[PATCH rtems-examples 11/23] Add User Driver Example
Wed Feb 23 22:21:39 UTC 2022
 misc/Makefile               |    2 +-
 misc/userdrv/Makefile       |   20 +
 misc/userdrv/main.c         |  100 ++
 misc/userdrv/mainpage.h     |   26 +
 misc/userdrv/rtems_config.c |   82 ++
 misc/userdrv/userdrv.c      |  254 +++++
 misc/userdrv/userdrv.cfg    | 2280 +++++++++++++++++++++++++++++++++++++++++++
 misc/userdrv/userdrv.h      |  264 +++++
 misc/userdrv/wscript        |   14 +
 misc/wscript                |    1 +
 10 files changed, 3042 insertions(+), 1 deletion(-)
 create mode 100644 misc/userdrv/Makefile
 create mode 100644 misc/userdrv/main.c
 create mode 100644 misc/userdrv/mainpage.h
 create mode 100644 misc/userdrv/rtems_config.c
 create mode 100644 misc/userdrv/userdrv.c
 create mode 100644 misc/userdrv/userdrv.cfg
 create mode 100644 misc/userdrv/userdrv.h
 create mode 100644 misc/userdrv/wscript
diff --git a/misc/Makefile b/misc/Makefile
index 3c6507f..ed31598 100644
--- a/misc/Makefile
+++ b/misc/Makefile
@@ -2,7 +2,7 @@ include $(RTEMS_MAKEFILE_PATH)/Makefile.inc
 include $(RTEMS_CUSTOM)
 include $(RTEMS_SHARE)/make/directory.cfg
-SUBDIRS=minimum bspcmdline extract_example nanosecond_tick_wrap
+SUBDIRS=minimum bspcmdline extract_example nanosecond_tick_wrap userdrv
 # If the POSIX API isn't enabled, we can't build these
 ifeq ($(RTEMS_HAS_POSIX_API),yes)
diff --git a/misc/userdrv/Makefile b/misc/userdrv/Makefile
new file mode 100644
index 0000000..cfb6ace
--- /dev/null
+++ b/misc/userdrv/Makefile
@@ -0,0 +1,20 @@
+#  RTEMS_MAKEFILE_PATH is typically set in an environment variable
+PGM=${ARCH}/userdrv.exe
+# C source names
+CSRCS = main.c rtems_config.c userdrv.c
+COBJS = $(CSRCS:%.c=${ARCH}/%.o)
+include $(RTEMS_MAKEFILE_PATH)/Makefile.inc
+include $(RTEMS_CUSTOM)
+include $(PROJECT_ROOT)/make/leaf.cfg
+OBJS= $(COBJS) $(CXXOBJS) $(ASOBJS)
+all:    ${ARCH} $(PGM)
+$(PGM): $(OBJS)
+	$(make-exe)
diff --git a/misc/userdrv/main.c b/misc/userdrv/main.c
index 0000000..880d526
--- /dev/null
+++ b/misc/userdrv/main.c
@@ -0,0 +1,100 @@
+ *  @file
+ *  @brief Program to Exercise Example User Driver
+ * Copyright (C) 2022 OAR Corporation
+ * are met:
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <sys/ioctl.h>
+#include <assert.h>
+#include <sys/types.h>
+#include <sys/stat.h>
+#include <fcntl.h>
+#include <unistd.h>
+#include "userdrv.h"    /* for ioctl numbers */
+int main(
+  int    argc,
+  char **argv
+  int      drv;
+  int      rc;
+  ssize_t  bytes;
+  printf( "\n\n*** USER DRIVER TEST ***\n" );
+  /* Exercise open() */
+  printf( "open(userdrv)\n" );
+  drv = open("/dev/userdrv", O_RDWR);
+  assert(drv != -1);
+  /* Exercise write() */
+  const char string_to_write[] = "Application data to write with driver.";
+  size_t     to_write = strlen(string_to_write);
+  printf( "\nwrite(%d, %s)\n", to_write, string_to_write );
+  bytes = write(drv, string_to_write, to_write);
+  printf("  write() returned bytes written=%d\n", bytes);
+  assert(bytes == to_write);
+// TBD write should be returning number written
+  /* Exercise read() */
+  char   inbuf[80];
+  size_t bufsize = 80;
+  printf( "\nread(%d)\n", bufsize);
+  bytes = read(drv, inbuf, bufsize);
+  printf("  read() returned bytes read=%d\n", bytes);
+  printf("  %d bytes: %s\n", bytes, inbuf);
+  /* Exercise ioctl() */
+  const char *ioctl_string = "ioctl buffer string";
+  printf( "\nioctl(%s)\n", ioctl_string);
+  rc = ioctl(drv, USERDRV_IOCTL_DO_SOMETHING, ioctl_string);
+  assert(rc == 0);
+  printf( "  ioctl() returned %d\n", rc);
+/* TBD */
+  /* Exercise fclose() */
+  printf( "\nclose(userdrv)\n" );
+  rc = close(drv);
+  assert(rc == 0);
+  printf( "  close() returned %d\n", rc);
+  printf( "*** END OF USER DRIVER TEST ***\n" );
+  exit( 0 );
+/* end of file */
diff --git a/misc/userdrv/mainpage.h b/misc/userdrv/mainpage.h
index 0000000..1fa240b
--- /dev/null
+++ b/misc/userdrv/mainpage.h
@@ -0,0 +1,26 @@
+ * @file
+ * @brief Doxygen Main Page for Example User Driver
+ * @mainpage
+ * This is an example RTEMS user driver which is accessed via POSIX system
+ * calls such as open(2), read(2), etc. It is not intended to be used via
+ * the corresponding Standard C Library calls such as fopen(3), fread(3), etc.
+ * The header file documents the interface and what is passed in from the
+ * device driver file adapter.
+ * This is not a particularly exciting device driver. It just prints to
+ * indicate which operations have been invoked, prints strings passed
+ * via write(2), and returns string data via read(2).
+ * It is just a starting point for custom device drivers. It should also
+ * be a good starting point for writing an RTEMS device driver which mimics
+ * the interface provided by a FreeBSD or GNU/Linux device driver which
+ * has a user level library making supporting calls to a device driver.
+ * It is not an example of a driver supporting termios, block access, or
+ * network interfaces.
diff --git a/misc/userdrv/rtems_config.c b/misc/userdrv/rtems_config.c
index 0000000..446e430
--- /dev/null
+++ b/misc/userdrv/rtems_config.c
@@ -0,0 +1,82 @@
+ *  @file
+ *  @brief RTEMS Configuration for Application Using Example User Driver
+ * are met:
+int main(int argc, char **argv);
+static char *argv_list[] = {
+  "userdrv",
+static void *POSIX_Init(void *arg)
+  int rc;
+  (void) arg;  /* deliberately ignored */
+   * Initialize optional services
+   * Could get arguments from command line or have a static set.
+  rc = main(1, argv_list);
+   * Implicitly closes all FILE * and runs C++ global destructors.
+  exit(rc);
+  return NULL;
+#include <bsp.h> /* for device driver prototypes */
+/* NOTICE: the clock driver is explicitly disabled */
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_EXTRA_DRIVERS \
+    USERDRV_DRIVER_TABLE_ENTRY
+#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 4
+#define CONFIGURE_POSIX_INIT_THREAD_TABLE
+#define CONFIGURE_UNLIMITED_OBJECTS
+#define CONFIGURE_UNIFIED_WORK_AREAS
+#define CONFIGURE_MINIMUM_TASK_STACK_SIZE (64 * 1024)
+#define CONFIGURE_INIT
+#include <rtems/confdefs.h>
diff --git a/misc/userdrv/userdrv.c b/misc/userdrv/userdrv.c
index 0000000..2d44926
--- /dev/null
+++ b/misc/userdrv/userdrv.c
@@ -0,0 +1,254 @@
+ * @file
+ * @brief Example User Driver
+ * @ingroup user_driver Device Driver
+ * @brief Example User Device Driver Implementation
+ * are met:
+#include <rtems.h>
+#include <rtems/libio.h>
+#include <rtems/bspIo.h>
+#include <pthread.h>
+ * This is the major number for this device driver. It is stored during
+ * the initialize entry. It is not used in this driver but may be of use
+ * in other cases.
+static uint32_t    USERDRV_major;
+ * This variable indicates whether the driver has been initialized.
+static char initialized = 0;
+rtems_device_driver userdrv_initialize(
+  rtems_device_major_number  major,
+  rtems_device_minor_number  minor RTEMS_UNUSED,
+  void                      *pargp RTEMS_UNUSED
+  rtems_device_driver status;
+  printk("  userdrv_initialize\n");
+   * @internal
+   * If this is the first call to the initialize entry point, then register
+   * the device name(s) for this driver.
+   * If any device specific initialization needs to be done, this is the time.
+   * Initialization of specific instances sometimes can be deferred until the
+   * open entry point.
+  if ( !initialized ) {
+    initialized = 1;
+    status = rtems_io_register_name(
+      "/dev/userdrv",
+      major,
+      (rtems_device_minor_number) 0
+    if (status != RTEMS_SUCCESSFUL)
+      rtems_fatal_error_occurred(status);
+    USERDRV_major = major;
+  return RTEMS_SUCCESSFUL;
+rtems_device_driver userdrv_open(
+  printk("  userdrv_open\n");
+   * @internal
+   * In a more realistic driver, the open entry would validate the minor
+   * number passed in as representing a valid device instance. It may also
+   * keep track of multiple opens and support the device staying open until
+   * the last close.
+   * There may be some hardware initialization that occurs related to the
+   * device instance at this point. For example, a termios driver would
+   * register its callbacks with the termios framework and initialize a UART
+   * with the default settings.
+rtems_device_driver userdrv_close(
+  rtems_device_major_number major RTEMS_UNUSED,
+  printk("  userdrv_close\n");
+   * @internal
+   * In a more realistic driver, the close entry would validate the minor
+   * number passed in as representing a valid device instance. It would also
+   * verify that the device is open before closing it. If tracking nested
+   * open and close operations on the same device instance, that would also
+   * be managed here.
+   * There may be some shutdown for the device instance. For example, it
+   * may be necessary to disable intterrupts from this device instance.
+rtems_device_driver userdrv_read(
+  rtems_libio_rw_args_t *rw_args = (rtems_libio_rw_args_t *) pargp;
+  printk("  userdrv_read\n");
+   * @internal
+   * In a more realistic driver, the read entry would validate the minor
+   * number passed in as representing a valid device instance. There is
+   * likely more error checking on the arguments passed in. But it should
+   * be safe to trust the file system framework to pass the @a argp buffer
+   * as defined.
+  if ( rw_args == NULL ) {
+    printk("  nothing to read\n");
+  if ( rw_args->count == 0 ) {
+    printk("  buffer of zero\n");
+   * @internal
+   * A functional driver would replace this block with code that accesses
+   * the device instance and returns real data if any is available.
+  const char *outstr = "this is output";
+  size_t outlen = 15;
+  rw_args->bytes_moved = outlen;
+  memcpy(rw_args->buffer, outstr, outlen);
+  printk("  %d buffer size\n", rw_args->count);
+  printk("  buffer: %s\n", rw_args->buffer);
+rtems_device_driver userdrv_write(
+  void *pargp
+  printk("  userdrv_write\n");
+   * @internal
+   * In a more realistic driver, the write entry would validate the minor
+   * as defined.
+   * In a real driver, the data to be written would be passed to the device
+   * driver. That may involve interrupts.
+  if ( rw_args ) {
+    printk("  %d to write\n", rw_args->count);
+    rw_args->bytes_moved = rw_args->count;
+  } else {
+    printk("  nothing to write\n");
+    rw_args->bytes_moved = 0;
+rtems_device_driver userdrv_control(
+  rtems_libio_ioctl_args_t *ioctl_args = (rtems_libio_ioctl_args_t *) pargp;
+  rtems_status_code         retval     = RTEMS_SUCCESSFUL;
+  printk("  userdrv_control\n");
+   * @internal
+   * In a more realistic driver, the ioctl entry would validate the minor
+   * number passed in as representing a valid device instance. Then it would
+   * valid the requested ioctl operation number as valid.  There is
+   * as defined.
+  switch (ioctl_args->command) {
+    case USERDRV_IOCTL_DO_SOMETHING:
+      printk( "  Buffer: %s\n", (const char *) ioctl_args->buffer);
+      ioctl_args->ioctl_return = 0;
+      break;
+    default:
+      retval = RTEMS_INVALID_NUMBER;
+  return retval;
diff --git a/misc/userdrv/userdrv.cfg b/misc/userdrv/userdrv.cfg
index 0000000..4ae927d
--- /dev/null
+++ b/misc/userdrv/userdrv.cfg
@@ -0,0 +1,2280 @@
+# Doxyfile 1.8.5
+# This file describes the settings to be used by the documentation system
+# doxygen (www.doxygen.org) for a project.
