[PATCH rtems-examples 02/23] psx_sigint: Add new example of POSIX signal and default mask
Joel Sherrill
joel at rtems.org
Wed Feb 23 22:21:30 UTC 2022
posix_api/Makefile | 1 +
posix_api/psx_sigint/Makefile | 20 ++++++++
posix_api/psx_sigint/main.c | 99 +++++++++++++++++++++++++++++++++++++
posix_api/psx_sigint/rtems_config.c | 48 ++++++++++++++++++
posix_api/psx_sigint/wscript | 15 ++++++
posix_api/wscript | 1 +
6 files changed, 184 insertions(+)
create mode 100644 posix_api/psx_sigint/Makefile
create mode 100644 posix_api/psx_sigint/main.c
create mode 100644 posix_api/psx_sigint/rtems_config.c
create mode 100644 posix_api/psx_sigint/wscript
diff --git a/posix_api/Makefile b/posix_api/Makefile
index 601246c..586758a 100644
--- a/posix_api/Makefile
+++ b/posix_api/Makefile
@@ -14,5 +14,6 @@ ifeq ($(RTEMS_HAS_POSIX_API),yes)
SUBDIRS += psx_pthread_report
SUBDIRS += psx_rwlock_report
SUBDIRS += psx_sched_report
+ SUBDIRS += psx_sigint
SUBDIRS += livermore
endif
diff --git a/posix_api/psx_sigint/Makefile b/posix_api/psx_sigint/Makefile
new file mode 100644
index 0000000..0720473
--- /dev/null
+++ b/posix_api/psx_sigint/Makefile
@@ -0,0 +1,20 @@
+# RTEMS_MAKEFILE_PATH is typically set in an environment variable
+PGM=${ARCH}/psx_sigint.exe
+# C source names
+CSRCS = main.c rtems_config.c
+COBJS = $(CSRCS:%.c=${ARCH}/%.o)
+include $(RTEMS_MAKEFILE_PATH)/Makefile.inc
+include $(RTEMS_CUSTOM)
+include $(PROJECT_ROOT)/make/leaf.cfg
+OBJS= $(COBJS) $(CXXOBJS) $(ASOBJS)
+all: ${ARCH} $(PGM)
+$(PGM): $(OBJS)
+ $(make-exe)
diff --git a/posix_api/psx_sigint/main.c b/posix_api/psx_sigint/main.c
index 0000000..3793650
--- /dev/null
+++ b/posix_api/psx_sigint/main.c
@@ -0,0 +1,99 @@
+ * A C program that does not terminate when SIGINT is generated.
+ * Normally, SIGINT is generated with ctrl-c is pressed.
+#include <errno.h>
+#include <stdio.h>
+#include <signal.h>
+#include <stdlib.h>
+#include <string.h>
+#include <sys/types.h>
+#include <unistd.h>
+ * This program can be conditionally compiled to install the signal
+ * handler with signal() or sigaction(). The distinction is that
+ * using signal() only stays within the confines of the Standard
+ * C Library and does not assume any POSIX APIs or behavior.
+/* #define USE_SIGNAL */
+#define USE_SIGACTION
+/* Signal Handler for SIGINT */
+void sigintHandler(int signo)
+ if (signo != SIGINT) {
+ fprintf(
+ stderr,
+ "signalHandler: signal != SIGINT (%d != %d)\n",
+ signo,
+ SIGINT
+ exit(1);
+#ifdef USE_SIGNAL
+ /* Reset handler to catch SIGINT next time.
+ * Refer http://en.cppreference.com/w/c/program/signal
+ signal(SIGINT, sigintHandler);
+#endif
+ printf("\n Cannot be terminated using Ctrl+C \n");
+ fflush(stdout);
+int main(int argc, char **argv)
+ * POSIX does not appear to define the default signal mask. It discusses
+ * a forked process and created thread inheriting a mask from the creating
+ * process/thread, but not the default initial signal mask.
