New validation test suites
Mon Feb 14 13:43:27 UTC 2022
On 03/02/2022 09:09, Sebastian Huber wrote:
> On 30/01/2022 23:26, Chris Johns wrote:
>>>>> We just have to create a
>>>>> release branch for RTEMS 6 and reference release branch commits in the
>>>>> submodules.
>>>> How do you validate the generated sources in the sub-modules match
>>>> those in the
>>>> branched submodules? I think this should be done as part of the release
>>>> procedure to catch any mistakes.
>>> I will write something about this in the release procedure
>>> documentation.
>> Thank you, I appreciate this. This is a big help.
> I added a note to the post-branch procedure:
> https://docs.rtems.org/branches/master/eng/release-process.html#post-branch-procedure
How do we want to proceed here? I have no idea what should I do next.
The new validation tests are not the only work from the
pre-qualification activity I would like to integrate. We also have work
from Andrew Butterfields related to formal methods. There are changes in
the GR712RC and GR740 BSPs, the gcov code coverage support, and build
system changes to support the build of RTEMS libraries which contain
only the pre-qualified feature set.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