+# All text after a double hash (##) is considered a comment and is placed in
+# front of the TAG it is preceding.
+# All text after a single hash (#) is considered a comment and will be ignored.
+# The format is:
+# TAG = value [value, ...]
+# For lists, items can also be appended using:
+# TAG += value [value, ...]
+# Values that contain spaces should be placed between quotes (\" \").
+# Project related configuration options
+# This tag specifies the encoding used for all characters in the config file
+# that follow. The default is UTF-8 which is also the encoding used for all text
+# before the first occurrence of this tag. Doxygen uses libiconv (or the iconv
+# built into libc) for the transcoding. See http://www.gnu.org/software/libiconv
+# for the list of possible encodings.
+# The default value is: UTF-8.
+DOXYFILE_ENCODING      = UTF-8
+# The PROJECT_NAME tag is a single word (or a sequence of words surrounded by
+# double-quotes, unless you are using Doxywizard) that should identify the
+# project for which the documentation is generated. This name is used in the
+# title of most generated pages and in a few other places.
+# The default value is: My Project.
+PROJECT_NAME           = "RTEMS Example User Driver"
+# The PROJECT_NUMBER tag can be used to enter a project or revision number. This
+# could be handy for archiving the generated documentation or if some version
+# control system is used.
+PROJECT_NUMBER         =
+# Using the PROJECT_BRIEF tag one can provide an optional one line description
+# for a project that appears at the top of each page and should give viewer a
+# quick idea about the purpose of the project. Keep the description short.
+PROJECT_BRIEF          =
+# With the PROJECT_LOGO tag one can specify an logo or icon that is included in
+# the documentation. The maximum height of the logo should not exceed 55 pixels
+# and the maximum width should not exceed 200 pixels. Doxygen will copy the logo
+# to the output directory.
+PROJECT_LOGO           =
+# The OUTPUT_DIRECTORY tag is used to specify the (relative or absolute) path
+# into which the generated documentation will be written. If a relative path is
+# entered, it will be relative to the location where doxygen was started. If
+# left blank the current directory will be used.
+OUTPUT_DIRECTORY       = doxy
+# If the CREATE_SUBDIRS tag is set to YES, then doxygen will create 4096 sub-
+# directories (in 2 levels) under the output directory of each output format and
+# will distribute the generated files over these directories. Enabling this
+# option can be useful when feeding doxygen a huge amount of source files, where
+# putting all generated files in the same directory would otherwise causes
+# performance problems for the file system.
+# The default value is: NO.
+CREATE_SUBDIRS         = NO
+# The OUTPUT_LANGUAGE tag is used to specify the language in which all
+# documentation generated by doxygen is written. Doxygen will use this
+# information to generate all constant output in the proper language.
+# Possible values are: Afrikaans, Arabic, Brazilian, Catalan, Chinese, Chinese-
+# Traditional, Croatian, Czech, Danish, Dutch, English, Esperanto, Farsi,
+# Finnish, French, German, Greek, Hungarian, Italian, Japanese, Japanese-en,
+# Korean, Korean-en, Latvian, Norwegian, Macedonian, Persian, Polish,
+# Portuguese, Romanian, Russian, Serbian, Slovak, Slovene, Spanish, Swedish,
+# Turkish, Ukrainian and Vietnamese.
+# The default value is: English.
+OUTPUT_LANGUAGE        = English
+# If the BRIEF_MEMBER_DESC tag is set to YES doxygen will include brief member
+# descriptions after the members that are listed in the file and class
+# documentation (similar to Javadoc). Set to NO to disable this.
+# The default value is: YES.
+BRIEF_MEMBER_DESC      = YES
+# If the REPEAT_BRIEF tag is set to YES doxygen will prepend the brief
+# description of a member or function before the detailed description
+# Note: If both HIDE_UNDOC_MEMBERS and BRIEF_MEMBER_DESC are set to NO, the
+# brief descriptions will be completely suppressed.
+REPEAT_BRIEF           = YES
+# This tag implements a quasi-intelligent brief description abbreviator that is
+# used to form the text in various listings. Each string in this list, if found
+# as the leading text of the brief description, will be stripped from the text
+# and the result, after processing the whole list, is used as the annotated
+# text. Otherwise, the brief description is used as-is. If left blank, the
+# following values are used ($name is automatically replaced with the name of
+# the entity):The $name class, The $name widget, The $name file, is, provides,
+# specifies, contains, represents, a, an and the.
+ABBREVIATE_BRIEF       =
+# If the ALWAYS_DETAILED_SEC and REPEAT_BRIEF tags are both set to YES then
+# doxygen will generate a detailed section even if there is only a brief
+# description.
+ALWAYS_DETAILED_SEC    = NO
+# If the INLINE_INHERITED_MEMB tag is set to YES, doxygen will show all
+# inherited members of a class in the documentation of that class as if those
+# members were ordinary class members. Constructors, destructors and assignment
+# operators of the base classes will not be shown.
+INLINE_INHERITED_MEMB  = NO
+# If the FULL_PATH_NAMES tag is set to YES doxygen will prepend the full path
+# before files name in the file list and in the header files. If set to NO the
+# shortest path that makes the file name unique will be used
+FULL_PATH_NAMES        = YES
+# The STRIP_FROM_PATH tag can be used to strip a user-defined part of the path.
+# Stripping is only done if one of the specified strings matches the left-hand
+# part of the path. The tag can be used to show relative paths in the file list.
+# If left blank the directory from which doxygen is run is used as the path to
+# strip.
+# Note that you can specify absolute paths here, but also relative paths, which
+# will be relative from the directory where doxygen is started.
+# This tag requires that the tag FULL_PATH_NAMES is set to YES.
+STRIP_FROM_PATH        =
+# The STRIP_FROM_INC_PATH tag can be used to strip a user-defined part of the
+# path mentioned in the documentation of a class, which tells the reader which
+# header file to include in order to use a class. If left blank only the name of
+# the header file containing the class definition is used. Otherwise one should
+# specify the list of include paths that are normally passed to the compiler
+# using the -I flag.
+STRIP_FROM_INC_PATH    =
+# If the SHORT_NAMES tag is set to YES, doxygen will generate much shorter (but
+# less readable) file names. This can be useful is your file systems doesn't
+# support long names like on DOS, Mac, or CD-ROM.
+SHORT_NAMES            = NO
+# If the JAVADOC_AUTOBRIEF tag is set to YES then doxygen will interpret the
+# first line (until the first dot) of a Javadoc-style comment as the brief
+# description. If set to NO, the Javadoc-style will behave just like regular Qt-
+# style comments (thus requiring an explicit @brief command for a brief
+# description.)
+JAVADOC_AUTOBRIEF      = NO
+# If the QT_AUTOBRIEF tag is set to YES then doxygen will interpret the first
+# line (until the first dot) of a Qt-style comment as the brief description. If
+# set to NO, the Qt-style will behave just like regular Qt-style comments (thus
+# requiring an explicit \brief command for a brief description.)
+QT_AUTOBRIEF           = NO
+# The MULTILINE_CPP_IS_BRIEF tag can be set to YES to make doxygen treat a
+# multi-line C++ special comment block (i.e. a block of //! or /// comments) as
+# a brief description. This used to be the default behavior. The new default is
+# to treat a multi-line C++ comment block as a detailed description. Set this
+# tag to YES if you prefer the old behavior instead.
+# Note that setting this tag to YES also means that rational rose comments are
+# not recognized any more.
+MULTILINE_CPP_IS_BRIEF = NO
+# If the INHERIT_DOCS tag is set to YES then an undocumented member inherits the
+# documentation from any documented member that it re-implements.
+INHERIT_DOCS           = YES
+# If the SEPARATE_MEMBER_PAGES tag is set to YES, then doxygen will produce a
+# new page for each member. If set to NO, the documentation of a member will be
+# part of the file/class/namespace that contains it.
+SEPARATE_MEMBER_PAGES  = NO
+# The TAB_SIZE tag can be used to set the number of spaces in a tab. Doxygen
+# uses this value to replace tabs by spaces in code fragments.
+# Minimum value: 1, maximum value: 16, default value: 4.
+TAB_SIZE               = 4
+# This tag can be used to specify a number of aliases that act as commands in
+# the documentation. An alias has the form:
+# name=value
+# For example adding
+# "sideeffect=@par Side Effects:\n"
+# will allow you to put the command \sideeffect (or @sideeffect) in the
+# documentation, which will result in a user-defined paragraph with heading
+# "Side Effects:". You can put \n's in the value part of an alias to insert
+# newlines.
+ALIASES                =
+# This tag can be used to specify a number of word-keyword mappings (TCL only).
+# A mapping has the form "name=value". For example adding "class=itcl::class"
+# will allow you to use the command class in the itcl::class meaning.
+TCL_SUBST              =
+# Set the OPTIMIZE_OUTPUT_FOR_C tag to YES if your project consists of C sources
+# only. Doxygen will then generate output that is more tailored for C. For
+# instance, some of the names that are used will be different. The list of all
+# members will be omitted, etc.
+OPTIMIZE_OUTPUT_FOR_C  = NO
+# Set the OPTIMIZE_OUTPUT_JAVA tag to YES if your project consists of Java or
+# Python sources only. Doxygen will then generate output that is more tailored
+# for that language. For instance, namespaces will be presented as packages,
+# qualified scopes will look different, etc.
+OPTIMIZE_OUTPUT_JAVA   = NO
+# Set the OPTIMIZE_FOR_FORTRAN tag to YES if your project consists of Fortran
+# sources. Doxygen will then generate output that is tailored for Fortran.
+OPTIMIZE_FOR_FORTRAN   = NO
+# Set the OPTIMIZE_OUTPUT_VHDL tag to YES if your project consists of VHDL
+# sources. Doxygen will then generate output that is tailored for VHDL.
+OPTIMIZE_OUTPUT_VHDL   = NO
+# Doxygen selects the parser to use depending on the extension of the files it
+# parses. With this tag you can assign which parser to use for a given
+# extension. Doxygen has a built-in mapping, but you can override or extend it
+# using this tag. The format is ext=language, where ext is a file extension, and
+# language is one of the parsers supported by doxygen: IDL, Java, Javascript,
+# C#, C, C++, D, PHP, Objective-C, Python, Fortran, VHDL. For instance to make
+# doxygen treat .inc files as Fortran files (default is PHP), and .f files as C
+# (default is Fortran), use: inc=Fortran f=C.
+# Note For files without extension you can use no_extension as a placeholder.
+# Note that for custom extensions you also need to set FILE_PATTERNS otherwise
+# the files are not read by doxygen.
+EXTENSION_MAPPING      =
+# If the MARKDOWN_SUPPORT tag is enabled then doxygen pre-processes all comments
+# according to the Markdown format, which allows for more readable
+# documentation. See http://daringfireball.net/projects/markdown/ for details.
+# The output of markdown processing is further processed by doxygen, so you can
+# mix doxygen, HTML, and XML commands with Markdown formatting. Disable only in
+# case of backward compatibilities issues.
+MARKDOWN_SUPPORT       = YES
+# When enabled doxygen tries to link words that correspond to documented
+# classes, or namespaces to their corresponding documentation. Such a link can
+# be prevented in individual cases by by putting a % sign in front of the word
+# or globally by setting AUTOLINK_SUPPORT to NO.
+AUTOLINK_SUPPORT       = YES
+# If you use STL classes (i.e. std::string, std::vector, etc.) but do not want
+# to include (a tag file for) the STL sources as input, then you should set this
+# tag to YES in order to let doxygen match functions declarations and
+# definitions whose arguments contain STL classes (e.g. func(std::string);
+# versus func(std::string) {}). This also make the inheritance and collaboration
+# diagrams that involve STL classes more complete and accurate.
+BUILTIN_STL_SUPPORT    = NO
+# If you use Microsoft's C++/CLI language, you should set this option to YES to
+# enable parsing support.
+CPP_CLI_SUPPORT        = NO
+# Set the SIP_SUPPORT tag to YES if your project consists of sip (see:
+# http://www.riverbankcomputing.co.uk/software/sip/intro) sources only. Doxygen
+# will parse them like normal C++ but will assume all classes use public instead
+# of private inheritance when no explicit protection keyword is present.
+SIP_SUPPORT            = NO
+# For Microsoft's IDL there are propget and propput attributes to indicate
+# getter and setter methods for a property. Setting this option to YES will make
+# doxygen to replace the get and set methods by a property in the documentation.
+# This will only work if the methods are indeed getting or setting a simple
+# type. If this is not the case, or you want to show the methods anyway, you
+# should set this option to NO.
