[PATCH rtems-examples 00/14] RTEMS Examples Clean Up
Chris Johns
chrisj at rtems.org
Thu Feb 24 22:50:26 UTC 2022
Looks good, OK to push.
Thanks for all the examples.
On 24/2/22 9:21 am, Joel Sherrill wrote:
> Hi
> In using the examples in classes and writing examples for users,
> I have accumulated some changes. These changes cover a bit of
> territory.
> + Fix build issues
> + Address warnings
> + Fix issues from RTEMS updates
> + General clean up
> + Add some missing files to RTEMS Makefile build
> + Added example of using std::map from RTEMS
> + Added example for restarting a POSIX thread
> + Added example for a User Device Driver accessed via POSIX system calls
> + Added ticker showing stack checker and CPU usage
> + Added ticker with tracing enabled so it wasn't bolted on both_hello
> Yes to many of us, some of these examples may not be needed
> but they do help users and show real functional approaches.
> --joel
> Joel Sherrill (23):
> Conditionalize CONFIGURE_TERMIOS_DISABLE so the examples span versions
> psx_sigint: Add new example of POSIX signal and default mask
> psx_initial_sigmask: Add POSIX initial signal mask reporter
> psx_sched_report/rtems_config.c: Fix spacing
> cxx_stdmap: Add example of using std::map with RTEMS
> cxx_throw/wscript: Fix comment
> classic_api/triple_period/tasks.c: Clean up formatting
> posix_api/psx_example_3/test3.c: Clean up and allow to build on Linux
> led/delay/init.c: Use local variable for one second of ticks
> led/event_server/init.c: Use names for events to reflect application
> intent
> Add User Driver Example
> Add POSIX task and thread restart examples.
> ticker_stackhk: Add variant which prints stack and cpu usage reports
> tracing: Add a special ticker variant to show tracing.
> posix_api/Makefile ticker/Makefile: Add missing examples
> benchmarks/nbench: Fix warnings
> classic_api/classic_signal: Fix warnings
> misc/minimum/: Fix warnings
> misc/nanosecond_tick_wrap: Fix warnings
> ticker/low_ticker: Fix warnings
> ticker/low_ticker1: Fix warnings
> ticker/low_ticker2: Fix warnings
> file_io/crc/.gitignore misc/extract_example/.gitignore: New files
> benchmarks/nbench/main.c | 3 +-
> benchmarks/nbench/nbench-byte-2.2.3/emfloat.c | 6 +
> benchmarks/nbench/nbench-byte-2.2.3/hardware.c | 4 +
> benchmarks/nbench/nbench-byte-2.2.3/nbench0.c | 1 +
> benchmarks/nbench/nbench-byte-2.2.3/nbench1.c | 4 +-
> classic_api/classic_signal/test.c | 4 +-
> classic_api/triple_period/init.c | 17 +-
> classic_api/triple_period/tasks.c | 21 +-
> cxx/Makefile | 6 +-
> cxx/cxx_stdmap/Makefile | 41 +
> cxx/cxx_stdmap/main.cc | 33 +
> cxx/cxx_stdmap/rtems_config.c | 47 +
> cxx/cxx_stdmap/wscript | 14 +
> cxx/cxx_throw/wscript | 2 +-
> cxx/wscript | 1 +
> file_io/crc/.gitignore | 5 +
> hello/both_hello/hello-deep.ini | 47 -
> hello/both_hello/hello.ini | 45 -
> hello/both_hello/wscript | 22 +-
> led/delay/init.c | 10 +-
> led/event_server/init.c | 16 +-
> misc/Makefile | 2 +-
> misc/extract_example/.gitignore | 1 +
> misc/minimum/test.c | 22 +-
> misc/nanosecond_tick_wrap/init.c | 4 +-
> misc/userdrv/Makefile | 20 +
> misc/userdrv/main.c | 100 +
> misc/userdrv/mainpage.h | 26 +
> misc/userdrv/rtems_config.c | 82 +
> misc/userdrv/userdrv.c | 254 +++
> misc/userdrv/userdrv.cfg | 2280 +++++++++++++++++++++
> misc/userdrv/userdrv.h | 264 +++
> misc/userdrv/wscript | 14 +
> misc/wscript | 1 +
> posix_api/Makefile | 3 +
> posix_api/psx_example_3/test3.c | 45 +-
