[PATCH rtems-examples 00/14] RTEMS Examples Clean Up
Joel Sherrill
joel at rtems.org
Wed Feb 23 22:21:28 UTC 2022
Hi
In using the examples in classes and writing examples for users,
I have accumulated some changes. These changes cover a bit of
territory.
+ Fix build issues
+ Address warnings
+ Fix issues from RTEMS updates
+ General clean up
+ Add some missing files to RTEMS Makefile build
+ Added example of using std::map from RTEMS
+ Added example for restarting a POSIX thread
+ Added example for a User Device Driver accessed via POSIX system calls
+ Added ticker showing stack checker and CPU usage
+ Added ticker with tracing enabled so it wasn't bolted on both_hello
Yes to many of us, some of these examples may not be needed
but they do help users and show real functional approaches.
--joel
Joel Sherrill (23):
Conditionalize CONFIGURE_TERMIOS_DISABLE so the examples span versions
psx_sigint: Add new example of POSIX signal and default mask
psx_initial_sigmask: Add POSIX initial signal mask reporter
psx_sched_report/rtems_config.c: Fix spacing
cxx_stdmap: Add example of using std::map with RTEMS
cxx_throw/wscript: Fix comment
classic_api/triple_period/tasks.c: Clean up formatting
posix_api/psx_example_3/test3.c: Clean up and allow to build on Linux
led/delay/init.c: Use local variable for one second of ticks
led/event_server/init.c: Use names for events to reflect application
intent
Add User Driver Example
Add POSIX task and thread restart examples.
ticker_stackhk: Add variant which prints stack and cpu usage reports
tracing: Add a special ticker variant to show tracing.
posix_api/Makefile ticker/Makefile: Add missing examples
benchmarks/nbench: Fix warnings
classic_api/classic_signal: Fix warnings
misc/minimum/: Fix warnings
misc/nanosecond_tick_wrap: Fix warnings
ticker/low_ticker: Fix warnings
ticker/low_ticker1: Fix warnings
ticker/low_ticker2: Fix warnings
file_io/crc/.gitignore misc/extract_example/.gitignore: New files
benchmarks/nbench/main.c | 3 +-
benchmarks/nbench/nbench-byte-2.2.3/emfloat.c | 6 +
benchmarks/nbench/nbench-byte-2.2.3/hardware.c | 4 +
benchmarks/nbench/nbench-byte-2.2.3/nbench0.c | 1 +
benchmarks/nbench/nbench-byte-2.2.3/nbench1.c | 4 +-
classic_api/classic_signal/test.c | 4 +-
classic_api/triple_period/init.c | 17 +-
classic_api/triple_period/tasks.c | 21 +-
cxx/Makefile | 6 +-
cxx/cxx_stdmap/Makefile | 41 +
cxx/cxx_stdmap/main.cc | 33 +
cxx/cxx_stdmap/rtems_config.c | 47 +
cxx/cxx_stdmap/wscript | 14 +
cxx/cxx_throw/wscript | 2 +-
cxx/wscript | 1 +
file_io/crc/.gitignore | 5 +
hello/both_hello/hello-deep.ini | 47 -
hello/both_hello/hello.ini | 45 -
hello/both_hello/wscript | 22 +-
led/delay/init.c | 10 +-
led/event_server/init.c | 16 +-
misc/Makefile | 2 +-
misc/extract_example/.gitignore | 1 +
misc/minimum/test.c | 22 +-
misc/nanosecond_tick_wrap/init.c | 4 +-
misc/userdrv/Makefile | 20 +
misc/userdrv/main.c | 100 +
misc/userdrv/mainpage.h | 26 +
misc/userdrv/rtems_config.c | 82 +
misc/userdrv/userdrv.c | 254 +++
misc/userdrv/userdrv.cfg | 2280 +++++++++++++++++++++
misc/userdrv/userdrv.h | 264 +++
misc/userdrv/wscript | 14 +
misc/wscript | 1 +
posix_api/Makefile | 3 +
posix_api/psx_example_3/test3.c | 45 +-
posix_api/psx_initial_sigmask/Makefile | 20 +