+IDL_PROPERTY_SUPPORT   = YES
+# If member grouping is used in the documentation and the DISTRIBUTE_GROUP_DOC
+# tag is set to YES, then doxygen will reuse the documentation of the first
+# member in the group (if any) for the other members of the group. By default
+# all members of a group must be documented explicitly.
+DISTRIBUTE_GROUP_DOC   = NO
+# Set the SUBGROUPING tag to YES to allow class member groups of the same type
+# (for instance a group of public functions) to be put as a subgroup of that
+# type (e.g. under the Public Functions section). Set it to NO to prevent
+# subgrouping. Alternatively, this can be done per class using the
+# \nosubgrouping command.
+SUBGROUPING            = YES
+# When the INLINE_GROUPED_CLASSES tag is set to YES, classes, structs and unions
+# are shown inside the group in which they are included (e.g. using \ingroup)
+# instead of on a separate page (for HTML and Man pages) or section (for LaTeX
+# and RTF).
+# Note that this feature does not work in combination with
+# SEPARATE_MEMBER_PAGES.
+INLINE_GROUPED_CLASSES = NO
+# When the INLINE_SIMPLE_STRUCTS tag is set to YES, structs, classes, and unions
+# with only public data fields or simple typedef fields will be shown inline in
+# the documentation of the scope in which they are defined (i.e. file,
+# namespace, or group documentation), provided this scope is documented. If set
+# to NO, structs, classes, and unions are shown on a separate page (for HTML and
+# Man pages) or section (for LaTeX and RTF).
+INLINE_SIMPLE_STRUCTS  = NO
+# When TYPEDEF_HIDES_STRUCT tag is enabled, a typedef of a struct, union, or
+# enum is documented as struct, union, or enum with the name of the typedef. So
+# typedef struct TypeS {} TypeT, will appear in the documentation as a struct
+# with name TypeT. When disabled the typedef will appear as a member of a file,
+# namespace, or class. And the struct will be named TypeS. This can typically be
+# useful for C code in case the coding convention dictates that all compound
+# types are typedef'ed and only the typedef is referenced, never the tag name.
+TYPEDEF_HIDES_STRUCT   = NO
+# The size of the symbol lookup cache can be set using LOOKUP_CACHE_SIZE. This
+# cache is used to resolve symbols given their name and scope. Since this can be
+# an expensive process and often the same symbol appears multiple times in the
+# code, doxygen keeps a cache of pre-resolved symbols. If the cache is too small
+# doxygen will become slower. If the cache is too large, memory is wasted. The
+# cache size is given by this formula: 2^(16+LOOKUP_CACHE_SIZE). The valid range
+# is 0..9, the default is 0, corresponding to a cache size of 2^16=65536
+# symbols. At the end of a run doxygen will report the cache usage and suggest
+# the optimal cache size from a speed point of view.
+# Minimum value: 0, maximum value: 9, default value: 0.
+LOOKUP_CACHE_SIZE      = 0
+# Build related configuration options
+# If the EXTRACT_ALL tag is set to YES doxygen will assume all entities in
+# documentation are documented, even if no documentation was available. Private
+# class members and static file members will be hidden unless the
+# EXTRACT_PRIVATE respectively EXTRACT_STATIC tags are set to YES.
+# Note: This will also disable the warnings about undocumented members that are
+# normally produced when WARNINGS is set to YES.
+EXTRACT_ALL            = NO
+# If the EXTRACT_PRIVATE tag is set to YES all private members of a class will
+# be included in the documentation.
+EXTRACT_PRIVATE        = NO
+# If the EXTRACT_PACKAGE tag is set to YES all members with package or internal
+# scope will be included in the documentation.
+EXTRACT_PACKAGE        = NO
+# If the EXTRACT_STATIC tag is set to YES all static members of a file will be
+# included in the documentation.
+EXTRACT_STATIC         = NO
+# If the EXTRACT_LOCAL_CLASSES tag is set to YES classes (and structs) defined
+# locally in source files will be included in the documentation. If set to NO
+# only classes defined in header files are included. Does not have any effect
+# for Java sources.
+EXTRACT_LOCAL_CLASSES  = YES
+# This flag is only useful for Objective-C code. When set to YES local methods,
+# which are defined in the implementation section but not in the interface are
+# included in the documentation. If set to NO only methods in the interface are
+# included.
+EXTRACT_LOCAL_METHODS  = NO
+# If this flag is set to YES, the members of anonymous namespaces will be
+# extracted and appear in the documentation as a namespace called
+# 'anonymous_namespace{file}', where file will be replaced with the base name of
+# the file that contains the anonymous namespace. By default anonymous namespace
+# are hidden.
+EXTRACT_ANON_NSPACES   = NO
+# If the HIDE_UNDOC_MEMBERS tag is set to YES, doxygen will hide all
+# undocumented members inside documented classes or files. If set to NO these
+# members will be included in the various overviews, but no documentation
+# section is generated. This option has no effect if EXTRACT_ALL is enabled.
+HIDE_UNDOC_MEMBERS     = NO
+# If the HIDE_UNDOC_CLASSES tag is set to YES, doxygen will hide all
+# undocumented classes that are normally visible in the class hierarchy. If set
+# to NO these classes will be included in the various overviews. This option has
+# no effect if EXTRACT_ALL is enabled.
+HIDE_UNDOC_CLASSES     = NO
+# If the HIDE_FRIEND_COMPOUNDS tag is set to YES, doxygen will hide all friend
+# (class|struct|union) declarations. If set to NO these declarations will be
+HIDE_FRIEND_COMPOUNDS  = NO
+# If the HIDE_IN_BODY_DOCS tag is set to YES, doxygen will hide any
+# documentation blocks found inside the body of a function. If set to NO these
+# blocks will be appended to the function's detailed documentation block.
+HIDE_IN_BODY_DOCS      = NO
+# The INTERNAL_DOCS tag determines if documentation that is typed after a
+# \internal command is included. If the tag is set to NO then the documentation
+# will be excluded. Set it to YES to include the internal documentation.
+INTERNAL_DOCS          = YES
+# If the CASE_SENSE_NAMES tag is set to NO then doxygen will only generate file
+# names in lower-case letters. If set to YES upper-case letters are also
+# allowed. This is useful if you have classes or files whose names only differ
+# in case and if your file system supports case sensitive file names. Windows
+# and Mac users are advised to set this option to NO.
+# The default value is: system dependent.
+CASE_SENSE_NAMES       = YES
+# If the HIDE_SCOPE_NAMES tag is set to NO then doxygen will show members with
+# their full class and namespace scopes in the documentation. If set to YES the
+# scope will be hidden.
+HIDE_SCOPE_NAMES       = NO
+# If the SHOW_INCLUDE_FILES tag is set to YES then doxygen will put a list of
+# the files that are included by a file in the documentation of that file.
+SHOW_INCLUDE_FILES     = YES
+# If the FORCE_LOCAL_INCLUDES tag is set to YES then doxygen will list include
+# files with double quotes in the documentation rather than with sharp brackets.
+FORCE_LOCAL_INCLUDES   = NO
+# If the INLINE_INFO tag is set to YES then a tag [inline] is inserted in the
+# documentation for inline members.
+INLINE_INFO            = YES
+# If the SORT_MEMBER_DOCS tag is set to YES then doxygen will sort the
+# (detailed) documentation of file and class members alphabetically by member
+# name. If set to NO the members will appear in declaration order.
+SORT_MEMBER_DOCS       = YES
+# If the SORT_BRIEF_DOCS tag is set to YES then doxygen will sort the brief
+# descriptions of file, namespace and class members alphabetically by member
+SORT_BRIEF_DOCS        = NO
+# If the SORT_MEMBERS_CTORS_1ST tag is set to YES then doxygen will sort the
+# (brief and detailed) documentation of class members so that constructors and
+# destructors are listed first. If set to NO the constructors will appear in the
+# respective orders defined by SORT_BRIEF_DOCS and SORT_MEMBER_DOCS.
+# Note: If SORT_BRIEF_DOCS is set to NO this option is ignored for sorting brief
+# member documentation.
+# Note: If SORT_MEMBER_DOCS is set to NO this option is ignored for sorting
+# detailed member documentation.
+SORT_MEMBERS_CTORS_1ST = NO
+# If the SORT_GROUP_NAMES tag is set to YES then doxygen will sort the hierarchy
+# of group names into alphabetical order. If set to NO the group names will
+# appear in their defined order.
+SORT_GROUP_NAMES       = NO
+# If the SORT_BY_SCOPE_NAME tag is set to YES, the class list will be sorted by
+# fully-qualified names, including namespaces. If set to NO, the class list will
+# be sorted only by class name, not including the namespace part.
+# Note: This option is not very useful if HIDE_SCOPE_NAMES is set to YES.
+# Note: This option applies only to the class list, not to the alphabetical
+# list.
+SORT_BY_SCOPE_NAME     = NO
+# If the STRICT_PROTO_MATCHING option is enabled and doxygen fails to do proper
+# type resolution of all parameters of a function it will reject a match between
+# the prototype and the implementation of a member function even if there is
+# only one candidate or it is obvious which candidate to choose by doing a
+# simple string match. By disabling STRICT_PROTO_MATCHING doxygen will still
+# accept a match between prototype and implementation in such cases.
+STRICT_PROTO_MATCHING  = NO
+# The GENERATE_TODOLIST tag can be used to enable ( YES) or disable ( NO) the
+# todo list. This list is created by putting \todo commands in the
+# documentation.
+GENERATE_TODOLIST      = YES
+# The GENERATE_TESTLIST tag can be used to enable ( YES) or disable ( NO) the
+# test list. This list is created by putting \test commands in the
+# documentation.
+GENERATE_TESTLIST      = YES
+# The GENERATE_BUGLIST tag can be used to enable ( YES) or disable ( NO) the bug
+# list. This list is created by putting \bug commands in the documentation.
+GENERATE_BUGLIST       = YES
+# The GENERATE_DEPRECATEDLIST tag can be used to enable ( YES) or disable ( NO)
+# the deprecated list. This list is created by putting \deprecated commands in
+GENERATE_DEPRECATEDLIST= YES
+# The ENABLED_SECTIONS tag can be used to enable conditional documentation
+# sections, marked by \if <section_label> ... \endif and \cond <section_label>
+# ... \endcond blocks.
+ENABLED_SECTIONS       =
+# The MAX_INITIALIZER_LINES tag determines the maximum number of lines that the
+# initial value of a variable or macro / define can have for it to appear in the
+# documentation. If the initializer consists of more lines than specified here
+# it will be hidden. Use a value of 0 to hide initializers completely. The
+# appearance of the value of individual variables and macros / defines can be
+# controlled using \showinitializer or \hideinitializer command in the
+# documentation regardless of this setting.
+# Minimum value: 0, maximum value: 10000, default value: 30.
+MAX_INITIALIZER_LINES  = 30
+# Set the SHOW_USED_FILES tag to NO to disable the list of files generated at
+# the bottom of the documentation of classes and structs. If set to YES the list
+# will mention the files that were used to generate the documentation.
+SHOW_USED_FILES        = YES
+# Set the SHOW_FILES tag to NO to disable the generation of the Files page. This
+# will remove the Files entry from the Quick Index and from the Folder Tree View
+# (if specified).
+SHOW_FILES             = YES
+# Set the SHOW_NAMESPACES tag to NO to disable the generation of the Namespaces
+# page. This will remove the Namespaces entry from the Quick Index and from the
+# Folder Tree View (if specified).
+SHOW_NAMESPACES        = YES
+# The FILE_VERSION_FILTER tag can be used to specify a program or script that
+# doxygen should invoke to get the current version for each file (typically from
+# the version control system). Doxygen will invoke the program by executing (via
+# popen()) the command command input-file, where command is the value of the
+# FILE_VERSION_FILTER tag, and input-file is the name of an input file provided
+# by doxygen. Whatever the program writes to standard output is used as the file
+# version. For an example see the documentation.
+FILE_VERSION_FILTER    =
+# The LAYOUT_FILE tag can be used to specify a layout file which will be parsed
+# by doxygen. The layout file controls the global structure of the generated
+# output files in an output format independent way. To create the layout file
+# that represents doxygen's defaults, run doxygen with the -l option. You can
+# optionally specify a file name after the option, if omitted DoxygenLayout.xml
+# will be used as the name of the layout file.
+# Note that if you run doxygen from a directory containing a file called
+# DoxygenLayout.xml, doxygen will parse it automatically even if the LAYOUT_FILE
+# tag is left empty.
+LAYOUT_FILE            =
+# The CITE_BIB_FILES tag can be used to specify one or more bib files containing
+# the reference definitions. This must be a list of .bib files. The .bib
+# extension is automatically appended if omitted. This requires the bibtex tool
+# to be installed. See also http://en.wikipedia.org/wiki/BibTeX for more info.