> posix_api/psx_initial_sigmask/Makefile | 20 +
> posix_api/psx_initial_sigmask/main.c | 125 ++
> posix_api/psx_initial_sigmask/rtems_config.c | 48 +
> posix_api/psx_initial_sigmask/wscript | 15 +
> posix_api/psx_sched_report/rtems_config.c | 1 +
> posix_api/psx_sigint/Makefile | 20 +
> posix_api/psx_sigint/main.c | 99 +
> posix_api/psx_sigint/rtems_config.c | 48 +
> posix_api/psx_sigint/wscript | 15 +
> posix_api/psx_task_restart/Makefile | 20 +
> posix_api/psx_task_restart/psx_task_restart.c | 158 ++
> posix_api/psx_task_restart/rtems_config.c | 48 +
> posix_api/psx_task_restart/wscript | 15 +
> posix_api/psx_thread_restart/Makefile | 20 +
> posix_api/psx_thread_restart/psx_thread_restart.c | 3 +
> posix_api/psx_thread_restart/rtems_config.c | 2 +
> posix_api/psx_thread_restart/wscript | 15 +
> posix_api/wscript | 3 +
> ticker/Makefile | 7 +-
> ticker/low_ticker/init.c | 26 +-
> ticker/low_ticker1/init.c | 29 +-
> ticker/low_ticker2/init.c | 19 +-
> ticker/ticker_stackchk/Makefile | 23 +
> ticker/ticker_stackchk/init.c | 106 +
> ticker/ticker_stackchk/wscript | 15 +
> ticker/ticker_trace/Makefile | 23 +
> ticker/ticker_trace/init.c | 99 +
> ticker/ticker_trace/ticker-deep.ini | 46 +
> ticker/ticker_trace/ticker.ini | 43 +
> ticker/ticker_trace/wscript | 26 +
> ticker/wscript | 7 +-
> 67 files changed, 4419 insertions(+), 192 deletions(-)
> create mode 100644 cxx/cxx_stdmap/Makefile
> create mode 100644 cxx/cxx_stdmap/main.cc
> create mode 100644 cxx/cxx_stdmap/rtems_config.c
> create mode 100644 cxx/cxx_stdmap/wscript
> create mode 100644 file_io/crc/.gitignore
> delete mode 100644 hello/both_hello/hello-deep.ini
> delete mode 100644 hello/both_hello/hello.ini
> create mode 100644 misc/extract_example/.gitignore
> create mode 100644 misc/userdrv/Makefile
> create mode 100644 misc/userdrv/main.c
> create mode 100644 misc/userdrv/mainpage.h
> create mode 100644 misc/userdrv/rtems_config.c
> create mode 100644 misc/userdrv/userdrv.c
> create mode 100644 misc/userdrv/userdrv.cfg
> create mode 100644 misc/userdrv/userdrv.h
> create mode 100644 misc/userdrv/wscript
> create mode 100644 posix_api/psx_initial_sigmask/Makefile
> create mode 100644 posix_api/psx_initial_sigmask/main.c
> create mode 100644 posix_api/psx_initial_sigmask/rtems_config.c
> create mode 100644 posix_api/psx_initial_sigmask/wscript
> create mode 100644 posix_api/psx_sigint/Makefile
> create mode 100644 posix_api/psx_sigint/main.c
> create mode 100644 posix_api/psx_sigint/rtems_config.c
> create mode 100644 posix_api/psx_sigint/wscript
> create mode 100644 posix_api/psx_task_restart/Makefile
> create mode 100644 posix_api/psx_task_restart/psx_task_restart.c
> create mode 100644 posix_api/psx_task_restart/rtems_config.c
> create mode 100644 posix_api/psx_task_restart/wscript
> create mode 100644 posix_api/psx_thread_restart/Makefile
> create mode 100644 posix_api/psx_thread_restart/psx_thread_restart.c
> create mode 100644 posix_api/psx_thread_restart/rtems_config.c
> create mode 100644 posix_api/psx_thread_restart/wscript
> create mode 100644 ticker/ticker_stackchk/Makefile
> create mode 100644 ticker/ticker_stackchk/init.c
> create mode 100644 ticker/ticker_stackchk/wscript
> create mode 100644 ticker/ticker_trace/Makefile
> create mode 100644 ticker/ticker_trace/init.c
> create mode 100644 ticker/ticker_trace/ticker-deep.ini
> create mode 100644 ticker/ticker_trace/ticker.ini
> create mode 100644 ticker/ticker_trace/wscript
