config, _IO_Initialize_all_drivers
Heinz Junkes
junkes at fhi-berlin.mpg.de
Fri Feb 18 16:18:43 UTC 2022
I'm still trying to get the booting and registering and initialising of the i2c devices on the MVME3100 to work properly.
In confdefs/iodrivers.h the driver address table is built up and then
_IO_Initialize_all_drivers() is called without registering the individual devices first.
If I now enter in already before in bspstart.c
RTEMS_SYSINIT_ITEM(
mvme3100_i2c_initialize,
RTEMS_SYSINIT_BSP_PRE_DRIVERS,
RTEMS_SYSINIT_ORDER_MIDDLE
a device (register it and e.g. got the major number 0) this is ignored by the IO_Initialize_all_drivers().
Shouldn't initialisation be preceded by registration ( rtems_io_register_driver() )?
Heinz
rtems_driver_address_table
_IO_Driver_address_table[ CONFIGURE_MAXIMUM_DRIVERS ] = {
#ifdef CONFIGURE_BSP_PREREQUISITE_DRIVERS
CONFIGURE_BSP_PREREQUISITE_DRIVERS,
#endif
#ifdef CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS
CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS,
#endif
#ifdef CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
CONSOLE_DRIVER_TABLE_ENTRY,
#endif
#ifdef CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER
RTC_DRIVER_TABLE_ENTRY,
#endif
#ifdef CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER
WATCHDOG_DRIVER_TABLE_ENTRY,
#endif
#ifdef CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
DEVNULL_DRIVER_TABLE_ENTRY,
#endif
#ifdef CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER
DEVZERO_DRIVER_TABLE_ENTRY,
#endif
#ifdef CONFIGURE_APPLICATION_NEEDS_IDE_DRIVER
IDE_CONTROLLER_DRIVER_TABLE_ENTRY,
#endif
#ifdef CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER
ATA_DRIVER_TABLE_ENTRY,
#endif
#ifdef CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER
FRAME_BUFFER_DRIVER_TABLE_ENTRY,
#endif
#ifdef CONFIGURE_APPLICATION_EXTRA_DRIVERS
CONFIGURE_APPLICATION_EXTRA_DRIVERS,
#endif
#if defined(CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER) \
|| ( !defined(CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER) \
&& !defined(CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER) \
&& !defined(CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER) \
&& !defined(CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER) \
&& !defined(CONFIGURE_APPLICATION_NEEDS_IDE_DRIVER) \
&& !defined(CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER) \
&& !defined(CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER) \
&& !defined(CONFIGURE_APPLICATION_EXTRA_DRIVERS) )
#endif
const size_t _IO_Number_of_drivers =
RTEMS_ARRAY_SIZE( _IO_Driver_address_table );
RTEMS_SYSINIT_ITEM(
_IO_Initialize_all_drivers,
RTEMS_SYSINIT_DEVICE_DRIVERS,
Fritz-Haber-Institut | Phone: (+49 30) 8413-4270
Heinz Junkes | Fax (G3+G4): (+49 30) 8413-5900
Faradayweg 4-6 | VC: 102220181216 at bjn.vc
D - 14195 Berlin | E-Mail: junkes at fhi-berlin.mpg.de
