Update to GDB 11.2?
Fri Feb 25 14:07:31 UTC 2022
On Thu, Feb 24, 2022 at 11:53 PM Sebastian Huber <
> On 24/02/2022 14:53, Sebastian Huber wrote:
> > On 24/02/2022 14:40, Joel Sherrill wrote:
> >> On Thu, Feb 24, 2022, 5:50 AM Sebastian Huber
> >> <sebastian.huber at embedded-brains.de
> >> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> >>     Hello,
> >>     we still use GDB 10 for the RTEMS 6 tool suite. I noticed some build
> >>     problems for this version. Should we update to the latest GDB 11.2
> >>     release?
> >> If it solves build problems and doesn't introduce others, sure. I tend
> >> to want to bump to the latest  versions.
> > Ok, I started a build on Linux using GDB 11.2. If this works, I will
> > update the RSB.
> It didn't help to fix the build issues on macOS. Now all GDB builds seem
> to fail with:
> checking whether to use MPFR... auto
> checking for libmpfr... no
> configure: WARNING: MPFR is missing or unusable; some features may be
> unavailable.
> checking whether to use python... /usr/bin/python2
> checking for python... no
> configure: error: no usable python found at /usr/bin/python2
Is this a lack of Python2 or Python2 development libraries?
The message used to confuse the two.
Either way, the requirement for Python 2 at this point  isn't great.
--joel
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