+ * On RTEMS 4.11 and older, all signals are masked by default for both POSIX
+ * threads and Classic API tasks. With version 5, they are enabled by
+ * default for POSIX threads and disabled by default for Classic API tasks.
+ * On Linux, all signals are unmasked by default.
+ * The following code unmasks the signal of interest.
+#if __rtems__ && (__RTEMS_MAJOR__ < 5)
+ sigset_t old_set,new_set;
+ sigprocmask(SIG_SETMASK, NULL, &old_set);
+ /* printf( "mask=0x%08lx\n", old_set); */
+ sigemptyset(&new_set);
+ sigaddset(&new_set,SIGINT);
+ sigprocmask(SIG_UNBLOCK, &new_set, NULL);
+#endif
+#ifdef USE_SIGNAL
+ /* Set the SIGINT (Ctrl-C) signal handler to sigintHandler
+ Refer http://en.cppreference.com/w/c/program/signal */
+#endif
+#ifdef USE_SIGACTION
+ struct sigaction new_action;
+ int rc;
+ new_action.sa_handler = sigintHandler;
+ new_action.sa_flags = 0;
+ rc = sigaction(SIGINT, &new_action, NULL);
+ if (rc != 0) {
+ fprintf(stderr, "sigaction -> %s\n", strerror(errno));
+#endif
+ int sent_signal = 0;
+ while(1)
+ if (sent_signal == 0) {
+ kill(getpid(), SIGINT);
+ sent_signal = 1;
+ return 0;
diff --git a/posix_api/psx_sigint/rtems_config.c b/posix_api/psx_sigint/rtems_config.c
index 0000000..fd0a0f8
--- /dev/null
+++ b/posix_api/psx_sigint/rtems_config.c
@@ -0,0 +1,48 @@
+ * This file contains the RTEMS Configuration for this example.
+ * Copyright 2018 Joel Sherrill (joel at rtems.org)
+ * This file's license is 2-clause BSD as in this distribution's LICENSE.2 file.
+int main(int argc, char **argv);
+static char *argv_list[] = {
+ "report",
+static void *POSIX_Init(void *arg)
+ (void) arg; /* deliberately ignored */
+ * Initialize optional services
+ * Could get arguments from command line or have a static set.
+ (void) main(1, argv_list);
+ return NULL;
+#include <bsp.h> /* for device driver prototypes */
+/* NOTICE: the clock driver is explicitly disabled */
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_POSIX_INIT_THREAD_TABLE
+#define CONFIGURE_UNLIMITED_OBJECTS
+#define CONFIGURE_UNIFIED_WORK_AREAS
+#define CONFIGURE_MINIMUM_TASK_STACK_SIZE (64 * 1024)
+#define CONFIGURE_INIT
+#include <rtems/confdefs.h>
diff --git a/posix_api/psx_sigint/wscript b/posix_api/psx_sigint/wscript
index 0000000..e09594c
--- /dev/null
+++ b/posix_api/psx_sigint/wscript
@@ -0,0 +1,15 @@
+# Copyright 2013 Gedare Bloom (gedare at rtems.org)
+# This file's license is 2-clause BSD as in this distribution's LICENSE.2 file.
+import rtems_waf.rtems as rtems
+def build(bld):
+ rtems.build(bld)
+ bld(features = 'c cprogram',
+ target = 'psx_sigint.exe',
+ source = ['main.c','rtems_config.c'],
+ lib = ['c'])
diff --git a/posix_api/wscript b/posix_api/wscript
index 912063b..19b6e3e 100644
--- a/posix_api/wscript
+++ b/posix_api/wscript
@@ -17,4 +17,5 @@ def build(bld):
bld.recurse('psx_pthread_report')
bld.recurse('psx_rwlock_report')
bld.recurse('psx_sched_report')
+ bld.recurse('psx_sigint')
bld.recurse('livermore')
1.8.3.1