+# For LaTeX the style of the bibliography can be controlled using
+# LATEX_BIB_STYLE. To use this feature you need bibtex and perl available in the
+# search path. Do not use file names with spaces, bibtex cannot handle them. See
+# also \cite for info how to create references.
+CITE_BIB_FILES         =
+# Configuration options related to warning and progress messages
+# The QUIET tag can be used to turn on/off the messages that are generated to
+# standard output by doxygen. If QUIET is set to YES this implies that the
+# messages are off.
+QUIET                  = NO
+# The WARNINGS tag can be used to turn on/off the warning messages that are
+# generated to standard error ( stderr) by doxygen. If WARNINGS is set to YES
+# this implies that the warnings are on.
+# Tip: Turn warnings on while writing the documentation.
+WARNINGS               = YES
+# If the WARN_IF_UNDOCUMENTED tag is set to YES, then doxygen will generate
+# warnings for undocumented members. If EXTRACT_ALL is set to YES then this flag
+# will automatically be disabled.
+WARN_IF_UNDOCUMENTED   = YES
+# If the WARN_IF_DOC_ERROR tag is set to YES, doxygen will generate warnings for
+# potential errors in the documentation, such as not documenting some parameters
+# in a documented function, or documenting parameters that don't exist or using
+# markup commands wrongly.
+WARN_IF_DOC_ERROR      = YES
+# This WARN_NO_PARAMDOC option can be enabled to get warnings for functions that
+# are documented, but have no documentation for their parameters or return
+# value. If set to NO doxygen will only warn about wrong or incomplete parameter
+# documentation, but not about the absence of documentation.
+WARN_NO_PARAMDOC       = NO
+# The WARN_FORMAT tag determines the format of the warning messages that doxygen
+# can produce. The string should contain the $file, $line, and $text tags, which
+# will be replaced by the file and line number from which the warning originated
+# and the warning text. Optionally the format may contain $version, which will
+# be replaced by the version of the file (if it could be obtained via
+# FILE_VERSION_FILTER)
+# The default value is: $file:$line: $text.
+WARN_FORMAT            = "$file:$line: $text"
+# The WARN_LOGFILE tag can be used to specify a file to which warning and error
+# messages should be written. If left blank the output is written to standard
+# error (stderr).
+WARN_LOGFILE           =
+# Configuration options related to the input files
+# The INPUT tag is used to specify the files and/or directories that contain
+# documented source files. You may enter file names like myfile.cpp or
+# directories like /usr/src/myproject. Separate the files or directories with
+# spaces.
+# Note: If this tag is empty the current directory is searched.
+INPUT                  =
+# This tag can be used to specify the character encoding of the source files
+# that doxygen parses. Internally doxygen uses the UTF-8 encoding. Doxygen uses
+# libiconv (or the iconv built into libc) for the transcoding. See the libiconv
+# documentation (see: http://www.gnu.org/software/libiconv) for the list of
+# possible encodings.
+INPUT_ENCODING         = UTF-8
+# If the value of the INPUT tag contains directories, you can use the
+# FILE_PATTERNS tag to specify one or more wildcard patterns (like *.cpp and
+# *.h) to filter out the source-files in the directories. If left blank the
+# following patterns are tested:*.c, *.cc, *.cxx, *.cpp, *.c++, *.java, *.ii,
+# *.ixx, *.ipp, *.i++, *.inl, *.idl, *.ddl, *.odl, *.h, *.hh, *.hxx, *.hpp,
+# *.h++, *.cs, *.d, *.php, *.php4, *.php5, *.phtml, *.inc, *.m, *.markdown,
+# *.md, *.mm, *.dox, *.py, *.f90, *.f, *.for, *.tcl, *.vhd, *.vhdl, *.ucf,
+# *.qsf, *.as and *.js.
+FILE_PATTERNS          =
+# The RECURSIVE tag can be used to specify whether or not subdirectories should
+# be searched for input files as well.
+RECURSIVE              = NO
+# The EXCLUDE tag can be used to specify files and/or directories that should be
+# excluded from the INPUT source files. This way you can easily exclude a
+# subdirectory from a directory tree whose root is specified with the INPUT tag.
+# Note that relative paths are relative to the directory from which doxygen is
+# run.
+EXCLUDE                =
+# The EXCLUDE_SYMLINKS tag can be used to select whether or not files or
+# directories that are symbolic links (a Unix file system feature) are excluded
+# from the input.
+EXCLUDE_SYMLINKS       = NO
+# EXCLUDE_PATTERNS tag to specify one or more wildcard patterns to exclude
+# certain files from those directories.
+# Note that the wildcards are matched against the file with absolute path, so to
+# exclude all test directories for example use the pattern */test/*
+EXCLUDE_PATTERNS       =
+# The EXCLUDE_SYMBOLS tag can be used to specify one or more symbol names
+# (namespaces, classes, functions, etc.) that should be excluded from the
+# output. The symbol name can be a fully qualified name, a word, or if the
+# wildcard * is used, a substring. Examples: ANamespace, AClass,
+# AClass::ANamespace, ANamespace::*Test
+# exclude all test directories use the pattern */test/*
+EXCLUDE_SYMBOLS        =
+# The EXAMPLE_PATH tag can be used to specify one or more files or directories
+# that contain example code fragments that are included (see the \include
+# command).
+EXAMPLE_PATH           =
+# If the value of the EXAMPLE_PATH tag contains directories, you can use the
+# EXAMPLE_PATTERNS tag to specify one or more wildcard pattern (like *.cpp and
+# *.h) to filter out the source-files in the directories. If left blank all
+# files are included.
+EXAMPLE_PATTERNS       =
+# If the EXAMPLE_RECURSIVE tag is set to YES then subdirectories will be
+# searched for input files to be used with the \include or \dontinclude commands
+# irrespective of the value of the RECURSIVE tag.
+EXAMPLE_RECURSIVE      = NO
+# The IMAGE_PATH tag can be used to specify one or more files or directories
+# that contain images that are to be included in the documentation (see the
+# \image command).
+IMAGE_PATH             =
+# The INPUT_FILTER tag can be used to specify a program that doxygen should
+# invoke to filter for each input file. Doxygen will invoke the filter program
+# by executing (via popen()) the command:
+# <filter> <input-file>
+# where <filter> is the value of the INPUT_FILTER tag, and <input-file> is the
+# name of an input file. Doxygen will then use the output that the filter
+# program writes to standard output. If FILTER_PATTERNS is specified, this tag
+# will be ignored.
+# Note that the filter must not add or remove lines; it is applied before the
+# code is scanned, but not when the output code is generated. If lines are added
+# or removed, the anchors will not be placed correctly.
+INPUT_FILTER           =
+# The FILTER_PATTERNS tag can be used to specify filters on a per file pattern
+# basis. Doxygen will compare the file name with each pattern and apply the
+# filter if there is a match. The filters are a list of the form: pattern=filter
+# (like *.cpp=my_cpp_filter). See INPUT_FILTER for further information on how
+# filters are used. If the FILTER_PATTERNS tag is empty or if none of the
+# patterns match the file name, INPUT_FILTER is applied.
+FILTER_PATTERNS        =
+# If the FILTER_SOURCE_FILES tag is set to YES, the input filter (if set using
+# INPUT_FILTER ) will also be used to filter the input files that are used for
+# producing the source files to browse (i.e. when SOURCE_BROWSER is set to YES).
+FILTER_SOURCE_FILES    = NO
+# The FILTER_SOURCE_PATTERNS tag can be used to specify source filters per file
+# pattern. A pattern will override the setting for FILTER_PATTERN (if any) and
+# it is also possible to disable source filtering for a specific pattern using
+# *.ext= (so without naming a filter).
+# This tag requires that the tag FILTER_SOURCE_FILES is set to YES.
+FILTER_SOURCE_PATTERNS =
+# If the USE_MDFILE_AS_MAINPAGE tag refers to the name of a markdown file that
+# is part of the input, its contents will be placed on the main page
+# (index.html). This can be useful if you have a project on for instance GitHub
+# and want to reuse the introduction page also for the doxygen output.
+USE_MDFILE_AS_MAINPAGE =
+# Configuration options related to source browsing
+# If the SOURCE_BROWSER tag is set to YES then a list of source files will be
+# generated. Documented entities will be cross-referenced with these sources.
+# Note: To get rid of all source code in the generated output, make sure that
+# also VERBATIM_HEADERS is set to NO.
+SOURCE_BROWSER         = NO
+# Setting the INLINE_SOURCES tag to YES will include the body of functions,
+# classes and enums directly into the documentation.
+INLINE_SOURCES         = NO
+# Setting the STRIP_CODE_COMMENTS tag to YES will instruct doxygen to hide any
+# special comment blocks from generated source code fragments. Normal C, C++ and
+# Fortran comments will always remain visible.
+STRIP_CODE_COMMENTS    = YES
+# If the REFERENCED_BY_RELATION tag is set to YES then for each documented
+# function all documented functions referencing it will be listed.
+REFERENCED_BY_RELATION = NO
+# If the REFERENCES_RELATION tag is set to YES then for each documented function
+# all documented entities called/used by that function will be listed.
+REFERENCES_RELATION    = NO
+# If the REFERENCES_LINK_SOURCE tag is set to YES and SOURCE_BROWSER tag is set
+# to YES, then the hyperlinks from functions in REFERENCES_RELATION and
+# REFERENCED_BY_RELATION lists will link to the source code. Otherwise they will
+# link to the documentation.
+REFERENCES_LINK_SOURCE = YES
+# If SOURCE_TOOLTIPS is enabled (the default) then hovering a hyperlink in the
+# source code will show a tooltip with additional information such as prototype,
+# brief description and links to the definition and documentation. Since this
+# will make the HTML file larger and loading of large files a bit slower, you
+# can opt to disable this feature.
+# This tag requires that the tag SOURCE_BROWSER is set to YES.
+SOURCE_TOOLTIPS        = YES
+# If the USE_HTAGS tag is set to YES then the references to source code will
+# point to the HTML generated by the htags(1) tool instead of doxygen built-in
+# source browser. The htags tool is part of GNU's global source tagging system
+# (see http://www.gnu.org/software/global/global.html). You will need version
+# 4.8.6 or higher.
+# To use it do the following:
+# - Install the latest version of global
+# - Enable SOURCE_BROWSER and USE_HTAGS in the config file
+# - Make sure the INPUT points to the root of the source tree
+# - Run doxygen as normal
+# Doxygen will invoke htags (and that will in turn invoke gtags), so these
+# tools must be available from the command line (i.e. in the search path).
+# The result: instead of the source browser generated by doxygen, the links to
+# source code will now point to the output of htags.
+USE_HTAGS              = NO
+# If the VERBATIM_HEADERS tag is set the YES then doxygen will generate a
+# verbatim copy of the header file for each class for which an include is
+# specified. Set to NO to disable this.
+# See also: Section \class.
+VERBATIM_HEADERS       = YES
+# Configuration options related to the alphabetical class index
+# If the ALPHABETICAL_INDEX tag is set to YES, an alphabetical index of all
+# compounds will be generated. Enable this if the project contains a lot of
+# classes, structs, unions or interfaces.
+ALPHABETICAL_INDEX     = YES
+# The COLS_IN_ALPHA_INDEX tag can be used to specify the number of columns in
+# which the alphabetical index list will be split.
+# Minimum value: 1, maximum value: 20, default value: 5.
+# This tag requires that the tag ALPHABETICAL_INDEX is set to YES.
+COLS_IN_ALPHA_INDEX    = 5
+# In case all classes in a project start with a common prefix, all classes will
+# be put under the same header in the alphabetical index. The IGNORE_PREFIX tag
+# can be used to specify a prefix (or a list of prefixes) that should be ignored
+# while generating the index headers.
+IGNORE_PREFIX          =
+# Configuration options related to the HTML output
+# If the GENERATE_HTML tag is set to YES doxygen will generate HTML output
+GENERATE_HTML          = YES
+# The HTML_OUTPUT tag is used to specify where the HTML docs will be put. If a
+# relative path is entered the value of OUTPUT_DIRECTORY will be put in front of
+# it.
+# The default directory is: html.
+# This tag requires that the tag GENERATE_HTML is set to YES.
+HTML_OUTPUT            = html
+# The HTML_FILE_EXTENSION tag can be used to specify the file extension for each
+# generated HTML page (for example: .htm, .php, .asp).
+# The default value is: .html.
+HTML_FILE_EXTENSION    = .html
+# The HTML_HEADER tag can be used to specify a user-defined HTML header file for
+# each generated HTML page. If the tag is left blank doxygen will generate a
+# standard header.
+# To get valid HTML the header file that includes any scripts and style sheets
+# that doxygen needs, which is dependent on the configuration options used (e.g.
