config, _IO_Initialize_all_drivers
Thu Feb 24 07:11:02 UTC 2022
Hello Heinz,
On 18/02/2022 17:18, Heinz Junkes wrote:
> I'm still trying to get the booting and registering and initialising of the i2c devices on the MVME3100 to work properly.
> In confdefs/iodrivers.h the driver address table is built up and then
> _IO_Initialize_all_drivers() is called without registering the individual devices first.
the device drivers are already registered which means they are contained
in _IO_Driver_address_table.
> If I now enter in already before in bspstart.c
> RTEMS_SYSINIT_ITEM(
>    mvme3100_i2c_initialize,
>    RTEMS_SYSINIT_BSP_PRE_DRIVERS,
>    RTEMS_SYSINIT_ORDER_MIDDLE
> a device (register it and e.g. got the major number 0) this is ignored by the IO_Initialize_all_drivers().
> Shouldn't initialisation be preceded by registration ( rtems_io_register_driver() )?
There are two ways to register a legacy device driver:
1. Through application configuration options which populate
2. Via calls to rtems_io_register_driver().
Device drivers registered when _IO_Initialize_all_drivers() is called
are initialized. Adding a file system node is the job of the
initialization entry (done using mknod()).
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
