[PATCH rtems-examples 20/23] ticker/low_ticker: Fix warnings
Joel Sherrill
joel at rtems.org
Wed Feb 23 22:21:48 UTC 2022
ticker/low_ticker/init.c | 19 ++++++++++---------
1 file changed, 10 insertions(+), 9 deletions(-)
diff --git a/ticker/low_ticker/init.c b/ticker/low_ticker/init.c
index b71e38c..fcb4b2a 100644
--- a/ticker/low_ticker/init.c
+++ b/ticker/low_ticker/init.c
@@ -17,10 +17,9 @@ rtems_task Test_task(
rtems_time_of_day time;
- rtems_status_code status;
for ( ; ; ) {
- status = rtems_clock_get_tod( &time );
+ (void) rtems_clock_get_tod( &time );
if ( time.second >= 35 ) {
printk( "*** END OF LOW MEMORY CLOCK TICK TEST ***\n" );
rtems_shutdown_executive( 0 );
@@ -29,7 +28,7 @@ rtems_task Test_task(
task_index, " - rtems_clock_get_tod - ",
(int) time.hour, (int) time.minute, (int) time.second,
(int) time.month, (int) time.day, (int) time.year );
- status = rtems_task_wake_after(
+ (void) rtems_task_wake_after(
task_index * 5 * rtems_clock_get_ticks_per_second()
@@ -39,7 +38,6 @@ static void *Init(
uintptr_t ignored
rtems_id id;
int i;
@@ -54,18 +52,21 @@ static void *Init(
time.second = 0;
time.ticks = 0;
- status = rtems_clock_set( &time );
+ (void) rtems_clock_set( &time );
for (i=1 ; i<=3 ; i++ ) {
- status = rtems_task_create(
+ (void) rtems_task_create(
rtems_build_name( 'T', 'A', 0x30+1, ' ' ), 1, 0, RTEMS_DEFAULT_MODES,
RTEMS_DEFAULT_ATTRIBUTES, &id
- status = rtems_task_start( id, Test_task, i );
+ (void) rtems_task_start( id, Test_task, i );
- while( 1 )
+ while( 1 ) {
+ return NULL;
/**************** START OF CONFIGURATION INFORMATION ****************/
@@ -79,7 +80,7 @@ static void *Init(
#define CONFIGURE_MINIMUM_TASK_STACK_SIZE 512
#define CONFIGURE_MAXIMUM_PRIORITY 15
#define CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS
-#define CONFIGURE_IDLE_TASK_BODY Init
+#define CONFIGURE_IDLE_TASK_BODY (Thread_Idle_body)Init
#define CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
#define CONFIGURE_MAXIMUM_TASKS 3
1.8.3.1
