[PATCH rtems-examples 22/23] ticker/low_ticker2: Fix warnings
Wed Feb 23 22:21:50 UTC 2022
 ticker/low_ticker2/init.c | 19 ++++++++++---------
 1 file changed, 10 insertions(+), 9 deletions(-)
diff --git a/ticker/low_ticker2/init.c b/ticker/low_ticker2/init.c
index a687be9..f739f2a 100644
--- a/ticker/low_ticker2/init.c
+++ b/ticker/low_ticker2/init.c
@@ -16,20 +16,19 @@ rtems_task Test_task(
   rtems_task_argument task_index
-  rtems_status_code status;
   rtems_interval    ticks;
   struct timespec   uptime;
   ticks = task_index * 5 * rtems_clock_get_ticks_per_second();
   for ( ; ; ) {
-    status = rtems_task_wake_after( ticks );
+    (void) rtems_task_wake_after( ticks );
-    status = rtems_clock_get_uptime( &uptime );
+    (void) rtems_clock_get_uptime( &uptime );
     if ( uptime.tv_sec >= 35 ) {
       printk( "*** END OF LOW MEMORY CLOCK TICK TEST (delay) ***\n" );
       rtems_shutdown_executive( 0 );
-    printk( "TA%d - rtems_clock_uptime - %d:%d\n",
+    printk( "TA%d - rtems_clock_uptime - %lld:%ld\n",
       task_index, uptime.tv_sec, uptime.tv_nsec
@@ -39,22 +38,24 @@ void *Init(
   uintptr_t argument
   rtems_id          id;
   int               i;
   printk( "\n\n*** LOW MEMORY CLOCK TICK TEST (delay) ***\n" );
   for (i=1 ; i<=3 ; i++ ) {
-    status = rtems_task_create(
+    (void) rtems_task_create(
       rtems_build_name( 'T', 'A', 0x30+1, ' ' ), 1, 0, RTEMS_DEFAULT_MODES,
       RTEMS_DEFAULT_ATTRIBUTES, &id
-    status = rtems_task_start( id, Test_task, i );
+    (void) rtems_task_start( id, Test_task, i );
-  while( 1 )
+  while( 1 ) {
+  return NULL;
 /**************** START OF CONFIGURATION INFORMATION ****************/
@@ -68,7 +69,7 @@ void *Init(
 #define CONFIGURE_MINIMUM_TASK_STACK_SIZE 512
 #define CONFIGURE_MAXIMUM_PRIORITY 15
 #define CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS
-#define CONFIGURE_IDLE_TASK_BODY Init
+#define CONFIGURE_IDLE_TASK_BODY (Thread_Idle_body) Init
 #define CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
 #define CONFIGURE_MAXIMUM_TASKS             3
1.8.3.1