+# the setting GENERATE_TREEVIEW). It is highly recommended to start with a
+# default header using
+# doxygen -w html new_header.html new_footer.html new_stylesheet.css
+# YourConfigFile
+# and then modify the file new_header.html. See also section "Doxygen usage"
+# for information on how to generate the default header that doxygen normally
+# uses.
+# Note: The header is subject to change so you typically have to regenerate the
+# default header when upgrading to a newer version of doxygen. For a description
+# of the possible markers and block names see the documentation.
+HTML_HEADER            =
+# The HTML_FOOTER tag can be used to specify a user-defined HTML footer for each
+# generated HTML page. If the tag is left blank doxygen will generate a standard
+# footer. See HTML_HEADER for more information on how to generate a default
+# footer and what special commands can be used inside the footer. See also
+# section "Doxygen usage" for information on how to generate the default footer
+# that doxygen normally uses.
+HTML_FOOTER            =
+# The HTML_STYLESHEET tag can be used to specify a user-defined cascading style
+# sheet that is used by each HTML page. It can be used to fine-tune the look of
+# the HTML output. If left blank doxygen will generate a default style sheet.
+# See also section "Doxygen usage" for information on how to generate the style
+# sheet that doxygen normally uses.
+# Note: It is recommended to use HTML_EXTRA_STYLESHEET instead of this tag, as
+# it is more robust and this tag (HTML_STYLESHEET) will in the future become
+# obsolete.
+HTML_STYLESHEET        =
+# The HTML_EXTRA_STYLESHEET tag can be used to specify an additional user-
+# defined cascading style sheet that is included after the standard style sheets
+# created by doxygen. Using this option one can overrule certain style aspects.
+# This is preferred over using HTML_STYLESHEET since it does not replace the
+# standard style sheet and is therefor more robust against future updates.
+# Doxygen will copy the style sheet file to the output directory. For an example
+# see the documentation.
+HTML_EXTRA_STYLESHEET  =
+# The HTML_EXTRA_FILES tag can be used to specify one or more extra images or
+# other source files which should be copied to the HTML output directory. Note
+# that these files will be copied to the base HTML output directory. Use the
+# $relpath^ marker in the HTML_HEADER and/or HTML_FOOTER files to load these
+# files. In the HTML_STYLESHEET file, use the file name only. Also note that the
+# files will be copied as-is; there are no commands or markers available.
+HTML_EXTRA_FILES       =
+# The HTML_COLORSTYLE_HUE tag controls the color of the HTML output. Doxygen
+# will adjust the colors in the stylesheet and background images according to
+# this color. Hue is specified as an angle on a colorwheel, see
+# http://en.wikipedia.org/wiki/Hue for more information. For instance the value
+# 0 represents red, 60 is yellow, 120 is green, 180 is cyan, 240 is blue, 300
+# purple, and 360 is red again.
+# Minimum value: 0, maximum value: 359, default value: 220.
+HTML_COLORSTYLE_HUE    = 220
+# The HTML_COLORSTYLE_SAT tag controls the purity (or saturation) of the colors
+# in the HTML output. For a value of 0 the output will use grayscales only. A
+# value of 255 will produce the most vivid colors.
+# Minimum value: 0, maximum value: 255, default value: 100.
+HTML_COLORSTYLE_SAT    = 100
+# The HTML_COLORSTYLE_GAMMA tag controls the gamma correction applied to the
+# luminance component of the colors in the HTML output. Values below 100
+# gradually make the output lighter, whereas values above 100 make the output
+# darker. The value divided by 100 is the actual gamma applied, so 80 represents
+# a gamma of 0.8, The value 220 represents a gamma of 2.2, and 100 does not
+# change the gamma.
+# Minimum value: 40, maximum value: 240, default value: 80.
+HTML_COLORSTYLE_GAMMA  = 80
+# If the HTML_TIMESTAMP tag is set to YES then the footer of each generated HTML
+# page will contain the date and time when the page was generated. Setting this
+# to NO can help when comparing the output of multiple runs.
+HTML_TIMESTAMP         = NO
+# If the HTML_DYNAMIC_SECTIONS tag is set to YES then the generated HTML
+# documentation will contain sections that can be hidden and shown after the
+# page has loaded.
+HTML_DYNAMIC_SECTIONS  = NO
+# With HTML_INDEX_NUM_ENTRIES one can control the preferred number of entries
+# shown in the various tree structured indices initially; the user can expand
+# and collapse entries dynamically later on. Doxygen will expand the tree to
+# such a level that at most the specified number of entries are visible (unless
+# a fully collapsed tree already exceeds this amount). So setting the number of
+# entries 1 will produce a full collapsed tree by default. 0 is a special value
+# representing an infinite number of entries and will result in a full expanded
+# tree by default.
+# Minimum value: 0, maximum value: 9999, default value: 100.
+HTML_INDEX_NUM_ENTRIES = 100
+# If the GENERATE_DOCSET tag is set to YES, additional index files will be
+# generated that can be used as input for Apple's Xcode 3 integrated development
+# environment (see: http://developer.apple.com/tools/xcode/), introduced with
+# OSX 10.5 (Leopard). To create a documentation set, doxygen will generate a
+# Makefile in the HTML output directory. Running make will produce the docset in
+# that directory and running make install will install the docset in
+# ~/Library/Developer/Shared/Documentation/DocSets so that Xcode will find it at
+# startup. See http://developer.apple.com/tools/creatingdocsetswithdoxygen.html
+# for more information.
+GENERATE_DOCSET        = NO
+# This tag determines the name of the docset feed. A documentation feed provides
+# an umbrella under which multiple documentation sets from a single provider
+# (such as a company or product suite) can be grouped.
+# The default value is: Doxygen generated docs.
+# This tag requires that the tag GENERATE_DOCSET is set to YES.
+DOCSET_FEEDNAME        = "Doxygen generated docs"
+# This tag specifies a string that should uniquely identify the documentation
+# set bundle. This should be a reverse domain-name style string, e.g.
+# com.mycompany.MyDocSet. Doxygen will append .docset to the name.
+# The default value is: org.doxygen.Project.
+DOCSET_BUNDLE_ID       = org.doxygen.Project
+# The DOCSET_PUBLISHER_ID tag specifies a string that should uniquely identify
+# the documentation publisher. This should be a reverse domain-name style
+# string, e.g. com.mycompany.MyDocSet.documentation.
+# The default value is: org.doxygen.Publisher.
+DOCSET_PUBLISHER_ID    = org.doxygen.Publisher
+# The DOCSET_PUBLISHER_NAME tag identifies the documentation publisher.
+# The default value is: Publisher.
+DOCSET_PUBLISHER_NAME  = Publisher
+# If the GENERATE_HTMLHELP tag is set to YES then doxygen generates three
+# additional HTML index files: index.hhp, index.hhc, and index.hhk. The
+# index.hhp is a project file that can be read by Microsoft's HTML Help Workshop
+# (see: http://www.microsoft.com/en-us/download/details.aspx?id=21138) on
+# Windows.
+# The HTML Help Workshop contains a compiler that can convert all HTML output
+# generated by doxygen into a single compiled HTML file (.chm). Compiled HTML
+# files are now used as the Windows 98 help format, and will replace the old
+# Windows help format (.hlp) on all Windows platforms in the future. Compressed
+# HTML files also contain an index, a table of contents, and you can search for
+# words in the documentation. The HTML workshop also contains a viewer for
+# compressed HTML files.
+GENERATE_HTMLHELP      = NO
+# The CHM_FILE tag can be used to specify the file name of the resulting .chm
+# file. You can add a path in front of the file if the result should not be
+# written to the html output directory.
+# This tag requires that the tag GENERATE_HTMLHELP is set to YES.
+CHM_FILE               =
+# The HHC_LOCATION tag can be used to specify the location (absolute path
+# including file name) of the HTML help compiler ( hhc.exe). If non-empty
+# doxygen will try to run the HTML help compiler on the generated index.hhp.
+# The file has to be specified with full path.
+HHC_LOCATION           =
+# The GENERATE_CHI flag controls if a separate .chi index file is generated (
+# YES) or that it should be included in the master .chm file ( NO).
+GENERATE_CHI           = NO
+# The CHM_INDEX_ENCODING is used to encode HtmlHelp index ( hhk), content ( hhc)
+# and project file content.
+CHM_INDEX_ENCODING     =
+# The BINARY_TOC flag controls whether a binary table of contents is generated (
+# YES) or a normal table of contents ( NO) in the .chm file.
+BINARY_TOC             = NO
+# The TOC_EXPAND flag can be set to YES to add extra items for group members to
+# the table of contents of the HTML help documentation and to the tree view.
+TOC_EXPAND             = NO
+# If the GENERATE_QHP tag is set to YES and both QHP_NAMESPACE and
+# QHP_VIRTUAL_FOLDER are set, an additional index file will be generated that
+# can be used as input for Qt's qhelpgenerator to generate a Qt Compressed Help
+# (.qch) of the generated HTML documentation.
+GENERATE_QHP           = NO
+# If the QHG_LOCATION tag is specified, the QCH_FILE tag can be used to specify
+# the file name of the resulting .qch file. The path specified is relative to
+# the HTML output folder.
+# This tag requires that the tag GENERATE_QHP is set to YES.
+QCH_FILE               =
+# The QHP_NAMESPACE tag specifies the namespace to use when generating Qt Help
+# Project output. For more information please see Qt Help Project / Namespace
+# (see: http://qt-project.org/doc/qt-4.8/qthelpproject.html#namespace).
+QHP_NAMESPACE          = org.doxygen.Project
+# The QHP_VIRTUAL_FOLDER tag specifies the namespace to use when generating Qt
+# Help Project output. For more information please see Qt Help Project / Virtual
+# Folders (see: http://qt-project.org/doc/qt-4.8/qthelpproject.html#virtual-
+# folders).
+# The default value is: doc.
+QHP_VIRTUAL_FOLDER     = doc
+# If the QHP_CUST_FILTER_NAME tag is set, it specifies the name of a custom
+# filter to add. For more information please see Qt Help Project / Custom
+# Filters (see: http://qt-project.org/doc/qt-4.8/qthelpproject.html#custom-
+# filters).
+QHP_CUST_FILTER_NAME   =
+# The QHP_CUST_FILTER_ATTRS tag specifies the list of the attributes of the
+# custom filter to add. For more information please see Qt Help Project / Custom
+# filters).
+QHP_CUST_FILTER_ATTRS  =
+# The QHP_SECT_FILTER_ATTRS tag specifies the list of the attributes this
+# project's filter section matches. Qt Help Project / Filter Attributes (see:
+# http://qt-project.org/doc/qt-4.8/qthelpproject.html#filter-attributes).
+QHP_SECT_FILTER_ATTRS  =
+# The QHG_LOCATION tag can be used to specify the location of Qt's
+# qhelpgenerator. If non-empty doxygen will try to run qhelpgenerator on the
+# generated .qhp file.
+QHG_LOCATION           =
+# If the GENERATE_ECLIPSEHELP tag is set to YES, additional index files will be
+# generated, together with the HTML files, they form an Eclipse help plugin. To
+# install this plugin and make it available under the help contents menu in
+# Eclipse, the contents of the directory containing the HTML and XML files needs
+# to be copied into the plugins directory of eclipse. The name of the directory
+# within the plugins directory should be the same as the ECLIPSE_DOC_ID value.
+# After copying Eclipse needs to be restarted before the help appears.
+GENERATE_ECLIPSEHELP   = NO
+# A unique identifier for the Eclipse help plugin. When installing the plugin
+# the directory name containing the HTML and XML files should also have this
+# name. Each documentation set should have its own identifier.
+# This tag requires that the tag GENERATE_ECLIPSEHELP is set to YES.
+ECLIPSE_DOC_ID         = org.doxygen.Project
+# If you want full control over the layout of the generated HTML pages it might
+# be necessary to disable the index and replace it with your own. The
+# DISABLE_INDEX tag can be used to turn on/off the condensed index (tabs) at top
+# of each HTML page. A value of NO enables the index and the value YES disables
+# it. Since the tabs in the index contain the same information as the navigation
+# tree, you can set this option to YES if you also set GENERATE_TREEVIEW to YES.
+DISABLE_INDEX          = NO
+# The GENERATE_TREEVIEW tag is used to specify whether a tree-like index
+# structure should be generated to display hierarchical information. If the tag
+# value is set to YES, a side panel will be generated containing a tree-like
+# index structure (just like the one that is generated for HTML Help). For this
+# to work a browser that supports JavaScript, DHTML, CSS and frames is required
+# (i.e. any modern browser). Windows users are probably better off using the
+# HTML help feature. Via custom stylesheets (see HTML_EXTRA_STYLESHEET) one can
+# further fine-tune the look of the index. As an example, the default style
+# sheet generated by doxygen has an example that shows how to put an image at
+# the root of the tree instead of the PROJECT_NAME. Since the tree basically has
+# the same information as the tab index, you could consider setting
+# DISABLE_INDEX to YES when enabling this option.
