[PATCH v2 4/6] microblaze: Decouple exceptions from interrupts
Kinsey Moore kinsey.moore at oarcorp.com
Fri Feb 18 16:57:31 UTC 2022
Exception handling should be enabled at all times during execution to
ensure that exceptions are not ignored which would cause further
problems. This separates use of the exception enable bit from use of the
interrupt enable bit in the machine status register so that they can be
manipulated independently.
 bsps/microblaze/microblaze_fpga/start/crtinit.S       |  3 +++
 cpukit/score/cpu/microblaze/cpu.c                     |  6 +++---
 cpukit/score/cpu/microblaze/include/rtems/score/cpu.h | 10 +++++-----
 3 files changed, 11 insertions(+), 8 deletions(-)
diff --git a/bsps/microblaze/microblaze_fpga/start/crtinit.S b/bsps/microblaze/microblaze_fpga/start/crtinit.S
index a9779404b2..d56bee3b19 100644
--- a/bsps/microblaze/microblaze_fpga/start/crtinit.S
+++ b/bsps/microblaze/microblaze_fpga/start/crtinit.S
@@ -81,6 +81,9 @@ _crtinit:
 #ifndef __rtems__
 	brlid	r15, main					   /* Execute the program */
 #else
+	mfs r3, rmsr
+	ori r3, r3, 0x100					   /* Set Exception Enable MSR flag */
+	mts rmsr, r3
 	brlid	r15, boot_card
 #endif /* __rtems__ */
 	addi	r5, r0, 0
diff --git a/cpukit/score/cpu/microblaze/cpu.c b/cpukit/score/cpu/microblaze/cpu.c
index 960ac1bfea..259053f88a 100644
--- a/cpukit/score/cpu/microblaze/cpu.c
+++ b/cpukit/score/cpu/microblaze/cpu.c
@@ -142,9 +142,9 @@ void _CPU_ISR_Set_level( uint32_t level )
   _CPU_MSR_GET( microblaze_switch_reg );
   if ( level == 0 ) {
-    microblaze_switch_reg |= (MICROBLAZE_MSR_IE | MICROBLAZE_MSR_EE);
+    microblaze_switch_reg |= MICROBLAZE_MSR_IE;
   } else {
-    microblaze_switch_reg &= ~(MICROBLAZE_MSR_IE | MICROBLAZE_MSR_EE);
+    microblaze_switch_reg &= ~(MICROBLAZE_MSR_IE);
   _CPU_MSR_SET( microblaze_switch_reg );
@@ -158,7 +158,7 @@ uint32_t _CPU_ISR_Get_level( void )
   /* This is unique. The MSR register contains an interrupt enable flag where
    * most other architectures have an interrupt disable flag. */
-  return ( level & (MICROBLAZE_MSR_IE | MICROBLAZE_MSR_EE) ) == 0;
+  return ( level & MICROBLAZE_MSR_IE ) == 0;
 void _CPU_ISR_install_vector(
diff --git a/cpukit/score/cpu/microblaze/include/rtems/score/cpu.h b/cpukit/score/cpu/microblaze/include/rtems/score/cpu.h
index 9c6b213e20..253810ad59 100644
--- a/cpukit/score/cpu/microblaze/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/microblaze/include/rtems/score/cpu.h
@@ -212,7 +212,7 @@ typedef struct {
     unsigned int _new_msr;  \
     _CPU_MSR_GET(_isr_cookie); \
-    _new_msr = (_isr_cookie) & ~(MICROBLAZE_MSR_IE | MICROBLAZE_MSR_EE); \
+    _new_msr = (_isr_cookie) & ~(MICROBLAZE_MSR_IE); \
     _CPU_MSR_SET(_new_msr); \
@@ -221,9 +221,9 @@ typedef struct {
     uint32_t _microblaze_interrupt_enable; \
     uint32_t _microblaze_switch_reg; \
-    _microblaze_interrupt_enable = (_isr_cookie) & (MICROBLAZE_MSR_IE | MICROBLAZE_MSR_EE); \
+    _microblaze_interrupt_enable = (_isr_cookie) & (MICROBLAZE_MSR_IE); \
     _CPU_MSR_GET(_microblaze_switch_reg); \
-    _microblaze_switch_reg &= ~(MICROBLAZE_MSR_IE | MICROBLAZE_MSR_EE); \
+    _microblaze_switch_reg &= ~(MICROBLAZE_MSR_IE); \
     _microblaze_switch_reg |= _microblaze_interrupt_enable; \
     _CPU_MSR_SET(_microblaze_switch_reg); \
@@ -232,7 +232,7 @@ typedef struct {
     _CPU_MSR_SET(_isr_cookie); \
@@ -242,7 +242,7 @@ uint32_t _CPU_ISR_Get_level( void );
 RTEMS_INLINE_ROUTINE bool _CPU_ISR_Is_enabled( uint32_t level )
-  return ( level & (MICROBLAZE_MSR_IE | MICROBLAZE_MSR_EE) ) != 0;
+  return ( level & MICROBLAZE_MSR_IE ) != 0;
 void _CPU_Context_Initialize(
2.30.2
