Problem compiling leon3 and gr712rc with Tests and SMP enabled.
Jerzy Jaskuc jaskucj at tcd.ie
Fri Feb 18 11:02:56 UTC 2022
Hi,
I've been trying to manually build BSP using waf on RTEMS 6. I'm working
off HEAD of the RTEMS master branch.
However, on gr712rc, whenever I try to have both SMP and tests enabled I
get compile errors, which I can't really understand. When I try building
with only either option, it works in both cases.
Contents of my .ini file:
`[sparc/gr712rc]
RTEMS_SMP = True
BUILD_TESTS = True`
Commands I run:
`./waf configure --prefix=$HOME/RTEMS/rtems/6`
`./waf -v`
Bottom excerpt of error Log:
`/home/yoman/RTEMS/rtems/6/lib/gcc/sparc-rtems6/10.3.1/../../../../sparc-rtems6/bin/ld:
./librtemscpu.a(threadqops.c.59.o): in function
`_Thread_Scheduler_get_node_by_index':
/home/yoman/RTEMS/src/rtems/build/sparc/gr712rc/../../../cpukit/include/rtems/score/threadimpl.h:1553:
undefined reference to `_Scheduler_Node_size'
./librtemscpu.a(threadqops.c.59.o):/home/yoman/RTEMS/src/rtems/build/sparc/gr712rc/../../../cpukit/include/rtems/score/threadimpl.h:1553:
more undefined references to `_Scheduler_Node_size' follow
./librtemscpu.a(threadrestart.c.59.o): in function `_Per_CPU_Get_index':
/home/yoman/RTEMS/src/rtems/build/sparc/gr712rc/../../../cpukit/include/rtems/score/percpu.h:681:
undefined reference to `_Per_CPU_Information'
./librtemscpu.a(userextaddset.c.59.o): in function `_Per_CPU_Acquire_all':
/home/yoman/RTEMS/src/rtems/build/sparc/gr712rc/../../../cpukit/include/rtems/score/percpu.h:744:
/home/yoman/RTEMS/src/rtems/build/sparc/gr712rc/../../../cpukit/include/rtems/score/percpu.h:746:
./librtemscpu.a(userextaddset.c.59.o):/home/yoman/RTEMS/src/rtems/build/sparc/gr712rc/../../../cpukit/include/rtems/score/percpu.h:746:
more undefined references to `_Per_CPU_Information' follow
collect2: error: ld returned 1 exit status
Waf: Leaving directory `/home/yoman/RTEMS/src/rtems/build/sparc/gr712rc'
Build failed
 -> task in '' failed with exit status 1:
{task 139809939310064: link dl04-tar.o,init.o,dl-load.o -> dl04.pre}
{task 139809939309840: link dl02-tar.o,init.o,dl-load.o -> dl02.pre}
{task 139809939310512: link dl06-pre-tar.o,pre-init.o,dl-load.o -> dl06.pre}
{task 139809939309616: link dl01-tar.o,init.o,dl-load.o -> dl01.pre}
Similarly when I'm trying the same with Leon3. However, on Leon3 I can't
even build it with only tests enabled.
`[sparc/leon3]
BUILD_TESTS = True`
Commands I run:
`./waf -v`
Log excerpt:
/home/yoman/RTEMS/src/rtems/build/sparc/leon3/testsuites/libtests/dl10/init.o:(.rodata._Scheduler_Table+0x30):
undefined reference to `_Scheduler_default_Sticky_do_nothing'
/home/yoman/RTEMS/src/rtems/build/sparc/leon3/testsuites/libtests/dl10/init.o:(.rodata._Scheduler_Table+0x34):
/home/yoman/RTEMS/src/rtems/build/sparc/leon3/testsuites/libtests/dl10/init.o:(.rodata._Scheduler_Table+0x38):
undefined reference to `_Scheduler_default_Pin_or_unpin_do_nothing'
/home/yoman/RTEMS/src/rtems/build/sparc/leon3/testsuites/libtests/dl10/init.o:(.rodata._Scheduler_Table+0x3c):
/home/yoman/RTEMS/src/rtems/build/sparc/leon3/testsuites/libtests/dl10/init.o:(.rodata._Scheduler_Table+0x5c):
undefined reference to `_Scheduler_default_Set_affinity'
Waf: Leaving directory `/home/yoman/RTEMS/src/rtems/build/sparc/leon3'
Build failed
{task 139903699298224: link dl06-pre-tar.o,pre-init.o,dl-load.o -> dl06.pre}
{task 139903699299344: link dl10-tar.o,init.o,dl-load.o -> dl10.pre}
I've been able to build tests for both Leon3 and gr712rc without problems a
few months ago, but that's without SMP.
Am I doing something wrong or missing some new steps with it? Any help
would be appreciated!
Thank you in advance and all the best,
Jerzy
