >  Documentation Standard
> >> > diff --git a/common/waf.py b/common/waf.py
> >> > index fa9aecb..e6ae059 100644
> >> > --- a/common/waf.py
> >> > +++ b/common/waf.py
> >> > @@ -240,6 +240,11 @@ def cmd_configure(ctx):
> >> >          check_sphinx_extension(ctx, 'sphinxcontrib.bibtex')
> >> > + # Build specific manuals.
> >> This spacing looks wrong.
> >> > + if ctx.options.build_manuals!="":
> >> Follow the coding style of the surrounding text. For Python code, we
> >> generally follow
> >> https://docs.rtems.org/branches/master/eng/python-devel.html
> > Thanks, I will take a look.
> >> > + ctx.env.MANUALS = ctx.options.build_manuals.split(',')
> >> Probably want a blank line here. None of the other options take
> >> multiple values. I wonder if there is any value to having a multiple
> >> option here, versus building just one manual selectively? You could
> >> still have an 'all' option as the default. That will reduce the
> >> complexity of the command line argument processing.
> >> I guess by default this will not build any manuals? The principle of
> >> least surprise suggests that by default the behavior should be what it
> >> used to be if you omit the argument, so build everything. otherwise,
> >> you break existing workflows and scripts.
> > This does has the action of building all manuals by default.
> >> This is not good python, no indent after 'if', so there's nothing in
> >> the conditional code block, you just always set building to
> >> ctx.env.MANUALS.
> >> > + print("Building the following manuals:-")
> >> > + for manual in building:
> >> > + print(manual)
> >> missing indent here too. But the print statements seem to be
> >> inconsistent with other printed output for this code. You generally
> >> want to keep that consistent.
> > This is my first time submitting a patch by mail and looks like I messed
> something up up while copying the diff, should have checked by applying the
> diff before submitting. Looks like the indents are missing :)
> If you don't have git-send-email working, then use git-format-patch
> and just email the patch instead of trying to copy-paste into your
> emailer
> > Thanks
> > Shashvat
