[PATCH] added malloc usable size and test
zack leung
zakthertemsdev at gmail.com
Sat Feb 26 02:46:08 UTC 2022
ping
On Sat, 26 Feb 2022 at 02:42, zack leung <zakthertemsdev at gmail.com> wrote:
> ping
> On Sun, 20 Feb 2022 at 02:55, zack leung <zakthertemsdev at gmail.com> wrote:
>> diff --git a/cpukit/include/rtems/libcsupport.h
>> b/cpukit/include/rtems/libcsupport.h
>> index f4be4cfc9a..ec385bb71a 100644
>> --- a/cpukit/include/rtems/libcsupport.h
>> +++ b/cpukit/include/rtems/libcsupport.h
>> @@ -73,7 +73,10 @@ extern size_t malloc_free_space(void);
>> * Find amount of free heap remaining.
>> extern int malloc_info(Heap_Information_block *the_info);
>> + * @brief Find the usable size of the block of memory.
>> +extern size_t malloc_usable_size( void *ptr );
>> * Prototypes required to install newlib reentrancy user extension
>> @@ -185,6 +188,7 @@ bool rtems_resource_snapshot_equal(
>> bool rtems_resource_snapshot_check(const rtems_resource_snapshot
>> *snapshot);
>> #ifdef __cplusplus
>> diff --git a/cpukit/libcsupport/src/mallocusablesize.c
>> b/cpukit/libcsupport/src/mallocusablesize.c
>> new file mode 100644
>> index 0000000000..d9211b1390
>> --- /dev/null
>> +++ b/cpukit/libcsupport/src/mallocusablesize.c
>> @@ -0,0 +1,51 @@
>> + * SPDX-License-Identifier: BSD-2-Clause
>> + * Copyright (C) 2022 Zacchaeus Leung
>> + * Redistribution and use in source and binary forms, with or without
>> + * modification, are permitted provided that the following conditions
>> + * are met:
>> + * 1. Redistributions of source code must retain the above copyright
>> + * notice, this list of conditions and the following disclaimer.
>> + * 2. Redistributions in binary form must reproduce the above copyright
>> + * notice, this list of conditions and the following disclaimer in the
>> + * documentation and/or other materials provided with the
>> distribution.
>> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
>> "AS IS"
>> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
>> THE
>> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>> PURPOSE
>> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS
>> BE
>> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>> BUSINESS
>> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
>> IN
>> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>> OTHERWISE)
>> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
>> OF THE
>> + * POSSIBILITY OF SUCH DAMAGE.
>> +#ifdef HAVE_CONFIG_H
>> +#include "config.h"
>> +#endif
>> +#include <rtems/libcsupport.h>
>> +#include <rtems/malloc.h>
>> +#include <rtems/score/heapimpl.h>
>> +size_t malloc_usable_size(void *ptr) {
>> + Heap_Control *heap_ptr ;
>> + size_t size;
>> + if (ptr == NULL) {
>> + return 0;
>> + heap_ptr = malloc_get_heap_pointer();
>> + bool rv=_Heap_Size_of_alloc_area(heap_ptr, ptr, &size);
>> + if( rv==false ){
>> + return 0;
>> + return size;
>> \ No newline at end of file
>> diff --git a/spec/build/cpukit/librtemscpu.yml
>> b/spec/build/cpukit/librtemscpu.yml
>> index 7d6dbae0db..5902008c94 100644
>> --- a/spec/build/cpukit/librtemscpu.yml
>> +++ b/spec/build/cpukit/librtemscpu.yml
>> @@ -670,6 +670,7 @@ source:
>> - cpukit/libcsupport/src/lseek.c
>> - cpukit/libcsupport/src/lstat.c
>> - cpukit/libcsupport/src/malloc.c
>> +- cpukit/libcsupport/src/mallocusablesize.c
>> - cpukit/libcsupport/src/malloc_deferred.c
>> - cpukit/libcsupport/src/malloc_dirtier.c
>> - cpukit/libcsupport/src/malloc_walk.c
>> diff --git a/testsuites/libtests/malloctest/init.c
>> b/testsuites/libtests/malloctest/init.c
>> index a33764177d..38f5554440 100644
>> --- a/testsuites/libtests/malloctest/init.c
>> +++ b/testsuites/libtests/malloctest/init.c
>> @@ -1362,6 +1362,18 @@ static void test_alloc_zero_size(void)
>> rtems_test_assert( p == NULL );
>> rtems_test_assert( errno == -1 );
>> +static void test_usablesize(void)
>> + int * a = malloc(sizeof( int )*100);
>> + int alloc_size=sizeof( int ) *100 ;
>> + rtems_test_assert( malloc_usable_size(a) <= alloc_size +
>> CPU_HEAP_ALIGNMENT);
>> + free(a);
>> + char * b = malloc(sizeof( char )* 100);
>> + int alloc_size2=sizeof( char ) * 100;
>> + rtems_test_assert( malloc_usable_size ( b ) <= alloc_size2 +
>> + free(b);
>> rtems_task Init(
>> rtems_task_argument argument
>> @@ -1405,6 +1417,7 @@ rtems_task Init(
>> test_protected_heap_info();
>> test_rtems_heap_allocate_aligned_with_boundary();
>> test_rtems_malloc();
>> + test_usablesize();
>> test_rtems_calloc();
>> test_greedy_allocate();
>> test_alloc_zero_size();
>> 2.35.1
