[PATCH rtems-examples 13/23] ticker_stackhk: Add variant which prints stack and cpu usage reports
Joel Sherrill
joel at rtems.org
Wed Feb 23 22:21:41 UTC 2022
ticker/ticker_stackchk/Makefile | 23 +++++++++
ticker/ticker_stackchk/init.c | 106 ++++++++++++++++++++++++++++++++++++++++
ticker/ticker_stackchk/wscript | 15 ++++++
ticker/wscript | 6 ++-
4 files changed, 149 insertions(+), 1 deletion(-)
create mode 100644 ticker/ticker_stackchk/Makefile
create mode 100644 ticker/ticker_stackchk/init.c
create mode 100644 ticker/ticker_stackchk/wscript
diff --git a/ticker/ticker_stackchk/Makefile b/ticker/ticker_stackchk/Makefile
new file mode 100644
index 0000000..4347705
--- /dev/null
+++ b/ticker/ticker_stackchk/Makefile
@@ -0,0 +1,23 @@
+# RTEMS_MAKEFILE_PATH is typically set in an environment variable
+PGM=${ARCH}/ticker.exe
+# optional managers required
+MANAGERS=all
+# C source names
+CSRCS = init.c
+COBJS = $(CSRCS:%.c=${ARCH}/%.o)
+include $(RTEMS_MAKEFILE_PATH)/Makefile.inc
+include $(RTEMS_CUSTOM)
+include $(PROJECT_ROOT)/make/leaf.cfg
+OBJS= $(COBJS) $(CXXOBJS) $(ASOBJS)
+all: ${ARCH} $(PGM)
+$(PGM): $(OBJS)
+ $(make-exe)
diff --git a/ticker/ticker_stackchk/init.c b/ticker/ticker_stackchk/init.c
index 0000000..bf34305
--- /dev/null
+++ b/ticker/ticker_stackchk/init.c
@@ -0,0 +1,106 @@
+ * COPYRIGHT (c) 1989-2007.
+ * On-Line Applications Research Corporation (OAR).
+ * http://www.rtems.com/license/LICENSE.
+#include <stdio.h>
+#include <stdlib.h>
+#include <rtems/stackchk.h>
+#include <rtems/cpuuse.h>
+#include <bsp.h>
+#include "../../testmacros.h"
+rtems_id Task_id[ 4 ]; /* array of task ids */
+rtems_name Task_name[ 4 ]; /* array of task names */
+rtems_task Test_task(
+ rtems_task_argument task_index
+ rtems_time_of_day time;
+ rtems_interval ticks;
+ ticks = task_index * 5 * rtems_clock_get_ticks_per_second();
+ for ( ; ; ) {
+ (void) rtems_clock_get_tod( &time );
+ if ( time.second >= 35 ) {
+ puts( "*** END OF CLOCK TICK TEST ***" );
+ rtems_stack_checker_report_usage();
+ puts("");
+ rtems_cpu_usage_report();
+ exit( 0 );
+ put_name( Task_name[ task_index ], FALSE );
+ print_time( " - rtems_clock_get_tod - ", &time, "\n" );
+ (void) rtems_task_wake_after( ticks );
+rtems_task Init(
+ rtems_task_argument argument
+ puts( "\n\n*** CLOCK TICK TEST ***" );
+ time.year = 1988;
+ time.month = 12;
+ time.day = 31;
+ time.hour = 9;
+ time.minute = 0;
+ time.second = 0;
+ time.ticks = 0;
+ (void) rtems_clock_set( &time );
+ Task_name[ 1 ] = rtems_build_name( 'T', 'A', '1', ' ' );
+ Task_name[ 2 ] = rtems_build_name( 'T', 'A', '2', ' ' );
+ Task_name[ 3 ] = rtems_build_name( 'T', 'A', '3', ' ' );
+ (void) rtems_task_create(
+ Task_name[ 1 ], 1, RTEMS_MINIMUM_STACK_SIZE * 2, RTEMS_DEFAULT_MODES,
+ RTEMS_FLOATING_POINT, &Task_id[ 1 ]
+ Task_name[ 2 ], 1, RTEMS_MINIMUM_STACK_SIZE * 2, RTEMS_DEFAULT_MODES,
+ RTEMS_FLOATING_POINT, &Task_id[ 2 ]
+ Task_name[ 3 ], 1, RTEMS_MINIMUM_STACK_SIZE * 2, RTEMS_DEFAULT_MODES,
+ RTEMS_FLOATING_POINT, &Task_id[ 3 ]
+ (void) rtems_task_start( Task_id[ 1 ], Test_task, 1 );
+ (void) rtems_task_start( Task_id[ 2 ], Test_task, 2 );
+ (void) rtems_task_start( Task_id[ 3 ], Test_task, 3 );
+ (void) rtems_task_delete( RTEMS_SELF );
+/**************** START OF CONFIGURATION INFORMATION ****************/
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS 4
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_INIT_TASK_STACK_SIZE (2 * RTEMS_MINIMUM_STACK_SIZE)
+#define CONFIGURE_EXTRA_TASK_STACKS (4 * RTEMS_MINIMUM_STACK_SIZE)
+#define CONFIGURE_STACK_CHECKER_ENABLED
+#include <rtems/confdefs.h>
+/**************** END OF CONFIGURATION INFORMATION ****************/
diff --git a/ticker/ticker_stackchk/wscript b/ticker/ticker_stackchk/wscript
index 0000000..6f4ae3e
--- /dev/null
+++ b/ticker/ticker_stackchk/wscript
@@ -0,0 +1,15 @@
+# Copyright 2013 Gedare Bloom (gedare at rtems.org)
+# This file's license is 2-clause BSD as in this distribution's LICENSE.2 file.
+# Waf build script for an RTEMS Hello
+import rtems_waf.rtems as rtems
+def build(bld):
+ rtems.build(bld)
+ bld(features = 'c cprogram',
+ target = 'ticker_stackchk.exe',
+ source = ['init.c'])
diff --git a/ticker/wscript b/ticker/wscript
index d35629e..df7a45e 100644
--- a/ticker/wscript
+++ b/ticker/wscript
@@ -6,5 +6,9 @@
def build(bld):
- bld.recurse(['ticker', 'low_ticker', 'low_ticker1', 'low_ticker2'])
+ bld.recurse(['ticker',
+ 'ticker_stackchk',
+ 'low_ticker',
+ 'low_ticker1',
+ 'low_ticker2'])
1.8.3.1
