Using config.ini to specify name for BSP variant on install
Joel Sherrill
joel at rtems.org
Mon Feb 21 16:51:04 UTC 2022
Thanks
On Mon, Feb 21, 2022, 12:19 AM Sebastian Huber <
> On 20/02/2022 18:46, Joel Sherrill wrote:
> > We've had a discussion over on Discord about a BSP variant for a
> > custom Microblaze SoC. Given that it is custom, officially adding a
> > variant to the RTEMS.org source is out of the question. It is possible
> > that the variant can be achieved with just configuration settings. The
> > issue is that the BSP is for the reference board they would also like
> > to have built and installed at the same time. If they build the kcu105
> > with their custom settings, it will install over the kcu105 with the
> > default settings which work on the reference board.
> > Is there a magic bit that takes care of this now? Any thoughts on
> > adding something to achieve this?
> The installation name can be set by the configuration file, for example:
> [sparc/gr740_smp]
> INHERIT = gr740
> RTEMS_SMP = True
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
