[PATCH] added malloc usable size and test
zack leung
zakthertemsdev at gmail.com
Sun Feb 20 02:54:58 UTC 2022
diff --git a/cpukit/include/rtems/libcsupport.h b/cpukit/include/rtems/libcsupport.h
index f4be4cfc9a..ec385bb71a 100644
--- a/cpukit/include/rtems/libcsupport.h
+++ b/cpukit/include/rtems/libcsupport.h
@@ -73,7 +73,10 @@ extern size_t malloc_free_space(void);
* Find amount of free heap remaining.
extern int malloc_info(Heap_Information_block *the_info);
+ * @brief Find the usable size of the block of memory.
+extern size_t malloc_usable_size( void *ptr );
* Prototypes required to install newlib reentrancy user extension
@@ -185,6 +188,7 @@ bool rtems_resource_snapshot_equal(
bool rtems_resource_snapshot_check(const rtems_resource_snapshot *snapshot);
#ifdef __cplusplus
diff --git a/cpukit/libcsupport/src/mallocusablesize.c b/cpukit/libcsupport/src/mallocusablesize.c
new file mode 100644
index 0000000000..d9211b1390
--- /dev/null
+++ b/cpukit/libcsupport/src/mallocusablesize.c
@@ -0,0 +1,51 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2022 Zacchaeus Leung
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/libcsupport.h>
+#include <rtems/malloc.h>
+#include <rtems/score/heapimpl.h>
+size_t malloc_usable_size(void *ptr) {
+ Heap_Control *heap_ptr ;
+ size_t size;
+ if (ptr == NULL) {
+ return 0;
+ heap_ptr = malloc_get_heap_pointer();
+ bool rv=_Heap_Size_of_alloc_area(heap_ptr, ptr, &size);
+ if( rv==false ){
+ return 0;
+ return size;
\ No newline at end of file
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index 7d6dbae0db..5902008c94 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -670,6 +670,7 @@ source:
- cpukit/libcsupport/src/lseek.c
- cpukit/libcsupport/src/lstat.c
- cpukit/libcsupport/src/malloc.c
+- cpukit/libcsupport/src/mallocusablesize.c
- cpukit/libcsupport/src/malloc_deferred.c
- cpukit/libcsupport/src/malloc_dirtier.c
- cpukit/libcsupport/src/malloc_walk.c
diff --git a/testsuites/libtests/malloctest/init.c b/testsuites/libtests/malloctest/init.c
index a33764177d..38f5554440 100644
--- a/testsuites/libtests/malloctest/init.c
+++ b/testsuites/libtests/malloctest/init.c
@@ -1362,6 +1362,18 @@ static void test_alloc_zero_size(void)
rtems_test_assert( p == NULL );
rtems_test_assert( errno == -1 );
+static void test_usablesize(void)
+ int * a = malloc(sizeof( int )*100);
+ int alloc_size=sizeof( int ) *100 ;
+ rtems_test_assert( malloc_usable_size(a) <= alloc_size + CPU_HEAP_ALIGNMENT);
+ free(a);
+ char * b = malloc(sizeof( char )* 100);
+ int alloc_size2=sizeof( char ) * 100;
+ rtems_test_assert( malloc_usable_size ( b ) <= alloc_size2 + CPU_HEAP_ALIGNMENT);
+ free(b);
rtems_task Init(
rtems_task_argument argument
@@ -1405,6 +1417,7 @@ rtems_task Init(
test_protected_heap_info();
test_rtems_heap_allocate_aligned_with_boundary();
test_rtems_malloc();
+ test_usablesize();
test_rtems_calloc();
test_greedy_allocate();
test_alloc_zero_size();
2.35.1