+GENERATE_TREEVIEW      = NO
+# The ENUM_VALUES_PER_LINE tag can be used to set the number of enum values that
+# doxygen will group on one line in the generated HTML documentation.
+# Note that a value of 0 will completely suppress the enum values from appearing
+# in the overview section.
+# Minimum value: 0, maximum value: 20, default value: 4.
+ENUM_VALUES_PER_LINE   = 4
+# If the treeview is enabled (see GENERATE_TREEVIEW) then this tag can be used
+# to set the initial width (in pixels) of the frame in which the tree is shown.
+# Minimum value: 0, maximum value: 1500, default value: 250.
+TREEVIEW_WIDTH         = 250
+# When the EXT_LINKS_IN_WINDOW option is set to YES doxygen will open links to
+# external symbols imported via tag files in a separate window.
+EXT_LINKS_IN_WINDOW    = NO
+# Use this tag to change the font size of LaTeX formulas included as images in
+# the HTML documentation. When you change the font size after a successful
+# doxygen run you need to manually remove any form_*.png images from the HTML
+# output directory to force them to be regenerated.
+# Minimum value: 8, maximum value: 50, default value: 10.
+FORMULA_FONTSIZE       = 10
+# Use the FORMULA_TRANPARENT tag to determine whether or not the images
+# generated for formulas are transparent PNGs. Transparent PNGs are not
+# supported properly for IE 6.0, but are supported on all modern browsers.
+# Note that when changing this option you need to delete any form_*.png files in
+# the HTML output directory before the changes have effect.
+FORMULA_TRANSPARENT    = YES
+# Enable the USE_MATHJAX option to render LaTeX formulas using MathJax (see
+# http://www.mathjax.org) which uses client side Javascript for the rendering
+# instead of using prerendered bitmaps. Use this if you do not have LaTeX
+# installed or if you want to formulas look prettier in the HTML output. When
+# enabled you may also need to install MathJax separately and configure the path
+# to it using the MATHJAX_RELPATH option.
+USE_MATHJAX            = NO
+# When MathJax is enabled you can set the default output format to be used for
+# the MathJax output. See the MathJax site (see:
+# http://docs.mathjax.org/en/latest/output.html) for more details.
+# Possible values are: HTML-CSS (which is slower, but has the best
+# compatibility), NativeMML (i.e. MathML) and SVG.
+# The default value is: HTML-CSS.
+# This tag requires that the tag USE_MATHJAX is set to YES.
+MATHJAX_FORMAT         = HTML-CSS
+# When MathJax is enabled you need to specify the location relative to the HTML
+# output directory using the MATHJAX_RELPATH option. The destination directory
+# should contain the MathJax.js script. For instance, if the mathjax directory
+# is located at the same level as the HTML output directory, then
+# MATHJAX_RELPATH should be ../mathjax. The default value points to the MathJax
+# Content Delivery Network so you can quickly see the result without installing
+# MathJax. However, it is strongly recommended to install a local copy of
+# MathJax from http://www.mathjax.org before deployment.
+# The default value is: http://cdn.mathjax.org/mathjax/latest.
+MATHJAX_RELPATH        = http://cdn.mathjax.org/mathjax/latest
+# The MATHJAX_EXTENSIONS tag can be used to specify one or more MathJax
+# extension names that should be enabled during MathJax rendering. For example
+# MATHJAX_EXTENSIONS = TeX/AMSmath TeX/AMSsymbols
+MATHJAX_EXTENSIONS     =
+# The MATHJAX_CODEFILE tag can be used to specify a file with javascript pieces
+# of code that will be used on startup of the MathJax code. See the MathJax site
+# (see: http://docs.mathjax.org/en/latest/output.html) for more details. For an
+# example see the documentation.
+MATHJAX_CODEFILE       =
+# When the SEARCHENGINE tag is enabled doxygen will generate a search box for
+# the HTML output. The underlying search engine uses javascript and DHTML and
+# should work on any modern browser. Note that when using HTML help
+# (GENERATE_HTMLHELP), Qt help (GENERATE_QHP), or docsets (GENERATE_DOCSET)
+# there is already a search function so this one should typically be disabled.
+# For large projects the javascript based search engine can be slow, then
+# enabling SERVER_BASED_SEARCH may provide a better solution. It is possible to
+# search using the keyboard; to jump to the search box use <access key> + S
+# (what the <access key> is depends on the OS and browser, but it is typically
+# <CTRL>, <ALT>/<option>, or both). Inside the search box use the <cursor down
+# key> to jump into the search results window, the results can be navigated
+# using the <cursor keys>. Press <Enter> to select an item or <escape> to cancel
+# the search. The filter options can be selected when the cursor is inside the
+# search box by pressing <Shift>+<cursor down>. Also here use the <cursor keys>
+# to select a filter and <Enter> or <escape> to activate or cancel the filter
+# option.
+SEARCHENGINE           = YES
+# When the SERVER_BASED_SEARCH tag is enabled the search engine will be
+# implemented using a web server instead of a web client using Javascript. There
+# are two flavours of web server based searching depending on the
+# EXTERNAL_SEARCH setting. When disabled, doxygen will generate a PHP script for
+# searching and an index file used by the script. When EXTERNAL_SEARCH is
+# enabled the indexing and searching needs to be provided by external tools. See
+# the section "External Indexing and Searching" for details.
+# This tag requires that the tag SEARCHENGINE is set to YES.
+SERVER_BASED_SEARCH    = NO
+# When EXTERNAL_SEARCH tag is enabled doxygen will no longer generate the PHP
+# script for searching. Instead the search results are written to an XML file
+# which needs to be processed by an external indexer. Doxygen will invoke an
+# external search engine pointed to by the SEARCHENGINE_URL option to obtain the
+# search results.
+# Doxygen ships with an example indexer ( doxyindexer) and search engine
+# (doxysearch.cgi) which are based on the open source search engine library
+# Xapian (see: http://xapian.org/).
+# See the section "External Indexing and Searching" for details.
+EXTERNAL_SEARCH        = NO
+# The SEARCHENGINE_URL should point to a search engine hosted by a web server
+# which will return the search results when EXTERNAL_SEARCH is enabled.
+# Xapian (see: http://xapian.org/). See the section "External Indexing and
+# Searching" for details.
+SEARCHENGINE_URL       =
+# When SERVER_BASED_SEARCH and EXTERNAL_SEARCH are both enabled the unindexed
+# search data is written to a file for indexing by an external tool. With the
+# SEARCHDATA_FILE tag the name of this file can be specified.
+# The default file is: searchdata.xml.
+SEARCHDATA_FILE        = searchdata.xml
+# EXTERNAL_SEARCH_ID tag can be used as an identifier for the project. This is
+# useful in combination with EXTRA_SEARCH_MAPPINGS to search through multiple
+# projects and redirect the results back to the right project.
+EXTERNAL_SEARCH_ID     =
+# The EXTRA_SEARCH_MAPPINGS tag can be used to enable searching through doxygen
+# projects other than the one defined by this configuration file, but that are
+# all added to the same external search index. Each project needs to have a
+# unique id set via EXTERNAL_SEARCH_ID. The search mapping then maps the id of
+# to a relative location where the documentation can be found. The format is:
+# EXTRA_SEARCH_MAPPINGS = tagname1=loc1 tagname2=loc2 ...
+EXTRA_SEARCH_MAPPINGS  =
+# Configuration options related to the LaTeX output
+# If the GENERATE_LATEX tag is set to YES doxygen will generate LaTeX output.
+GENERATE_LATEX         = YES
+# The LATEX_OUTPUT tag is used to specify where the LaTeX docs will be put. If a
+# it.
+# The default directory is: latex.
+# This tag requires that the tag GENERATE_LATEX is set to YES.
+LATEX_OUTPUT           = latex
+# The LATEX_CMD_NAME tag can be used to specify the LaTeX command name to be
+# invoked.
+# Note that when enabling USE_PDFLATEX this option is only used for generating
+# bitmaps for formulas in the HTML output, but not in the Makefile that is
+# written to the output directory.
+# The default file is: latex.
+LATEX_CMD_NAME         = latex
+# The MAKEINDEX_CMD_NAME tag can be used to specify the command name to generate
+# index for LaTeX.
+# The default file is: makeindex.
+MAKEINDEX_CMD_NAME     = makeindex
+# If the COMPACT_LATEX tag is set to YES doxygen generates more compact LaTeX
+# documents. This may be useful for small projects and may help to save some
+# trees in general.
+COMPACT_LATEX          = NO
+# The PAPER_TYPE tag can be used to set the paper type that is used by the
+# printer.
+# Possible values are: a4 (210 x 297 mm), letter (8.5 x 11 inches), legal (8.5 x
+# 14 inches) and executive (7.25 x 10.5 inches).
+# The default value is: a4.
+PAPER_TYPE             = a4
+# The EXTRA_PACKAGES tag can be used to specify one or more LaTeX package names
+# that should be included in the LaTeX output. To get the times font for
+# instance you can specify
+# EXTRA_PACKAGES=times
+# If left blank no extra packages will be included.
+EXTRA_PACKAGES         =
+# The LATEX_HEADER tag can be used to specify a personal LaTeX header for the
+# generated LaTeX document. The header should contain everything until the first
+# chapter. If it is left blank doxygen will generate a standard header. See
+# section "Doxygen usage" for information on how to let doxygen write the
+# default header to a separate file.
+# Note: Only use a user-defined header if you know what you are doing! The
+# following commands have a special meaning inside the header: $title,
+# $datetime, $date, $doxygenversion, $projectname, $projectnumber. Doxygen will
+# replace them by respectively the title of the page, the current date and time,
+# only the current date, the version number of doxygen, the project name (see
+# PROJECT_NAME), or the project number (see PROJECT_NUMBER).
+LATEX_HEADER           =
+# The LATEX_FOOTER tag can be used to specify a personal LaTeX footer for the
+# generated LaTeX document. The footer should contain everything after the last
+# chapter. If it is left blank doxygen will generate a standard footer.
+# Note: Only use a user-defined footer if you know what you are doing!
+LATEX_FOOTER           =
+# The LATEX_EXTRA_FILES tag can be used to specify one or more extra images or
+# other source files which should be copied to the LATEX_OUTPUT output
+# directory. Note that the files will be copied as-is; there are no commands or
+# markers available.
+LATEX_EXTRA_FILES      =
+# If the PDF_HYPERLINKS tag is set to YES, the LaTeX that is generated is
+# prepared for conversion to PDF (using ps2pdf or pdflatex). The PDF file will
+# contain links (just like the HTML output) instead of page references. This
+# makes the output suitable for online browsing using a PDF viewer.
+PDF_HYPERLINKS         = YES
+# If the LATEX_PDFLATEX tag is set to YES, doxygen will use pdflatex to generate
+# the PDF file directly from the LaTeX files. Set this option to YES to get a
+# higher quality PDF documentation.
+USE_PDFLATEX           = YES
+# If the LATEX_BATCHMODE tag is set to YES, doxygen will add the \batchmode
+# command to the generated LaTeX files. This will instruct LaTeX to keep running
+# if errors occur, instead of asking the user for help. This option is also used
+# when generating formulas in HTML.
+# The default value is: NO.
+LATEX_BATCHMODE        = NO
+# If the LATEX_HIDE_INDICES tag is set to YES then doxygen will not include the
+# index chapters (such as File Index, Compound Index, etc.) in the output.
+LATEX_HIDE_INDICES     = NO
+# If the LATEX_SOURCE_CODE tag is set to YES then doxygen will include source
+# code with syntax highlighting in the LaTeX output.
+# Note that which sources are shown also depends on other settings such as
+# SOURCE_BROWSER.
+LATEX_SOURCE_CODE      = NO
+# The LATEX_BIB_STYLE tag can be used to specify the style to use for the
+# bibliography, e.g. plainnat, or ieeetr. See
+# http://en.wikipedia.org/wiki/BibTeX and \cite for more info.
+# The default value is: plain.
+LATEX_BIB_STYLE        = plain
+# Configuration options related to the RTF output
+# If the GENERATE_RTF tag is set to YES doxygen will generate RTF output. The
+# RTF output is optimized for Word 97 and may not look too pretty with other RTF
+# readers/editors.
+GENERATE_RTF           = NO
+# The RTF_OUTPUT tag is used to specify where the RTF docs will be put. If a
+# it.
+# The default directory is: rtf.
+# This tag requires that the tag GENERATE_RTF is set to YES.
