[PATCH rtems-tools] bin2c: Add option for alignment
Joel Sherrill
joel at rtems.org
Mon Feb 14 16:06:16 UTC 2022
I think this looks ok
On Mon, Feb 14, 2022, 9:44 AM Christian Mauderer <
christian.mauderer at embedded-brains.de> wrote:
> Sometimes it's useful if structures are aligned. This patch add a
> -A alignment
> option. Note that this doesn't check for valid alignments. It accepts
> any positive number in decimal or hex format. If for example an
> alignment of 7 is specified, the compiler will complain that it is not a
> power of 2. But it's not really useful to duplicate this check here.
> misc/bin2c/rtems-bin2c.c | 42 ++++++++++++++++++++++++++++++++++++----
> 1 file changed, 38 insertions(+), 4 deletions(-)
> diff --git a/misc/bin2c/rtems-bin2c.c b/misc/bin2c/rtems-bin2c.c
> index 462ecf0..8d0e6a1 100644
> --- a/misc/bin2c/rtems-bin2c.c
> +++ b/misc/bin2c/rtems-bin2c.c
> @@ -42,6 +42,7 @@ int verbose = 0;
> int zeroterminated = 0;
> int createC = 1;
> int createH = 1;
> +unsigned int align = 0;
> static void sanitize_file_name(char *p)
> @@ -175,11 +176,22 @@ void process(const char *ifname, const char *ofname,
> const char *forced_name)
> /* print structure */
> fprintf(
> ocfile,
> - "%s%sunsigned char %s[] = {\n ",
> + "%s%sunsigned char %s[] ",
> ((usestatic) ? "static " : ""),
> ((useconst) ? "const " : ""),
> buf
> + if (align > 0) {
> + fprintf(
> + ocfile,
> + "__attribute__(( __aligned__(%d) )) ",
> + align
> + fprintf(
> + ocfile,
> + "= {\n "
> int c, col = 1;
> while ((c = myfgetc(ifile)) != EOF) {
> if (col >= 78 - 6) {
> @@ -238,15 +250,22 @@ void process(const char *ifname, const char *ofname,
> fprintf(
> ohfile,
> - "extern %s%sunsigned char %s[];",
> + "extern %s%sunsigned char %s[]",
> buf
> + if (align > 0) {
> + fprintf(
> + ohfile,
> + " __attribute__(( __aligned__(%d) ))",
> + align
> /* print sizeof */
> fprintf(
> ohfile,
> - "\n"
> + ";\n"
> "extern %s%ssize_t %s_size;\n",
> @@ -274,7 +293,7 @@ void usage(void)
> fprintf(
> stderr,
> - "usage: bin2c [-csvzCH] [-N name] <input_file> <output_file>\n"
> + "usage: bin2c [-csvzCH] [-N name] [-A alignment] <input_file>
> <output_file>\n"
> " <input_file> is the binary file to convert\n"
> " <output_file> should not have a .c or .h extension\n"
> "\n"
> @@ -285,6 +304,7 @@ void usage(void)
> " -H - create c-header only\n"
> " -C - create c-source file only\n"
> " -N - force name of data array\n"
> + " -A - add alignment - parameter can be a hexadecimal or decimal
> number\n"
> exit(1);
> @@ -329,6 +349,20 @@ int main(int argc, char **argv)
> name = argv[1];
> --argc;
> ++argv;
> + } else if (!strcmp(argv[1], "-A")) {
> + --argc;
> + ++argv;
> + if (argc <= 1) {
> + fprintf(stderr, "error: -A needs an alignment\n");
> + usage();
> + align = strtoul(argv[1], NULL, 0);
> + if (align == 0) {
> + fprintf(stderr, "error: Couldn't convert argument of -A\n");
> + usage();
> + --argc;
> + ++argv;
> } else {
> usage();
> 2.31.1
> devel mailing list
> devel at rtems.org
