[PATCH rtems-examples 16/23] benchmarks/nbench: Fix warnings
Joel Sherrill
joel at rtems.org
Wed Feb 23 22:21:44 UTC 2022
benchmarks/nbench/main.c | 3 +--
benchmarks/nbench/nbench-byte-2.2.3/emfloat.c | 6 ++++++
benchmarks/nbench/nbench-byte-2.2.3/hardware.c | 4 ++++
benchmarks/nbench/nbench-byte-2.2.3/nbench0.c | 1 +
benchmarks/nbench/nbench-byte-2.2.3/nbench1.c | 4 ++--
5 files changed, 14 insertions(+), 4 deletions(-)
diff --git a/benchmarks/nbench/main.c b/benchmarks/nbench/main.c
index 68f799e..eebd1f5 100644
--- a/benchmarks/nbench/main.c
+++ b/benchmarks/nbench/main.c
@@ -68,7 +68,6 @@ rtems_task Init(rtems_task_argument arg)
rtems_status_code sc;
rtems_id task_id_nbench;
- char *args[1] = {"./nbench"};
rtems_interval tickspersec;
@@ -90,7 +89,7 @@ rtems_task Init(rtems_task_argument arg)
tickspersec = rtems_clock_get_ticks_per_second();
- printf("clocks per sec: %ld\n", tickspersec);
+ printf("clocks per sec: %u\n", tickspersec);
printf("Starting Shell\n");
rtems_shell_main_loop(NULL);
diff --git a/benchmarks/nbench/nbench-byte-2.2.3/emfloat.c b/benchmarks/nbench/nbench-byte-2.2.3/emfloat.c
index 5e73890..6e18b03 100644
--- a/benchmarks/nbench/nbench-byte-2.2.3/emfloat.c
+++ b/benchmarks/nbench/nbench-byte-2.2.3/emfloat.c
@@ -647,6 +647,7 @@ case NORMAL_NORMAL:
z->exp= locx.exp;
else
if (exponent_difference > 0)
@@ -715,11 +716,13 @@ case NORMAL_NORMAL:
z->sign = 0; /* positive */
else
if (locx.type == IFPF_IS_NORMAL ||
locy.type == IFPF_IS_NORMAL)
normalize(z);
else
@@ -742,8 +745,11 @@ case NORMAL_NORMAL:
z->type = IFPF_IS_NORMAL;
else
if (z->mantissa[0] & 0x8000)
break;
diff --git a/benchmarks/nbench/nbench-byte-2.2.3/hardware.c b/benchmarks/nbench/nbench-byte-2.2.3/hardware.c
index 53bbec9..e4fde25 100644
--- a/benchmarks/nbench/nbench-byte-2.2.3/hardware.c
+++ b/benchmarks/nbench/nbench-byte-2.2.3/hardware.c
@@ -28,11 +28,13 @@ static void output_string(const char *buffer, const int write_to_file,
** Removes a trailing newline character if present
static void removeNewLine(char * s) {
if(strlen(s)>0 && s[strlen(s)-1] == '\n') {
s[strlen(s)-1] = '\0';
@@ -180,7 +182,9 @@ void hardware(const int write_to_file, FILE *global_ofile) {
char os[BUF_SIZ];
char model[BUF_SIZ];
char cache[BUF_SIZ];
+#ifndef NO_UNAME
char os_command[] = "uname -s -r";
+#endif
#ifdef NO_UNAME
os[0] = '\0';
#else
diff --git a/benchmarks/nbench/nbench-byte-2.2.3/nbench0.c b/benchmarks/nbench/nbench-byte-2.2.3/nbench0.c
index 13fd6d9..0e5d045 100644
--- a/benchmarks/nbench/nbench-byte-2.2.3/nbench0.c
+++ b/benchmarks/nbench/nbench-byte-2.2.3/nbench0.c
@@ -331,6 +331,7 @@ output_string("* Trademarks are property of their respective holder.\n");
//exit(0);
+return 0;
diff --git a/benchmarks/nbench/nbench-byte-2.2.3/nbench1.c b/benchmarks/nbench/nbench-byte-2.2.3/nbench1.c
index be081e6..3ac8dbb 100644
--- a/benchmarks/nbench/nbench-byte-2.2.3/nbench1.c
+++ b/benchmarks/nbench/nbench-byte-2.2.3/nbench1.c
@@ -3149,7 +3149,7 @@ return((1<<bitnumb) & comparray[byteoffset] );
void DoNNET(void)
NNetStruct *locnnetstruct; /* Local ptr to global data */
-char *errorcontext;
+/* char *errorcontext; */
ulong accumtime;
double iterations;
@@ -3161,7 +3161,7 @@ locnnetstruct=&global_nnetstruct;
** Set error context
-errorcontext="CPU:NNET";
+/* errorcontext="CPU:NNET"; */
** Init random number generator.
1.8.3.1