+RTF_OUTPUT             = rtf
+# If the COMPACT_RTF tag is set to YES doxygen generates more compact RTF
+COMPACT_RTF            = NO
+# If the RTF_HYPERLINKS tag is set to YES, the RTF that is generated will
+# contain hyperlink fields. The RTF file will contain links (just like the HTML
+# output) instead of page references. This makes the output suitable for online
+# browsing using Word or some other Word compatible readers that support those
+# fields.
+# Note: WordPad (write) and others do not support links.
+RTF_HYPERLINKS         = NO
+# Load stylesheet definitions from file. Syntax is similar to doxygen's config
+# file, i.e. a series of assignments. You only have to provide replacements,
+# missing definitions are set to their default value.
+# default style sheet that doxygen normally uses.
+RTF_STYLESHEET_FILE    =
+# Set optional variables used in the generation of an RTF document. Syntax is
+# similar to doxygen's config file. A template extensions file can be generated
+# using doxygen -e rtf extensionFile.
+RTF_EXTENSIONS_FILE    =
+# Configuration options related to the man page output
+# If the GENERATE_MAN tag is set to YES doxygen will generate man pages for
+# classes and files.
+GENERATE_MAN           = NO
+# The MAN_OUTPUT tag is used to specify where the man pages will be put. If a
+# it. A directory man3 will be created inside the directory specified by
+# MAN_OUTPUT.
+# The default directory is: man.
+# This tag requires that the tag GENERATE_MAN is set to YES.
+MAN_OUTPUT             = man
+# The MAN_EXTENSION tag determines the extension that is added to the generated
+# man pages. In case the manual section does not start with a number, the number
+# 3 is prepended. The dot (.) at the beginning of the MAN_EXTENSION tag is
+# optional.
+# The default value is: .3.
+MAN_EXTENSION          = .3
+# If the MAN_LINKS tag is set to YES and doxygen generates man output, then it
+# will generate one additional man file for each entity documented in the real
+# man page(s). These additional files only source the real man page, but without
+# them the man command would be unable to find the correct page.
+MAN_LINKS              = NO
+# Configuration options related to the XML output
+# If the GENERATE_XML tag is set to YES doxygen will generate an XML file that
+# captures the structure of the code including all documentation.
+GENERATE_XML           = NO
+# The XML_OUTPUT tag is used to specify where the XML pages will be put. If a
+# it.
+# The default directory is: xml.
+# This tag requires that the tag GENERATE_XML is set to YES.
+XML_OUTPUT             = xml
+# The XML_SCHEMA tag can be used to specify a XML schema, which can be used by a
+# validating XML parser to check the syntax of the XML files.
+XML_SCHEMA             =
+# The XML_DTD tag can be used to specify a XML DTD, which can be used by a
+XML_DTD                =
+# If the XML_PROGRAMLISTING tag is set to YES doxygen will dump the program
+# listings (including syntax highlighting and cross-referencing information) to
+# the XML output. Note that enabling this will significantly increase the size
+# of the XML output.
+# The default value is: YES.
+XML_PROGRAMLISTING     = YES
+# Configuration options related to the DOCBOOK output
+# If the GENERATE_DOCBOOK tag is set to YES doxygen will generate Docbook files
+# that can be used to generate PDF.
+GENERATE_DOCBOOK       = NO
+# The DOCBOOK_OUTPUT tag is used to specify where the Docbook pages will be put.
+# If a relative path is entered the value of OUTPUT_DIRECTORY will be put in
+# front of it.
+# The default directory is: docbook.
+# This tag requires that the tag GENERATE_DOCBOOK is set to YES.
+DOCBOOK_OUTPUT         = docbook
+# Configuration options for the AutoGen Definitions output
+# If the GENERATE_AUTOGEN_DEF tag is set to YES doxygen will generate an AutoGen
+# Definitions (see http://autogen.sf.net) file that captures the structure of
+# the code including all documentation. Note that this feature is still
+# experimental and incomplete at the moment.
+GENERATE_AUTOGEN_DEF   = NO
+# Configuration options related to the Perl module output
+# If the GENERATE_PERLMOD tag is set to YES doxygen will generate a Perl module
+# file that captures the structure of the code including all documentation.
+# Note that this feature is still experimental and incomplete at the moment.
+GENERATE_PERLMOD       = NO
+# If the PERLMOD_LATEX tag is set to YES doxygen will generate the necessary
+# Makefile rules, Perl scripts and LaTeX code to be able to generate PDF and DVI
+# output from the Perl module output.
+# This tag requires that the tag GENERATE_PERLMOD is set to YES.
+PERLMOD_LATEX          = NO
+# If the PERLMOD_PRETTY tag is set to YES the Perl module output will be nicely
+# formatted so it can be parsed by a human reader. This is useful if you want to
+# understand what is going on. On the other hand, if this tag is set to NO the
+# size of the Perl module output will be much smaller and Perl will parse it
+# just the same.
+PERLMOD_PRETTY         = YES
+# The names of the make variables in the generated doxyrules.make file are
+# prefixed with the string contained in PERLMOD_MAKEVAR_PREFIX. This is useful
+# so different doxyrules.make files included by the same Makefile don't
+# overwrite each other's variables.
+PERLMOD_MAKEVAR_PREFIX =
+# Configuration options related to the preprocessor
+# If the ENABLE_PREPROCESSING tag is set to YES doxygen will evaluate all
+# C-preprocessor directives found in the sources and include files.
+ENABLE_PREPROCESSING   = YES
+# If the MACRO_EXPANSION tag is set to YES doxygen will expand all macro names
+# in the source code. If set to NO only conditional compilation will be
+# performed. Macro expansion can be done in a controlled way by setting
+# EXPAND_ONLY_PREDEF to YES.
+# This tag requires that the tag ENABLE_PREPROCESSING is set to YES.
+MACRO_EXPANSION        = NO
+# If the EXPAND_ONLY_PREDEF and MACRO_EXPANSION tags are both set to YES then
+# the macro expansion is limited to the macros specified with the PREDEFINED and
+# EXPAND_AS_DEFINED tags.
+EXPAND_ONLY_PREDEF     = NO
+# If the SEARCH_INCLUDES tag is set to YES the includes files in the
+# INCLUDE_PATH will be searched if a #include is found.
+SEARCH_INCLUDES        = YES
+# The INCLUDE_PATH tag can be used to specify one or more directories that
+# contain include files that are not input files but should be processed by the
+# preprocessor.
+# This tag requires that the tag SEARCH_INCLUDES is set to YES.
+INCLUDE_PATH           =
+# You can use the INCLUDE_FILE_PATTERNS tag to specify one or more wildcard
+# patterns (like *.h and *.hpp) to filter out the header-files in the
+# directories. If left blank, the patterns specified with FILE_PATTERNS will be
+# used.
+INCLUDE_FILE_PATTERNS  =
+# The PREDEFINED tag can be used to specify one or more macro names that are
+# defined before the preprocessor is started (similar to the -D option of e.g.
+# gcc). The argument of the tag is a list of macros of the form: name or
+# name=definition (no spaces). If the definition and the "=" are omitted, "=1"
+# is assumed. To prevent a macro definition from being undefined via #undef or
+# recursively expanded use the := operator instead of the = operator.
+PREDEFINED             =
+# If the MACRO_EXPANSION and EXPAND_ONLY_PREDEF tags are set to YES then this
+# tag can be used to specify a list of macro names that should be expanded. The
+# macro definition that is found in the sources will be used. Use the PREDEFINED
+# tag if you want to use a different macro definition that overrules the
+# definition found in the source code.
+EXPAND_AS_DEFINED      =
+# If the SKIP_FUNCTION_MACROS tag is set to YES then doxygen's preprocessor will
+# remove all refrences to function-like macros that are alone on a line, have an
+# all uppercase name, and do not end with a semicolon. Such function macros are
+# typically used for boiler-plate code, and will confuse the parser if not
+# removed.
+SKIP_FUNCTION_MACROS   = YES
+# Configuration options related to external references
+# The TAGFILES tag can be used to specify one or more tag files. For each tag
+# file the location of the external documentation should be added. The format of
+# a tag file without this location is as follows:
+# TAGFILES = file1 file2 ...
+# Adding location for the tag files is done as follows:
+# TAGFILES = file1=loc1 "file2 = loc2" ...
+# where loc1 and loc2 can be relative or absolute paths or URLs. See the
+# section "Linking to external documentation" for more information about the use
+# of tag files.
+# Note: Each tag file must have an unique name (where the name does NOT include
+# the path). If a tag file is not located in the directory in which doxygen is
+# run, you must also specify the path to the tagfile here.
+TAGFILES               =
+# When a file name is specified after GENERATE_TAGFILE, doxygen will create a
+# tag file that is based on the input files it reads. See section "Linking to
+# external documentation" for more information about the usage of tag files.
+GENERATE_TAGFILE       =
+# If the ALLEXTERNALS tag is set to YES all external class will be listed in the
+# class index. If set to NO only the inherited external classes will be listed.
+ALLEXTERNALS           = NO
+# If the EXTERNAL_GROUPS tag is set to YES all external groups will be listed in
+# the modules index. If set to NO, only the current project's groups will be
+# listed.
+EXTERNAL_GROUPS        = YES
+# If the EXTERNAL_PAGES tag is set to YES all external pages will be listed in
+# the related pages index. If set to NO, only the current project's pages will
+# be listed.
+EXTERNAL_PAGES         = YES
+# The PERL_PATH should be the absolute path and name of the perl script
+# interpreter (i.e. the result of 'which perl').
+# The default file (with absolute path) is: /usr/bin/perl.
+PERL_PATH              = /usr/bin/perl
+# Configuration options related to the dot tool
+# If the CLASS_DIAGRAMS tag is set to YES doxygen will generate a class diagram
+# (in HTML and LaTeX) for classes with base or super classes. Setting the tag to
+# NO turns the diagrams off. Note that this option also works with HAVE_DOT
+# disabled, but it is recommended to install and use dot, since it yields more
+# powerful graphs.
+CLASS_DIAGRAMS         = YES
+# You can define message sequence charts within doxygen comments using the \msc
+# command. Doxygen will then run the mscgen tool (see:
+# http://www.mcternan.me.uk/mscgen/)) to produce the chart and insert it in the
+# documentation. The MSCGEN_PATH tag allows you to specify the directory where
+# the mscgen tool resides. If left empty the tool is assumed to be found in the
+# default search path.
+MSCGEN_PATH            =
+# If set to YES, the inheritance and collaboration graphs will hide inheritance
+# and usage relations if the target is undocumented or is not a class.
+HIDE_UNDOC_RELATIONS   = YES
+# If you set the HAVE_DOT tag to YES then doxygen will assume the dot tool is
+# available from the path. This tool is part of Graphviz (see:
+# http://www.graphviz.org/), a graph visualization toolkit from AT&T and Lucent
+# Bell Labs. The other options in this section have no effect if this option is
+# set to NO
+HAVE_DOT               = NO
+# The DOT_NUM_THREADS specifies the number of dot invocations doxygen is allowed
+# to run in parallel. When set to 0 doxygen will base this on the number of
+# processors available in the system. You can set it explicitly to a value
+# larger than 0 to get control over the balance between CPU load and processing
+# speed.
+# Minimum value: 0, maximum value: 32, default value: 0.
+# This tag requires that the tag HAVE_DOT is set to YES.
+DOT_NUM_THREADS        = 0
+# When you want a differently looking font n the dot files that doxygen
+# generates you can specify the font name using DOT_FONTNAME. You need to make
+# sure dot is able to find the font, which can be done by putting it in a
+# standard location or by setting the DOTFONTPATH environment variable or by
+# setting DOT_FONTPATH to the directory containing the font.
+# The default value is: Helvetica.
+DOT_FONTNAME           = Helvetica
+# The DOT_FONTSIZE tag can be used to set the size (in points) of the font of
+# dot graphs.
+# Minimum value: 4, maximum value: 24, default value: 10.
+DOT_FONTSIZE           = 10
+# By default doxygen will tell dot to use the default font as specified with
+# DOT_FONTNAME. If you specify a different font using DOT_FONTNAME you can set
+# the path where dot can find it using this tag.
+DOT_FONTPATH           =
+# If the CLASS_GRAPH tag is set to YES then doxygen will generate a graph for
+# each documented class showing the direct and indirect inheritance relations.
+# Setting this tag to YES will force the CLASS_DIAGRAMS tag to NO.
+CLASS_GRAPH            = YES
+# If the COLLABORATION_GRAPH tag is set to YES then doxygen will generate a
+# graph for each documented class showing the direct and indirect implementation
+# dependencies (inheritance, containment, and class references variables) of the
+# class with other documented classes.
+COLLABORATION_GRAPH    = YES
+# If the GROUP_GRAPHS tag is set to YES then doxygen will generate a graph for
+# groups, showing the direct groups dependencies.
+GROUP_GRAPHS           = YES
+# If the UML_LOOK tag is set to YES doxygen will generate inheritance and
+# collaboration diagrams in a style similar to the OMG's Unified Modeling
+# Language.