posix_api/psx_initial_sigmask/main.c | 125 ++
posix_api/psx_initial_sigmask/rtems_config.c | 48 +
posix_api/psx_initial_sigmask/wscript | 15 +
posix_api/psx_sched_report/rtems_config.c | 1 +
posix_api/psx_sigint/Makefile | 20 +
posix_api/psx_sigint/main.c | 99 +
posix_api/psx_sigint/rtems_config.c | 48 +
posix_api/psx_sigint/wscript | 15 +
posix_api/psx_task_restart/Makefile | 20 +
posix_api/psx_task_restart/psx_task_restart.c | 158 ++
posix_api/psx_task_restart/rtems_config.c | 48 +
posix_api/psx_task_restart/wscript | 15 +
posix_api/psx_thread_restart/Makefile | 20 +
posix_api/psx_thread_restart/psx_thread_restart.c | 3 +
posix_api/psx_thread_restart/rtems_config.c | 2 +
posix_api/psx_thread_restart/wscript | 15 +
posix_api/wscript | 3 +
ticker/Makefile | 7 +-
ticker/low_ticker/init.c | 26 +-
ticker/low_ticker1/init.c | 29 +-
ticker/low_ticker2/init.c | 19 +-
ticker/ticker_stackchk/Makefile | 23 +
ticker/ticker_stackchk/init.c | 106 +
ticker/ticker_stackchk/wscript | 15 +
ticker/ticker_trace/Makefile | 23 +
ticker/ticker_trace/init.c | 99 +
ticker/ticker_trace/ticker-deep.ini | 46 +
ticker/ticker_trace/ticker.ini | 43 +
ticker/ticker_trace/wscript | 26 +
ticker/wscript | 7 +-
67 files changed, 4419 insertions(+), 192 deletions(-)
create mode 100644 cxx/cxx_stdmap/Makefile
create mode 100644 cxx/cxx_stdmap/main.cc
create mode 100644 cxx/cxx_stdmap/rtems_config.c
create mode 100644 cxx/cxx_stdmap/wscript
create mode 100644 file_io/crc/.gitignore
delete mode 100644 hello/both_hello/hello-deep.ini
delete mode 100644 hello/both_hello/hello.ini
create mode 100644 misc/extract_example/.gitignore
create mode 100644 misc/userdrv/Makefile
create mode 100644 misc/userdrv/main.c
create mode 100644 misc/userdrv/mainpage.h
create mode 100644 misc/userdrv/rtems_config.c
create mode 100644 misc/userdrv/userdrv.c
create mode 100644 misc/userdrv/userdrv.cfg
create mode 100644 misc/userdrv/userdrv.h
create mode 100644 misc/userdrv/wscript
create mode 100644 posix_api/psx_initial_sigmask/Makefile
create mode 100644 posix_api/psx_initial_sigmask/main.c
create mode 100644 posix_api/psx_initial_sigmask/rtems_config.c
create mode 100644 posix_api/psx_initial_sigmask/wscript
create mode 100644 posix_api/psx_sigint/Makefile
create mode 100644 posix_api/psx_sigint/main.c
create mode 100644 posix_api/psx_sigint/rtems_config.c
create mode 100644 posix_api/psx_sigint/wscript
create mode 100644 posix_api/psx_task_restart/Makefile
create mode 100644 posix_api/psx_task_restart/psx_task_restart.c
create mode 100644 posix_api/psx_task_restart/rtems_config.c
create mode 100644 posix_api/psx_task_restart/wscript
create mode 100644 posix_api/psx_thread_restart/Makefile
create mode 100644 posix_api/psx_thread_restart/psx_thread_restart.c
create mode 100644 posix_api/psx_thread_restart/rtems_config.c
create mode 100644 posix_api/psx_thread_restart/wscript
create mode 100644 ticker/ticker_stackchk/Makefile
create mode 100644 ticker/ticker_stackchk/init.c
create mode 100644 ticker/ticker_stackchk/wscript
create mode 100644 ticker/ticker_trace/Makefile
create mode 100644 ticker/ticker_trace/init.c
create mode 100644 ticker/ticker_trace/ticker-deep.ini
create mode 100644 ticker/ticker_trace/ticker.ini
create mode 100644 ticker/ticker_trace/wscript
1.8.3.1