+UML_LOOK               = NO
+# If the UML_LOOK tag is enabled, the fields and methods are shown inside the
+# class node. If there are many fields or methods and many nodes the graph may
+# become too big to be useful. The UML_LIMIT_NUM_FIELDS threshold limits the
+# number of items for each type to make the size more manageable. Set this to 0
+# for no limit. Note that the threshold may be exceeded by 50% before the limit
+# is enforced. So when you set the threshold to 10, up to 15 fields may appear,
+# but if the number exceeds 15, the total amount of fields shown is limited to
+# 10.
+# Minimum value: 0, maximum value: 100, default value: 10.
+UML_LIMIT_NUM_FIELDS   = 10
+# If the TEMPLATE_RELATIONS tag is set to YES then the inheritance and
+# collaboration graphs will show the relations between templates and their
+# instances.
+TEMPLATE_RELATIONS     = NO
+# If the INCLUDE_GRAPH, ENABLE_PREPROCESSING and SEARCH_INCLUDES tags are set to
+# YES then doxygen will generate a graph for each documented file showing the
+# direct and indirect include dependencies of the file with other documented
+# files.
+INCLUDE_GRAPH          = YES
+# If the INCLUDED_BY_GRAPH, ENABLE_PREPROCESSING and SEARCH_INCLUDES tags are
+# set to YES then doxygen will generate a graph for each documented file showing
+# the direct and indirect include dependencies of the file with other documented
+# files.
+INCLUDED_BY_GRAPH      = YES
+# If the CALL_GRAPH tag is set to YES then doxygen will generate a call
+# dependency graph for every global function or class method.
+# Note that enabling this option will significantly increase the time of a run.
+# So in most cases it will be better to enable call graphs for selected
+# functions only using the \callgraph command.
+CALL_GRAPH             = NO
+# If the CALLER_GRAPH tag is set to YES then doxygen will generate a caller
+# So in most cases it will be better to enable caller graphs for selected
+# functions only using the \callergraph command.
+CALLER_GRAPH           = NO
+# If the GRAPHICAL_HIERARCHY tag is set to YES then doxygen will graphical
+# hierarchy of all classes instead of a textual one.
+GRAPHICAL_HIERARCHY    = YES
+# If the DIRECTORY_GRAPH tag is set to YES then doxygen will show the
+# dependencies a directory has on other directories in a graphical way. The
+# dependency relations are determined by the #include relations between the
+# files in the directories.
+DIRECTORY_GRAPH        = YES
+# The DOT_IMAGE_FORMAT tag can be used to set the image format of the images
+# generated by dot.
+# Note: If you choose svg you need to set HTML_FILE_EXTENSION to xhtml in order
+# to make the SVG files visible in IE 9+ (other browsers do not have this
+# requirement).
+# Possible values are: png, jpg, gif and svg.
+# The default value is: png.
+DOT_IMAGE_FORMAT       = png
+# If DOT_IMAGE_FORMAT is set to svg, then this option can be set to YES to
+# enable generation of interactive SVG images that allow zooming and panning.
+# Note that this requires a modern browser other than Internet Explorer. Tested
+# and working are Firefox, Chrome, Safari, and Opera.
+# Note: For IE 9+ you need to set HTML_FILE_EXTENSION to xhtml in order to make
+# the SVG files visible. Older versions of IE do not have SVG support.
+INTERACTIVE_SVG        = NO
+# The DOT_PATH tag can be used to specify the path where the dot tool can be
+# found. If left blank, it is assumed the dot tool can be found in the path.
+DOT_PATH               =
+# The DOTFILE_DIRS tag can be used to specify one or more directories that
+# contain dot files that are included in the documentation (see the \dotfile
+# command).
+DOTFILE_DIRS           =
+# The MSCFILE_DIRS tag can be used to specify one or more directories that
+# contain msc files that are included in the documentation (see the \mscfile
+# command).
+MSCFILE_DIRS           =
+# The DOT_GRAPH_MAX_NODES tag can be used to set the maximum number of nodes
+# that will be shown in the graph. If the number of nodes in a graph becomes
+# larger than this value, doxygen will truncate the graph, which is visualized
+# by representing a node as a red box. Note that doxygen if the number of direct
+# children of the root node in a graph is already larger than
+# DOT_GRAPH_MAX_NODES then the graph will not be shown at all. Also note that
+# the size of a graph can be further restricted by MAX_DOT_GRAPH_DEPTH.
+# Minimum value: 0, maximum value: 10000, default value: 50.
+DOT_GRAPH_MAX_NODES    = 50
+# The MAX_DOT_GRAPH_DEPTH tag can be used to set the maximum depth of the graphs
+# generated by dot. A depth value of 3 means that only nodes reachable from the
+# root by following a path via at most 3 edges will be shown. Nodes that lay
+# further from the root node will be omitted. Note that setting this option to 1
+# or 2 may greatly reduce the computation time needed for large code bases. Also
+# note that the size of a graph can be further restricted by
+# DOT_GRAPH_MAX_NODES. Using a depth of 0 means no depth restriction.
+# Minimum value: 0, maximum value: 1000, default value: 0.
+MAX_DOT_GRAPH_DEPTH    = 0
+# Set the DOT_TRANSPARENT tag to YES to generate images with a transparent
+# background. This is disabled by default, because dot on Windows does not seem
+# to support this out of the box.
+# Warning: Depending on the platform used, enabling this option may lead to
+# badly anti-aliased labels on the edges of a graph (i.e. they become hard to
+# read).
+DOT_TRANSPARENT        = NO
+# Set the DOT_MULTI_TARGETS tag to YES allow dot to generate multiple output
+# files in one run (i.e. multiple -o and -T options on the command line). This
+# makes dot run faster, but since only newer versions of dot (>1.8.10) support
+# this, this feature is disabled by default.
+DOT_MULTI_TARGETS      = NO
+# If the GENERATE_LEGEND tag is set to YES doxygen will generate a legend page
+# explaining the meaning of the various boxes and arrows in the dot generated
+# graphs.
+GENERATE_LEGEND        = YES
+# If the DOT_CLEANUP tag is set to YES doxygen will remove the intermediate dot
+# files that are used to generate the various graphs.
+DOT_CLEANUP            = YES
diff --git a/misc/userdrv/userdrv.h b/misc/userdrv/userdrv.h
new file mode 100644
index 0000000..8a54931
--- /dev/null
+++ b/misc/userdrv/userdrv.h
@@ -0,0 +1,264 @@
+ * @file
+ * @brief RTEMS /dev/userdrv Device Driver
+ * This include file defines the interface to the RTEMS /dev/userdrv
+ * device driver. This driver is intended to be used from section 2
+ * system calls like open(), read(), etc. It does not support being used
+ * from C Standard Library calls like fopen(), etc.
+ * The major number passed to the initialization method indicates the
+ * slot in the RTEMS Device Driver Table. This can vary based upon the
+ * application configuration. The same major number should be passed into
+ * every invocation.
+ * The minor number indicates the device instance and is interpreted by
+ * each device driver in a driver specific manner. It is common to simply
+ * be an integer that indicates the instance number.
+ * The pargp or pointer to argument block parameter contents vary based
+ * on the device driver entry. See the specific driver entry point for
+ * details.
+ * The mapping between device drivers and the RTEMS file oriented
+ * system calls is via the file libcsupport/src/sup_fs_deviceio.c.
+ * For read, write, and ioctl, on error, the RTEMS Classic API status
+ * will be mapped into a POSIX errno value and returned to the user
+ * via the wrapper method in sup_fs_deviceio.c.
+ * Copyright (C) 2022 OAR Corporation
+ * are met:
+#ifndef _USERDRV_H
+#define _USERDRV_H
+#include <rtems/io.h>
+ *  @defgroup user_driver Example User Device Driver
+ *  @ingroup RTEMSDeviceDrivers
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * This defines the device driver entries which go into the
+ * Device Driver Table configured by the user. this
+ * @code
+ *   #define CONFIGURE_APPLICATION_EXTRA_DRIVERS \
+ *      USERDRV_DRIVER_TABLE_ENTRY
+ * @endcode
+#define USERDRV_DRIVER_TABLE_ENTRY \
+  { userdrv_initialize, userdrv_open, userdrv_close, userdrv_read, \
+    userdrv_write, userdrv_control }
+ * @brief User Driver Specific IOCTL
+#define USERDRV_IOCTL_DO_SOMETHING 0x320001
+ * @brief User Driver Initialize
+ * This routine is the user device driver init routine. It initializes
+ * the devices and registers the device names for subsequent use. In this
+ * specific driver, the device name /dev/userdrv is registered for
+ * subsequent use.
+ * @param[in] major The device major number
+ * @param[in] minor The device minor number
+ * @param[in] pargp The pointer to open parameter block
+ * The calling framework for driver initialization always passes
+ * NULL for @a pargp.
+ * @return This method returns RTEMS_SUCCESSFUL on success and calls
+ *         @a rtems_fatal_error otherwise.
+rtems_device_driver userdrv_initialize(
+  rtems_device_major_number  major,
+  rtems_device_minor_number  minor,
+  void                      *pargp
+ * @brief User Driver Open
+ * This routine is the user device driver open routine. It may need
+ * to check the access mode and manage if multiple opens are allowed
+ * concurrently.
+ * @a pargp points to a data structure of type @a rtems_libio_open_close_args_t
+ * which is filled in as follows:
+ *   - iop - Pointer to an @a rtems_libio_t instance. This is the internal
+ *     file management structure.
+ *   - flags - libio style read/write access flags.
+ *   - mode - access mode per POSIX @a mode_t
+ * @return This method returns RTEMS_SUCCESSFUL on success.
+rtems_device_driver userdrv_open(
+  void                      *pargp
+ * @brief User Driver Close
+ * This routine is the user device driver close routine.
+ * @param[in] pargp The pointer to close parameter block
+ *   - flags - is 0.
+ *   - mode - is 0.
+rtems_device_driver userdrv_close(
+  void                      *pargp
+ * @brief User Driver Read
+ * This routine is the user device driver read routine.
+ * @a pargp points to a data structure of type @a rtems_libio_rw_args_t
+ *   - offset - the file offset to read from.
+ *   - buffer - the user buffer to read into.
+ *   - count - the maximum number of bytes to read.
+ *   - bytes_moved - set to 0.
+ * @return This method returns RTEMS_SUCCESSFUL on success. Additionally
+ *    the @a bytes_moved field of the  @a rtems_libio_rw_args_t structure
+ *    will have the number of bytes actually returned. On error, the
+ *    appropriate Classic API status code is returned.
+rtems_device_driver userdrv_read(
+  void                      *pargp
+ * @brief User Driver Write
+ * This routine is the user device driver write routine.
+ *   - buffer - user buffer to write from.
+ *   - offset - the file offset to write to.
+ *   - count - the maximum number of bytes to write.
+ *    will have the number of bytes actually written. On error, the
+rtems_device_driver userdrv_write(
+  void                      *pargp
+ * @brief User Driver IO Control
+ * This routine is the user device driver IO control routine.
+ * @a pargp points to a data structure of type @a rtems_libio_ioctl_args_t
+ *   - command - the ioctl command to execute.
+ *   - buffer - user buffer to support the operation.
+ *   - ioctl_return - undefined.
+ *    the @a ioctl_return field of the  @a rtems_libio_ioctl_args_t structure
+ *    will have the POSIX style return code to return to the user. On error,
+ *    the appropriate Classic API status code is returned.
+rtems_device_driver userdrv_control(
+  void                      *pargp
+#ifdef __cplusplus
+#endif
+#endif
+/* end of include file */
diff --git a/misc/userdrv/wscript b/misc/userdrv/wscript
index 0000000..124a6e2
--- /dev/null
+++ b/misc/userdrv/wscript
@@ -0,0 +1,14 @@
+# Copyright 2022 Joel Sherrill (joel at rtems.org)
+# This file's license is 2-clause BSD as in this distribution's LICENSE.2 file.
+# Waf build script for an RTEMS Hello
+import rtems_waf.rtems as rtems
+def build(bld):
+    rtems.build(bld)
+    bld(features = 'c cprogram',
+        target = 'userdrv.exe',
+        source = ['main.c','rtems_config.c', 'userdrv.c'])
diff --git a/misc/wscript b/misc/wscript
index 39fed4b..8689080 100644
--- a/misc/wscript
+++ b/misc/wscript
@@ -15,5 +15,6 @@ def build(bld):
     bld.recurse('nanosecond_tick_wrap')
     bld.recurse('qemu_vfat')
     bld.recurse('applib')
+    bld.recurse('userdrv')
     #if rtems.check_posix(bld):
     #    bld.recurse('adamain')
1.8.3.1
